查看: 3116|回复: 1
[PDF格式] ts-8550-schematic-revb
发表于 2016-5-30 22:22 | 显示全部楼层 |阅读模式
The TS-8550 is a complete platform for development, evaluation, and prototyping with TS-SOCKET macrocontroller CoMs.
It is compatible with any TS-4xxx module.
All signals on the board to board TS-SOCKET connectors are brought out to external connectors on the TS-8550.
Detailed Feature List
    [li]TS-SOCKET Baseboard
    (requires TS-SOCKET Macrocontroller)[/li][li]Ideal for Development/Evaluation[/li][li]RS-232 DB9 Console[/li][li]5 VDC or 8-28 VDC Inputs[/li][li]3x USB Host Ports[/li][li]10/100/1000 Ethernet Connector[/li][li]10/100 Ethernet Connector[/li][li]MicroSD Card Socket[/li][li]CAN bus and RS-485 Port[/li][li]Mini PCIe Socket (w/ Half Size Support)[/li][li]Coin Cell Battery Holder[/li][li]SATA Connector[/li][li]SD Boot Jumper[/li][li]Reset Push Switch[/li][li]User Push Switch[/li]
ts-8550-schematic-revb.pdf
217 KB, 下载次数: 2, 下载积分:金币 -1 枚
  • 打卡总天数:2
  • 打卡总奖励:4
  • 最近打卡:2025-11-08 15:04:09
发表于 2021-5-9 08:22 | 显示全部楼层
