| Name | Part Type | PCB Decal | Value |
| CON4 | USB2.0_TYPEA_90D | USB-4P-A | USB2.0_TypeA_90D |
| CON5 | SMD_USB_TYPEAB_0 | MICRO-USB-5F-B-SZ | 22MCH-051T-126L1 |
| CON8 | MIPI_3 | FPC40PIN-0.5MMA | MIPI |
| CON9 | HEADER_20X2_3 | FPC_6PIN | FPC_6PINB_Up_Type |
| CON10 | HEADER_1X4-2MM_180D | B2.0V-L4P | RED Wafer/2.0mm/1*4p/180D/Male |
| CON11 | HEADER_1X4-2MM_180D | B2.0V-L4P | RED Wafer/2.0mm/1*4p/180D/Male |
| CONR1 | RJ45_0 | JACK-12P-RJ45 | RJ45_1X1-90D |
| CONR2 | RJ45_0 | JACK-12P-RJ45 | RJ45_1X1-90D |
| D1 | DIODE_SCHOTTKY31_1 | SOD123 | DC52C24 |
| D2 | DIODE_1 | SOD-323HE | B5819WS |
| D3 | DIODE_1 | SOD-323HE | B5819WS |
| D7 | DIODE_1 | DO-214AC | SS24 |
| D11 | DIODE | D0402_0.55X0.6 | NC/DCE0510D2 |
| D12 | DIODE | D0402_0.55X0.6 | NC/DCE0510D2 |
| D13 | DIODE | D0402_0.55X0.6 | NC/DCE0510D2 |
| D14 | DIODE | D0402_0.55X0.6 | NC/DCE0510D2 |
| D15 | DIODE | D0402_0.55X0.6 | NC/DCE0510D2 |
| D16 | DIODE | D0402_0.55X0.6 | NC/DCE0510D2 |
| D19 | DIODE_0 | SOD-523 | NC/AZ5123-01F |
| D20 | DIODE_0 | SOD-523 | NC/AZ5123-01F |
| D23 | DIODE_0 | DFN1006 | DCE0310D2 |
| D24 | DIODE_0 | DFN1006 | DCE0310D2 |
| D25 | DIODE_0 | DFN1006 | DCE0310D2 |
| D26 | DIODE_0 | DFN1006 | DCE0310D2 |
| D32 | DIODE_1 | SOD-323HE | B5819WS |
| D38 | DIODE_0 | DFN1006 | DCE0310D2 |
| D39 | DIODE_0 | DFN1006 | DCE0310D2 |
| D40 | DIODE_0 | DFN1006 | DCE0310D2 |
| D41 | DIODE_0 | DFN1006 | DCE0310D2 |
| D42 | DIODE_ZENER | SOD123 | DC52C3V6 |
| D43 | DIODE_1 | DO-214AC | NC/SS24 |
| D45 | DIODE_ZENER | SOD123 | NC/DC52C3V6 |
| D48 | DIODE_1 | SOD-323HE | B5819WS |
| DEM1 | DIODE_SCHOTTKY31_1 | SOD-123-DIODE | NC/1N5819HW/B130LAW-7-F |
| EC1 | C-DIP_470UF/25V | CE-3.5X8 | 470uF/50V |
| EC2 | C-DIP_470UF/25V | CE-3.5X8 | 47uF/50V |
| ECEM1 | C-DIP_470UF/25V | CE-3.5X8 | NC/220uF |
| F1 | FUSE_24V/_5A | FB-1210 | 0R |
| F2 | FUSE_24V/_5A | FB-1210 | 0R |
| FB1 | L0402_0 | L0402 | FB_60R_300mA |
| FB2 | BEAD | R0402 | 0R |
| IR5 | IR/RX_MSTAR | IR | IR/RX |
| J4 | SMA-3PIN_0 | KK23011-02-7H | NC/IPEX1 |
| J5 | CON36_1 | FPC-36-0.5MM-B | HBS36-05-V |
| J6 | CON36_1 | FPC-36-0.5MM-B | HBS36-05-V |
| J7 | CON6_0 | HCON6-DIP-1.25 | CON6 |
| J8 | AIC1734-XXPU_3 | FPC10-0.5-2 | CON10-0D5 |
| J9 | AIC1734-XXPU_3 | FPC10-0.5-2 | CON10-0D5 |
| JP1 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP2 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP3 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP4 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP5 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP14 | HEADER4X10 | JP-10X4 | HEADER4X10 |
| JP15 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP16 | CON20A | JP-2X10B | BH-20P/Box Header/2.54mm/2*10p/180D/Male |
| JP17 | 3CON100_3 | JP-1X4 | NC/Header/2.54mm/1*4p/180D/Male |
| JP18 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP19 | HEADER_2_0 | JP-1X6 | SAR Header/2.54mm/180D/Male |
| JP103 | 3CON100_3 | JP-1X4 | Header/2.54mm/1*4p/180D/Male |
| JP184 | HEADER_2_0 | JP-1X6 | NC/Header/2.54mm/1*6p/180D/Male |
| JP185 | HEADER_1 | JP10X3 | HEADER10X3 |
| JP187 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| JP188 | HEADER_2_0 | JP-1X6 | NC/Header/2.54mm/1*6p/180D/Female/WOS |
| JPR1 | HEADER_4_0 | JP-1X2 | NC/Header/2.54mm/1*2p/180D/Male |
| JPR2 | HEADER_4_0 | JP-1X2 | NC/Header/2.54mm/1*2p/180D/Male |
| JPSD1 | HEADER_4_0 | JP-1X2 | Header/2.54mm/1*2p/180D/Male |
| L1 | CHOKE_4.7UH/4.1A-L8.0W8.0H4.0 | AMPI0420ED | 1uH/AMPI0420ED1R0MTHB4 |
| L3 | CHOKE_4.7UH/4.1A-L8.0W8.0H4.0 | AMPI0420ED | 1uH/AMPI0420ED1R0MTHB4 |
| L4 | CHOKE_4.7UH/4.1A-L8.0W8.0H4.0 | DFE2016 | 2.2uH/DFE201610E-2R2M |
| L5 | CHOKE_4.7UH/4.1A-L8.0W8.0H4.0 | DFE2016 | 1uH/DFE201610E-1R0M |
| L6 | CHOKE_4.7UH/4.1A-L8.0W8.0H4.0 | DFE2016 | 1uH/DFE201610E-1R0M |
| L8 | CHOKE_4.7UH/4.1A-L8.0W8.0H4.0 | AMPI0630ED | 2.2uH/AMPI0630ED2R2MTHB4 |
| L11 | CHOKE_4.7UH/4.1A-L8.0W8.0H4.0 | DFE3225 | 4.7uH/DFE322512F-4R7M |
| L96 | L/0402 | L0402 | NC/2nH |
| L97 | L/0402 | L0402 | NC/1.2nH |
| LEDSD1 | LED_0 | LED-0603 | LED/GREEN |
| LR1 | INDUCTOR | L0402 | 0R |
| LR2 | INDUCTOR | L0402 | 0R |
| LR3 | INDUCTOR | L0402 | 0R |
| LR4 | INDUCTOR | L0402 | 0R |
| LR5 | INDUCTOR | L0402 | 0R |
| LR6 | INDUCTOR | L0402 | 0R |
| M1 | T_POINT_R | MAK | TP |
| M2 | SD-55091-006-80 | SD-55091-80 | 55091-0874 |
| M3 | T_POINT_R | MAK | TP |
| M4 | T_POINT_R | MAK | TP |
| M5 | T_POINT_R | MAK | TP |
| MIC1 | MIC_0 | DIP1X02PM-80-V | MIC_1 |
| MIC2 | MIC_0 | DIP1X02PM-80-V | MIC_1 |
| MIC3 | MIC_0 | DIP1X02PM-80-V | MIC_1 |
| Q1 | SMD_NMOS_SOT-23DGS_1 | SOT-23 | NC/DC3401 |
| Q2 | MMBT3904_SOT23-3_1 | SOT-23 | NC/MMBT3904 |
| Q6 | IRLML2502_0 | SOT-23DGS | 2N7002 |
| Q8 | SMD_NMOS_SOT-23DGS_1 | SOT-23 | DC3407AH |
| Q9 | SMD_NMOS_SOT-23DGS_1 | SOT-23 | DC3401 |
| Q12 | MMBT3904_SOT23-3_1 | SOT-23 | MMBT3904 |
| Q13 | SMD_NMOS_SOT-23DGS_1 | SOT-23 | DC3401 |
| Q14 | SMD_NMOS_SOT-23DGS_1 | SOT-23 | DC3401 |
| Q22 | IRLML2502_0 | SOT-23DGS | 2N7002 |
| Q23 | IRLML2502_0 | SOT-23DGS | 2N7002 |
| Q24 | IRLML2502_0 | SOT-23DGS | 2N7002 |
| Q25 | IRLML2502_0 | SOT-23DGS | 2N7002 |
| QR1 | IRLML2502_0 | SOT-23DGS | 2N7002 |
| QR2 | IRLML2502_0 | SOT-23DGS | 2N7002 |
| QSD11 | SMD_NMOS_SOT-23DGS_1 | SOT-23 | DC3401 |
| S1 | HOLE-V8_1 | H6D3 | NC/H6D3 |
| S2 | HOLE-V8_1 | H6D3 | NC/H6D3 |
| S3 | HOLE-V8_1 | H6D3 | NC/H6D3 |
| S4 | HOLE-V8_1 | H6D3 | NC/H6D3 |
| S5 | SW_PUSHBUTTON_0 | SW2P | KEY |
| S6 | SW_PUSHBUTTON_0 | SW2P | KEY |
| S7 | SW_0 | SW_6P_2.54MM | SW_6P |
| SD1 | SKTSD-KALER-TF01A-K3 | SK10056619_WGQ | SK10056619 |
| SPK_L1 | HEADER_1X4-2MM_2 | DIP1X02PM-80-V | CON2-DIP-2.0mm |
| SPK_R1 | HEADER_1X4-2MM_2 | DIP1X02PM-80-V | CON2-DIP-2.0mm |
| SW1 | ROCKER_SWITCHES | SW-2P-MRA1KKAT0B | Rocker Switch |
| TR1 | 10/100BASE-TX_LAN_MAGNETIC | IC-16P-10_100BASE | HST-0041SAR |
| TR2 | 10/100BASE-TX_LAN_MAGNETIC | IC-16P-10_100BASE | HST-0041SAR |
| U1 | ETA3417/TMI3411 | SOT23-5P | TMI3411U |
| U3 | ETA3417/TMI3411 | SOT23-5P | TMI3411U |
| U4 | LDO_ID9306-AD_300MA_1 | SOT23-5P | TMI3411U |
| U5 | LDO_ID9306-AD_300MA_1 | SOT23-5P | TMI3411U |
| U6 | LDO_ID9306-AD_300MA_1 | SOT23-5P | TMI3411 |
| U7 | ADP1610_7 | SOT23-5P | TMI6030-33 |
| U8 | ADP1610_7 | SOT23-5P | TMI6050-25 |
| U9 | BL8079AGCB5TR_0 | SOT23-5P | NC/BL8079AGCB5TR |
| U10 | ADP1610_7 | SOT23-5P | NC/TMI6030-33 |
| U11 | ADP1610_7 | SOT23-5P | NC/TMI6030-18 |
| U12 | WIFI_1 | WF-MODULE-6 | WF-MODULE-6 |
| U14 | TMI6263BH | SOT23-5P | TMI6263BH |
| U15 | ADP1610_7 | SOT23-5P | NC/TMI6050-18 |
| U16 | MIC4576_2 | IC-6P-TSOT23 | FP6755S6CTR |
| U39 | P3P_EXTDRAM_BGA14X14_84 | IC385-P065-14X14 | BGA14x14 |
| U41 | ETA8156_0 | SOT23-6 | TMI3255S |
| UA1 | CS8138S/LTK5150 | SOP-8L | CS8138S/LTK5150 |
| UA2 | CS8138S/LTK5150 | SOP-8L | CS8138S/LTK5150 |
| UEM1 | AM29LV160_2 | IC-0.5MM153P-FBGA | BWCTARJ11X32G |
| UF1 | 24C08_0 | SOP8A-150+208 | GD25Q128E/3V3 |
| UF2 | 24C08_3 | SOP8-150+208A9 | GD5F1GM7UEYIG/1Gb-3V3 |
| UM1 | DDR4_DRAM | IC-96P-TFBGA-DDR4-DRAM | DDR4_DRAM/ NT5AD512M16C4-JRI |
| UR1 | IP101A_2 | IC-32P-QFN-4X4-P04 | IP101GR |
| UR2 | IP101A_2 | IC-32P-QFN-4X4-P04 | IP101GR |
| VR1 | DIODE_BI-DIR_TRIG | R0402 | NC/DCE0510D2LC |
| VR2 | RESISTOR_VAR | VR-TC33X-1 | 10K |
| Y1 | OSC-20MHZ_HALF_0 | XTALS-2_5X3_2MM | Crystal/[24MHz,18pF,∮10ppm]; /3.2x2.5mm/YIC-24M18PI/XT324-10/20 |
| Y2 | CRYSTAL-2PIN_0 | XTALS-SMD-3215 | DST310S/32.768KHz |
| YR1 | OSC-20MHZ_HALF_0 | XTALS-2_5X3_2MM | Crystal/[25MHz,18pF,∮10ppm]; /3.2x2.5mm/YIC-25M18PI/XT324-10/20 |
| YR2 | OSC-20MHZ_HALF_0 | XTALS-2_5X3_2MM | Crystal/[25MHz,18pF,∮10ppm]; /3.2x2.5mm/YIC-25M18PI/XT324-10/20 |
