[/free]如题,已量产的文件
IPTV_V010.pcb
(4.9 MB, 下载次数: 5)
[free]
****************以下信息由管理员
@老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
| Name | Part Type | PCB Decal | Value |
| C35 | CPC-5R0X10R0-0R8 | CPC-5R0X10R0-0R8 | |
| D2 | DFN1R0X2R5-10-1-N | DFN1R0X2R5-10-1-N | |
| D3 | SOT223 | SOT223 | |
| D4 | R-PBGA10X14-96-0R80-N | R-PBGA10X14-96-0R80-N | |
| D5 | R-PBGA10X14-96-0R80-N | R-PBGA10X14-96-0R80-N | |
| D6 | SQFP7X7-48 | SQFP7X7-48 | |
| D7 | R-PBGA12X16-169-0R50-N | R-PBGA12X16-169-0R50-N | |
| D8 | R-PBGA11R5X13R0-153-0R50-N | R-PBGA11R5X13R0-153-0R50-N | |
| D9 | PBGA19X19FO407-0R80-N | PBGA19X19FO407-0R80-N | |
| D10 | SC70-6 | SC70-6 | |
| D11 | SOT23-6-B | SOT23-6-B | |
| D14 | TSSOP14-0R65-4R40-B | TSSOP14-0R65-4R40-B | |
| D16 | MC_LSD5WF_3015-B | MC_LSD5WF_3015-B | |
| D18 | SOT23-6-B | SOT23-6-B | |
| D22 | IRM_3638-IRM-3638 | SIP3-TM-5R6X6R0-W | |
| D49 | SC70-6 | SC70-6 | |
| FV1 | SMCJ15CA | SMC | |
| G5 | CO2-5R0X11R5-V | CO2-5R0X11R5-V | |
| HL1 | GT3A-5RG03W0112G | LED3-2R54X3R85-0R9-W | |
| HL2 | DIODE_LED_3_TM-HFR103P-12 | LED2-2R54X3R0-0R9-W | |
| HL4 | GT3A-5RG03W0112G | LED3-2R54X3R85-0R9-W | |
| L1 | 2520L-C-1 | 2520L-C-1 | |
| L2 | INDUCTOR_POWER_-IHLP2020CZER4RA | IND2SM-5R5X5R2-B | |
| S1 | SW_JY_KEY-JY-KEY | SW4SM-3R5X2R9-B | |
| S2 | SW4SM-6R0X6R0-1 | SW4SM-6R0X6R0-1 | |
| SB1 | HOLE_SM_7R00D3R20 | HOLE_SM_7R00D3R20 | |
| SB2 | HOLE_SM_7R00D3R20 | HOLE_SM_7R00D3R20 | |
| T1 | TRAN16SM-7R3X12R7 | TRAN16SM-7R3X12R7 | |
| U4 | SOT23-6-B | SOT23-6-B | |
| VD2 | MOB_DIODE_ZENER_2_SOD523-MM5Z5A | SOD523_D-N | |
| VT1 | SOT23-3 | SOT23-3 | |
| VT2 | RFROHM-EMD5 | RFROHM-EMD5 | |
| VT3 | RFROHM-EMD5 | RFROHM-EMD5 | |
| X1 | CON20VP2R54-1X4TM | CON20VP2R54-1X4TM | |
| X2 | STD_2R50_2TM-PA66 | CON21VP2R50-2TM-1-W | |
| X3 | CON90_2R54_3TM-DQT-012 | CON90RS2R54-3TM-1-W | |
| X4 | CON17-TM5R40-12-1-W | CON17-TM5R40-12-1-W | |
| X5 | EARPHONE_4TM-PJ-370A | CON50TM-5-14R0X6R1-W | |
| X6 | CON90RS0R50-19SM-1 | CON90RS0R50-19SM-1 | |
| X7 | 73725-0110B | CON90RS2R00-4TM | |
| X8 | AV3-8.4-5 | CON50TM-6-40R0X19R5-W | |
| X9 | CON40RP6R60-3TM | CON40RP6R60-3TM | |
| X10 | CON22-TF-44019-00029-B | CON22-TF-44019-00029-B | |
| X11 | CON22-TF-44019-00029-B | CON22-TF-44019-00029-B | |
| X13 | CON10-2R6X2R6-B | CON10-2R6X2R6-B | |
| X14 | STDVM_2R00_8TM-PH-8A | CON21VP2R00-8TM | |
| X15 | CON90_2R50_4TM-XH-4A | CON90VP2R50-4TM-W | |
| X18 | POWERCON_3TM_11-DC-002 | CON50TM-3-11R1X5R0-W | |
| X19 | 73725-0110B | CON90RS2R00-4TM | |
| X20 | CON20VP2R54-1X3TM-1 | CON20VP2R54-1X3TM-1 | |
