| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| B1 | BEEP_HC12085P_PS1240P02BT_PS124 | PS1240P02BT | PS1240P02BT |
| D1 | LED_0_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D2 | LED_0_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D3 | LED_0_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D4 | LED_0_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D5 | DIODE13_7_SOD-123_1N4148W-TP | 1N4148W-TP | SOD-123 |
| D6 | DIODE13_7_SOD-123_1N4148W-TP | 1N4148W-TP | SOD-123 |
| F1 | FUSE_SMD-1210_SMD1210-6V2A | SMD1210-6V2A | SMD-1210 |
| J1 | CON20_0_HEADER10X2_2R54_HEADER1 | HEADER10X2_2R54 | HEADER10X2_2R54 |
| J2 | CONN RCPT 9X2_OV2640_OV7620 | OV7620 | OV2640 |
| J3 | CONN RCPT 4_HEADER4X1_2R54_HEAD | HEADER4X1_2R54 | HEADER4X1_2R54 |
| J4 | CONN RCPT 2_KF7R62-2P_KF7R62-2P | KF7R62-2P | KF7R62-2P |
| J5 | CONN RCPT 2_KF7R62-2P_KF7R62-2P | KF7R62-2P | KF7R62-2P |
| J6 | HR911105A_HR911105A_HR911105A | HR911105A | HR911105A |
| L1 | IND_BEAD_0805_600OHM_1_LC0805_B | BEAD_GZ2012D102TF | LC0805 |
| L3 | IND_BEAD_0805_600OHM_1_LC0805_B | BEAD_GZ2012D102TF | LC0805 |
| L5 | IND_BEAD_0805_600OHM_200MA_LC08 | BEAD_BLM21PG600 | LC0805 |
| MH1 | HOLD_1_HOLD250D134_HOLD-M3 | HOLD-M3 | HOLD250D134 |
| MH2 | HOLD_1_HOLD250D134_HOLD-M3 | HOLD-M3 | HOLD250D134 |
| MH3 | HOLD_1_HOLD250D134_HOLD-M3 | HOLD-M3 | HOLD250D134 |
| MH4 | HOLD_1_HOLD250D134_HOLD-M3 | HOLD-M3 | HOLD250D134 |
| Q1 | L14G1/TO_2_SOT23_123_S9013LT1 | S9013LT1 | SOT23_123 |
| Q2 | L14G1/TO_2_SOT23_123_S9013LT1 | S9013LT1 | SOT23_123 |
| Q3 | L14G1/TO_1_SOT23_123_S8050 | S8050 | SOT23_123 |
| RP1 | RESISTOR VAR_0_VISHAY_RES_VAR_6 | M64W104KB40 | VISHAY_RES_VAR_64W |
| SW1 | SWITCH-SPST-4P_SW-6X6X6-SMD_KEY | KEY | SW-6X6X6-SMD |
| SW2 | SWITCH-SPST-4P_SW-6X6X6-SMD_KEY | KEY | SW-6X6X6-SMD |
| SW3 | SWITCH-SPST-4P_SW-6X6X6-SMD_KEY | KEY | SW-6X6X6-SMD |
| SW4 | SWITCH-SPST-4P_SW-6X6X6-SMD_KEY | KEY | SW-6X6X6-SMD |
| T1 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| T2 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| T3 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| T4 | TOUCHPAD_TOUCHPAD_TOUCHPAD | TouchPad | TOUCHPAD |
| TP1 | TESTPOINT_TP-0R75_TESTPOINT | TestPoint | TP-0R75 |
| TP2 | TESTPOINT_TP-0R75_TESTPOINT | TestPoint | TP-0R75 |
| TP3 | TESTPOINT_TP-0R75_TESTPOINT | TestPoint | TP-0R75 |
| U1 | NRF24L01PACK_NRF24L01PACK_NRF24 | NRF24L01PACK | NRF24L01PACK |
| U2 | CEIT_C5000_0_SOIC-8_208_W25Q128 | W25Q128FVSIG | SOIC-8_208 |
| U3 | CH340G_SOIC16_CH340G | CH340G | SOIC16 |
| U4 | K60_LQFP-144_MK60DN512VLQ10 | MK60DN512VLQ10 | LQFP-144 |
| U5 | HS0038_HS0038_HS0038 | HS0038 | HS0038 |
| U6 | AMS1117-3.3_SOT-223_AMS1117-3.3 | AMS1117-3.3 | SOT-223 |
| U7 | ADXL345_0_LGA-14_ADXL345BCCZ-RL | ADXL345BCCZ-RL7 | LGA-14 |
| U8 | AT24C512_SOIC8_AT24C02C-SSHM-T | AT24C02C-SSHM-T | SOIC8 |
| U9 | BATTERY_CR1220_BATTERY_CR1220 | BATTERY_CR1220 | CR1220 |
| U10 | IS61LV25626_TSOP-44_IS61LV25616 | IS61LV25616AL-10TL | TSOP-44 |
| U11 | TFCARD_1_TFCARD_TFCARD | TFCARD | TFCARD |
| U12 | LM2904VQDR_SOIC8_LM2904VQDR | LM2904VQDR | SOIC8 |
| U13 | MAX3485ESA_0_SOIC8_MAX3485EESA | MAX3485EESA | SOIC8 |
| U14 | TJA1050_SOIC8_TJA1050T/CM | TJA1050T/CM | SOIC8 |
| U15 | TFT-3R2_TFT-3R5_TFT-3R5 | TFT-3R5 | TFT-3R5 |
| U16 | XPT2046_TSSOP-16_XPT2046 | XPT2046 | TSSOP-16 |
| U17 | KSZ8041NL_MLF-32_KSZ8041NLI | KSZ8041NLI | MLF-32 |
| USB1 | USB-MICRO_USB-MICRO_USB-MICRO | USB-MICRO | USB-MICRO |
| USB2 | USB-MICRO_USB-MICRO_USB-MICRO | USB-MICRO | USB-MICRO |
| Y1 | X322525MOB4SI_X-4P-3R2X2R5-SMD_ | X322512MOB4SI | X-4P-3R2X2R5-SMD |
| Y2 | SMD_OSC_3_X-4P-5R0X3R2-SMD_SG50 | SG5032CAN-50M-TJGA | X-4P-5R0X3R2-SMD |
| Y3 | XTAL_5032_0_X-2P-3R2X1R5-SMD_FC | FC-135R32.768kHz | X-2P-3R2X1R5-SMD |
