重要提示:PCB作品文件展下载说明
radxa-cm3i-io-board.7z
5.98 MB, 下载次数: 4, 下载积分:金币 -5 枚
| Name | Part Type | PCB Decal | Value | | CN14A1 | SD_SOCKET_0 | TF-CKT01-009D | TF_SD_SOCKET | | D1 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D2 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D3 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D4 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D5 | DIODE_3 | SOD_323 | B5819WS | | D14 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D15 | DIODE_2 | DO_214AC | SS54 | | D16 | DIODE_ZENER1 | SOD_123 | SMFJ18A | | D17 | DIODE_3 | SOD_323 | B5819WS | | D26 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D27 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D28 | DIODE_1 | DO_214AA | SMBJ58A | | D30 | DIODE_2 | DO_214AC | SS54 | | D31 | DIODE | DO214AC | SS34 | | D32 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D33 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D34 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D35 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | D36 | DIODE_DOUBLE | SOT_23 | BAT54C | | D37 | DIODE_3 | SOD_123 | 5819 | | D38 | DIODE_3 | SOD323 | NC | | ED18 | DIODE_BI_DIR_TRIG_0 | ESD0402_1XD5 | BTR04G02 | | FB1 | BEAD | L0603 | 120R-100MHz | | FB2 | BEAD | L0603 | 120R-100MHz | | FB3 | FERRITE_BEAD | R0402 | FB120R | | FB4 | R-PACK4_1_2 | GMDG-4PIN_ESD | BCMF122P900H | | FB5 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | FB6 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | FB7 | FB | R0402 | FB120R | | FB8 | FB | R0402 | FB120R | | FB9 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | FB10 | RES_1B | R0603 | FB120R | | FB11 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | FB12 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | FB13 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | FB14 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | FB15 | R-PACK4_3 | GMDG-4PIN_ESD | BCMF122P900H | | FB16 | R-PACK4_0_2 | GMDG-6PIN_ESD | BCMEF122P900H | | GND_1 | TEST | TP32 | GND | | H2 | HOLE | HOLE_R6_3D2MM | HOLE | | H3 | HOLE | HOLE_R6_3D2MM | HOLE | | H4 | HOLE | HOLE_R6_3D2MM | HOLE | | H6 | HOLE | HOLE_R6_3D2MM | HOLE | | J1 | CON3_1X3 | DIP3_1X3D5 | CON_3P_3D5_DIP | | J3 | CON4_0 | DIP4_1X3D5 | DIP4_1X3D5 | | J4 | CON15_5 | FPC15PIN-1.0MM-LS | CON15 | | J5 | CON3_1X3 | DIP3_1X3D5 | CON_3P_3D5_DIP | | J6 | CN_9 | DF40C_100DS | PCIE | | J7 | CN_10 | DF40C_100DS | I/O | | J8 | CON15_5 | FPC15PIN-1.0MM-LS | CON15 | | J14 | HEADER_1X4P | 4PINX2_54_DIP_XIAO4P | HEADER_1X4P | | J15 | SIM-SPPN08-X0-1X80_0 | MICRO_SIM | MICRO_SIM | | J16 | SATA_DIP_1 | SMD_SATA_7P_50_180 | SATA_7P_H_SMD | | J19 | HDMI_A | HDMIA19S | HDMI_A | | J20 | CON1 | HOLE_5D5X2D7MM | HOLE | | J21 | HR911130C_1 | RJ45_HRK1 | 1000MHz_POE | | J23 | CON4_1 | DIP_POE_AG5412 | POE_AG5412_12V | | J28 | CON6_1 | FPC6-0.5MM-2660H | CON6 | | J32 | CON1 | HOLE_5D5X2D7MM | HOLE | | J33 | CON1 | HOLE_5D5X2D7MM | HOLE | | J35 | DC091-5521 | DC091-5521 | DC091-5521 | | J90036 | HR911130C_1 | RJ45_HRK1 | HRK1-1B71G59-36A1BB-1R | | L1 | INDUCTORS_OF_FERRITE_2 | IND-4X4 | 4.7uH | | L2 | INDUCTORS_OF_FERRITE_2 | IND-4X4 | 4.7uH | | L3 | INDUCTORS_OF_FERRITE | IND-5020 | SPM5020T-2R2M-LR | | L4 | INDUCTORS_OF_FERRITE_2 | IND-4X4 | 4.7uH | | L6 | R-PACK4_1 | RCMF7060 | RCMF7060F-701-2P-T | | L7 | INDUCTORS_OF_FERRITE_2 | IND-4X4 | 4.7uH | | L10 | INDUCTORS_OF_FERRITE | IND-4X4 | 4.7UH/2A | | L6801 | INDUCTOR_COM | RP2_0405 | BCMF122P900H | | L6803 | INDUCTORS_OF_FERRITE_2 | IND_252010 | 2.2uH | | LCD1 | EDP_0 | 20455-040E-TOP | FPC-40P-0.5MM | | LCD2 | EDP30PIN | FPC30-0.5MM | FPC30-0.5MM | | LED2 | LED | LED0603 | NC | | Q1 | NPN | SOT_23 | S8050 | | Q2 | MOSFET_P_2 | SOT23 | NC/WPM2301 | | Q3 | P-MOSFET | S0T-23 | NC/AO3401 | | Q4 | N-MOSFET | S0T-23 | NC/WNM2021-3/TR | | Q5 | NPN | SOT_23 | S8050 | | Q6 | MOSFET_P_2 | SOT23 | WPM2301 | | Q7 | NPN | SOT_23 | S8050 | | Q8 | NPN | SOT_23 | S8050 | | Q9 | NPN | SOT23 | S8050 | | Q10 | NPN | SOT23 | S8050 | | Q11 | MOSFET_P_2 | SOT23 | WPM2015-3/TR | | Q12 | NPN | SOT23 | S8050 | | Q13 | MOSFET_P | SOT_23 | WPM2015-3/TR | | Q14 | NPN4 | SOT23 | S8050 | | Q15 | MOSFET_N_2 | SOT23 | AO3416 | | Q16 | N-MOSFET | SOT_323 | 2SK3018 | | Q17 | MOSFET_N | SOT_323 | 2SK3018 | | Q18 | N-MOSFET | SOT_323 | 2SK3018 | | Q19 | MOSFET_P | SOT_23 | WPM2015-3/TR | | Q20 | NPN4 | SOT23 | S8050 | | RP1 | R-PACK4 | RN8P4RC | 22RX4 | | RP2 | R-PACK4 | RN8P4RC | 22RX4 | | SW1 | KEY_0 | SW_4_DIP | RECOVERY_KEY | | SW3 | LED_0 | DIP_SWITCH | CB-031-DWZ-16P-13S-01 | | T1 | TEST | TP32 | 12V | | TP1 | TP | TP_0R70 | TP_0.7 | | TP2 | TP | TP_0R70 | TP_0.7 | | TP8 | TP | TP_0R70 | TP_0.7 | | TP9 | TP | TP_0R70 | TP_0.7 | | U1 | XR21V1410_0 | SSOP20_1 | SP3222EEA-L/SSOP20 | | U2 | MAX3485_0 | SOP8_5R00X4R00X1R75_T | SIT3485E | | U3 | TJA1051T_0 | SOP8_5R00X4R00X1R75_T | TCAN1044V-Q1 | | U6 | M_5.2_NGFF_EKEY_SOCKET | M2_NGFF_KEY_M_1 | M2-MKEY | | U7 | M_6.2_NGFF_EKEY_SOCKET | M2_NGFF_KEY_B-GX | M2-BKEY | | U8 | DCDC_SY8113 | SOT_23_6 | SY8113B/SM8103ADC | | U9 | DCDC_SY8113 | SOT_23_6 | SY8113B | | U10 | LDO_PT5108 | SOT_23_5 | RT9193-33GB | | U11 | AU5426_DEVICE | AU5426_QFN32 | Au5426_device | | U12 | CH482X | QFN20-2D5X4D5 | CH482D | | U14 | OSC_4PIN_1 | CRY4_3R20X2R50X0R80 | NC/SOC_24MHz | | U17 | DCDC_NB679 | QFN12_2R00X3R00X1R00 | NB679GD | | U18 | CON3_7 | DIP2_1X3D5 | DIP2_1X3D5 | | U20 | DCDC_SY8113 | SOT_23_6 | SY8113B/SM8103ADC | | U21 | ESD_ESD5304D | SON10_2R50X1R00X0R50 | ESD5344D | | U22 | ESD_ESD5304D | SON10_2R50X1R00X0R50 | ESD5344D | | U23 | SWITCH_SY6280 | SOT_23_5 | SY6280AAC/TCS9163 | | U24 | M_8.2_NGFF_EKEY_SOCKET | M2_NGFF_KEY_E_42X30 | M2_NGFF_KEY_E | | U25 | DCDC_SY8113 | SOT_23_6 | SY8113B/SM8103ADC | | U26 | ESD_ESD5304D | SON10_2R50X1R00X0R50 | ESD5344D | | U27 | ESD_ESD5304D | SON10_2R50X1R00X0R50 | ESD5344D | | U31 | AO4409_0 | SOP8-50-150 | AO4409 | | U32 | RECTIFIER_B | SOP4_1D27_4 | HD06-T | | U33 | RECTIFIER_B | SOP4_1D27_4 | HD06-T | | U34 | MP3202-QFN8_1 | DFN10P_3X3 | SY7203 | | U35 | CON_BATTERY-20MM_0 | BAT_CR1220 | CR1220-3V | | U36 | RTC_HYM8563 | MSOP8 | HYM8563TS | | U37 | CON3_6 | SMD_1D25X2PIN_90 | SMD_1D25X2PIN_90 | | U38 | HETER_4 | DF40C-200DS-70X40_MZ_3D5 | J1000 | | U39 | CON3_0 | DIP_14PIN-2_54MM | DIP_2D54MM_14PIN_180 | | U41 | ETHERNET_RTL8211F | QFN40_5R00X5R00X0R90_T | RTL8211F-CG | | U42 | LCD39P_03 | LCD39PIN-OK | LCD39P_03 | | USB6 | USB30_TYPE_A | USB30-L1 | USB30_A | | USB2503 | USB20_TYPE_A | USB20A4_USB_AF_01_001 | USB-HUB_PORTBA | | Y1 | 7W50000024_4 | CRY4_3R20X2R50X0R80 | 100MHz,3.3V,3225 | | Y3 | CRYSTAL_2P_0 | CRY-3215 | 32.768KHz | | Y4 | CRYSTAL_4P | CRY4_3R20X2R50X0R80 | 25MHz |
重要提示:PCB作品文件展下载说明
