重要提示:PCB作品文件展下载说明
凌阳方案原理图与PCB,
SPCA1628.rar
259 KB, 下载次数: 4, 下载积分:金币 -5 枚
SG330V10M.rar
487 KB, 下载次数: 4, 下载积分:金币 -5 枚
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
| Name | Part Type | PCB Decal | Value | | B2 | INDUCTOR_4 | BEED-0603 | FCM1608K-601T03 | | CON1 | OV3630REV4_0 | CON20-PIN-WM | CON20-PIN-WM | | CON5 | OV3630REV4_0 | CON30-PIN-WM | CON20P | | CON8 | HEADER_4_0 | 2PIN2.0MM | CON2P | | CON9 | OV3630REV4_1 | CON30-PIN-WM | CON8P | | D2 | B0805_4 | D-0603 | 0603ESDA-04 | | D3 | DIODE_11 | D-1206 | 1N4148 | | D15 | DIODE_34/DD_0_3 | D-5819 | SS14 | | D16 | BAT54C/SOT_1 | SOT-23 | BAT54C/SOT | | D19 | RB501V-40 | D-5819 | B340A | | D21 | DIODE_12 | 1N5822 | 1N5822 | | J1 | MMC4_0.0 | SD-SOCKET | SD_CARD | | J2 | CON3 | PIR | PIR | | J3 | DCJACK_1 | DCJACK | DCJACK | | J4 | LGK1709_0 | PJ-327A-D3.5 | PJK-633M | | J5 | CON5_1 | USB-5PIN | UC1112C | | J6 | PAD2-0_02_SMD | PAD2-0_02_SMD | 2pin | | JP1 | HEADER_20_0 | LCM-36PIN | LCM36 | | JP2 | HEADER_20_1_2 | LCM-40PIN | LCM40P | | L13 | R_1 | ACM2012-2P | ACM2012-900-2P | | Q3 | MOSFET_P_SGD_2 | SOT23 | APM2300 | | Q11 | P_DSG_0 | SOT23 | APM2301 | | Q12 | NPN_BEC | SOT23 | MMBT3904 | | U1 | SPCA1628_0 | QFP176-0.4 | SPCA1628-LQFP176 | | U2 | RT9161_1 | SOT-23 | BL8509-293DNRM | | U3 | SDRAM_0 | TSOP-54 | 128Mb | | U4 | SST25VF020_5 | SOP8 | EN25F16 | | U5 | MI5100_0 | LCC48-MI5100 | MI5100 | | U6 | RT9167-NNCB_1_2 | SOT-25 | IT6213A28M | | U7 | RT9167-NNCB_9 | SOT-23 | IT6206AT18 | | U8 | RT9167-NNCB_9 | SOT-23 | NC | | U9 | RT9167-NNCB_8 | BISS0001 | BISS0001 | | U10 | MC34063A_3 | DIP8-SOP | PT1102 | | U11 | RT9167-NNCB_5_2 | SOT-25 | ITC2106B-ADJ(SOT25) | | U14 | RT9167-NNCB_9 | SOT-23 | HT7533-3(SOT-89) | | U16 | IC_STEPDOWN_LM1 | TD1501-ADJ | TD1501-ADJ | | U17 | IC_MOTOR_HG7881 | SOP8 | HG7881 | | U18 | PIC12F675ISN_0 | SOP-20 | MCU | | Y1 | CRYSTAL32.768KHZ | XTAL-2X6 | 27M | | Y3 | CRYSTAL32.768KHZ | XTAL-2X6 | 32768HZ |
评分
查看全部评分
重要提示:PCB作品文件展下载说明
