| Name | Part Type | PCB Decal | Value |
| ANT0400 | CON-SPRING-T105-11F2R | CON-SPRING-T105-11F2R | |
| ANT7203 | CON-SPRING-TP-220-000 | CON_SPRING_TP-220-000 | |
| ANT7204 | CON-SPRING-TP-220-000 | CON_SPRING_TP-220-000 | |
| D4100 | DIODE-SCHOTTKY-WSB5543W-2/TR | SOD_FL_2412_H070 | |
| D5100 | DIODE-LED-YELLOW-LTW-M670ZVS-BT | DIODE-LED-YELLOW-LTW-M670ZVS-BT | YELLOW |
| D6100 | DIODE-ZENER-PZ3D5V1H | SOD_2513_H110 | |
| FB3100 | BEAD-1000-OHM-100MHZ-100MA-0402 | SL0402 | 1000ohm/100MHz/100mA |
| FB3101 | BEAD-600-OHM-100MHZ-700MA-0603 | SL0603-S | 600ohm@100MHz 700mA |
| FB3106 | BEAD-1000-OHM-100MHZ-100MA-0402 | SL0402 | 1000ohm/100MHz/100mA |
| FB3107 | BEAD-1000-OHM-100MHZ-100MA-0402 | SL0402 | 1000ohm/100MHz/100mA |
| FB3108 | BEAD-1000-OHM-100MHZ-100MA-0402 | SL0402 | 1000ohm/100MHz/100mA |
| FB4100 | BEAD-470-OHM-100MHZ-0.5A-0603 | SL0603-S | 470ohm@100MHz 500mA |
| FB7200 | RES-0-0201 | SR0201 | 0 |
| FD6201 | NC-FIDUCIALMARK | PAD-FID | |
| FD6202 | NC-FIDUCIALMARK | PAD-FID | |
| FD6203 | NC-FIDUCIALMARK | PAD-FID | |
| FD6204 | NC-FIDUCIALMARK | PAD-FID | |
| J0400 | CON-RF-SWITCH-MM8430-2610RA1 | CON-RF-SWITCH-MM8430-2610RA1 | |
| J0401 | CON-RF-ARF00-0285011-0001 | CON_RF_ARF00-0285011-0001 | |
| J0402 | CON-RF-ARF00-0285011-0001 | CON_RF_ARF00-0285011-0001 | |
| J3100 | CON-EAR-J301-R05GA-MZL2 | CON-EAR-J301-R05GA-MZL2 | |
| J3103 | CON-SPRING-21-111-00200-2 | CON-SPRING-21-111-00200-2 | |
| J3104 | CON-SPRING-21-111-00200-2 | CON-SPRING-21-111-00200-2 | |
| J4100 | CON-FPC-196200-25041_REV | CON-FPC-196200-25041_REV | |
| J4107 | CON-FPC-196243-06041-3 | CON-FPC-196243-06041-3 | |
| J5100 | CON-FPC-196200-25041_REV | CON-FPC-196200-25041_REV | |
| J5101 | CON-BTB-F-OK-22NF030-04 | CON-BTB-F-OK-22NF030-04 | |
| J6100 | CON-BAT-PAN30-03193-S118 | CON-BAT-PAN30-03193-S118 | |
| J6200 | CON-USB-MICRO-HY07-AB0720 | CON-USB-MICRO-HY07-AB0720 | |
| J6201 | CON-BTB-M-AXT640224_CW | CON_BTB_M_AXT640224_CW | |
| J6400 | SOCKET-SIM-CAF99-08153-010605 | SOCKET-SIM-CAF99-08153-010605 | |
| J6402 | SOCKET-SIM-CAF99-08153-010605 | SOCKET-SIM-CAF99-08153-010605 | |
| J6500 | SOCKET-TFLASH-CAF11-08153-011401 | SKT_TFLASH_CAF11-08153-011401 | |
| J7200 | CON-RF-SWITCH-MM8030-2610RK0 | CON-RF-SWITCH-MM8030-2610RK0 | |
| L0300 | IND-POWER-2.2UH-SPH252012H2R2MT | IND-POWER-SPH2520 | 2.2uH |
| L0301 | IND-POWER-1.0UH-MLP2520W1R0M | IND_POW_MLP2520_H100 | 1.0uH |
| L0302 | IND-POWER-2.2UH-SPH252012H2R2MT | IND-POWER-SPH2520 | 2.2uH |
| L0303 | IND-POWER-1.0UH-MLP2520W1R0M | IND_POW_MLP2520_H100 | 1.0uH |
| L0305 | IND-POWER-2.2UH-SPH252012H2R2MT | IND-POWER-SPH2520 | 2.2uH |
| L0400 | IND-NF-0201 | IND-NF-0201 | NF |
| M6600 | MOTOR-F102730-15Q | PAD_2_P300_R200X400 | |
| MIC3100 | AUDIO-MIC-OF-F15PD42-11EP | AUDIO-MIC-OF-F15PD42-11EP | |
| MIC3101 | AUDIO-MIC-OB-F15LX44-1290-RCEP | AUDIO-MIC-OB-F15LX44-1290-RCEP | (NF) |
| Q6100 | TRIODE-PNP-WPT2E33-3/TR | SOT-89 | 3A |
| Q6101 | FET-N-PNM523T201E0 | SOT_3_P050_160_H090 | |
| TP6226 | CON-SPRING-818009999 | CON-SPRING-818009999 | |
| TVS3125 | TVS-ESD9L5.0ST5G | SOD_FL_1006_H040 | |
| TVS4100 | TVS-NZQA6V8XV5T1G | SOT_FL_5_P050_160_H060 | (NF) |
| TVS4102 | MLV-AVLC5S02050 | SMLV0402 | (NF) |
| TVS6200 | TVS-ESD9L5.0ST5G | SOD_FL_1006_H040 | |
| TVS6201 | TVS-ESD9L5.0ST5G | SOD_FL_1006_H040 | |
| TVS6202 | TVS-ESD5Z7.0T1G | SOD_FL_1608_H070 | (NF) |
| U0100 | ASIC-SC7731C-600-0.4 | BGA_600_P040_1330X1210_H090 | |
| U0400 | RF-SW+PA-SKY77592 | PQFN_28_P073X075_600X600_T387_H100 | |
| U0401 | RF-SAW-SAFFB1G95AA0F0A | FILTER_5_110X090_H050 | 1950MHz(NF) |
| U0402 | RF-SAW-DUPLEX-SAYEY1G95HA0F0A | FILTER_8_180X140_H060 | TxRx:1950/2140MHz |
| U0403 | RF-SAW-DUPLEX-SAYEY1G88CA0B0A | FILTER_8_180X140_H060 | TxRx:1880/1960MHz |
| U0404 | RF-BALUN-RFBLN2012090BS0T50 | FILTER_CAF_10_P050_200X125_H105 | |
| U0405 | RF-TRANSCEIVER-SR3533G | BGAS_49_P040_330X330_H079_SR3533G | |
| U0406 | RF-PA-SKY77761 | RF-PA-SKYWORKS-3X3-10PIN | |
| U0407 | RF-PA-SKY77762 | RF-PA-SKYWORKS-3X3-10PIN | |
| U0409 | RF-PA-SKY77768 | RF-PA-SKYWORKS-3X3-10PIN | |
| U0410 | RF-SAW-DUPLEX-SAYEY897MHA0F0A | FILTER_8_180X140_H060 | TxRx:897.5/942.5MHz |
| U0412 | RF-SWITCH-EC278 | QFN2X2-12-P0.5-T0.9X0.9 | (NF) |
| U0500 | MEM-NAND+LPDDR2-MT29RZ4C4DZZHGPL-18 | BGA_162_P050_1150X1300_H080 | |
| U4105 | POWER-DC2DC-WD3119E-6/TR | SOT_6_P095_280_H130 | |
| U5200 | SENSOR-MOTION-LIS3DH | PQFN_16_P050_300X300_H100 | |
| U5202 | SENSOR-LIGHT+PROX-EPL21822KVWJP | SENSOR-LIGHT+PROX-EPL21822KVWJP | |
| U7200 | BT+WIFI+FM+GPS-SR2351C | BT+WIFI+FM+GPS-SR2351 | |
| U7201 | RF-SAW-DPX-DPX1608LL87R1524A | RF-SAW-DPX-1.6X0.8-YAGEO | 1.5/2.4GHz |
| U7202 | RF-SAW-LFB212G45CL1D172 | RF-SAW-LFB212G45CL1D172 | |
| U7203 | RF-SAW-SAFFB1G57KE0F0A | RF-SAW-1.1X0.9 | 1575.42MHz |
| U7204 | RF-LNA-GPS-BGU8009 | RF-LNA-GPS-BGU8009 | |
| U7206 | RF-SW+PA-2.4G-SR2319A | RF-SW+PA-2.4G-SR2319A | |
| X0200 | 32.768K-Q-SC32S0322070AAAF | XTAL_CC_320X150_H085 | 32.768KHz |
| X0401 | XTAL-TCXO-26MHZ-1XXB26000MAB | OSC_CC_250X200_H090_KDS | 26MHz(NF) |
| Y7200 | XTAL-TCXO-26MHZ-1XXB26000MAB | OSC_CC_250X200_H090_KDS | 26MHz |
