| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D2 | LED_4_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D3 | BAT54C_SOT23-3_BAT54C | BAT54C | SOT23-3 |
| D4 | LED_4_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D5 | DIODE13_6_TO-227A_V10P10 | V10P10 | TO-227A |
| DC1 | DC005_DC005_DC005 | DC005 | DC005 |
| J1 | CONN RCPT 6X2_CN2X6-2P54-Z_CN2X | CN2X6-2P54-Z | CN2X6-2P54-Z |
| J2 | CONN RECT 17X2_CN2X17-2P54-Z_CN | CN2X17-2P54-Z | CN2X17-2P54-Z |
| J3 | CONN RCPT 2_WJ2EDGRC-5R08-2P_WJ | WJ2EDGRC-5R08-2P | WJ2EDGRC-5R08-2P |
| J4 | CONN RCPT 2_WJ2EDGRC-5R08-2P_WJ | WJ2EDGRC-5R08-2P | WJ2EDGRC-5R08-2P |
| J5 | BATTERY_CR1220HOLDER-SMD_CR1220 | CR1220 | CR1220HOLDER-SMD |
| J6 | CONN RCPT 4_CN1X4-2P54-Z_CN1X4- | CN1X4-2P54-Z/NI | CN1X4-2P54-Z |
| J7 | CON20_0_CN2X10-2P54-Z_CN2X10-2P | CN2X10-2P54-Z | CN2X10-2P54-Z |
| J8 | CON_RJ45_1X8_F_RA_0_HR911105A_H | HR911105A | HR911105A |
| L1 | IND_BEAD_0805_600OHM_1_L0805_BL | BLM21PG600 | L0805 |
| L2 | IND_BEAD_0805_600OHM_1_L0805_BL | BLM21PG600 | L0805 |
| L3 | INDUCTOR_0_L4020_SWPA4020S4R7MT | SWPA4020S4R7MT | L4020 |
| L4 | INDUCTOR_0_L4020_SWPA4020S4R7MT | SWPA4020S4R7MT | L4020 |
| Q1 | DTC043ZMT2L_SOT723_DTC043ZMT2L | DTC043ZMT2L | SOT723 |
| Q2 | DTC043ZMT2L_SOT723_DTC043ZMT2L | DTC043ZMT2L | SOT723 |
| S1 | SW PUSHBUTTON_0_KEY-2P-SMD-6R2X | KEY | KEY-2P-SMD-6R2X3R8X2R5 |
| S2 | SW PUSHBUTTON_0_KEY-2P-SMD-6R2X | KEY | KEY-2P-SMD-6R2X3R8X2R5 |
| TP1 | TESTPOINT_TP-0R75_TESTPOINT/NI | TestPoint/NI | TP-0R75 |
| TP2 | TESTPOINT_TP-0R75_TESTPOINT/NI | TestPoint/NI | TP-0R75 |
| U1 | MK60DN512VLL10_6_LQFP100-14X14X | MK60DN512VLL10 | LQFP100-14X14X0R5 |
| U2 | TFCARD_1_TFCARD_THD2528-11SD-GF | THD2528-11SD-GF | TFCARD |
| U3 | CEIT_C5000_0_SOIC8_208_W25Q16JV | W25Q16JVSNIQ | SOIC8_208 |
| U4 | MB85RC64PNF-G-JNERE1_SOIC8_AT24 | AT24C02D-SSHM-T | SOIC8 |
| U5 | NRF24L01PACK_NRF24L01PACK_NRF24 | NRF24L01PACK | NRF24L01PACK |
| U6 | MAX3485ESA_SOIC8_SP3485EN-L/TR | SP3485EN-L/TR | SOIC8 |
| U7 | TJA1050_SOIC8_SN65HVD230DR | SN65HVD230DR | SOIC8 |
| U8 | PESD1CAN_SOT23-3_PESD1CAN | PESD1CAN | SOT23-3 |
| U9 | ADXL345_0_LGA14-5R0X3R0_ADXL345 | ADXL345BCCZ-RL7 | LGA14-5R0X3R0 |
| U10 | LIS3DHTR_LGA16-3R0X3R0_LIS3DHTR | LIS3DHTR | LGA16-3R0X3R0 |
| U11 | PS1240P02BT_PS1240P02BT_PS1240P | PS1240P02BT | PS1240P02BT |
| U12 | CY2305C_0_SOIC8_CY2305SXI-1HT | CY2305SXI-1HT | SOIC8 |
| U13 | KSZ8041NL_QFN32-5X5X0R5-3R1X3R1 | KSZ8041NLI | QFN32-5X5X0R5-3R1X3R1 |
| U14 | BL8032CB6TR_SOT23-6_BL8032CB6TR | BL8032CB6TR | SOT23-6 |
| U15 | BL8032CB6TR_SOT23-6_BL8032CB6TR | BL8032CB6TR | SOT23-6 |
| USB1 | USB-MICRO_USB-U-F-M5SS-W-1_U-F- | U-F-M5SS-W-1 | USB-U-F-M5SS-W-1 |
| X1 | XTAL_5032_0_X-2P-3R2X1R5-SMD_Q1 | Q13FC1350000400 | X-2P-3R2X1R5-SMD |
| X2 | SMD_OSC_3_X-4P-5R0X3R2-SMD_SG50 | SG5032CAN-50M-TJGA | X-4P-5R0X3R2-SMD |
