查看: 1986|回复: 1
[PDF格式] DragonBoard410c Schematics
发表于 2016-5-30 22:10 | 显示全部楼层 |阅读模式
    [li]OS Support: Android 5.1 (Lollipop) on Linux Kernel 3.10, Linux based on Debian 8.0, and Windows 10 IoT Core[/li][li]CPU: Quad-core ARM® Cortex® A53 at up to 1.2 GHz per core with both 32-bit and 64-bit support[/li][li]Memory/storages: 1GB LPDDR3 533MHz / 8GB eMMC 4.5 / SD 3.0 (UHS-I)[/li][li]Graphics: Qualcomm Adreno 306 GPU with support for advanced APIs, including OpenGL ES 3.0, OpenCL, DirectX, and content security[/li][li]Video: 1080p@30fps HD video playback and capture with H.264 (AVC), and 720p playback with H.265 (HEVC)[/li][li]Camera Support: Integrated ISP with support for image sensors up to 13MP[/li][li]Connectivity and Location: Wi-Fi 802.11 b/g/n 2.4GHz, integrated digital core[/li][li]Bluetooth 4.1, integrated digital core[/li][li]Qualcomm® IZat™ location technology Gen8C[/li][li]On-board Wi-Fi, BT and GPS antenna[/li]
I/O Interfaces: HDMI Full-size Type A connector, one micro USB (device mode only), two USB 2.0 (host mode only), micro SD card slot
    [li]Note: Micro USB (device mode) and USB 2.0 (host mode) are mutually exclusive and cannot be operated at the same time[/li]
Expansion:
    [li]One 40-pin low speed expansion connector: UART, SPI, I2S, I2C x2, GPIO x12, DC power[/li][li]One 60-pin high speed expansion connector: 4L MIPI-DSI, USB, I2C x2, 2L+4L MIPI-CSI[/li][li]Footprint for one optional 16-pin analog expansion connector for stereo headset/line-out, speaker and analog line-in.[/li][li]The board can be made compatible with Arduino using an add-on mezzanine board[/li]
Schematics_DragonBoard.pdf
931 KB, 下载次数: 1, 下载积分:金币 -1 枚
  • 打卡总天数:2
  • 打卡总奖励:4
  • 最近打卡:2025-11-08 15:04:09
发表于 2021-5-11 01:34 | 显示全部楼层
