| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BAT1 | BATT_HOLD_BH501_BATT2_78X492_CR | CR1220MFR FV, DNI | BATT2_78X492 |
| D1 | DIO_ZEN_DDZ9678-7_1.8V_DO221AC_ | SK54AFL-TP | DO221AC |
| D2 | DIO_ZEN_DDZ9678-7_1.8V_DO221AC_ | SK54AFL-TP | DO221AC |
| D3 | LED_LTST_C150GKT_LED_603_DISCRE | LTST-C191KFKT | LED_603 |
| D4 | LED_LTST_C150GKT_LED_603_DISCRE | LTST-C191KFKT | LED_603 |
| D5 | LED_LTST_C150GKT_LED_603_DISCRE | LTST-C191KFKT | LED_603 |
| D6 | LED_LTST_C150GKT_LED_603_DISCRE | LTST-C191KFKT | LED_603 |
| D7 | LED_LTST_C150GKT_LED_603_DISCRE | LTST-C191KFKT | LED_603 |
| D8 | PROT_PESD0603_240_603_PESD0603- | PESD0603-240 | 603 |
| D9 | PROT_PESD0603_240_603_PESD0603- | PESD0603-240 | 603 |
| D10 | PROT_PESD0603_240_603_PESD0603- | PESD0603-240 | 603 |
| D11 | PROT_PESD0603_240_603_PESD0603- | PESD0603-240 | 603 |
| D22 | IC_TPD2E001DRL_U_5_DRL_TPD2E001 | TPD2E001DRL | U_5_DRL |
| D23 | IC_TPD2E001DRL_U_5_DRL_TPD2E001 | TPD2E001DRL | U_5_DRL |
| D24 | DIO_ZEN_DDZ9678-7_1.8V_DO221AC_ | SK54AFL-TP | DO221AC |
| D25 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D26 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D27 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D28 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D29 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D30 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D31 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D32 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D33 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D34 | IC_TPD1E05U06_2XSON_TPD1E10B06 | TPD1E10B06 | 2XSON |
| D35 | IC_TPD1E05U06_2XSON_TPD1E10B06 | TPD1E10B06 | 2XSON |
| D36 | IC_TPD1E05U06_2XSON_TPD1E10B06 | TPD1E10B06 | 2XSON |
| D37 | IC_TPD1E05U06_2XSON_TPD1E10B06 | TPD1E10B06 | 2XSON |
| D38 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D40 | IC_TPD2EUSB30ADRTR_1_SOT3_DRT_1 | TPD2EUSB30ADR | SOT3_DRT_1P0XP8MM |
| D41 | LED_LTST_C150GKT_LED_603_DISCRE | LTST-C191KFKT | LED_603 |
| D42 | IC_TPD1E05U06_2XSON_TPD1E10B06 | TPD1E10B06 | 2XSON |
| F1 | FUSE_4A_QUICK_FU250_200X400SMD_ | 5A_SlowBlow | FU250_200X400SMD |
| FB1 | FERRITE_180_800_0805_805_150OHM | 150OHM800mA | 805 |
| FB2 | RES_0_1/16W_1%_0402_805_0,1%,08 | 0,1%,0805 | 805 |
| FB3 | FERRITE_180_800_0805_805_150OHM | 150OHM800mA | 805 |
| FB4 | FERRITE_180_800_0805_805_150OHM | 150OHM800mA | 805 |
| FB5 | FERRITE_180_800_0805_805_150OHM | 150OHM800mA | 805 |
| FB6 | RES_0_1/16W_1%_0402_805_0,1%,08 | 0,1%,0805 | 805 |
| FB7 | FERRITE_180_800_0805_805_150OHM | 150OHM800mA | 805 |
| FB8 | FERRITE_180_800_0805_805_150OHM | 150OHM800mA | 805 |
| FB9 | FERRITE_180_800_0805_805_150OHM | 150OHM800mA | 805 |
| FB10 | FERRITE_180_800_0805_1206_DNI | DNI | 1206 |
| FB11 | FERRITE_180_800_0805_1206_DNI | DNI | 1206 |
| FB12 | FERRITE_180_800_0805_402_BLM15B | BLM15BD182SN1 | 402 |
| FB13 | FERRITE_180_800_0805_402_BLM15B | BLM15BD182SN1 | 402 |
| FB14 | FERRITE_180_800_0805_402_BLM15B | BLM15BD182SN1 | 402 |
| FB15 | FERRITE_180_800_0805_402_BLM15B | BLM15BD182SN1 | 402 |
| FL1 | CHOKE_DLW21SN121HQ2_3_CHOKE4_08 | DLW21SN900HQ2 | CHOKE4_0805-2 |
| FL2 | CHOKE_DLW21SN121HQ2_3_CHOKE4_08 | DLW21SN900HQ2 | CHOKE4_0805-2 |
| FL3 | CHOKE_DLW21SN121HQ2_3_CHOKE4_08 | DLW21SN900HQ2 | CHOKE4_0805-2 |
| FL4 | CHOKE_DLW21SN121HQ2_3_CHOKE4_08 | DLW21SN900HQ2 | CHOKE4_0805-2 |
| FL5 | CM2021Y330R-10_CMC_CM2021Y_CM20 | CM2021Y330R-10 | CMC_CM2021Y |
| J1 | HDR_1X1_M_0.1_CON2_49LS_DNI | DNI | CON2_49LS |
| J3 | HDR_1X3_0.1_SIP3_HDR_1X3 | HDR_1x3 | SIP3 |
| J4 | HDR_1X3_0.1_SIP3_HDR_1X3 | HDR_1x3 | SIP3 |
| J5 | HDR_1X1_M_.1_SIP2_HDR_1X1_M_.1, | HDR_1x1_M_.1, DNI | SIP2 |
| J6 | HDR_1X3_0.1_SIP3_HDR_1X3 | HDR_1x3 | SIP3 |
| L1 | INDUCTOR_IND130_208X216_4.7UH | 4.7uH | IND130_208X216 |
| L2 | INDUCTOR_IND130_208X216_3.3UH,7 | 3.3uH,7A | IND130_208X216 |
| L3 | IND_PWR_1.0UH_4.2A_SMD_IND130_1 | 1.0uH,4.2A | IND130_160X175 |
| L4 | IND_PWR_1.0UH_4.2A_SMD_IND130_1 | 1.0uH,4.2A | IND130_160X175 |
| L5 | IND_PWR_1.0UH_4.2A_SMD_IND130_1 | 1.0uH,4.2A | IND130_160X175 |
| L6 | IND_PWR_1.0UH_4.2A_SMD_IND130_1 | 1.0uH,4.2A | IND130_160X175 |
| L7 | IND_PWR_1.0UH_4.2A_SMD_IND130_1 | 1.0uH,4.2A | IND130_160X175 |
| L8 | IND_PWR_1.0UH_4.2A_SMD_IND130_1 | 1.0uH,4.2A | IND130_160X175 |
| L9 | IND_PWR_1.0UH_4.2A_SMD_IND130_1 | 1.0uH,4.2A | IND130_160X175 |
| L10 | FLT_HIFREQ_.47UF_FLT3SMD_0805-2 | FLT_HIFREQ_.47UF | FLT3SMD_0805-2 |
| L11 | FLT_HIFREQ_.47UF_FLT3SMD_0805-2 | FLT_HIFREQ_.47UF | FLT3SMD_0805-2 |
| L12 | FLT_HIFREQ_.47UF_FLT3SMD_0805-2 | FLT_HIFREQ_.47UF | FLT3SMD_0805-2 |
| L13 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L14 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L15 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L16 | INDUCTOR_IND130_208X216_4.7UH | 4.7uH | IND130_208X216 |
| L17 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L18 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L19 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L20 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L21 | FLT_HIFREQ_.47UF_FLT3SMD_0805-2 | FLT_HIFREQ_.47UF | FLT3SMD_0805-2 |
| L22 | FLT_HIFREQ_.47UF_FLT3SMD_0805-2 | FLT_HIFREQ_.47UF | FLT3SMD_0805-2 |
| L23 | FERRITE_220_0805_IND_0805_BLM21 | BLM21PG221SN1D | IND_0805 |
| L24 | FLT_HIFREQ_.47UF_FLT3SMD_0805-2 | FLT_HIFREQ_.47UF | FLT3SMD_0805-2 |
| MH1 | TESTPOINT_MTGH250C125D_PL_MOUNT | MOUNT_HOLE | MTGH250C125D_PL |
| MH2 | TESTPOINT_MTGH250C125D_PL_MOUNT | MOUNT_HOLE | MTGH250C125D_PL |
| MH3 | TESTPOINT_MTGH250C125D_PL_MOUNT | MOUNT_HOLE | MTGH250C125D_PL |
| MH4 | TESTPOINT_MTGH250C125D_PL_MOUNT | MOUNT_HOLE | MTGH250C125D_PL |
| MH5 | TESTPOINT_MTGH200C102D_PL_MOUNT | MOUNT_HOLE | MTGH200C102D_PL |
| P1 | CONN MOD 8-8_J_7_JACK_PJ-063-08 | PJ-0XXBH | JACK_PJ-063-080BH |
| P4 | HDR_JTAG_20P_HEADER10X2_SMD_20 | 20 Pin JTAG | HEADER10X2_SMD |
| P5 | CONN_RJ45_DUAL_GIGABIT_1_RJ45_2 | LPJG17561BGNL Dual RJ45 10/100/1000 | RJ45_2X1_XFRM_LED |
| P6 | CONN_11P_ESATA_ESATA-USB_COMBO_ | eSATA | ESATA-USB_COMBO_RA |
| P7 | CONN_MINI-USB-AB_1_USB5_FCI-101 | Micro USB-B | USB5_FCI-10103594 |
| P8 | CONN_STEREO_3.5MM_1SW_JACK5-472 | SJ1-3524NG | JACK5-472X551-SJ1-3524NG |
| P9 | CONN_STEREO_3.5MM_1SW_JACK5-472 | SJ1-3524NG | JACK5-472X551-SJ1-3524NG |
| P10 | HEADER 6_SIP6_HEADER 6 | HEADER 6 | SIP6 |
| P11 | HDMI-RA-19_0_HDMI-SMT-W-FLANGE_ | HDMI-RA-19-TYPEA | HDMI-SMT-W-FLANGE |
| P12 | MICROSD_CONN_0_SD-MICRO-SCHA5B0 | SCHA5B0200 | SD-MICRO-SCHA5B0300 |
| P13 | CONN_USB3_3.0_A_USB9RA_2SHIELDE | CONN_USB3.0_A | USB9RA_2SHIELDED |
| P15 | CONN_USB3_3.0_A_DUAL_USB18RA_4S | GSB311231HR | USB18RA_4SHIELDED |
| P16 | CONN_30X2_5.27MM_HDR2X30SMD_FX1 | CONN_30x2_0.8 | HDR2X30SMD_FX18-60P-0P8SV |
| P17 | CONN_30X2_5.27MM_HDR2X30SMD_FX1 | CONN_30x2_0.8 | HDR2X30SMD_FX18-60P-0P8SV |
| P18 | CONN_30X2_5.27MM_HDR2X30SMD_FX1 | CONN_30x2_0.8 | HDR2X30SMD_FX18-60P-0P8SV |
| P19 | CONN_30X2_5.27MM_HDR2X30SMD_FX1 | CONN_30x2_0.8 | HDR2X30SMD_FX18-60P-0P8SV |
| Q1 | IRF5210S/SM_0_SOT223-1_FDT434P | FDT434P | SOT223-1 |
| Q2 | IRF5210S/SM_0_SOT223-1_FDT434P | FDT434P | SOT223-1 |
| Q3 | TRN_DMC56404_SMINI6-F3-B_DMC564 | DMC56404 | SMINI6-F3-B |
| Q4 | TRN_DMC56404_SMINI6-F3-B_DMC564 | DMC56404 | SMINI6-F3-B |
| Q5 | TRN_NTA4153N_SC75_NTA4153N | NTA4153N | SC75 |
| Q6 | TRN_BSS138_0_SC70_BSS138 | BSS138 | SC70 |
| Q8 | TRN_1_SOT23-3_TRN_2N2907 | TRN_2N2907 | SOT23-3 |
| Q9 | TRN_1_SOT23-3_TRN_2N2907 | TRN_2N2907 | SOT23-3 |
| Q11 | 2N2222_0_SOT-23_MMBT2222A | MMBT2222A | SOT-23 |
| S1 | SW PUSH_TH_SW4_EVQF004R_SW PUSH | SW PUSH_TH | SW4_EVQF004R |
| S2 | SW PUSH_TH_SW4_EVQF004R_SW PUSH | SW PUSH_TH | SW4_EVQF004R |
| TP4 | TESTPT1_TP1-8040_TESTPT1 | TESTPT1 | TP1-8040 |
| U1 | IC_TPS54331,3A_0_DDA-8_TPS54531 | TPS54531D | DDA-8 |
| U2 | TPS22965DSG_1_WSON-8_TPS22965DS | TPS22965DSG | WSON-8 |
| U3 | IC_TPS54331,3A_0_DDA-8_TPS54531 | TPS54531D | DDA-8 |
| U4 | IC_TMP102AIDRL_SOT563_SOT563_TM | TMP102AIDRLT | SOT563 |
| U5 | IC_TPS659039_8_BGA169_N13_P8_TP | TPS6590374ZWSR | BGA169_N13_P8 |
| U6 | IC_MCP79410_DFN8_2X3MM_MCP79410 | MCP79410,TFDN | DFN8_2X3MM |
| U7 | IC_CDCM9102RHBR_0_QFN32_CDCM910 | CDCM9102RHBR | QFN32 |
| U8 | MEM_24WC256_0_SOIC_8_MEM_24WC25 | MEM_24WC256_8SOIC | SOIC_8 |
| U9 | IC_SN74LVC1G11_DRY_SC70-6_SN74L | SN74LVC1G11DBV | SC70-6 |
| U10 | IC_SN74LVC1G08_DCK_SC70-5_SN74L | SN74LVC1G08DCK | SC70-5 |
| U11 | IC_AM572X_BGA_34_SKTBGA-ZKK-633 | AM5728 | SKTBGA-ZKK-6334-P760 |
| U12 | PWR_TPS3808G09DBVR_SOT23_0_SOT2 | TPS_3808G09 | SOT23-6 |
| U13 | PWR_TPS3808G09DBVR_SOT23_0_SOT2 | TPS_3808G09 | SOT23-6 |
| U14 | IC_KSZ9031RNX_QFN48_9_QFN48_KSZ | KSZ9031RNX | QFN48 |
| U15 | IC_KSZ9031RNX_QFN48_9_QFN48_KSZ | KSZ9031RNX | QFN48 |
| U16 | PWR_TPS74801_SON_DRC10-11X33_TP | TPS74801 | DRC10-11X33 |
| U17 | IC_TUSB8041_2_VQFN64S9X9P5_TUSB | TUSB8041 | VQFN64S9X9P5 |
| U18 | IC_TLV320AIC3104_5_QFN32_TLV320 | TLV320AIC3104 | QFN32 |
| U19 | PWR_TPS7018DBV_SOT23_5_SOT23-5_ | TPS77018DBV | SOT23-5 |
| U20 | IC_SN74LVC2G241_1_U_8_DCU_SN74L | SN74LVC2G241 | U_8_DCU |
| U21 | IC_TPD12S016_QFN24S_2X4P4_TPD12 | TPD12S016 24UQFN | QFN24S_2X4P4 |
| U22 | MEM_MNAND_1_BGA153_P14_P5_11P5X | MEM_MNAND_4GB | BGA153_P14_P5_11P5X13 |
| U23 | MEM_DDR3L_256MBX16_0_BGA96_T9_P | 256MBx16 DDR3L | BGA96_T9_P8_9X14 |
| U24 | MEM_DDR3L_256MBX16_0_BGA96_T9_P | 256MBx16 DDR3L | BGA96_T9_P8_9X14 |
| U25 | MEM_DDR3L_256MBX16_0_BGA96_T9_P | 256MBx16 DDR3L | BGA96_T9_P8_9X14 |
| U26 | MEM_DDR3L_256MBX16_0_BGA96_T9_P | 256MBx16 DDR3L | BGA96_T9_P8_9X14 |
| U27 | IC_TPS51200_10S0N_DRC10-11X33_T | TPS51200_10SON | DRC10-11X33 |
| U28 | IC_TPS54331,3A_0_DDA-8_TPS54531 | TPS54531D | DDA-8 |
| U29 | PWR_TPS2560_DRC_0_DRC10-11X33_T | TPS2561DRC | DRC10-11X33 |
| U30 | PWR_TPS2560_DRC_0_DRC10-11X33_T | TPS2561DRC | DRC10-11X33 |
| U31 | IC_PI2DBS212ZHE_TQFN_9_TQFN28S_ | PI2DBS212_TQFN | TQFN28S_3P5X5P5P5 |
| U32 | TC648_0_SO8-25X75_TC648 | TC648 | SO8-25X75 |
| U33 | IC_SN75LVCP412A_1_QFN20S4X4P5-2 | SN75LVCP412A | QFN20S4X4P5-2 |
| U34 | IC_SN74LVC2G132DCU_U_8_DCU_SN74 | SN74LVC2G132DCU | U_8_DCU |
| U35 | MA735/TO_0_SOT23-3_TLVH431 | TLVH431 | SOT23-3 |
| U43 | MA735/TO_0_SOT23-3_TLVH431 | TLVH431 | SOT23-3 |
| Y1 | CRYS_32_768KHZ_SMD_XTAL_CFS-206 | CFS206-32.768KDZB | XTAL_CFS-206 |
| Y2 | CRYS_20MHZ_12.5PF_2P_3.2X1.5_XT | 20MHz,SMD | XTAL2_6X3P5_SMD |
| Y3 | CRYS_22.5792MHZ_7PF_4P_3.2X2.5_ | 22.5792MHZ | XTAL4_3P2X2P5_SMD |
| Y5 | CRYS_25MHZ_18PF_2P_5.0X3.2_XTAL | 25MHz | XTAL_3P2X5SMD |
| Y6 | CRYS_25MHZ_18PF_2P_5.0X3.2_XTAL | 25MHz | XTAL_3P2X5SMD |
| Y7 | CRYS_24MHZ_2PIN_OSC4_87-146SMD_ | 24MHz | OSC4_87-146SMD_126X197-1 |
| Y8 | CRYS_25MHZ_8PF_4P_3.2X2.5_XTAL4 | 25MHz,8pF | XTAL4_3P2X2P5_SMD |
| Y9 | CRYS_24MHZ_SCC_XTAL4_3P2X2P5_SM | 16.384MHz | XTAL4_3P2X2P5_SMD |
| Y10 | CRYS_24MHZ_SCC_OSC4_2P5X2P0XP5_ | 16.384MHz | OSC4_2P5X2P0XP5 |
