| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BAT1 | JMP-2_0_CR1220_CR2032/NI | CR2032/NI | CR1220 |
| BAT2 | JMP-2_0_ER14250_ER14250 | ER14250 | ER14250 |
| CON1 | SIM_CARD_2_SIM_PUSH_5039600696 | 5039600696 | SIM_PUSH |
| D1 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D2 | LED_4_LED0805_LED_RED | LED_RED | LED0805 |
| D3 | BAT54C_SOT23-3_BAT54C | BAT54C | SOT23-3 |
| D4 | LED_4_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D5 | LED_4_LED0805_LED_GREEN | LED_GREEN | LED0805 |
| D6 | DIODE13_6_TO-227A_V10P10 | V10P10 | TO-227A |
| DC1 | DC005_DC005_DC005 | DC005 | DC005 |
| F1 | FUSE_SMD-1210_SMD1210-200 | SMD1210-200 | SMD-1210 |
| F2 | FUSE_SMD-1210_SMD1210-200 | SMD1210-200 | SMD-1210 |
| F3 | FUSE_FUSE2920_SMD150L | SMD150L | FUSE2920 |
| J1 | CONN RCPT 4_HEADER4X1_2R54_HEAD | HEADER4X1_2R54 | HEADER4X1_2R54 |
| J2 | CONN RCPT 4_HEADER4X1_2R54_HEAD | HEADER4X1_2R54 | HEADER4X1_2R54 |
| J5 | CON_RJ45_1X8_F_RA_0_HR911105A_H | HR911105A | HR911105A |
| J6 | CON_RJ45_1X8_F_RA_0_HR911105A_H | HR911105A | HR911105A |
| J7 | PJ-393_PJ-393_PJ-393 | PJ-393 | PJ-393 |
| J8 | CONN RCPT 2_XHB-2A_XHB-2A | XHB-2A | XHB-2A |
| J9 | PJ-393_PJ-393_PJ-393 | PJ-393 | PJ-393 |
| J10 | FPC50_FFC-50P-0R5-SMD_FH12-50S- | FH12-50S-0R5SV | FFC-50P-0R5-SMD |
| J11 | FPC30_FFC-30P-0R5-SMD_FH12-30S- | FH12-30S-0R5SV | FFC-30P-0R5-SMD |
| J12 | DB9-F_0_DB9-F_DB9-F | DB9-F | DB9-F |
| J13 | CONN RCPT 5X2_HEADER5X2_2R54_HE | HEADER5X2_2R54 | HEADER5X2_2R54 |
| J14 | CONN RECT 10X2_HEADER10X2_2R54_ | HEADER10X2_2R54 | HEADER10X2_2R54 |
| J15 | HDR_1_WJ2EDGRC-5R08-2P_WJ2EDGRC | WJ2EDGRC-5R08-2P | WJ2EDGRC-5R08-2P |
| J16 | CONN RCPT 2_WJ2EDGRC-5R08-2P_WJ | WJ2EDGRC-5R08-2P | WJ2EDGRC-5R08-2P |
| J17 | CONN RCPT 2_WJ2EDGRC-5R08-2P_WJ | WJ2EDGRC-5R08-2P | WJ2EDGRC-5R08-2P |
| L1 | 744822222_0_ACM2012-900-2P_ACM2 | ACM2012-900-2P-T002 | ACM2012-900-2P |
| L2 | IND_BEAD_0805_600OHM_200MA_LC08 | BLM21PG600 | LC0805 |
| L3 | IND_BEAD_0805_600OHM_1_LC0805_B | BLM21PG600 | LC0805 |
| L4 | IND_BEAD_0805_600OHM_1_LC0805_B | BLM21PG600 | LC0805 |
| L5 | IND_BEAD_0805_600OHM_1_LC0805_B | BLM21PG600 | LC0805 |
| L6 | IND_BEAD_0805_600OHM_1_LC0805_B | BLM21PG600 | LC0805 |
| L7 | IND_BEAD_0805_600OHM_1_LC0805_B | BLM21PG600 | LC0805 |
| L8 | IND_BEAD_0805_600OHM_1_LC0805_B | BLM21PG600 | LC0805 |
| L9 | IND_BEAD_0805_600OHM_1_LC0805_B | BLM21PG600 | LC0805 |
| L10 | INDUCTOR_0_TSM0630_TSM0630-3R3M | TSM0630-3R3M | TSM0630 |
| L11 | INDUCTOR_0_TSM0630_TSM0630-3R3M | TSM0630-3R3M | TSM0630 |
| L12 | INDUCTOR_0_TSM0630_TSM0630-3R3M | TSM0630-3R3M | TSM0630 |
| Q1 | MOS-P_0_SOT23-3_2N7002 | 2N7002 | SOT23-3 |
| Q2 | MOS-P_0_SOT23-3_2N7002 | 2N7002 | SOT23-3 |
| Q3 | MOS-P_0_SOT23-3_2N7002 | 2N7002 | SOT23-3 |
| SW1 | SW DIP-4_0_DM-04-V_DM-04-V | DM-04-V | DM-04-V |
| SW2 | SWITCH-SPST-4P_K2-1112SW-A4SW-0 | K2-1112SW-A4SW-04 | K2-1112SW-A4SW-04 |
| SW3 | SWITCH-SPST-4P_K2-1112SW-A4SW-0 | K2-1112SW-A4SW-04 | K2-1112SW-A4SW-04 |
| SW4 | SWITCH-SPST-4P_K2-1112SW-A4SW-0 | K2-1112SW-A4SW-04 | K2-1112SW-A4SW-04 |
| U1 | MYC-Y6ULX_SOM_MYC-Y6ULX_SOM_MYC | MYC-Y6ULX_SOM | MYC-Y6ULX_SOM |
| U2 | TPS2051BDBVR_SOT23-5_TPS2041BDB | TPS2041BDBV | SOT23-5 |
| U3 | TPD4E1U06DBVR_SOT363_TPD4E1U06D | TPD4E1U06DCKR | SOT363 |
| U4 | TFCARD_TFCARD_TFCARD | TFCARD | TFCARD |
| U5 | TSX-3225_X-4P-3R2X2R5-SMD_X3225 | X322512MSB4SI | X-4P-3R2X2R5-SMD |
| U6 | GL850G_TSSOP28_GL850G | GL850G | TSSOP28 |
| U7 | AT24C512_SOIC8_AT24C02C-SSHM-T | AT24C02C-SSHM-T | SOIC8 |
| U8 | MINI_PCI_LATCH_1_MINI_PCIE_SLOT | 679105700(molex Mini PCI-E) | MINI_PCIE_SLOT |
| U9 | SMF05CT1G_SOT363_SMF05C | SMF05C | SOT363 |
| U10 | TPD4E1U06DBVR_SOT363_TPD4E1U06D | TPD4E1U06DCKR | SOT363 |
| U11 | TPD4E1U06DBVR_SOT363_TPD4E1U06D | TPD4E1U06DCKR | SOT363 |
| U12 | LAN8720A_QFN-24_LAN8720A | LAN8720A | QFN-24 |
| U13 | TPD4E1U06DBVR_SOT363_TPD4E1U06D | TPD4E1U06DCKR | SOT363 |
| U14 | TPD4E1U06DBVR_SOT363_TPD4E1U06D | TPD4E1U06DCKR | SOT363 |
| U15 | WM8904_QFN-32-0R4_WM8904CGEFL | WM8904CGEFL | QFN-32-0R4 |
| U16 | RT9013-18GB_SOT23-5_RT9013-18GB | RT9013-18GB | SOT23-5 |
| U17 | ADM202_0_SOIC16_SP3232EEN-L/TR | SP3232EEN-L/TR | SOIC16 |
| U18 | MAX3485ESA_SOIC8_SP3485EN-L/TR | SP3485EN-L/TR | SOIC8 |
| U19 | TJA1050_SOIC8_SN65HVD230DR | SN65HVD230DR | SOIC8 |
| U20 | PESD1CAN_SOT23-3_PESD1CAN | PESD1CAN | SOT23-3 |
| U21 | BL8032CB6TR_SOT23-6_BL8032CB6TR | BL8032CB6TR | SOT23-6 |
| U22 | BL8032CB6TR_SOT23-6_BL8032CB6TR | BL8032CB6TR | SOT23-6 |
| U23 | BL8032CB6TR_SOT23-6_BL8032CB6TR | BL8032CB6TR | SOT23-6 |
| USB1 | USB-MICRO_USB-U-F-M5SS-W-1_USB- | USB-MICRO | USB-U-F-M5SS-W-1 |
| USB2 | USB-A-DOUBLE_USB-A-DOUBLE_USB-A | USB-A-DOUBLE | USB-A-DOUBLE |
