| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BT1 | BATTERY_0_KEYSTONE_BT-2994_BATT | Battery | KEYSTONE_BT-2994 |
| CN1 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uF | CAP_PACK_4_1206 |
| CN2 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uF | CAP_PACK_4_1206 |
| CN3 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uF | CAP_PACK_4_1206 |
| CN4 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uF | CAP_PACK_4_1206 |
| CN5 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uF | CAP_PACK_4_1206 |
| CN6 | CAP_ARRAY_CAP_PACK_4_1206_0.1UF | 0.1uF | CAP_PACK_4_1206 |
| D1 | LED_LUMEX_LED0805_GREEN_LED | Green_LED | LUMEX_LED0805 |
| D30 | LED_LUMEX_LED0805_GREEN_LED | Green_LED | LUMEX_LED0805 |
| D31 | LTC4352CDD_DFN12_EPAD_LTC4352CD | LTC4352CDD | DFN12_EPAD |
| D32 | LED_LUMEX_LED0805_GREEN_LED | Green_LED | LUMEX_LED0805 |
| D33 | LTC4352CDD_DFN12_EPAD_LTC4352CD | LTC4352CDD | DFN12_EPAD |
| D34 | LED_LUMEX_LED0805_YELLOW LED | YELLOW LED | LUMEX_LED0805 |
| D35 | LED_LUMEX_LED0805_YELLOW LED | YELLOW LED | LUMEX_LED0805 |
| D36 | DIODE, SCHOTTKY CMDSH-3_SOD323_ | CMDSH-3 | SOD323 |
| D37 | DIODE, SCHOTTKY CMDSH-3_SOD323_ | CMDSH-3 | SOD323 |
| D38 | D-SCHOTTKY_0_SOD323_CMDSH-3 | CMDSH-3 | SOD323 |
| D39 | MMBD1205_SOT23_MMBD1205 | MMBD1205 | SOT23 |
| D40 | D-SCHOTTKY_0_SOD323_CMDSH-3 | CMDSH-3 | SOD323 |
| D41 | DIODE, SCHOTTKY CMDSH-3_SOD323_ | CMDSH-3 | SOD323 |
| D42 | DIODE, SCHOTTKY CMDSH-3_SOD323_ | CMDSH-3 | SOD323 |
| D43 | DIODE, SCHOTTKY CMDSH-3_SOD323_ | CMDSH-3 | SOD323 |
| D44 | LED_LUMEX_LED0805_YELLOW LED | YELLOW LED | LUMEX_LED0805 |
| D45 | LED_LUMEX_LED0805_YELLOW LED | YELLOW LED | LUMEX_LED0805 |
| J1 | QSH_HSM_SAMTEC_QSHDP120CUSTOM_A | ASP-122953-01 | SAMTEC_QSHDP120CUSTOM |
| J2 | QSH_HSM_SAMTEC_QSHDP120CUSTOM_A | ASP-122953-01 | SAMTEC_QSHDP120CUSTOM |
| J3 | SMA_LTI_SASF54GT_0_SMA_LTI-SASF | LTI-SASF546-P26-X1 | SMA_LTI-SASF546-P26-X1 |
| J4 | SMA_SMA_LTI-SASF546-P26-X1_LTI- | LTI-SASF546-P26-X1 | SMA_LTI-SASF546-P26-X1 |
| J5 | USB_CON_TH_MOLEX_MINI-AB_USB_TH | USB MINI-AB | MOLEX_MINI-AB_USB_TH |
| J6 | SMA_LTI_SASF54GT_0_SMA_LTI-SASF | LTI-SASF546-P26-X1 | SMA_LTI-SASF546-P26-X1 |
| J7 | SMA_SMA_LTI-SASF546-P26-X1_LTI- | LTI-SASF546-P26-X1 | SMA_LTI-SASF546-P26-X1 |
| J8 | CONN JACK PWR_3_RAPC712_CONN JA | CONN JACK PWR | RAPC712 |
| J9 | HFJ11-1G02E_RJ45_HFJ11-1G02E | HFJ11-1G02E | RJ45 |
| J10 | LCD_HEADER_NEWHAVEN_LCD_LCD_HEA | LCD_HEADER | NEWHAVEN_LCD |
| J11 | CONN, MINI SMB, THM, RA_SMB_RA_ | Mini SMB | SMB_RA_JACK_RECEP |
| J12 | CONN, MINI SMB, THM, RA_SMB_RA_ | Mini SMB | SMB_RA_JACK_RECEP |
| J13 | 70247-1051_MLX_SHROUD_VRT_HDR_1 | 70246-1004 | MLX_SHROUD_VRT_HDR_10PIN |
| J14 | SMA_SMA_LTI-SASF546-P26-X1_LTI- | LTI-SASF546-P26-X1 | SMA_LTI-SASF546-P26-X1 |
| J15 | CON2_MLX_22_23_2021_MLX_22_23_2 | 22_23_2021 | MLX_22_23_2021_VRT_HDR_2P |
| J16 | PCIE_BRACKET_X4_PCIX-4PORT_PCIE | PCIE_Slot | PCIX-4PORT |
| J17 | CON6A_SAMTEC_HDR_2X3_2MM_SMT_DN | DNI | SAMTEC_HDR_2X3_2MM_SMT |
| J18 | 2X5_HDR2X5_100MIL_SMT_DNI | DNI | HDR2X5_100MIL_SMT |
| L1 | IND 1.2UH IR=6.5A CUBE SMD_IND_ | 1.2uH | IND_SUSUMU_PCMC_BTYPE |
| L2 | IND 1.2UH IR=6.5A CUBE SMD_IND_ | 1.2uH | IND_SUSUMU_PCMC_BTYPE |
| L3 | INDUCTOR_IND_WURTH_744325120_1. | 1.2uH | IND_WURTH_744325120 |
| L4 | INDUCTOR_IND_WURTH_744325120_1. | 1.2uH | IND_WURTH_744325120 |
| L5 | BEAD_FERRITE_SM_IND_0603_3A, 30 | 3A, 30 Ohm FB | IND_0603 |
| L6 | IND 0.47UH IR=18A ISAT=20A SMD_ | 0.47uH | IND_WURTH_744314047 |
| L7 | IND 0.47UH IR=18A ISAT=20A SMD_ | 0.47uH | IND_WURTH_744314047 |
| L8 | IND 1.2UH IR=6.5A CUBE SMD_IND_ | 1.2uH | IND_SUSUMU_PCMC_BTYPE |
| L9 | INDUCTOR_0402_3.9NH | 3.9nH | 402 |
| L10 | BEAD_FERRITE_SM_0603_120 OHM FB | 120 Ohm FB | 603 |
| L11 | INDUCTOR_0402_5.6NH | 5.6nH | 402 |
| L12 | INDUCTOR_0402_5.6NH | 5.6nH | 402 |
| L13 | BEAD_FERRITE_SM_IND_0603_3A, 30 | 3A, 30 Ohm FB | IND_0603 |
| Q1 | RJK0301DPB_LFPAK-4_RJK0305DPB | RJK0305DPB | LFPAK-4 |
| Q2 | RJK0301DPB_LFPAK-4_BUK7Y7R0-40H | BUK7Y7R0-40HX | LFPAK-4 |
| Q3 | RJK0301DPB_LFPAK-4_BUK7Y7R0-40H | BUK7Y7R0-40HX | LFPAK-4 |
| Q4 | RJK0301DPB_LFPAK-4_RJK0305DPB | RJK0305DPB | LFPAK-4 |
| Q5 | PWRMOSFET_EN_GSD_0_SOT23_FDV305 | FDV305N | SOT23 |
| RN6 | RES_PACK_0_RES_PACK_8_S1+S2+S3+ | 51 | RES_PACK_8 |
| RN7 | RES_PACK_0_RES_PACK_8_S1+S2+S3+ | 51 | RES_PACK_8 |
| S1 | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | WURTH_6X3P5_TACT_SWITCH |
| S2 | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | WURTH_6X3P5_TACT_SWITCH |
| S3 | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | WURTH_6X3P5_TACT_SWITCH |
| S4 | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | WURTH_6X3P5_TACT_SWITCH |
| S5 | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | WURTH_6X3P5_TACT_SWITCH |
| S6 | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | WURTH_6X3P5_TACT_SWITCH |
| S7 | TS-A02SA-2-S100_0_WURTH_6X3P5_T | PB Switch | WURTH_6X3P5_TACT_SWITCH |
| SW1 | 76SB08_DIPSWITCH_SMT_OCTAL_TDA0 | TDA08H0SB1 | DIPSWITCH_SMT_OCTAL |
| SW2 | SW_SLIDE_DPDT_EG2207_SW_SLIDE_D | SW_SLIDE_DPDT | EG2207 |
| SW3 | SPST4_DIPSWITCH_SMT_QUAD_TDA04H | TDA04H0SB1 | DIPSWITCH_SMT_QUAD |
| SW4 | SPST4_DIPSWITCH_SMT_QUAD_TDA04H | TDA04H0SB1 | DIPSWITCH_SMT_QUAD |
| SW5 | SPST4_DIPSWITCH_SMT_QUAD_TDA04H | TDA04H0SB1 | DIPSWITCH_SMT_QUAD |
| U1 | REG SWITCHING, LTC3605EUF_QFN24 | LTC3605EUF | QFN24 |
| U2 | REG SWITCHING, LTC3605EUF_QFN24 | LTC3605EUF | QFN24 |
| U3 | IDT5T9306_0_VFQFPN-28_EPAD_IDT5 | IDT5T9306 | VFQFPN-28_EPAD |
| U4 | CY7C68013A_VFBGA_VFBGA56_CY7C68 | CY7C68013A_VFBGA | VFBGA56 |
| U5 | TPD2EUSB30_DRT_TPD2EUSB30 | TPD2EUSB30 | DRT |
| U6 | MAX811_SOT-143_MAX811 | MAX811 | SOT-143 |
| U7 | LT3022EDHC_DFN16_EPAD_5X3_LT302 | LT3022EDHC | DFN16_EPAD_5X3 |
| U8 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | MICRON_DDR3_96_9X14 |
| U9 | FDMC8878_VER2_FDMC8878_VER2_FDM | FDMC8882 | FDMC8878_VER2 |
| U10 | LTC3085EDCB_DFN6-3X2_EPAD_LT308 | LT3085EDCB | DFN6-3X2_EPAD |
| U11 | 88E1111_BCC96_88E1111 | 88E1111 | BCC96 |
| U12 | MAX3372EEKA_0_SOT23-8_MAX3373 | MAX3373 | SOT23-8 |
| U13 | 5CGTFD9E5F35_F1152_5CGTFD9E5F35 | 5CGTFD9E5F35 | F1152 |
| U14 | FDMC8878_VER2_FDMC8878_VER2_FDM | FDMC8882 | FDMC8878_VER2 |
| U15 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | MICRON_DDR3_96_9X14 |
| U16 | FDMC8878_VER2_FDMC8878_VER2_FDM | FDMC8882 | FDMC8878_VER2 |
| U17 | FDMC8878_VER2_FDMC8878_VER2_FDM | FDMC8882 | FDMC8878_VER2 |
| U18 | LT3022EDHC_DFN16_EPAD_5X3_LT302 | LT3022EDHC | DFN16_EPAD_5X3 |
| U19 | FDMC8878_VER2_FDMC8878_VER2_FDM | FDMC8882 | FDMC8878_VER2 |
| U20 | MT28EW01GABA1HPC-0SIT_3_HC_TK0_ | MT28EW01GABA1HPC-0SIT | HC_TK0_BGA64 |
| U21 | REG SWITCHING, LTC3608_QFN52_3E | LTC3608 | QFN52_3EPAD |
| U22 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | MICRON_DDR3_96_9X14 |
| U23 | EPM570M100_0_M100_S1,S2,S3_DNI | DNI | M100 |
| U24 | LTC3613EWKH_7_QFN56_7X9MM_LTC36 | LTC3613EWKH_6 | QFN56_7X9MM |
| U25 | REG SWITCHING, LTC3605EUF_QFN24 | LTC3605EUF | QFN24 |
| U26 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | MICRON_DDR3_96_9X14 |
| U27 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | MICRON_DDR3_96_9X14 |
| U28 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | MICRON_DDR3_96_9X14 |
| U29 | IDTQS3861_QSOP24P_IDTQS3861 | IDTQS3861 | QSOP24P |
| U30 | MT41J128M16HA_MICRON_DDR3_96_9X | MT41K128M16JT | MICRON_DDR3_96_9X14 |
| U31 | FXL5T244_DQFN14_DNI | DNI | DQFN14 |
| U32 | 5M2210ZF256_F256_5M2210ZF256 | 5M2210ZF256 | F256 |
| U33 | EPCQ256_SO16_WIDE_MT25QL256ABA8 | MT25QL256ABA8ESF-0SIT | SO16_WIDE |
| U34 | FXL5T244_DQFN14_DNI | DNI | DQFN14 |
| U35 | MAX3023_TSSOP14_MAX3023 | MAX3023 | TSSOP14 |
| U36 | TS5A23157_MSOP10_TS5A23157 | TS5A23157 | MSOP10 |
| U37 | TS5A23157_MSOP10_TS5A23157 | TS5A23157 | MSOP10 |
| U38 | MAX3372EEKA_0_SOT23-8_MAX3373 | MAX3373 | SOT23-8 |
| U39 | LTC3025-1_0_DFN6-2X2_EPAD_LTC30 | LTC3025-1 | DFN6-2X2_EPAD |
| U40 | LTC3855_QFN40_LTC3855EUJ | LTC3855EUJ | QFN40 |
| U41 | LTC4357_DFN6_EPAD_LTC4357 | LTC4357 | DFN6_EPAD |
| U42 | LT3009XDC_0_DFN6-2X2_EPAD_LT300 | LT3009xDC | DFN6-2X2_EPAD |
| U43 | TPS51200_DRC-10_EPAD_TPS51200 | TPS51200 | DRC-10_EPAD |
| U44 | LTC4357_DFN6_EPAD_LTC4357 | LTC4357 | DFN6_EPAD |
| U45 | LTC2418_SSOP28_NAR_LTC2418 | LTC2418 | SSOP28_NAR |
| U46 | LTC4357_DFN6_EPAD_LTC4357 | LTC4357 | DFN6_EPAD |
| U47 | LMH0384_LLP16_EPAD_LMH0384 | LMH0384 | LLP16_EPAD |
| U48 | MAX3378_0_TSSOP14_MAX3378 | MAX3378 | TSSOP14 |
| U49 | EPM570T100 | EPM570GT100C3N | TQFP100SQ |
| U50 | LMH0303_LLP16_EPAD_LMH0303 | LMH0303 | LLP16_EPAD |
| U51 | RESET, MAX811_SOT-143_DNI | DNI | SOT-143 |
| U52 | SL18860DC_TDFN-10_SL18860DC | SL18860DC | TDFN-10 |
| U53 | TPS51200_DRC-10_EPAD_TPS51200 | TPS51200 | DRC-10_EPAD |
| V1 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| V2 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| V3 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| V4 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| V5 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| V6 | SENSE_PAD_SENSE_SENSE_PAD | SENSE_PAD | SENSE |
| X1 | OSC_ALT_XTAL_SG310_25.00MHZ | 25.00MHz | XTAL_SG310 |
| X2 | OSC_ALT_1_XTAL_XG-1000CB_100MHZ | 100MHz | XTAL_XG-1000CB |
| X3 | SI571_XTAL_SI570_SI571 | SI571 | XTAL_SI570 |
| X4 | SI570_ALT1_XTAL_SI570_SI570 | SI570 | XTAL_SI570 |
| X5 | 635L3C3_XTAL_EG2100_125.0MHZ | 125.0MHz | XTAL_EG2100 |
| X6 | OSC_ALT_0_ECS3525_50MHZ | 50MHz | ECS3525 |
| Y1 | CRYSTAL_SM_13_XTAL_FA-128_24.00 | 24.00MHz | XTAL_FA-128 |
