| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BT1 | BAT_MF621F_2_CON_2PIN_SMT_CON_2 | CON_2PIN_SMT | CON_2PIN_SMT |
| CN1 | 2XCN18_2MM_DIP_3_2XCN18_2MM_DIP | 2.0 DIP 180 | 2XCN18_2MM_DIP |
| CN2 | 2XCN10_2MM_DIP_3_2XCN10_2MM_SMD | DIP 180 | 2XCN10_2MM_SMD |
| CN4 | DC_090050_DC_090050_DC_090050 | DC_090050 | DC_090050 |
| COM1 | PH_4A_USB_4_CAN-3P_2.05PIN | 2.0 5PIN | CAN-3P |
| COM2 | LBST_CON254_0_JUMPER3_2_54MM_3P | 3PIN | JUMPER3_2_54MM |
| CON3 | SF7W006S1A_CON_SIM_CD_2P54MM_IO | CON 6 SIM CARD | CON_SIM_CD_2P54MM |
| CON5 | CONN_HDR_4X1_BAT-4PIN_IO_NCC | NC CON_1X4 | BAT-4PIN |
| D1 | DIODESCHOTTKY_CD214C_B330 | B330 | CD214C |
| D2 | BIDIRECTIONESD_SOD-923_NP_ESD5 | ESD5B5VL | SOD-923_NP |
| D3 | BIDIRECTIONESD_SOD-923_NP_ESD5 | ESD5B5VL | SOD-923_NP |
| D4 | BIDIRECTIONESD_SOD-923_NP_ESD5 | ESD5B5VL | SOD-923_NP |
| D5 | BIDIRECTIONESD_SOD-923_NP_ESD5 | ESD5B5VL | SOD-923_NP |
| D6 | LED_LED_0603_IC_NCLED_ORANGE | NC LED_ORANGE | LED_0603 |
| D7 | LED_LED_0603_IC_LED_GREEN | LED_GREEN | LED_0603 |
| D8 | LED_LED_0603_IC_LED_ORANGE | LED_ORANGE | LED_0603 |
| D9 | LED_LED_0603_IC_LED_YELLOW | LED_YELLOW | LED_0603 |
| D10 | DIODESCHOTTKY_2_SOD123_IN5819 | IN5819 | SOD123 |
| D12 | DIODE_SOD323_IC_BAT54HT1 | BAT54HT1 | SOD323 |
| D13 | BIDIRECTIONESD_CD214C_NC SMBJ1 | NC SMBJ18CA | CD214C |
| D14 | BIDIRECTIONESD_CD214C_NC SMBJ1 | NC SMBJ18CA | CD214C |
| D15 | BIDIRECTIONESD_CD214C_NC SMBJ1 | NC SMBJ18CA | CD214C |
| D16 | BIDIRECTIONESD_CD214C_NC SMBJ | NC SMBJ18CA | CD214C |
| D17 | BIDIRECTIONESD_CD214C_NC SMBJ1 | NC SMBJ18CA | CD214C |
| D18 | BIDIRECTIONESD_CD214C_NC SMBJ1 | NC SMBJ18CA | CD214C |
| D19 | BIDIRECTIONESD_CD214C_NC SMBJ1 | NC SMBJ18CA | CD214C |
| D20 | BIDIRECTIONESD_CD214C_NC SMBJ1 | NC SMBJ18CA | CD214C |
| D21 | DIODESCHOTTKY_SMC_B330 | B330 | SMC |
| D22 | BIDIRECTIONESD_R-R0402_NC ESD5 | NC ESD5B5VL | R-R0402 |
| D23 | DIODESCHOTTKY_SOD123B_SS32A | SS32A | SOD123B |
| D24 | DIODESCHOTTKY_2_SOD123_MBR0540 | MBR0540 | SOD123 |
| IR1 | LBST_CON254_3P_JUMPER3_2_54MM_3 | 3PIN | JUMPER3_2_54MM |
| J1 | 3.5MM_AUDIO_JACK_PJ3640_IO_AUDI | Audio Jack | PJ3640 |
| J2 | 3.5MM_AUDIO_JACK_PJ3640_IO_AUDI | Audio Jack | PJ3640 |
| J3 | CONN_SATA_22P_CON_SATA_22F_XIEM | 10029364-001LF | CON_SATA_22F_XIEMEI |
| J4 | CONN_SDC013_19P_CON19_SDCARD_28 | CONN CRD 19 | CON19_SDCARD_28X16_SM |
| J5 | 2XCN4_2MM_DIP_0_2XCN3_2MM_DIP_2 | 2.0 DIP 180 | 2XCN3_2MM_DIP |
| J6 | OV2659_1_FPC24_OV2659 | OV2659 | FPC24 |
| J7 | V890-1AX1-A1_0_SI-61001_IO_SI-6 | si-61001-F | SI-61001 |
| J9 | MINI_PCI_LATCH_0_MINIPCIE_52PIN | CON 2X26 MINI PCIEXPRESS | MINIPCIE_52PIN |
| J11 | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | CON5_MICROUSB |
| J12 | USB_MINI_AB_RECEPTACLE_CON5_MIC | MICRO USB AB 5 | CON5_MICROUSB |
| J13 | CONN_HDMI_19P_TYPE_A_1_HDMI_TYP | 10029449-001RLF | HDMI_TYPE_A |
| J14 | FPC10 FOR 9_0.7TOUCH_FPC-10PIN | 10PIN*0.5 | FPC-10PIN-1_0MM |
| JP1 | PH_6A_PH_6A_2.0 6PIN | 2.0 6PIN | PH_6A |
| L1 | BEAD_0_L0603_DISCRETE_120OHM | 120OHM | L0603 |
| L2 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L3 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L4 | BEAD_0_L0603_DISCRETE_120OHM | 120OHM | L0603 |
| L5 | BEAD_0_L0603_DISCRETE_120OHM | 120OHM | L0603 |
| L6 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L7 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L8 | BEAD_0_L0603_DISCRETE_120OHM | 120OHM | L0603 |
| L9 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L10 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L11 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L12 | IND_L0603_DISCRETE_100OHM@100M | 100 OHM@100MHZ | L0603 |
| L15 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L17 | DLW43_IND4_CHOKE_0805_DISCRETE_ | NC 90OHM | IND4_CHOKE_0805 |
| L18 | DLW43_IND4_CHOKE_0805_DISCRET_1 | NC 90OHM | IND4_CHOKE_0805 |
| L19 | DLW43_IND4_CHOKE_0805_DISCRET_2 | NC 90OHM | IND4_CHOKE_0805 |
| L20 | DLW43_IND4_CHOKE_0805_DISCRETE_ | NC 90OHM | IND4_CHOKE_0805 |
| L21 | DLW43_IND4_CHOKE_0805_DISCRET_3 | NC 90OHM | IND4_CHOKE_0805 |
| L22 | DLW43_IND4_CHOKE_0805_DISCRETE_ | NC 90OHM | IND4_CHOKE_0805 |
| L23 | DLW43_IND4_CHOKE_0805_DISCRETE_ | NC 90OHM | IND4_CHOKE_0805 |
| L24 | DLW43_IND4_CHOKE_0805_DISCRETE_ | NC 90OHM | IND4_CHOKE_0805 |
| L25 | DLW43_IND4_CHOKE_0805_DISCRETE_ | NC 90OHM | IND4_CHOKE_0805 |
| L26 | DLW43_IND4_CHOKE_0805_DISCRETE_ | NC 90OHM | IND4_CHOKE_0805 |
| L27 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L28 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L29 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L30 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L31 | FERRITEBEAD_0_L0603_120R_100MH | 120R_100MHz_3A_0603 | L0603 |
| L32 | FERRITEBEAD_0_L0603_120R_100MH | 120R_100MHz_3A_0603 | L0603 |
| L33 | COMMON MODEINDUCTOR_FIL-2X1_2- | EXD24CD900U | FIL-2X1_2-4 |
| L34 | COMMON MODEINDUCTOR_FIL-2X1_2- | EXD24CD900U | FIL-2X1_2-4 |
| L35 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L36 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L37 | BEAD_0_0603_CC_DISCRETE_120OHM | 120OHM | 0603_CC |
| L38 | INDUCTOR_IND_VLS3012_SM_DISCRET | 4.7UH SPN3015 | IND_VLS3012_SM |
| L39 | BEAD_0_C0603_DISCRETE_120OHM | 120OHM | C0603 |
| L40 | INDUCTOR_L0402_NC | NC | L0402 |
| L41 | INDUCTOR_L0402_NC | NC | L0402 |
| L42 | DLW43_IND4_CHOKE_0805_DISCRET_3 | NC 90OHM | IND4_CHOKE_0805 |
| L43 | INDUCTOR_POWER_L6020_6.8UH2A | 6.8uH 2A SPN6020 | L6020 |
| L44 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L45 | INDUCTOR_L0603_DISCRETE_470OHM | 470OHM | L0603 |
| L46 | DLW43_IND4_CHOKE_0805_DISCRET_4 | 90OHM | IND4_CHOKE_0805 |
| L47 | INDUCTOR_L0603_DISCRETE_470OHM | 470OHM | L0603 |
| L48 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L49 | BEAD_0_L0603_DISCRETE_120OHM | 120OHM | L0603 |
| L50 | FERRITEBEAD_0_L0603_60R_100M_1 | 60R_100MHz | L0603 |
| L52 | BEAD_0_L0603_DISCRETE_120OHM | 120OHM | L0603 |
| L53 | BEAD_0_L0603_DISCRETE_120OHM | 120OHM | L0603 |
| L54 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L55 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L56 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L59 | INDUCTOR_IND_4X4_DISCRETE_1UH | 1UH SPN252012 | IND_4X4 |
| L60 | INDUCTOR_IND_4X4_DISCRETE_1UH | 1UH SPN252012 | IND_4X4 |
| L521 | INDUCTOR_POWER_VEPD0603_4R7M_2. | 2.2uH 3A SPN6020 | VEPD0603_4R7M |
| L522 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L523 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| L526 | BEAD_0_L0402_DISCRETE_120OHM | 120OHM | L0402 |
| L527 | INDUCTOR_L0603_DISCRETE_100OHM | 100OHM | L0603 |
| L528 | INDUCTOR_L0603_DISCRETE_100OHM | 100OHM | L0603 |
| L529 | INDUCTOR_POWER_IND_5015_2.2UH2 | 2.2uH 2A SPN5020 | IND_5015 |
| L530 | FERRITEBEAD_0_L0603_60R_100MHZ | 60R_100MHz_3A_0603 | L0603 |
| Q1 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q2 | 2N7002_SOT23_IC_2N7002 | 2N7002 | SOT23 |
| Q3 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q4 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q5 | MOSFET_P_SOT23A_SOT23_SI2305 | SI2305 | SOT23 |
| Q6 | NPNSOT23A_SOT23_MMBT3904 | MMBT3904 | SOT23 |
| Q7 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q8 | 2N7002_SOT23_IC_2N7002 | 2N7002 | SOT23 |
| Q9 | MOSFETN_0_SOT23_WPM2026 | WPM2026 | SOT23 |
| Q10 | MOSFETN_0_SOT23_WPM2026 | WPM2026 | SOT23 |
| Q11 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q12 | 2N7002_SOT23_IC_2N7002 | 2N7002 | SOT23 |
| Q13 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q14 | MOSFET_2N_CHAN_SC70-6_IC_BSS138 | BSS138DW-7 | SC70-6 |
| Q15 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q16 | 2N7002_SOT23_IC_2N7002 | 2N7002 | SOT23 |
| Q17 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q18 | 2N7002_SOT23_IC_2N7002 | 2N7002 | SOT23 |
| Q20 | NPN_2_SOT23_2N9014 | 2N9014 | SOT23 |
| Q21 | MOSFET_P_SOT23_IC_IRLML6401 | IRLML6401 | SOT23 |
| Q22 | SI4435DY_0_SO8_SI4435DY | SI4435DY | SO8 |
| Q23 | NPN_2_SOT23_2N9014 | 2N9014 | SOT23 |
| Q24 | MOS_0_GDT7_5X5_SDM_GDT | GDT | GDT7_5X5_SDM |
| Q25 | 2N7002_SOT23_IC_AO3400 | AO3400 | SOT23 |
| Q26 | SI4435DY_0_SO8_SI4435DY | SI4435DY | SO8 |
| Q27 | NPN_2_SOT23_2N9014 | 2N9014 | SOT23 |
| RT1 | THERMISTOR_R0402_DISCRETE_10K | 10K | R0402 |
| RT2 | THERMISTOR_R0402_DISCRETE_10K | 10K | R0402 |
| SH3 | RES_SHORT-3_1TO2_SH0603-X2_PIN1 | 0 | SH0603-X2_PIN1TO2 |
| SH4 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | SH0805_40 |
| SH6 | RES_SHORT-2_SH0805_40_DISCRETE_ | SOLDER SHORT | SH0805_40 |
| SW2 | SW_TACT-SPST-2_SM_KEY6X6_IC_PB | PB switch | KEY6X6 |
| SW3 | EDGE_MOUNT_PB_SW_2_KEY6X6X5_IC_ | EVQPUA02K | KEY6X6X5 |
| SW4 | EDGE_MOUNT_PB_SW_2_KEY6X6X5_IC_ | EVQPUA02K | KEY6X6X5 |
| SW5 | EDGE_MOUNT_PB_SW_2_KEY6X6X5_IC_ | EVQPUA02K | KEY6X6X5 |
| SW6 | SW_TACT-SPST-2_SM_KEY6X6_IC_PB | PB switch | KEY6X6 |
| TP1 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP2 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP3 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP4 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP5 | TESTPAD_C035S_IC_TEST POINT | TEST POINT | C035S |
| TP15 | TESTPAD_C035S_IC_TEST POINT | TEST POINT | C035S |
| TP16 | TESTPAD_C035S_IC_TEST POINT | TEST POINT | C035S |
| TP17 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP18 | TESTLOOP_TPAD_020_IO_TPAD_020 | TPAD_020 | TPAD_020 |
| TP19 | TESTPAD_HOLE3_2X6_IC_TEST POIN | TEST POINT | HOLE3_2X6 |
| TP20 | TESTPAD_HOLE3_2X6_IC_TEST POIN | TEST POINT | HOLE3_2X6 |
| TP21 | TESTPAD_HOLE3_2X6_IC_TEST POIN | TEST POINT | HOLE3_2X6 |
| TP22 | TESTPAD_HOLE3_2X6_IC_TEST POIN | TEST POINT | HOLE3_2X6 |
| TVS1 | DIODE_TVS_BIDIR_SOD-923_NP_IC_E | ESD9B3.3ST5G | SOD-923_NP |
| TVS20 | DIODE_TVS_BIDIR_CD214C_IC_ESD9B | ESD9B3.3ST5G | CD214C |
| TVS21 | DIODE_TVS_BIDIR_CD214C_IC_ESD9B | ESD9B3.3ST5G | CD214C |
| TVS22 | DIODE_TVS_BIDIR_SOD-923_NP_IC_E | ESD9B3.3ST5G | SOD-923_NP |
| TVS23 | DIODE_TVS_BIDIR_SOD-923_NP_IC_E | ESD9B3.3ST5G | SOD-923_NP |
| TVS24 | DIODE_TVS_BIDIR_SOD-923_NP_IC_E | ESD9B3.3ST5G | SOD-923_NP |
| TVS25 | DIODE_TVS_BIDIR_CD214C_IC_ESD9B | ESD9B3.3ST5G | CD214C |
| TVS26 | DIODE_TVS_BIDIR_CD214C_IC_ESD9B | ESD9B3.3ST5G | CD214C |
| U1 | IMX6Q_CORE_CON_B_0_IMX6_IO_BOAR | IMX6Q_CORE_CON_B | IMX6_IO_BOARD |
| U2 | WM8962_BGA_49P_CUST_BGA49_0P5_3 | WM8962 | BGA49_0P5_3P62X4 |
| U3 | NC7WZ17_SC70_6LEAD_IC_NC7WZ17 | NC7WZ17 | SC70_6LEAD |
| U4 | ADMP421_LGA5_LGA5_CAV_4P1X3P1MM | NC ADMP421B | LGA5_CAV_4P1X3P1MM |
| U5 | ADMP421_LGA5_LGA5_CAV_4P1X3P1MM | NC ADMP421B | LGA5_CAV_4P1X3P1MM |
| U6 | ESD ARRAYDFN10_DFN10_*ESDA6V8U | *ESDA6V8UD | DFN10 |
| U7 | MAX11801_TQFN_12P_QFN12_IC_MAX1 | MAX11801 | QFN12 |
| U8 | NLSV1T34_ULLGA6_1P45X1_0P5MM_IC | NLSV1T34 | ULLGA6_1P45X1_0P5MM |
| U9 | GL850G_QFN28_2_GSL_QFN28_GL850G | GL850G | GSL_QFN28 |
| U10 | AR8031_QFN48_QFN48_0P4_6X6MM_EP | AR8031 | QFN48_0P4_6X6MM_EPAD |
| U11 | RTL8723AS_RTL8723AS_RTL8723AS | RTL8723AS | RTL8723AS |
| U12 | EUP3476_SOIC-8EDP_EUP3476DIR1 | EUP3476DIR1 | SOIC-8EDP |
| U13 | MODULE_AH-1613_MODULE_AH-1613_I | VK-1613 | MODULE_AH-1613 |
| U14 | 1G126_SOT353_IC_M74VHC1GT126DF1 | M74VHC1GT126DF1G | SOT353 |
| U16 | MIC2526_8P_SO8_IC_MIC2026-1YM | MIC2026-1YM | SO8 |
| U17 | SN74LVC2G126DCTR_SSOP8_IC_SN74L | SN74LVC2G126 | SSOP8 |
| U18 | FT232RQ_QFN32_MC1320X_IC_FT232R | FT232RQ | QFN32_MC1320X |
| U19 | NLSV1T34_ULLGA6_1P45X1_0P5MM_IC | NLSV1T34 | ULLGA6_1P45X1_0P5MM |
| U20 | TJA1040T_SO_8P_SO8_1P27_4X5_IC_ | TJA1040T | SO8_1P27_4X5 |
| U21 | ADM2587_ADM2587_ADM2587 | ADM2587 | ADM2587 |
| U24 | CM2020_TSSOP_38P_TSSOP38_0P5_4P | CM2020 | TSSOP38_0P5_4P5X9P8 |
| U25 | MMA8451Q_16P_A_QFN5X3_0P5_3X3_I | MMA8451Q | QFN5X3_0P5_3X3 |
| U26 | MAX202EEUE_SON_16_NCMAX232ECS | NC MAX232ECSE | SON_16 |
| U27 | MAX202EEUE_SON_16_NCMAX232ECSE | NC MAX232ECSE | SON_16 |
| U30 | MAX8903A_TQFN_28P_TQFN28_0P4_4X | MAX8903C | TQFN28_0P4_4X4 |
| U31 | MAX8903A_TQFN_28P_TQFN28_0P4_4X | MAX8903C | TQFN28_0P4_4X4 |
| U95 | TCXO RAKON SMD4P_TCXO325_RAKON | IT2205BE/16.368MHz | TCXO325 |
| U96 | GPS-RF_GPS-ANT_GPS-RF | GPS-RF | GPS-ANT |
| U529 | EUP3485_2_SOIC-8EDP_EUP3485 | EUP3485 | SOIC-8EDP |
| U531 | COM10PIN_0_COM10PIN-B_COM10PIN | com10pin | COM10PIN-B |
| U532 | COM10PIN_0_COM10PIN-B_COM10PIN | com10pin | COM10PIN-B |
| U533 | COM10PIN_0_COM10PIN-B_COM10PIN | com10pin | COM10PIN-B |
| U534 | RS485_0_RS485-2P_RS485 | RS485 | RS485-2P |
| U535 | CON4_1_IPEX_IPEX | IPEX | IPEX |
| U536 | CON20PIN-B_2XCN10_2MM_SMD_CON20 | CON20PIN-B | 2XCN10_2MM_SMD |
| U537 | COM10PIN_0_COM10PIN-B_COM10PIN | com10pin | COM10PIN-B |
| U538 | COM10PIN_0_COM10PIN-B_COM10PIN | com10pin | COM10PIN-B |
| U539 | EUP2573_0_SOT23_5_EUP2573 | EUP2573 | SOT23_5 |
| U540 | SPKER_SPEAKER_2-54M_SPKER | SPKER | SPEAKER_2-54M |
| U541 | SPKER_SPEAKER_2-54M_SPKER | SPKER | SPEAKER_2-54M |
| U542 | SN74LVC1G00_SOT23_5_SN74LVC1G00 | SN74LVC1G00 | SOT23_5 |
| U543 | RS485_0_RS485-2P_RS485 | RS485 | RS485-2P |
| USB1 | USB_AF_SIDE_DIP_USB_AF_SIDE_DIP | USB_AF_SIDE_DIP | USB_AF_SIDE_DIP |
| USB2 | USB_AF_SIDE_DIP_USB_AF_SIDE_DIP | USB_AF_SIDE_DIP | USB_AF_SIDE_DIP |
| Y1 | CRYSTAL_12M_20PPM_0_XTAL4_SX_32 | 12MHz | XTAL4_SX_3225 |
| Y2 | XTAL_13Y_XTAL4_SX_3225_IC_25MHZ | 25MHZ | XTAL4_SX_3225 |
