楼主 |
发表于 2014-6-22 12:46
显示全部楼层
:U盘的固件开发源程序,用keil c编程调试-U plate firmware development source program, programming debugs with keil the c
文件列表:
USB通信程序开发
...............\\源代码
...............\\......\\Avr_Usb_Disk.cof
...............\\......\\Avr_Usb_Disk.dbg
...............\\......\\Avr_Usb_Disk.hex
...............\\......\\Avr_Usb_Disk.IAB
...............\\......\\Avr_Usb_Disk.IAD
...............\\......\\Avr_Usb_Disk.IMB
...............\\......\\Avr_Usb_Disk.IMD
...............\\......\\Avr_Usb_Disk.lst
...............\\......\\Avr_Usb_Disk.mak
...............\\......\\Avr_Usb_Disk.mp
...............\\......\\Avr_Usb_Disk.PO
...............\\......\\Avr_Usb_Disk.PR
...............\\......\\Avr_Usb_Disk.PRI
...............\\......\\Avr_Usb_Disk.prj
...............\\......\\Avr_Usb_Disk.PS
...............\\......\\Avr_Usb_Disk.WK3
...............\\......\\D12.h
...............\\......\\D12.h.bak
...............\\......\\D12ISR.c
...............\\......\\D12ISR.c.bak
...............\\......\\D12ISR.lis
...............\\......\\D12ISR.o
...............\\......\\D12ISR.s
...............\\......\\D12ISR._c
...............\\......\\D12Setup.c
...............\\......\\D12Setup.c.bak
...............\\......\\D12Setup.h
...............\\......\\D12Setup.h.bak
...............\\......\\D12Setup.lis
...............\\......\\D12Setup.o
...............\\......\\D12Setup.s
...............\\......\\io8515v.h
...............\\......\\MainLoop.c
...............\\......\\MainLoop.c.bak
...............\\......\\MainLoop.lis
...............\\......\\MainLoop.o
...............\\......\\MainLoop.s
...............\\......\\NFlash32.c
...............\\......\\NFlash32.c.bak
...............\\......\\NFlash32.h
...............\\......\\NFlash32.h.bak
...............\\......\\NFlash32.lis
...............\\......\\NFlash32.o
...............\\......\\NFlash32.s
...............\\......\\NFlash32._c
...............\\......\\Scsi.c
...............\\......\\Scsi.c.bak
...............\\......\\Scsi.h
...............\\......\\Scsi.h.bak
...............\\......\\Scsi.lis
...............\\......\\Scsi.o
...............\\......\\Scsi.s
...............\\......\\Scsi._c
...............\\......\\Scsi_Data.h
...............\\......\\Scsi_Data.h.bak |
