重要提示:PCB作品文件展下载说明
PXA168.zip
14.27 MB, 下载次数: 2, 下载积分:金币 -5 枚
售价: 5 枚金币 [记录] [购买]
| 26 | 1 | D28 | SS14 | Fairchild | SS14 | DIODE SCHOTTKY 1A 40V SMA | SMA | | 27 | 1 | D31 | Diode | Microsemi | LSM115JE3/TR13 | DIODE SCHOTTKY 15V 1A DO214BA | DO214BA | | 28 | 9 | FB4,FB5,FB6,FB15,FB45,FB46,FB48,FB49,FB50 | FB/3A | Murata | BLM18KG121TN1 | FERRITE CHIP 120 OHM 3000MA 0603 | L-0603 | | 29 | 4 | FB8,FB9,FB10,FB11 | BEAD | Murata | BLM18BA470SN1 | FERRITE CHIP 47 OHM 300MA 0603 | L-0603 | | 30 | 1 | J1 | USB micro AB | Hirose | ZX62RD-AB-5P8 | CONN RCPT MCR USB AB SMD TH SHLL | USB-MICRO-AB-HIROSE | | 31 | 1 | J7 | 2x8-0.1in-SMD | Samtec | HLE-108-02-F-DV | CONN SOCKET 2.54MM 16POS GOLD | SKT2x8_100MIL_SMD | | 32 | 3 | J8,J32,J34 | Molex-52806-0510 | Molex | 52806-0510 | CONN FFC/FPC 5POS 1MM VERT T/H | Molex_52806_0510 | | 33 | 1 | J27 | PH | JST | S2B-PH-SM4-TB(LF)(SN) | CONN HEADER PH SIDE 2POS 2MM SMD | JST_PH2P_2MM | | 34 | 1 | J30 | uSD SLOT | Amphenol | 101-00660-68-6 | CONN MINI MICRO-SD 8PIN PCB GOLD | uSDCARD-push | | 35 | 1 | J33 | USB mini B | MOLEX | 513870530 | CONN RCPT MINIUSB B 5POS SMD R/A | USB-MINI-B-MOLEX | | 36 | 1 | J35 | BSW25x2 | Samtec | BSW-125-04-L-D | CONN RCPT 50POS .100" DBL GOLD BOTTOM ENTRY | RCPT25x2_100mil_BOT | | 37 | 2 | J36,J39 | HDR1x8 | Samtec | SSM-108-F-SV | CONN HEADER FEMALE 8POS .1" GOLD | HDR1x8_100milSMT | | 38 | 1 | J48 | FPC 51C 0.3mm top | HIrose | FH35-51S-0.3SHW(50) | CONN FPC 51POS 0.3MM SMD | FH35_51_0_3MM | | 39 | 1 | J50 | PHR3 | JST | S3B-PH-SM4-TB(LF)(SN) | CONN HEADER PH SIDE 3POS 2MM SMD | JST_PHR3P_2mm | | 40 | 2 | J51,J52 | ACH2P | JST | BM02B-ACHSS-GAN-TF(LF)(SN) | CONN HEADER ACH SIDE 2POS 1.2MM | JST_ACHSS_2P1_2MM | | 41 | 1 | LED13 | Green | Liteon | LTST-C191KGKT | LED GREEN CLEAR THIN 0603 SMD | LED-0603 | | 42 | 1 | L2 | 5.1nH | Murata | LQG15HS5N1S02D | INDUCTOR 5.1NH 300MA 0402 | L-0402 | | 43 | 1 | L10 | 1.0uH | TDK | FLF3215T-1R0N | INDUCTOR 1.0UH 2.0A 30% SMD | FLF3215 | | 44 | 1 | L11 | 1.2uH | TDK | VLC5020T-1R2N | INDUCTOR POWER 1.2UH 3.8A SMD | VLC5020T | | 45 | 1 | L12 | 1.5uH | Vishay | IFSC1008ABER1R5M01 | INDUCTOR POWER 1.5UH 2.6A SMD | INDUCTOR_MDT2520_CN_SERIES | | 46 | 1 | L34 | CMC | Taiyo | CM04RC01T | CHOKE COMMON MODE 800OHMS SMD | CMC | | 47 | 1 | L35 | 1.0uH | Vishay | IFSC1008ABER1R0M01 | INDUCTOR POWER 1UH 2.6A SMD | INDUCTOR_MDT2520_CR_SERIES | | 48 | 1 | L36 | 2.7uH | Bourns | SDR0302-2R7ML | INDUCTOR POWER 2.7UH 1.5A 0302 | SDR0302 | | 49 | 1 | NTC1 | 10K | Panasonic | ERT-J0EM103J | THERMISTOR NTC 10K OHM 5% 0402 | R-0402 | | 80 | 2 | SW5,SW13 | FSM2JSMA | Tyco | FSM2JSMATR | SWITCH TACTILE SPST-NO 0.05A 12V | FSM2JSMATR | | 81 | 1 | U1 | PXA166SA0 | Marvell | 88AP166SA0-BJD2C008 | IC App Processor SOC | fbga-18x18-320 | | 82 | 1 | U2 | DDR3_X16_BGA96 | Nanya | NT5CB64M16FP-CF | IC DDR3 1Gbit-64Mx16 | DDR3-96 | | 83 | 1 | U8 | 88CE156 | Marvell | 88CE156A0NAJ2C000 | IC CODEC HP STEREO HP SPKR DRVR | QFN32p-0_5-5X5X1MM | | 84 | 1 | U16 | 88PG867 | Marvell | 88PG867-HB0-NNY2C00 | IC Power, Dual 3A/1A buck | 3x4QFN24 | | 85 | 1 | U23 | 32.768KHz | TXC | 7XZ3270008 | OSCILLATOR 32.768KHZ 1.8V SMD | smy4p-3_2x2_5x1mm | | 86 | 1 | U99 | AW-NH387 | AzureWave | AW-NH387 | MODULE WIFI 8787 2.4G | LGA-88 | | 87 | 7 | U120,U131,U132,U141,U142,U147,U148 | RT9715EGB | Richtek | RT9715EGB | IC PWR SW USB 1.1A SOT23-5 | SOT23-5 | | 88 | 1 | U126 | W25Q128 | Winbond | W25Q128FVEIG | Flash Mem Serial-SPI 3.3V 128M-Bit 16M x 8 8ns 8-Pin VDFPN EP | qfn-8x6-8s | | 89 | 1 | U133 | 88PG8211 | Marvell | 88PG8211A2-NXS2C000 | IC power, 500mA buck 50mA LDO | 4X3QFN16_PAD_LENGTH_0P8MM_32MIL | | 90 | 1 | U134 | FT234 | FTDI | FT234XD-R | IC USB SERIAL BASIC UART 12DFN | DFN12 | | 91 | 2 | U135,U143 | PIC16F1508 | microchip | PIC16F1508-I/ML | IC microcontroller 20 pin | QFN20 | | 92 | 4 | U136,U137,U144,U145 | 74HC4094 | NXP | 74HC4094PW,118 | IC 8STAGE SHFT/STORE BUS 16TSSOP | TSSOP16 | | 93 | 1 | U146 | MAX17058G | maxim | MAX17058G+ | IC gas gauge m3 | TDFN8 | | 94 | 1 | U150 | MAX17112 | Maxim | MAX17112ETB+ | IC CONV DC-DC STEP UP 10TDFN | TDFN10EP | | 95 | 1 | U151 | PCA9543 | NXP | PCA9543AD,118 | IC I2C SWITCH 2CH 14-TSSOP | soic14-50-157 | | 96 | 1 | U154 | AP7333 | Doides | AP7333-33SRG-7 | IC LDO 3.3v .3A SOT23R | SOT23R | | 97 | 6 | U155,U156,U170,U171,U172,U173 | TPD8E003 | TI | TPD8E003DQDR | IC 8CH ESD PROT 8WSON | WSON8EP | | 98 | 1 | U159 | PIC12F508 | Microchip | PIC12F508I/MC | IC microcontroller | DFN8EP | | 99 | 1 | U169 | RT9525 | Richtek | RT9525GQW | IC charger linear Li-Poly | WQFN16EP | | 100 | 2 | U175,U176 | CM1293A | Onsemi | CM1293A-04SO | ESD PROT LOW CAP 4CH SC74 | SC-74 | | 101 | 1 | VR1 | 88PG839 | Marvell | 88PG839-A1-NAE2C000 | IC Power Switching | DFN-12 | | 102 | 1 | Y1 | 26MHz | TXC | 7M26070013 | CRYSTAL 26.000 MHZ 18PF SMD | o-3_2X2_5-4g | | Unpopulated Parts | | | | | | | 103 | 2 | CM1,CM2 | *CML201212T-121M | Murata | CML201212T-121M | IND common mode choke 2 lines | FIL-2X1_2-4 | | 104 | 3 | C188,C367,C369 | *2.2uF | TDK | C1005X5R1A225K | CAP CER 10UF 10V 10% X5R 0603 | C-0402 | | 105 | 1 | C328 | *4.7uF | Murata | GRM188R60J475KE19D | CAP CER 4.7UF 6.3V 10% X5R 0603 | CAP_0603 | | 106 | 1 | C334 | *9pF | Murata | GRM1555C1H9R0DZ01D | CAP CER 9PF 50V C0G 0402 | C-0402 | | 107 | 3 | C337,C384,C385 | *33pF | TDK | C1005C0G1H330J050BA | CAP CER 33PF 50V 5% NP0 0402 | C-0402 | | 108 | 1 | C361 | *560pF | TDK | C1005C0G1E561J | CAP CER 560PF 25V 5% NP0 0402 | C-0402 | | 109 | 4 | D12,D14,D29,D30 | *ESD | Vishay | MSE1PB-M3/89A | DIODE ESD PROT 1A 100V MICROSMP | MicroSMP | | 110 | 1 | FB47 | *FB/3A | Murata | BLM18KG121TN1 | FERRITE CHIP 120 OHM 3000MA 0603 | L-0603 | | 111 | 1 | J6 | *U.FL | Hirose | U.FL-R-SMT | Conn coax rf | USB_SINGLEBAND_A | | 112 | 1 | L3 | *1.2nH | Vishay | ILC0402ER1N2S | IND 1.2nH 300mA 0.12ohm Q=8 SMD 0402 GP | L-0402 | | 113 | 2 | Q1,Q108 | *FDV301N | FAIRCHILD | FDV301N | MOSFET N-CH 25V 220MA SOT-23 | SOT-23a | | 114 | 1 | Q3 | *MMBT3904 | On Semi | MMBT3904LT1G | Transistor NPN MMBT3904 | SOT23 |
1 | 6 | C1,C2,C3,C4,C5,C6 | 1uF | Taiyo | TMK107BJ105KA-T | CAP CER 1UF 25V 10% X5R 0603 | 2 | 2 | C322,C323 | 0.1uF | TDK | C1005X7R1A104K | CAP CER .10UF 10V X7R 0402 | 3 | 3 | D1,D2,D3 | B0540WS-7 | Diodes | B0540WS-7 | DIODE SCHOTTKY 40V 0.5A SOD323 | 4 | 2 | D15,D16 | RED | Lite-On | LTST-C193KRKT-5A | LED RED RECT CLEAR 0603 | 5 | 3 | J1,J4,J7 | FPC 51C 0.3mm top | HIrose | FH35-51S-0.3SHW(50) | CONN FPC 51POS 0.3MM TOP SMD | 6 | 2 | J2,J5 | FPC 45C 0.5mm bot | AVX | 046240054005800+ | CONN FPC ONE-TOUCH LCK .5MM 54 | 7 | 1 | J3 | FPC 6C 0.5mm BOT | FCI | SFV6R-1STE1HLF | CONN FPC/FFC 6POS BOT .5MM R/A SMD | 8 | 2 | J50,J74 | PHR3 | JST | S3B-PH-SM4-TB(LF)(SN) | CONN HEADER PH SIDE 3POS 2MM SMD | 9 | 2 | J55,J75 | KS1042SMD | Keystone | 1042 | HOLDER BATTERY 1CELL 18650 SMD | 10 | 1 | J76 | FPC 10C 0.5mm top | FCI | SFV10R-2STE1HLF | CONN FPC/FFC 10POS .5MM R/A SMD | 11 | 3 | L1,L2,L3 | 22uH | Taiyo | NR4012T220M | INDUCTOR 22UH 20% SMD | 12 | 7 | Q6,Q66,Q67,Q68,Q69,Q70,Q71 | FDV301N | FAIRCHILD | FDV301N | MOSFET N-CH 25V 220MA SOT-23 | 13 | 3 | R3,R6,R7 | 4.99R | Vishay | CRCW04024R99FKED | RES 4.99 OHM 1/16W 1% 0402 SMD | 14 | 7 | R27,R389,R391,R392,R414,R419,R424 | 10K | Panasonic | ERJ-2GEJ103X | RES 10K OHM 1/10W 5% 0402 SMD | 15 | 4 | R29,R388,R390,R393 | 220R | Panasonic | ERJ-2RKF2200X | RES 220 OHM 1/10W 1% 0402 SMD | 16 | 1 | R407 | 0R | Panasonic | ERJ-2GE0R00X | RES 0.0 OHM 1/10W 0402 SMD | 17 | 1 | R427 | 1.5K | Panasonic | ERJ-2GEJ152X | RES 1.5K OHM 1/10W 5% 0402 SMD | 18 | 3 | U1,U2,U3 | AP5724WG-7 | Diodes | AP5724WG-7 | IC LED DRVR WHITE BCKLGT SOT23-6 | 19 | 2 | U5,U6 | S8211C | SII | S-8211CAD-M5T1G | IC Lithium Battery Pack Protection | | Unpopulated Parts | | | | | 20 | 1 | C110 | *0.1uF | TDK | C1005X7R1A104K | CAP CER .10UF 10V X7R 0402 | 21 | 1 | C111 | *1uF | TDK | C1608X7R1A105K | CAP 1uF 10% 0603 10V X7R | 22 | 4 | C115,C116,C117,C118 | *1000pF | Kemet | C0402S102K3RACTU | CAP 1nF 10% 0402 25V X7R | 23 | 1 | FB5 | *FB/3A | Murata | BLM18KG121TN1 | FERRITE CHIP 120 OHM 3000MA 0603 | 24 | 1 | J8 | *SMD60_0.3MM | PCB fab | N/A | PCB foot print | 25 | 1 | J9 | *SMD60_0.5mm | PCB fab | N/A | PCB foot print | 26 | 1 | J10 | *TH34 | PCB fab | N/A | PCB foot print 2x17 x 28mil hole | 27 | 1 | J11 | *TH60 | PCB fab | N/A | PCB foot print 2x30 28mil hole | 28 | 1 | J12 | *TH14 | PCB fab | N/A | PCB foot print 1x14 x 28mil hole | 29 | 1 | J13 | *SMD14_1mm | PCB fab | N/A | PCB foot print | 30 | 1 | J14 | *SMD14_0.5MM | PCB fab | N/A | PCB foot print | 31 | 1 | J15 | *TH12 | PCB fab | N/A | PCB foot print 2x6 x 28mil hole | 32 | 3 | J16,J17,J77 | *TH1 | PCB fab | N/A | PCB foot print 28mil hole | 33 | 1 | J52 | *RTOUCH | | N/A | PCB TH 100mil D28mm | 34 | 14 | R102,R395,R396,R397,R398,R399,R400,R401,R402,R403,R404,R405,R406,R408 | *0R | Panasonic | ERJ-2GE0R00X | RES 0.0 OHM 1/10W 0402 SMD | 35 | 2 | R115,R429 | *0R | Panasonic | ERJ-3GEY0R00V | RES 0.0 OHM 1/10W 0603 SMD | 36 | 2 | R386,R394 | *1M | Panasonic | ERJ-2GEJ105X | RES 1M OHM 1/10W 5% 0402 SMD | 37 | 15 | R409,R410,R411,R412,R413,R415,R416,R417,R418,R420,R421,R422,R423,R425,R426 | *10K | Panasonic | ERJ-2GEJ103X | RES 10K OHM 1/10W 5% 0402 SMD | 38 | 1 | R428 | *4.99R | Vishay | CRCW04024R99FKED | RES 4.99 OHM 1/16W 1% 0402 SMD | 39 | 11 | TP1,TP3,TP5,TP6,TP7,TP8,TP9,TP10,TP11,TP12,TP13 | *T_POINT | Test | NA | SMT Test Point | 40 | 1 | U4 | *TSC2003TSSOP | TI | TSC2046IPWR | IC resistove touch controller |
重要提示:PCB作品文件展下载说明
