| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BAT1 | JMP-2_0_ER14250_ER14250 | ER14250 | ER14250 |
| D1 | LED_4_LED0603_GREEN-0603 | GREEN-0603 | LED0603 |
| D3 | LED_4_LED0603_GREEN-0603 | GREEN-0603 | LED0603 |
| J1 | DC3-10P-Z-L_DC3-10P-Z_DC3-10P-Z | DC3-10P-Z | DC3-10P-Z |
| J2 | CONN RCPT 2_CN1X2-2P54-Z_CN1X2- | CN1X2-2P54-Z | CN1X2-2P54-Z |
| J3 | CONN RCPT 2_HX25035-2A_HX25035- | HX25035-2A | HX25035-2A |
| J4 | CONN RCPT 2_CN1X2-2P54-Z_CN1X2- | CN1X2-2P54-Z | CN1X2-2P54-Z |
| J5 | SMA-KHD_SMA-KHD_SMA-KHD | SMA-KHD | SMA-KHD |
| J6 | CONN RCPT 6_CN1X6-2P54-Z_CN1X6- | CN1X6-2P54-Z | CN1X6-2P54-Z |
| J7 | CONN RCPT 4_CN1X4-2P54-Z_CN1X4- | CN1X4-2P54-Z | CN1X4-2P54-Z |
| L1 | IND_BEAD_0805_600OHM_1_L0402_LQ | LQW15AN40NG00 | L0402 |
| L2 | IND_BEAD_0805_600OHM_1_L0402_BL | BLM15AX102SN1 | L0402 |
| L3 | IND_BEAD_0805_600OHM_1_L0402__1 | LQW15AN33NG00 | L0402 |
| L4 | IND_BEAD_0805_600OHM_1_L0402__2 | LQW15AN82NG00 | L0402 |
| L5 | IND_BEAD_0805_600OHM_1_L0402__1 | LQW15AN33NG00 | L0402 |
| L6 | IND_BEAD_0805_600OHM_1_L0402__3 | LQW15AN30NG00 | L0402 |
| L7 | IND_BEAD_0805_600OHM_1_L0402__4 | LQW15ANR10J00 | L0402 |
| L8 | IND_BEAD_0805_600OHM_1_L0402__5 | LQW15AN13NG00 | L0402 |
| L9 | IND_BEAD_0805_600OHM_1_L0402_BL | BLM15AX102SN1 | L0402 |
| MH1 | HOLD_1_HOLE6R90X3R40_HOLE-M3/NI | HOLE-M3/NI | HOLE6R90X3R40 |
| MH2 | HOLD_1_HOLE6R90X3R40_HOLE-M3/NI | HOLE-M3/NI | HOLE6R90X3R40 |
| MH3 | HOLD_1_HOLE6R90X3R40_HOLE-M3/NI | HOLE-M3/NI | HOLE6R90X3R40 |
| MH4 | HOLD_1_HOLE6R90X3R40_HOLE-M3/NI | HOLE-M3/NI | HOLE6R90X3R40 |
| SW3 | SWITCH-SPST-4P_K2-1112SW-A4SW-0 | K2-1112SW-A4SW-04 | K2-1112SW-A4SW-04 |
| TP1 | TESTPOINT_TP-0R75_TP/NI | TP/NI | TP-0R75 |
| U1 | ADUCM3029BCPZ_LFCSP64-9X9X0R5-4 | ADUCM4050BCPZ | LFCSP64-9X9X0R5-4R5X4R5 |
| U4 | ADF7023BCPZ_0_LFCSP32-5X5X0R5-3 | ADF7023BCPZ | LFCSP32-5X5X0R5-3R3X3R3 |
| U5 | TMP117AIDRVR_WSON6-2R0X2R0X0R65 | TMP117AIDRVR | WSON6-2R0X2R0X0R65-1R6X1R0 |
| U29 | SPX3819M5-L-1-2_SOT23-5_SPX3819 | SPX3819M5-L-3-3/TR | SOT23-5 |
| USB1 | TYPE-C_0_TYPE-C-31-M-12_TYPE-C- | TYPE-C-31-M-12 | TYPE-C-31-M-12 |
| X1 | TSX-3225_X-4P-3R2X2R5-SMD_NX322 | NX3225SA-26.000000MHZ-G4 | X-4P-3R2X2R5-SMD |
| X2 | XTAL_5032_0_X-2P-3R2X1R5-SMD_AB | ABS07-32.768KHZ-6-T | X-2P-3R2X1R5-SMD |
| X3 | TSX-3225_X-4P-3R2X2R5-SMD_NX322 | NX3225SA-26.000000MHZ-G4 | X-4P-3R2X2R5-SMD |
