重要提示:PCB作品文件展下载说明
发出来给大家看看的。
有能JMF602-DB-02-001-2.pcb
1.68 MB, 下载次数: 9, 下载积分:金币 -5 枚
JMF602_SSD.rar
691 KB, 下载次数: 6, 下载积分:金币 -5 枚
JMF602-DB-PCB.rar
196 KB, 下载次数: 6, 下载积分:金币 -5 枚
JMF603.pdf
73 KB, 下载次数: 6, 下载积分:金币 -5 枚
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下元件和封装库,如有需要可以下载提取使用。
| Name | PCB Decal | Value | Part Type | | C1 | C0603 | 22pF/0603 | CAP_NP_2 | | C15 | C0402 | 10nF/0402 | CAP_NP_3 | | C16 | C0402 | 10nF/0402 | CAP_NP_3 | | C17 | C0402 | 10nF/0402 | CAP_NP_3 | | C18 | C0402 | 10nF/0402 | CAP_NP_3 | | C29 | C0402 | 15pF/0402 | CAP_NP_2 | | C30 | C0402 | 15pF/0402 | CAP_NP_2 | | C32 | C0603 | 1uF/0603 | CAP_NP_4 | | C61 | C0805 | 10uF/0805 | CAP_NP_2 | | C62 | C0402 | 0.1uF//0402 | CAP_NP_2 | | C63 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C64 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C65 | C0805 | 10uF/0805 | CAP_NP_2 | | C66 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C67 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C68 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C69 | C0805 | 10uF/0805 | CAP_NP_2 | | C70 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C71 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C72 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C73 | C0805 | 10uF/0805 | CAP_NP_2 | | C74 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C75 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C76 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C77 | C0805 | 10uF/0805 | CAP_NP_2 | | C78 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C79 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C80 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C81 | C0805 | 10uF/0805 | CAP_NP_2 | | C82 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C83 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C84 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C85 | C0805 | 10uF/0805 | CAP_NP_2 | | C86 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C87 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C88 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C89 | C0805 | 10uF/0805 | CAP_NP_2 | | C90 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C91 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C92 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C93 | C0402 | 15pF/0402 | CAP_NP | | C94 | C0402 | 0.1uF/0402 | CAP_NP | | C95 | C0805 | 10uF/0805 | CAP_NP_2 | | C96 | C0402 | 15pF/0402 | CAP_NP | | C97 | C0402 | 0.1uF/0402 | CAP_NP | | C98 | C0805 | 10uF/0805 | CAP_NP_2 | | C99 | C1206 | 47uF/0805 | CAP_NP | | C100 | C1206 | 47uF/0805 | CAP_NP | | C101 | C0805 | 10uF/0805 | CAP_NP_2 | | C102 | C0805 | 10uF/0805 | CAP_NP_2 | | C103 | C0805 | 10uF/0805 | CAP_NP_2 | | C104 | C0805 | 10uF/0805 | CAP_NP_2 | | C105 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C106 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C107 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C108 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C109 | C0805 | 10uF/0805 | CAP_NP_2 | | C110 | C0805 | 10uF/0805 | CAP_NP_2 | | C111 | C0805 | 10uF/0805 | CAP_NP_2 | | C112 | C0805 | 10uF/0805 | CAP_NP_2 | | C113 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C114 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C115 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C116 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C117 | C0805 | 10uF/0805 | CAP_NP_2 | | C118 | C0805 | 10uF/0805 | CAP_NP_2 | | C119 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C120 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C121 | C0402 | 10uF/0402 | CAP_NP_2 | | C122 | C0805 | 10uF/0805 | CAP_NP_2 | | C123 | C0402 | 0.1uF/0402 | CAP_NP_2 | | C124 | C0402 | 0.1uF/0402 | CAP_NP_2 | | CON1 | SATA22P-SMD-M | SATA-Male_22P | SATA_MALE_5 | | CON2 | CN_USB_MAB | MiniB | HEADER_4_1 | | F1 | PS\S3\4532 | 1A | FUSE_0.5A_SMD | | FB1 | L0805 | 1uH/0Ohm/L0805 | INDUCTOR | | FB2 | L0805 | 1uH/0Ohm/L0805 | INDUCTOR | | JP2 | SIP-4P | DIP_PAD | SIP_4 | | JP3 | RSETX3 | JP-3-200 | JUMPER_3_200 | | JP4 | RSETX3 | JP-3-200 | JUMPER_3_200 | | L1 | CHOKE-315 | 5.6uH/GSSQ-315PLD5R6N | INDUCTOR | | L2 | CHOKE-315 | 5.6uH/GSSQ-315PLD5R6N | INDUCTOR | | LED | LED-A3 | 3PIN LED | LED_8 | | P1 | TP-0603 | JP-2/0603 | JUMPER_2 | | P2 | TP-0603 | JP-2/0603 | JUMPER_2 | | PR3 | RP4 | 1K | RES_8P4R_RHN | | PR4 | RP4 | 1K | RES_8P4R_RHN | | R1 | R0603 | 12K/1%/0603 | R_2 | | R2 | R0603 | 51K/0402 | R | | R3 | R0603 | 110K/0402 | R | | R4 | R0603 | 0/0402 | R | | R5 | R0603 | 0/0402 | R | | R6 | R0402 | 4.7K/0402 | R | | R7 | R0402 | 1M/0402 | R_2 | | R8 | R0603 | 100K/0603 | R_3 | | R9 | R0402 | 4.7K/0402 | R | | R20 | R0402 | 4.7K/0402 | R | | R21 | R0402 | 4.7K/0402 | R | | R22 | R0402 | 4.7K/0402 | R | | R23 | R0402 | 4.7K/0402 | R | | R24 | R0402 | 4.7K/0402 | R | | R25 | R0402 | 4.7K/0402 | R | | R26 | R0402 | 4.7K/0402 | R | | R27 | R0402 | 4.7K/0402 | R | | R28 | R0402 | 4.7K/0402 | R | | R29 | R0402 | 4.7K/0402 | R | | R30 | R0402 | 4.7K/0402 | R | | R31 | R0402 | 4.7K/0402 | R | | R32 | R0402 | 4.7K/0402 | R | | R33 | R0402 | 4.7K/0402 | R | | R34 | R0402 | 4.7K/0402 | R | | R35 | R0402 | 4.7K/0402 | R | | R36 | R0603 | 1K/0603 | R_2 | | R38 | R0603 | 330/0603 | R_2 | | R39 | R0402 | 110K/0402 | R_2 | | R40 | R0402 | 510K/0402 | R_2 | | R41 | R0402 | 100K/0402 | R_2 | | R42 | R0402 | 200K/0402 | R_2 | | TP1 | SIP-1P | Testpin | TESTPIN | | U4 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U5 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U6 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U7 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U8 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U9 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U10 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U11 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U12 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U13 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U14 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U15 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U16 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U17 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U18 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U19 | TSOP48-12X20-SK | NAND Flash | NAND_FLASH_0 | | U20 | WDFN-6L-2X2 | RT8010PQW/WDFN 6L 2x2 | MIC293XX_6 | | U21 | WDFN-6L-2X2 | RT8010PQW/WDFN 6L 2x2 | MIC293XX_6 | | U22 | TFBGA211-12X12 | JMF602/TFBGA/211 balls | JMF602_25 | | Y1 | OSC-3X2 | 30MHz/NXK-32/3.2x2.5x1.5 | CRYSTAL_0 |
评分
查看全部评分
重要提示:PCB作品文件展下载说明
