查看: 1014|回复: 2
LED点阵屏静态显示16*64汉字
发表于 2016-5-16 06:44 | 显示全部楼层 |阅读模式
#include "msp430x14x.h"
#define LT0     P3OUT&=~BIT0
#define LT1     P3OUT|=BIT0
#define SK0     P3OUT&=~BIT1
#define SK1     P3OUT|=BIT1
#define EN0     P3OUT&=~BIT2
#define EN1     P3OUT|=BIT2
#define R0      P3OUT&=~BIT3
#define R1      P3OUT|=BIT3
#define LS      P1OUT
const char Table[]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xF0,0xCF,0xE7,0xE7,0xCF,0xF3,0x9F,0xF3,0x9F,
0xF3,0x9F,0xF3,0x9F,0xF3,0x9F,0xE7,0xCF,0xCF,0xE7,0x3F,0xF8,0xFF,0xFF,0xFF,0xFF,/*"0",0*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x07,0xFE,0x7F,0xFE,0x7F,0xFE,0x7F,0xFE,
0x7F,0xFE,0x7F,0xFE,0x7F,0xFE,0x7F,0xFE,0x7F,0xFE,0x07,0xE0,0xFF,0xFF,0xFF,0xFF,/*"1",1*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0xF0,0xE7,0xC7,0xFB,0xCF,0xF3,0xCF,0xFF,0xE7,
0xFF,0xFB,0xFF,0xFC,0x3F,0xFF,0xCF,0xDF,0xF7,0xCF,0x03,0xE0,0xFF,0xFF,0xFF,0xFF,/*"2",2*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xF8,0xF3,0xE3,0xF3,0xE7,0xFF,0xF3,0x3F,0xFC,
0xFF,0xE3,0xFF,0xCF,0xFF,0xCF,0xF3,0xCF,0xF3,0xE3,0x0F,0xF8,0xFF,0xFF,0xFF,0xFF,/*"3",3*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF3,0xFF,0xF0,0x7F,0xF1,0xBF,0xF1,0xDF,0xF1,
0xE7,0xF1,0xFB,0xF1,0x01,0x80,0xFF,0xF1,0xFF,0xF1,0x3F,0x80,0xFF,0xFF,0xFF,0xFF,/*"4",4*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xC0,0xEF,0xFF,0xEF,0xFF,0xF7,0xFF,0x17,0xF0,
0xE7,0xE7,0xFF,0xCF,0xFF,0xCF,0xF3,0xCF,0xFB,0xE3,0x07,0xF8,0xFF,0xFF,0xFF,0xFF,/*"5",5*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3F,0xE0,0x8F,0xCF,0xE7,0xFF,0xF7,0xFF,0x33,0xE0,
0xC3,0xCF,0xF3,0x9F,0xF3,0x9F,0xE7,0x9F,0xCF,0xCF,0x1F,0xF0,0xFF,0xFF,0xFF,0xFF,/*"6",6*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xC0,0xF3,0xEF,0xFB,0xF7,0xFF,0xFB,0xFF,0xFD,
0xFF,0xFE,0x7F,0xFF,0x7F,0xFF,0x3F,0xFF,0x3F,0xFF,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,/*"7",7*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xF0,0xE3,0xC7,0xF3,0xCF,0xE3,0xCF,0x8F,0xF7,
0x4F,0xF8,0xF3,0xE3,0xF9,0xCF,0xF9,0xCF,0xF3,0xE7,0x0F,0xF8,0xFF,0xFF,0xFF,0xFF,/*"8",8*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xF8,0xF3,0xE3,0xF9,0xEF,0xF9,0xCF,0xF9,0xCF,
0xF3,0xC3,0x07,0xCC,0xFF,0xE7,0xFF,0xE7,0xF3,0xF1,0x07,0xFC,0xFF,0xFF,0xFF,0xFF,/*"9",9*/
void delay(unsigned int n)   //延时函数
{ unsigned int k;
   for(k=0;k<n;k++);
void IO_Init(void)
//IO初始化---------------------------------------
   P1DIR |=0xFF;
   P3DIR |=0xFF;
void SendDate(unsigned char Data)
unsigned char i;
for(i = 0; i < 8; i++)
  if(Data&0x01) R1;   //串行输出Data数据
        else   R0;
  SK0;
  Data=Data>>1;
  //_NOP();
  SK1;
void led_show1(int i,int j,int k,int l)//静态显示16X16汉字
unsigned int num;
for(num=0;num<16;num++)
  SendDate(Table[num*2+0+32*i]);
  SendDate(Table[num*2+1+32*i]);
  SendDate(Table[num*2+0+32*j]);
  SendDate(Table[num*2+1+32*j]);
  SendDate(Table[num*2+0+32*k]);
  SendDate(Table[num*2+1+32*k]);
  SendDate(Table[num*2+0+32*l]);
  SendDate(Table[num*2+1+32*l]);
  EN1;    //关显示屏片选
  delay(500);
  //_NOP();//消影
  LT1;
  LT0;    //输出锁存
  LS=num;    //16行地址
  //_NOP();//消影
  EN0;     //开显示屏片选
void main( void )
  char z;
  WDTCTL = WDTPW + WDTHOLD;
  IO_Init();
   /*------选择系统主时钟为8MHz-------*/
    BCSCTL1 &= ~XT2OFF;                 //打开XT2高频晶体振荡器
    do
        IFG1 &= ~OFIFG;                 //清除晶振失败标志
        for (z = 0xFF; z > 0; z--);     //等待8MHz晶体起振
    while ((IFG1 & OFIFG));             //晶振失效标志仍然存在?
    BCSCTL2 |= SELM_2 + SELS;           //MCLK和SMCLK选择高频晶振
    while(1)
unsigned int i,j,k,l;
i=5;j=6;k=7;l=9;
   led_show1(i,j,k,l);
社区居民忠实会员社区劳模最爱沙发终身成就奖优秀斑竹奖
发表于 2016-5-16 08:36 | 显示全部楼层
  • 打卡总天数:159
  • 打卡总奖励:628
  • 最近打卡:2025-11-18 22:17:11
43
终身成就奖社区居民忠实会员社区明星最爱沙发优秀斑竹奖宣传大使奖特殊贡献奖
发表于 2016-5-16 08:37 | 显示全部楼层
q
