重要提示:PCB作品文件展下载说明
NEO-M8N.7z
8.51 MB, 下载次数: 2, 下载积分:金币 -5 枚
| 2JCP2540101Ga | ANT1 | 2JCP2540101GA | 2JCP2540101Ga | | 10UF 0402 6.3V 20% X5R | C1, C3, C4 | CAP0402N | CAP CER 10UF 0402 6.3V 20% X5R | | 470NF 0402 6.3V +50%/-20% | C2, C6, C10, C12, C14, C42 | YFF15PC | CAP FEEDTHRU 470NF 0402 6.3V +50%/-20% | | 1UF 0201 10V 20% X5R | C5, C31, C34, C43 | CAP0201L | CAP CER 1UF 0201 10V 20% X5R | | CAP CER 10PF 0201 25V 5% C0G | C7 | Passive0201L | CAP CER 10PF 0201 25V 5% C0G | | CAP NF 0402 | C8 | CAP0402N_NF | CAP NF 0402 | | 10NF 0402 16V 20% X7R | C9 | CAP0402N | CAP CER 10NF 0402 16V 20% X7R | | 1NF 0402 50V 5% | C11 | CAP0402N | CAP CER 1NF 0402 50V 5% C0G | | 100NF 0201 35V 10% X5R | C19, C32, C35, C36, C45 | CAP0201L | CAP CER 100NF 0201 35V 10% X5R | | 4.7UF 0402 10V 20% X5R | C22, C30 | CAP0402N | CAP CER 4.7UF 0402 10V 20% X5R | | 10UF 0603 16V 10% X5R | C24 | CAP0603N | CAP CER 10UF 0603 16V 10% X5R | | 470NF 0201 16V 20% X5R | C33 | CAP0201L | CAP CER 470NF 0201 16V 20% X5R | | APHF1608LSEEQBDZGKC | D1 | LED RGB 0603 | LED RGB 0603 2MA | | ESD9L5.0ST5G | D2 | SOD-923 | ESD9L5.0ST5G | | RCLAMP0504FBTCT | D3 | SC70-6 | RCLAMP0504FBTCT | | LTST-C190KSKT | D5 | DIOD0603N_YELLOW | LED YELLOW 0603 20MA VF=2V | | LTST-C190KGKT | D6 | DIOD0603N_GREEN | LED GREEN 0603 20MA VF=2V | | S2B-PH-SM4-TB | J1 | SM4-2 | CON HDR 2POS 2.0MM PITCH | | 47589-0001 | J2 | 475890001 | CON MICRO USB 2.0 TYPE AB R/A SMD | | TC2030-NL | J3 | TC2030NL | TC2030-NL | | M20-9990245 | J4 | HDR 2POS 2.54MM THRU HOLE | M20-9990245 | | 532611071 | J5 | 532611071 | 532611071 | | 532611471 | J7 | 532611471 | 532611471 | | 533980271 | J8 | 533980271 | 533980271 | | LPS3015-152MRC | L1 | LPS3015 UPDATE | IND PWR 1.5UH 20% 1.7A 2.95MM x 2.95MM x 1.4MM | | Mounting Hole M2 Plated | MH1, MH2, MH3, MH4 | MOUNTING HOLE M2 PLATED | Mounting Hole M2 Plated | | Mounting Hole 0.5mm | MH5, MH6 | Mounting Hole 0.5mm | Mounting Hole 0.5mm | | 0R 0201 | R1 | RES0201N | RES 0R 0201 | | 4.7K 0201 1% 100PPM | R2, R6 | RES0201L | RES 4.7K 0201 1% 100PPM | | 750R 0201 1% 100PPM | R3 | RES0201L | RES 750R 0201 1% 100PPM | | 330R 0201 1% 100PPM | R4, R27 | RES0201L | RES 330R 0201 1% 100PPM | | 1.6K 0201 1% 100PPM | R5 | RES0201L | RES 1.6K 0201 1% 100PPM | | 0R 0402 | R7, R8, R15 | RES0402N | RES 0R 0402 | | RES NF 0402 | R9 | RES0402N | RES NF 0402 | | 10K 0201 1% 100PPM | R10, R18, R23, R24, R35 | RES0201L | RES 10K 0201 1% 100PPM | | 3.3K 0201 1% 100PPM | R11 | RES0201L | RES 3.3K 0201 1% 100PPM | | 287K 0201 1% 100PPM | R12 | RES0201N | RES 287K 0201 1% 100PPM | | 51.1K 0201 1% 100PPM | R13 | RES0201N | RES 51.1K 0201 1% 100PPM | | 100K 0201 1% 100PPM | R14 | RES0201N | RES 100K 0201 1% 100PPM | | 10K 0402 1% | R16, R17 | RES0402N | RES 10K 0402 1% 100PPM | | 1M 0402 1% | R19, R22, R47 | RES0402N | RES 1M 0402 1% 100PPM | | 280K 0402 1% 100PPM | R20 | RES0402N | RES 280K 0402 1% 100PPM | | 100K 0402 1% | R21 | RES0402N | RES 100K 0402 1% 100PPM | | 330R 0201 1% 100PPM | R25 | RES0201N | RES 330R 0201 1% 100PPM | | 620R 0201 1% 200PPM | R26 | RES0201L | RES 620R 0201 1% 200PPM | | 680K 0402 1% | R46 | RES0402N | RES 680K 0402 1% 100PPM | | PTS820J2x | SW1, SW2 | TL1015 | PTS820J2x | | SW REED SPST | SW3 | CT05 | SW REED SPST | | ISP1807-LR | U1 | ISP1807-LR | ISP1807-LR | | NEO-M8N | U2 | NEO | NEO-M8N | | IS25LP128F-JKLE | U3 | SON127P600X80_HS-9N | IS25LP128F-JKLE | | BQ24230RGT | U4 | VQFN-16 | BQ24230RGT | | TPS63036YFGR | U5 | BGA8C40P2X4_108X181X62 | TPS63036YFGR | | LTC6995IS6 | U6 | SOT-23_DBV | LTC6995IS6 | | 74HC132BQ-Q100X | U7 | DHVQFN14 | 74HC132BQ-Q100X | | BQ27621YZFR-G1A | U8 | DSBGA-9 | BQ27621YZFR-G1A | | BMX160 | U9 | LGA14 | BMX160 | | MS5803-14BA | U10 | MS5803 | MS5803-14BA |
重要提示:PCB作品文件展下载说明
