查看: 1439|回复: 0
[PDF格式] RD163-CO2144_SMsC_LAN_Ext_Modem
发表于 2016-6-2 00:32 | 显示全部楼层 |阅读模式
iChip CO2144 with EBI Flash 10/100BaseT LAN (SMsC Phy) and External Modem
Introduction
This Reference Design demonstrates the iChip™ CO2144 IP Controller™ connected to ahost processor via USART,
to a flash memory chip via EBI interface, to 10/100BaseTLAN (SMsC Phy) via RMII, and to an external modem via USART.
Connect One’s AT+i™ commands are accepted at baud rates of up to 3Mbps.
Features
ƒ Supports serial host interface speeds of up to 3Mbps (250K, 1M, 1.5M, 3M)ƒ
SSL3/TLS1 security implemented in hardware provides better performanceƒ
Data and Internet connection through a 10/100BaseT Ethernet controller and anycellular or dial-up modemƒ
Operates at the industrial temperature rangeƒ
RoHS-compliant
RD163-CO2144_SMsC_LAN_Ext_Modem_16_4440_11.pdf
524 KB, 下载次数: 0, 下载积分:金币 -1 枚
