重要提示:PCB作品文件展下载说明
PCB:MP3--长条形山景6210(含解码、功放、电源板块)
MP3-6210.pcb
2.29 MB, 下载次数: 9, 下载积分:金币 -5 枚
****************以下信息由管理员 @老吴 整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
| Name | Part Type | PCB Decal | Value | | 1 | USB-ML | MICRO_USB_DIP | USB-ML | | 1C3 | PD4 | PD4 | AUDIO OUT | | 1LED2 | LED | LED3 | | | 1U1 | 24C02 | DIP8\SOA | 24C02 | | 1U2 | SOT-23-6-SC4004 | SOT-23-6 | KX4002 | | 3LED1 | LED5X7 | LED_12PIN | | | ANT-2 | ANT_0 | A-1X2MMAA | ANT | | AU6210K | AU6210K | LQFP48-0.5MM | AU6210K | | C1 | EC | CE10 | 1000uF/10V | | D1 | DIODE | DIO_4.5 | 1N5819 | | D2 | DIODE | DIO_4.5 | 1N5819 | | D3 | DIODE | DIO_4.5 | 1N4001 | | D4 | DD01 | DD5.0-8A | RS1006 | | EC1 | EC | CE05 | 10uF/16V | | EC2 | EC | CE05 | 1uF/25V | | FM_ANT | TP | A-1X2MMAB | | | J1 | CN02 | PD2-4.0 | AC10 IN | | J2 | USB-4LB | USB-4LD | | | J3 | CN02 | PD2-4.0 | VOUT | | J4 | STJACK3.5-2SW | PHONEJACK-5-2S | LINE IN | | J5 | CN03 | PD3-2.0 | KEY | | J9 | STJACK3.5-2S-2SW | PHONEJACK/S2/ST3.5-SW2 | HEADPHONE | | J17 | CN18 | FFC0.5-18-SMT | | | J18 | STJACK3.5-2SW | PHONEJACK-5-2S | MIC IN | | J19 | CON2P2.0MM | CON2P2.0MM | BAT | | J20 | CN02 | PD2-4.0 | VOUT | | J28 | CON_4/2 | USB2-8P | | | K1 | KEY_L6X6X7 | KEY_L6X6X7 | | | L-SPK2 | CON2P2.0MM | CON2P2.0MM | 2.0X2P | | M1 | MIC | MIC-6MMAAA | MIC | | MIC_IN | PHONE-CK-3.5N | PHONE-CK3-6.5 | | | MIC_IN1 | PHONE-CK-3.5N | PHONE-CK3-6.5 | | | Q4 | PNP | SOT-23 | S8550D | | Q5 | NPN9014 | SOT-23 | 9014C | | SW10 | KEY5.2X5.2MM | KEY5.2X5.2-SMT | | | U1 | AP1509-5V | SOP-8P-1.27MMB | AP1509/5V | | U2 | TDA7388A | TDA7388AA | TDA7388 | | U3 | LM7805-MT | TO-220T1015 | LM7812 | | U4 | PT2399 | SO16 | PT2399 | | U5 | 4558_1 | SOP-8P-1.27MMB | M358 | | U6 | LDO-2.5V | SOT-23 | LDO3.3V | | U7 | NJM4558 | SOP-8P-1.27MMB | LM358 | | U8 | IR | IR2.5 | | | U9 | NJM4558 | SOP-8P-1.27MMB | LM358 | | U11 | LM7805-MT | SOT-89 | 78L12 | | U12 | NJM4558 | SOP-8P-1.27MMB | LM358 | | U13 | TDA1308 | SOP8_NORMAL | TDA1308 | | U14 | LM7805-MT | SOT-89 | 78L05 | | U15 | BC08 | BC08-A | BC08-A-8645 | | U16 | SOP-16P-XHJ4863-1.27MMB | SOP-16P-1.27MMB | LM4863 | | USB | USB-4LB | USB-4LP | | | USB1 | PD8_2.0 | PD8_2.0 | | | USB3 | P2 | P2 | | | W1 | RV0921-SW | RV0921-SWAA | 50K | | W2 | VOL2 | RV0921 | 50K | | W3 | VOL2 | RV0921 | 50K | | Y1 | CRYSTAL | Y3X8MM | 32.768KHz | | Z1 | ZENER3 | D-SOD-123 | 7.5V |
评分
查看全部评分
重要提示:PCB作品文件展下载说明
