GV7601 Aviia™ Receiver Data Sheet
www.gennum.com
Key Features
• Serial digital video receiver for standard and high
definition component video:
• SD 525i and 625i
• HD 720p 24, 25, 30, 50 and 60
• HD 1080i 50, 60
• HD 1080p 24, 25, 30, 50 and 60
• Supports 8-bit, 10-bit or 12-bit component digital
video:
• RGB or YCbCr 4:4:4 sampled
• YCbCr 4:2:2 or 4:2:0 sampled
• Integrated cable equalizer for long reach cable
performance
• 200m typical HD performance over high quality 75Ω
coaxial cable
• Serial digital loop-though output
• Integrated audio de-embedder for the extraction of up
to 8 channels of 48kHz digital audio
• Supports IEC 13818-1 compliant transport streams
over the Asynchronous Serial Interface (ASI)
• Automatic selection between SD/HD component video
and ASI input data
• Ancillary (ANC) data detection and extraction
• User selectable processing features, including:
• Timing Reference Signal (TRS) error detection and
correction
• ANC data checksum error detection and correction
• Programmable ANC data detection
• Line number and CRC error detection and correction
• Illegal video code word re-mapping
• 4-wire Gennum Serial Peripheral Interface (GSPI) for
external host command and control
• JTAG test interface
• 1.2V core and 3.3V analog voltage power supplies
• 1.8V or 3.3V selectabledigital I/O power supply
• Small footprint 100-BGA (11mm x 11mm)
• Low power operation, typically 550mW
• Pb-free and RoHS compliant
Applications
• Digital video recorders (DVR)
•Video servers
•Video mixers and switchers
• Image capture devices
• Video framegrabbers
•Camcorders
• Video monitors & displays
Description
The GV7601 is a serial digital video receiver for standard
and high definition component video, operating at
270Mb/s, 1.485Gb/s and 2.97Gb/s data rates. With
integrated cable equalizer technology, the GV7601 is
capable of receiving digital video over 75Ωcoaxial cable at
lengths up to 300m for standard definition video, and up to
140m for high definition. This provides a complete receive
solution for the transmission of both interlaced and
progressive component digital video, up to 1920 x 1080, in
coaxial cable-based video systems.
Using the GV7601 with the complete Aviia™ receiver
reference design, it is possible to implement an all-digital,
bi-directional multimedia interface over coax. This
interface allows both DC power and a bi-directional,
half-duplex, auxiliary data interface to be carried over the
same single, robust and cost effective coaxial cable as the
high-speed serial digital video. The GV7601 also provides a
re-timed serial digital output for video loop-through
applications.
The GV7601 includes a broad range of user-selectable
processing features, such as Timing Reference Signal (TRS)
error detection and extraction, illegal code word
re-mapping, and ancillary data packet extraction. The
content of ancillary data packets, embedded by an Aviia
transmitter, can be extracted and retrieved via the host
interface. Device configuration and status reporting is
accomplished via the Gennum Serial Peripheral Interface
GV7601.pdf
5.08 MB, 下载次数: 8, 下载积分:金币 -1 枚
评分
查看全部评分
