| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT1 | ANT_IIFA_CC2420_32MIL_MIR_ANT_I | N/A | ANT_IIFA_CC2420_32MIL_MIR |
| C1 | CAP_NP_0603_10UF | 10uF | 603 |
| C2 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C5 | CAP_NP_0603_10UF | 10uF | 603 |
| C6 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C7 | CAP_NP_0402_1.0UF_0402_SMALL | 1.0uF | 402 |
| C8 | CAP_NP_0402_0.01UF_0402_SMALL | 0.01uF | 402 |
| C9 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C10 | CAP_NP_0603_10UF | 10uF | 603 |
| C11 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C12 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C13 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C14 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C15 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C16 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C17 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C18 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C19 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C20 | CAP_NP_0402_1.0UF_0402_SMALL | 1.0uF | 402 |
| C21 | CAP_NP_0402_1.0UF_0402_SMALL | 1.0uF | 402 |
| C22 | CAP_NP_0402_10PF_0402_SMALL | 10pF | 402 |
| C23 | CAP_NP_0402_10PF_0402_SMALL | 10pF | 402 |
| C24 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C25 | CAP_NP_0402_0.47UF_0402_SMALL | 0.47uF | 402 |
| C26 | CAP_NP_0402_0.47UF_0402_SMALL | 0.47uF | 402 |
| C27 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C28 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C29 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C30 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C31 | CAP_NP_0201_22PF_0201_SMALL | 22pF | 201 |
| C32 | CAP_NP_0402_1.0UF_0402_SMALL | 1.0uF | 402 |
| C33 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C34 | CAP_NP_0603_10UF | 10uF | 603 |
| C35 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| C36 | CAP_NP_0402_0.1UF_0402_SMALL | 0.1uF | 402 |
| D1 | LED_2P_LED_0603_GRN | GRN | LED_0603 |
| FB1 | FERRITE_BEAD_FB_0402_BK1005HS68 | BK1005HS680-T | FB_0402 |
| FB2 | FERRITE_BEAD_FB_0402_BK1005HS68 | BK1005HS680-T | FB_0402 |
| FB3 | FERRITE_BEAD_FB_0402_BK1005HS68 | BK1005HS680-T | FB_0402 |
| FL1 | FILTER_4PIN_GND_FIL_4_85X53X41_ | 2.45GHz | FIL_4_85X53X41 |
| J1 | HEADER_1X2_HDR_THVT_1X2_100_M_1 | 1x2 THVT | HDR_THVT_1X2_100_M |
| J2 | HEADER_1X2_HDR_THVT_1X2_100_M_1 | 1x2 THVT | HDR_THVT_1X2_100_M |
| LB1 | LABEL_BOARD_LABEL_THT-14_LINE1 | Line 1 Line 2 | LABEL_THT-14 |
| OSC1 | OSC_4_SM_3-OUT_OSC_4_SM_134X67X | 32.768KHz 15pF | OSC_4_SM_134X67X40 |
| P1 | CON_EDGE_2X50_25_MEC6_CON_EDGE_ | EDGE CARD | CON_EDGE_50_P635MM |
| P2 | HEADER_2X9_100_430L_HDR_THVT_2X | 2x9 | HDR_THVT_2X9_100_M |
| P3 | CON_COAXIAL_UFL-R-SMT_CON_COAXI | COAXIAL | CON_COAXIAL_UFL-R-SMT |
| R1 | RESISTOR_0402_0 | 0 | 402 |
| R2 | RESISTOR_0402_0 | 0 | 402 |
| R3 | RESISTOR_0402_0 | 0 | 402 |
| R4 | RESISTOR_0402_680_0402_SMALL | 680 | 402 |
| R5 | RESISTOR_0402_0 | 0 | 402 |
| R6 | RESISTOR_0402_0 | 0 | 402 |
| R7 | RESISTOR_0805_0.10 | 0.1 | 805 |
| R8 | RESISTOR_0402_0 | 0 | 402 |
| R9 | RESISTOR_0402_0 | 0 | 402 |
| R10 | RESISTOR_0805_0.10 | 0.1 | 805 |
| R11 | RESISTOR_0402_0 | 0 | 402 |
| R12 | RESISTOR_0402_10K_0402_SMALL | 10K | 402 |
| R13 | RESISTOR_0402_0 | 0 | 402 |
| R14 | RESISTOR_0402_0 | 0 | 402 |
| R15 | RESISTOR_0402_10K_0402_SMALL | 10K | 402 |
| R18 | RESISTOR_0402_0_0402_SMALL | 0 | 402 |
| R19 | RESISTOR_0402_10K_0402_SMALL | 10K | 402 |
| R20 | RESISTOR_0402_10K_0402_SMALL | 10K | 402 |
| R21 | RESISTOR_0402_0 | 0 | 402 |
| R22 | RESISTOR_0402_0 | 0 | 402 |
| R23 | RESISTOR_0402_0 | 0 | 402 |
| R24 | RESISTOR_0402_0 | 0 | 402 |
| R25 | RESISTOR_0402_0_0402_SMALL | 0 | 402 |
| R26 | RESISTOR_0402_0_0402_SMALL | 0 | 402 |
| R27 | RESISTOR_0402_10K_0402_SMALL | 10K | 402 |
| R28 | RESISTOR_0402_100K_0402_SMALL | 100K | 402 |
| R29 | RESISTOR_0402_0_0402_SMALL | 0 | 402 |
| R30 | RESISTOR_0402_0_0402_SMALL | 0 | 402 |
| R34 | RESISTOR_0402_10.0K_0402_SMALL | 10.0K | 402 |
| R35 | RESISTOR_0402_0 | 0 | 402 |
| R36 | RESISTOR_0402_0_0402_SMALL | 0 | 402 |
| RF1 | CON_2X10_FLIP_CC_CON_SMVT_2X10_ | 2x10 SMVT | CON_SMVT_2X10_50_F_SFM_FLIP_CC |
| RF2 | CON_2X10_FLIP_CC_CON_SMVT_2X10_ | 2x10 SMVT | CON_SMVT_2X10_50_F_SFM_FLIP_CC |
| SHLD1 | RF_SHIELD_8P_SH_BMI-S-202_650X6 | xx | SH_BMI-S-202_650X650 |
| TP1 | TESTPOINT_TP_THVT_060_RND_BLK | Blk | TP_THVT_060_RND |
| TP2 | TESTPOINT_TP_THVT_060_RND_BLK | Blk | TP_THVT_060_RND |
| TP3 | TESTPOINT_TP_VIA_030RND020_XX | XX | TP_VIA_030RND020 |
| U1 | TPS731XX_DBV5_SOT23_DBV5_LP2985 | LP2985-18DBV | SOT23_DBV5 |
| U2 | SN74AVC4T774_RSV16_PQFP_RSV16_S | SN74AVC4T774RSV | PQFP_RSV16 |
| U3 | SN74AVC4T774_RSV16_PQFP_RSV16_S | SN74AVC4T774RSV | PQFP_RSV16 |
| U4 | SN74AVC4T774_RSV16_PQFP_RSV16_S | SN74AVC4T774RSV | PQFP_RSV16 |
| U5 | BL6450Q_RVM_PVQFN_RVM_EP134X122 | CC2560RVM | PVQFN_RVM_EP134X122 |
| Y1 | XTAL_4P_GND_XTAL_4_SM_83X67X20_ | 26MHz | XTAL_4_SM_83X67X20 |
