| Name | PCB Decal | Value | Part Type |
| ANT5001 | ANT/2P/SMD/PVT1024 | SPR / PVT1024 | SPR_/_PVT1024 |
| ANT5002 | ANT/2P/SMD/PVT1024 | SPR / PVT1024 | SPR_/_PVT1024 |
| ANT5003 | ANT/2P/SMD/PVT1024 | SPR / PVT1024 | SPR_/_PVT1024 |
| ANT5101 | ANT/1P/SMD/CSS5301-6301F | SPR / CSS5304-6213E | ANTENNA |
| BEAD5001 | BEAD0402 | FB / BLM15AG601SN1 | FB_/_BLM15AG121SN1 |
| CON2101 | BAT/6P/SMD/P1.2/CPL6506-0130ESZ/SMK | CON / BAT-6PIN / CPL6506-0130ESZ | CON-BAT_6PIN_CPL6506-0130E-NEW |
| CON3301 | MM8130-2602 | Car_Kit / MM8130-2600 | CAR_KIT_/_MM8130-2600 |
| CON3303 | COAXIAL/SMD/TA-RF02-001-03-811 | CON / 4 / TA-RF02-001-03-811 | CON_/_4_/_TP-RF005-001-03-815_1 |
| CON3401 | MM8130-2602 | Car_Kit / MM8130-2600 | CAR_KIT_/_MM8130-2600 |
| CON3404 | COAXIAL/SMD/TA-RF02-001-03-811 | CON / 4 / TA-RF02-001-03-811 | CON_/_4_/_TP-RF005-001-03-815_1 |
| CON4001 | MICROSD/8P/SMD/TA-M015-012-04-811 | CON / 11 / TA-M015-012-04-811 | MS110-C10B-C13-A_2 |
| CON5001 | MM8430-2600B | Car_Kit / MM8430-2610 | TST_PORT_0 |
| CON6001 | AUDIOJACK/5P/DIP/EJ-36952-10-GP | CON / 5 / EJ-36952-10-GP | CON/AUDIO-JACK/EJ-36952-GP |
| CON6002 | CON8X2/SMD/F/P0.4/24-5804-016-000-829 | CON / 16 / 24-5804-016-000-829+ | CON/16/24-5804-016-000-829+ |
| CON6101 | CON32X2/SMD/P0.4/F/AXE564124/WS2307 | CON / 64 / AXE564124 | CON/CTP/AXE564124 |
| CON6102 | CON17X2/SMD/F/P0.4/24-5804-034-000-829 | CON / 34 / 24-5804-034-000-829+ | CON/DSI-4L/24-5804-034-000-829+ |
| CON6201 | CAMERA_MODULE/30P/SMD/CM9156-B1300BA-E | CON / 30 / 24-5804-030-000-829+ | CON/CSI-4L/24-5804-030-000-829+ |
| CON6202 | CAMERA_MODULE/30P/SMD/Q5V22K-0JG | CON / 30 / AXT530124 | CON/CAMERA_MODULE/30P/SMD/Q5V22 |
| CON6301 | H6/SMD/P0.5/FH34S-06S-0.5SH | CON / 6 / FH34SRJ-6S-0.5SH | CON/ZIP-6P/FH34SRJ-6S-0.5SH |
| CON6401 | MICROUSB/5P/SMD/P0.65/R/KIU90511S1R | CON / 5 / KEIRAKU KIU90511S1R | MINI_10PIN_3 |
| CON6501 | SIM/10P/SMD/SCGD1B0307 | CON / 10 / SCGD1B0307 | CON/SIM/SCGD1B0206 |
| CON6502 | SIM/10P/SMD/SCGD1B0307 | CON / 10 / SCGD1B0307 | CON/SIM/SCGD1B0206 |
| CON6503 | CON5X2/SMD/P0.4/F/AXE510127 | CON / 10 / AXE510127 | CON_/_10_/_AXE510127_AXE610124 |
| CON6601 | H2/SMD/P0.8/SM02B-SURS-TF/SUR | CON / 2 / SM02B-SURS-TF | CON/SUR-2P/SM02B-SURS-TF |
| CON9001 | CON20X2/SMD/M/AXT640124/FPC_ | CON / 40 / AXT640124 | CON/DEBUG/20X2/AXT640124 |
| D2102 | DIODE/SMD/CO-LAY/0603/AK | D / RB521CS-30 | DIODE_SCHOTTKY_0 |
| D2103 | DIODE/SMD/MMSZ5221B | D / MMSZ5231BT1G | D_/_MMSZ5231BT1G |
| D2301 | RB160M-30-EVB | D / RB160M-60 | DIODE_DIP_SCHOTTKY |
| F5001 | FILTER/SMD/LFD211G57ME3 | TRPX / TDK TPX205950MT-7110A1 | BL1608-05K2450_0 |
| FD9101 | FD | TP / 40 / mil | TP_R_1MM |
| FD9102 | FD | TP / 40 / mil | TP_R_1MM |
| FD9103 | FD | TP / 40 / mil | TP_R_1MM |
| FD9104 | FD | TP / 40 / mil | TP_R_1MM |
| L2106 | L/IND/SMD/2520 | PL / 2.2 / uH / 2520 | L_/_MDMK2020T1R0MM_/_SMD2520 |
| L2107 | L/IND/SMD/VLS201610E | PL / 2.2 / uH / 2016 | L_/_MDMK2020T1R0MM_/_SMD2520 |
| L2308 | L/IND/SMD/DFE252012F/TOKO | PL / PIFE32251B | L_/_MDMK2020T1R0MM_/_SMD2520 |
| L5101 | L/IND/SMD/0603 | L / MLF1608DR56J | FERRITE_BEAD_SMD_0402 |
| L5102 | L/IND/SMD/0603 | L / MLF1608DR56J | FERRITE_BEAD_SMD_0402 |
| L6001 | L0402 | R / 0 / ohm / 0402 | L_/_100_/_NH_/_0402 |
| L6002 | BEAD0603 | L / LQM18NN82NM00 | BEAD |
| LED2302 | FLASH_LED/LUW_F8DN | LED / LUW FQEL | LED_4 |
| MIC6002 | FILTER/SMD/SPU0410HR5H-PB | MIC / SPU0410HR5H-PB | MIC_/_SPM0410HR5H-PB_0 |
| NTC6301 | R0402 | NTC / NTCG104EF104F / 0402 | NTC_/_NCP15WF104F03RC_/_0402_ |
| NTC6302 | R0402 | NTC / NTCG104EF104F / 0402 | NTC_/_NCP15WF104F03RC_/_0402_ |
| PL2103 | L/IND/SMD/2520 | PL / PMSB25201T-R47MS | L_/_MDMK2020TR68MM_/_SMD2520 |
| PL2303 | L/IND/SMD/VLS201610E | PL / PMSB20161T-4R7MS | L_/_MDMK2020TR68MM_/_SMD2520 |
| PL2305 | L/IND/SMD/2520 | PL / VLS252010HBX-1R0M | L_/_MDMK2020TR68MM_/_SMD2520 |
| REC6001 | RECEIVE/SMD/NXP | REC / 2403 260 00031 / NC | REC_/_2403_260_00031_ |
| SC9184 | SHIELD_CAN_CLIP/PTV0703B | SC / PTV0703B | CON10_0 |
| SC9185 | CABLE_CLIP/3P/SMD/PCV1003 | SC / PCV1003 | CON/CABLE_CLIP/PCV1003 |
| SC9186 | CABLE_CLIP/3P/SMD/PCV1003 | SC / PCV1003 | CON/CABLE_CLIP/PCV1003 |
| SC9187 | SHIELD_CAN_CLIP/3P/SMD/PTV3121N | SC / PTV3121N | CON/CABLE_CLIP/PCV1003 |
| SH5100 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH5101 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH5102 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5103 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH5104 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH5105 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5106 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5107 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5108 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH5109 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH5110 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH5111 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5112 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5113 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5114 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5115 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5116 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH5117 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH6000 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH6003 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH6200 | NC/MMD/L8/4MIL | SHORT / NC-MMD-L9-4MIL | NO_PAD_0402_SMD_1 |
| SH6500 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| SH6501 | R0402/WS2458 | SHORT / 0402 / NC | R_/_SHORT_/_OHM_/_0402 |
| TP2311 | TP/SMD/12MIL | TP / 30 / mil | TP_/_30MIL_1 |
| TP5101 | TP/SMD/12MIL | TP / 30 / mil | T_POINT_F |
| TP5102 | TP/SMD/12MIL | TP / 30 / mil | T_POINT_F |
| TP6401 | TP/SMD/12MIL | TP / 30 / mil | TP_/_30MIL_1 |
| U1001 | MT6752/VFBGA677/P0.4/B0.25/12.6X12.6 | U / IC-MT6732-E1-SBS | IC-MT659X-E1-SBS_0 |
| U2001 | MT6325/VFBGA244/P0.4/B0.25/7.8X7.4 | U / MT6325-E1 / MT6325/TEMP | IC/MT6331-E1/XXXMM_32 |
| U2102 | CSP16/SMD/P0.4/B0.25/TPS6128X/S | U / TPS61280A | IC/BUCK/TPS6128 |
| U2301 | WLCSP9/SMD/P0.4/B0.25/RT4505 | U / RT4505 | RT4505 |
| U2302 | QFN24/SMD/P0.5/BQ24261 | U / BQ24261 | BQ24261_0 |
| U2305 | DSBGA9/SMD/P0.4/B0.25/TPS61163 | U / TPS61163YFF | IC/LCM_BL/TPS61163 |
| U3101 | MT7206/VFBGA175/P0.4/B0.25/6.2X5.4 | U / MT6169 | 60118A_22 |
| U3102 | TCXO/SMD/2.5X2.0/KT2520F | KT2520F26000DCW28QAK | KT2520F26000DCW28QAK |
| U3209 | SKY77778 | PA / SKY77778 | SKY77701_2 |
| U3210 | BALUN/SMD/HHM22112A2 | LPF / LF1608-B2R5KCB | LF1608-B2R5KCB |
| U3212 | WLCSP15/SMD/P0.4/B0.25/SKY13477 | 3P4T / SKY13477 | SKY13415_0 |
| U3215 | ACPF-7041/SMD | FBAR / ACPF-7041 | SAW_2 |
| U3216 | FILTER/SMD/885049 | SAW / 885049 | SAW_3 |
| U3302 | SKY13489 | SPDT / SKY13489 | XM0860SH-DL0601_0 |
| U3303 | BALUN/SMD/HHM22112A2 | CPL / LDJ18829M24AE003 | RF3145_0 |
| U3304 | SAW/SMD/SAWEN881MCY0F00R14 | SAW / SAWEN1G84CV0F00 | SAW_/_EN881MCY0F00R14_0 |
| U3305 | SAWFILTER/SMD/SAWFD1G90BH0F0A | DIPX / SAWFD1G90BK0F0A | SAWFD1G90BH0F0A_0 |
| U3306 | SAW/SMD/SAWEN881MCY0F00R14 | SAW / SAWEN881MCY0F00R14 | SAW_/_EN881MCY0F00R14_0_2 |
| U3307 | SKY77590 | PA / SKY77592 | PA_/_SKY77590_0 |
| U3324 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TDK-TFSZ06052460-3310A2 | TDK-BALUN_0 |
| U3329 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TDK-TFSZ06052460-3310A2 | TDK-BALUN_0 |
| U3404 | FILTER/SMD/885049 | SAW / 885049 | SAW_3 |
| U3407 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAW / SAFFB1G90FB0F0A | SAW_0 |
| U3413 | ACPF-7041/SMD | FBAR / ACPF-7041 | SAW_2 |
| U3414 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TDK-TFSZ06052460-3310A2 | TDK-BALUN_0 |
| U3415 | BALUN/SMD/TFSZ06052460-3310A2 | BAL / TDK-TFSZ06052460-3310A2 | TDK-BALUN_0 |
| U3421 | SKY13373 | SP3T / SKY13373 | SPDT_/_SKYWORKS_/_SKY13373 |
| U4102 | FBGA221/P0.5/B0.27/11.5X13/SAMSUNG | H9TQ17ABJTMCUR-KUM / FBGA221 | LP_DDR2(JEDEC_162B)_0 |
| U5001 | MT6625/SQFN40/SMD/P0.4/5X5 | U / MT6625L / QFN40 | MT6611_SMD_WLCSP-61_0 |
| U5002 | TCXO/SMD/2.5X2.0/IT2205BE | TCXO / 26 / MHz / IT2205AE | TCXO_RAKON_SMD_4P |
| U5003 | SAW/SMD/1.05X1.35 | U / EPOCOS_B8313 | SAFEB1G57KA0F00 |
| U5004 | TSLP6/SMD/P0.4/BGA725L6/S | U / BGA725L6 | NJG1107HB3_0 |
| U5005 | FILTER/SMD/ACPF-7124 | FBAR / ACPF-7124 | SAFEB1G57KA0F00 |
| U5101 | MT6605/MQFN32/SMD/P0.4/4X4/S | U / MT6605E3 | MT3301-140_SMD_PBGA-140_0 |
| U6101 | QFN68/SMD/P0.4/GT917S | U / GT917S | IC/CTP/GT917S/QFN68 |
| U6301 | WLCSP14/SMD/P0.4/B0.23/AK8963 | U / AK8963C | IC/MANG/AK8963C |
| U6302 | QFN24/SMD/P0.4/MPU-6515 | U / MPU-6515A | IC/ACC+GYRO/MPU-6050C_1 |
| U6303 | SENSOR/7P/SMD/BMP180-DS000 | U / BMP180 | IC/BARO/BMP180 |
| X2001 | CRYS/SMD/3.2X1.5/9H032000XX/TXC | X / 32 / KHz / CM7V-T1A | CRYSTAL_2 |
| X5101 | CRYS/SMD/FA-128 | X / 27.12 / MHz / FA-128 | QUARTZ_IQX0_1 |
