| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D1 | DIODE_8_SMB_DO-214AA_SS54 | SS54 | SMB_DO-214AA |
| D2 | DIODE_9_SMB_DO-214AA_SMBJ18A | SMBJ18A | SMB_DO-214AA |
| ERX1 | TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MM | TP1mm | TP40 |
| ESD1 | 1N6263_D4_5_DFN1006-2L-BI_ESD73031N-2/TR | ESD73031N-2/TR | DFN1006-2L-BI |
| ESD2 | 1N6263_D4_5_DFN1006-2L-BI_ESD73031N-2/TR | ESD73031N-2/TR | DFN1006-2L-BI |
| ETX1 | TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MM | TP1mm | TP40 |
| FB1 | BEAD102_FB0805_120R/4A | 120R/4A | FB0805 |
| FB2 | BEAD102_FB0805_120R/4A | 120R/4A | FB0805 |
| FB3 | BEAD0805_FB6_FB0805_120R/4A | 120R/4A | FB0805 |
| J1 | CON4_HDR-TH_4P-P2_54_HDR-TH_4P-P2_54 | hdr-th_4p-p2_54 | HDR-TH_4P-P2_54 |
| J2 | CON10_2_CONN-TH-10P_AFC11-S10ICC-00_AFC11-S10ICC-00 | AFC11-S10ICC-00 | CONN-TH-10P_AFC11-S10ICC-00 |
| J3 | CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MM | CON2,1.27MM | CONN-SMD-1_25MM-2PLT |
| J4 | CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MM | CON2,1.27MM | CONN-SMD-1_25MM-2PLT |
| J5 | CON14A_3_CONN-TH_PHB2_0-2X7PWZDK_PHB2.0-2X7PWZDK | PHB2.0-2x7PWZDK | CONN-TH_PHB2_0-2X7PWZDK |
| J6 | CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MM | CON2,1.27MM | CONN-SMD-1_25MM-2PLT |
| J7 | CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MM | CON2,1.27MM | CONN-SMD-1_25MM-2PLT |
| J8 | CON2_9_CONN-SMD-1_25MM-2PLT_CON2,1.27MM | CON2,1.27MM | CONN-SMD-1_25MM-2PLT |
| JMP1 | JMP2P_HDR-TH_2P-P2_00-V-M_JMP2P | JMP2P | HDR-TH_2P-P2_00-V-M |
| JMP2 | JMP2P_HDR-TH_2P-P2_00-V-M_JMP2P | JMP2P | HDR-TH_2P-P2_00-V-M |
| L1 | INDUCTOR_L6_7X6_7_3.3UH/5A | 3.3uH/5A | L6_7X6_7 |
| LCS1 | TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MM | TP1mm | TP40 |
| LDC1 | TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MM | TP1mm | TP40 |
| LED1 | LED0603_LED34_LED0603-RD_RED | RED | LED0603-RD |
| LRST1 | TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MM | TP1mm | TP40 |
| LSCLK1 | TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MM | TP1mm | TP40 |
| LSDA1 | TESTPOINT_SMD1MMCIRCLE_0_TP40_TP1MM | TP1mm | TP40 |
| MH1 | M_HOLE_PTHHOLE650CIR320_PTHHOLE650CIR320 | PTHHOLE650CIR320 | PTHHOLE650CIR320 |
| MH2 | M_HOLE_PTHHOLE650CIR320_PTHHOLE650CIR320 | PTHHOLE650CIR320 | PTHHOLE650CIR320 |
| MK1 | M_HOLE_ID-BOARD_MK | mk | ID-BOARD |
| MK2 | M_HOLE_ID-BOARD_MK | mk | ID-BOARD |
| MK3 | M_HOLE_ID-BOARD_MK | mk | ID-BOARD |
| Q1 | P-MOSFET-SOT-23_Q2_1_SOT-23_AO3401 | AO3401 | SOT-23 |
| Q2 | N-MOSFET-SOT-23_Q4_1_SOT-23_2N7002 | 2N7002 | SOT-23 |
| Q3 | P-MOSFET-SOT-23_Q2_1_SOT-23_AO3401 | AO3401 | SOT-23 |
| Q4 | N-MOSFET-SOT-23_Q4_1_SOT-23_2N7002 | 2N7002 | SOT-23 |
| Q5 | MMBT2222A/SOT_0_SOT-23_MMBT3904 | MMBT3904 | SOT-23 |
| Q7 | MMBT2222A/SOT_0_SOT-23_MMBT3904 | MMBT3904 | SOT-23 |
| U1 | ESP8080_11_SMD_32P-L21_2-W18_0_ESP32-C5-WROOM-1_ESP32-C5-WROOM-1 | ESP32-C5-wroom-1 | SMD_32P-L21_2-W18_0_ESP32-C5-WROOM-1 |
| U2 | LM317T-LIE_U7_SOT-223_AMS1117-3.3 | AMS1117-3.3 | SOT-223 |
| U3 | GT30L32S4W_U9_6_SOP-8_EP_SY8205FCC,SO8E | SY8205FCC,SO8E | SOP-8_EP |
| U4 | GT30L32S4W_U9_6_SOP-8_S8002 | S8002 | SOP-8 |
