重要提示:PCB作品文件展下载说明
| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME | | D1 | SD2723 | DZ | SD2723 | | D2 | HSOD882 | ESD8V0R1B_02LRH | HSOD882 | | D3 | HSOD882 | ESD8V0R1B_02LRH | HSOD882 | | D4 | HSOD882 | ESD8V0R1B_02LRH | HSOD882 | | D14 | HSOD882 | PESD5V0S1BL315 | HSOD882 | | D15 | SD0805-LED | SD0805-LED | SD0805-LED | | D16 | SD1714A | D | SD1714A | | D17 | SD1714D | TISP4350H3BJR_S | SD1714D | | D19 | HSOD323A | D_A | HSOD323A | | D20 | HSOD323A | D_A | HSOD323A | | F1 | SF6127 | 0451005MRL | SF6127 | | J1 | SED90-F-A | MIPI_90_CON_F | SED90-F-A | | J11 | HEAD0101-T-B | TSW_101_23_F_S | HEAD0101-T-B | | J12 | TF_CARD-MISOSD | 475792245 | TF_CARD-MISOSD | | J13 | TF_CARD-MISOSD | 475792245 | TF_CARD-MISOSD | | J14 | USB4-200-1907 | UB31123_K1_4F | USB4-200-1907 | | J15 | VAF2 | AV_84_5Y_HW | VAF2 | | J16 | PWC0103-M-N | DC-005-B | PWC0103-M-N | | J17 | J6-W2_54MM-141R | HEAD6_ALARM | J6-W2_54MM-141R | | J18 | CONN80-0_8MM-ERF8-DV | 80PIN-CON | CONN80-0_8MM-ERF8-DV | | J19 | CONN80-0_8MM-ERM8-DV | 80PIN-CON | CONN80-0_8MM-ERM8-DV | | J20 | MJ8-SRLFY | E5J88_14LJ24_L | MJ8-SRLFY | | J21 | WBC0108-49T | SDW12501A_8A_HW | WBC0108-49T | | J22 | SIP-2P | TSW_102_23_F_S | SIP-2P | | J23 | SIP-2P | TSW_102_23_F_S | SIP-2P | | J24 | SIP-2P | TSW_102_23_F_S | SIP-2P | | J25 | WBC0104-49T | SDW12501_4A_HW | WBC0104-49T | | J26 | WBC0104-49T | SDW12501_4A_HW | WBC0104-49T | | J27 | WBC0104-49T | SDW12501_4A_HW | WBC0104-49T | | J28 | MOLEX_47151 | HDMI | MOLEX_47151 | | J29 | PHONEJ6 | AUDIO | PHONEJ6 | | J30 | PHONEJ6 | AUDIO | PHONEJ6 | | J50 | SIP-2P-20 | TJC3_2A_34HW | SIP-2P-20 | | K1 | SRLY8-87-283 | UD2_3NU_L5 | SRLY8-87-283 | | L1 | SPL0404L | 3.9UH | SPL0404L | | L2 | SL2828 | 4.7UH | SL2828 | | L3 | HSL1008 | 2.2UH | HSL1008 | | L4 | HSL1008 | 1U | HSL1008 | | L5 | HSL1008 | 2.2UH | HSL1008 | | L6 | HSL1008 | 2.2UH | HSL1008 | | L7 | HSL1008 | 2.2UH | HSL1008 | | L8 | HSL1008 | 2.2UH | HSL1008 | | L9 | HSL1008 | 2.2UH | HSL1008 | | L10 | HSL1008 | 2.2UH | HSL1008 | | L11 | SL0805B | 100NH | SL0805B | | L12 | SPL0303A | 4.7U | SPL0303A | | L88 | SPL0303A | 4.7U | SPL0303A | | LB1 | SL0805 | LFBK2125HS101_T | SL0805 | | LB2 | SL0805 | LFBK2125HS101_T | SL0805 | | LB4 | SL0805 | LFBK2125HS101_T | SL0805 | | LB5 | SL0805 | LFBK2125HS101_T | SL0805 | | LB6 | SL0402 | BLM15HG102SN1D | SL0402 | | LB7 | SL0402 | BLM15HG102SN1D | SL0402 | | LB8 | SL0402 | BLM15HG102SN1D | SL0402 | | LB9 | SL0402 | BLM15HG102SN1D | SL0402 | | LB10 | SL0402 | BLM15HG102SN1D | SL0402 | | LB11 | SL0402 | BLM15HG102SN1D | SL0402 | | LB12 | SL0603 | MGLB1608_030T_LF | SL0603 | | LB19 | SL0805 | MGLB2012_220T_LF | SL0805 | | LB100 | SL0402 | BLM15HG102SN1D | SL0402 | | M1 | MTH_C6MMD3P2MM | HOLE | MTH_C6MMD3P2MM | | M2 | MTH_C6MMD3P2MM | HOLE | MTH_C6MMD3P2MM | | M3 | MTH_C6MMD3P2MM | HOLE | MTH_C6MMD3P2MM | | M4 | MTH_C6MMD3P2MM | HOLE | MTH_C6MMD3P2MM | | M5 | MTH_C6MMD3P2MM | HOLE | MTH_C6MMD3P2MM | | M6 | MTH_C6MMD3P2MM | HOLE | MTH_C6MMD3P2MM | | OSC1 | HSX4-0503 | 25MHZ | HSX4-0503 | | Q1 | SOT23 | PMOS-GSD | SOT23 | | Q2 | SOT23 | PMOS-GSD | SOT23 | | Q3 | SOT23 | NPN-BEC | SOT23 | | SW1 | SW4_6M6X5M4 | EMR_0415_T_V_T_R | SW4_6M6X5M4 | | SW2 | SW4_6M6X5M4 | EMR_0415_T_V_T_R | SW4_6M6X5M4 | | T1 | STFM24-40-280 | G24_0413ER | STFM24-40-280 | | U1 | MLF6-065-0202L | TPS2553DRVR | MLF6-065-0202L | | U2 | MLF48A-040-0606L | RTL8211E_VB | MLF48A-040-0606L | | U3 | BGA389-26-2222 | HI3519V100 | BGA389-26-2222 | | U4 | WSON8-MX25L12835ZN | 8PIN_SPI_FLASH | WSON8-MX25L12835ZN | | U5 | SGM8903 | SGM8903 | SGM8903 | | U6 | SOP8-50-150 | ADM3485EAR_REEL7 | SOP8-50-150 | | U7 | SOP48-20-720A | H27U2G8F2CTR_BC | SOP48-20-720A | | U8 | MSOP8A-26-118 | PAM8303D | MSOP8A-26-118 | | U9 | MLF8M-050-0202L | MP2162GQH_Z | MLF8M-050-0202L | | U10 | MLF56-050-1105 | PI3L500ZFE | MLF56-050-1105 | | U11 | DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 | | U12 | DFN2510P10E_AZ1045 | AZ1045-04F | DFN2510P10E_AZ1045 | | U13 | SOT23-5B | SN74LVC1G125DBVR | SOT23-5B | | U14 | BGA96-32-1609G | H5TQ4G83AFR-XXC | BGA96-32-1609G | | U15 | BGA96-32-1609G | H5TQ4G83AFR-XXC | BGA96-32-1609G | | U16 | SOP16-50-300A | MX25L25635FMI_16PIN | SOP16-50-300A | | U17 | SOT23-6L | AZC199-04S | SOT23-6L | | U18 | TSOT23-8 | MP2143 | TSOT23-8 | | U19 | SOP8-50-150 | TLV2372IDR | SOP8-50-150 | | U20 | QFN16-050-0303LH | MP6507 | QFN16-050-0303LH | | U21 | SOT23-6B | TPS79301 | SOT23-6B | | U22 | QFN-72 | SII9022 | QFN-72 | | U23 | TSOT23-8 | MP1495S | TSOT23-8 | | U24 | TSOT23-8 | MP1495S | TSOT23-8 | | U25 | SBAT2-13A | BR_1225F1AN | SBAT2-13A | | U26 | TSOT23-8 | MP2122 | TSOT23-8 | | U27 | TSOT23-8 | MP2122 | TSOT23-8 | | X1 | HSX4-0302 | 24MEG | HSX4-0302 | | X2 | HSX2-0302 | 32.768KHZ | HSX2-0302 |
支持4K的H265编码
原理图是ORCAD格式, PCB文件有两个格式版本,PADS9.5 和allegro16.6 两个版本文件
SDK 回头共享。 |
重要提示:PCB作品文件展下载说明
