查看: 1344|回复: 1
[PDF格式] NanoPi-2-1507-Schematic
发表于 2016-5-30 22:39 | 显示全部楼层 |阅读模式
The NanoPi2 is a high performance ARM Board developed by FriendlyARM for Hobbysts, Makers and Hackers for IOT projects.
It features the Samsung Cortex-A9 Quad Core S5P4418@1.4GHz SoC and 1G 32bit DDR3 RAM.
It has built-in WiFi and Bluetooth which supports 802.11 b/g/n and Bluetooth 4.0. It boots Android and Debian from a TF card.
It integrates an HDMI and LCD interface.
Its adoption of the Raspberry Pi’s GPIO pin header makes it compatible with both Raspberry Pi’s external GPIO modules and Arduino’s shield boards.
Its PCB dimension is 75 x 40 mm.
Features
    [li]CPU: S5P4418, 1.4GHz[/li][li]RAM: 1GB DDR3[/li][li]Built in SDIO WiFi and Bluetooth module[/li][li]USB 2.0 Type A x 1[/li][li]Debug Serial Port/UART0 x 1[/li][li]microSD Slot x 2[/li][li]microUSB x 1: for data transmission and power input[/li][li]LCD Interface: 0.5 mm pitch SMT FPC seat, for full-color LCD (RGB: 8-8-8)[/li][li]HDMI: HDMI 1.4A, Type-A, 1080P60[/li][li]DVP Camera Interface: 0.5mm spacing FPC socket. It includes ITU-R BT 601/656 8-bit, I2C and IO[/li][li]GPIO: 2.54mm spacing 40pin, compatible with Raspberry Pi's GPIO. It includes UART, SPI, I2C, IO etc[/li][li]Button: User Button x 1, Reset Button x 1[/li][li]LED: LED for Power Indication x 1, User LED x 1[/li][li]PCB Dimension: 75 x 40mm[/li][li]Power: DC 5V/2A[/li][li]OS: Android, Debian[/li]
NanoPi-2-1507-Schematic.pdf
341 KB, 下载次数: 2, 下载积分:金币 -1 枚
终身成就奖社区居民优秀斑竹奖
发表于 2016-5-31 08:56 | 显示全部楼层
