| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| 1D1 | SCHOTTKY_SOD123H14A_B5819W | B5819W | SOD123H14A |
| 1D2 | DIODENN_SOT-23_BAT54C | BAT54C | SOT-23 |
| 1D3 | SCHOTTKY_SOD123H14A_B5819W | B5819W | SOD123H14A |
| 1D4 | SCHOTTKY_SOD123H14A_B5819W | B5819W | SOD123H14A |
| 1D5 | SCHOTTKY_SOD123H14A_B5819W | B5819W | SOD123H14A |
| 1J1 | DC-05-06_DC_SMD_5PIN_DC-SUNTY7.85 | DC-Sunty7.85 | DC_SMD_5PIN |
| 1L1 | INDUCTOR_POWER_L5050_1UH_3A_5018 | 1uH_3A_5018 | L5050 |
| 1L2 | INDUCTOR_POWER_L5050_1UH_3A_5018 | 1uH_3A_5018 | L5050 |
| 1L3 | INDUCTOR_POWER_L5050_1UH_3A_5018 | 1uH_3A_5018 | L5050 |
| 1L4 | INDUCTOR_POWER_L4040_2.2UH_2A | 2.2uH_2A | L4040 |
| 1L5 | INDUCTOR_POWER_L4040_2.2UH_2A | 2.2uH_2A | L4040 |
| 1L6 | INDUCTOR_POWER_L4040_2.2UH_2A | 2.2uH_2A | L4040 |
| 1Q1 | MOSFETP_21_SOT-23_WPM2026 | WPM2026 | SOT-23 |
| 1SW2 | BUTTON_7PIN_SW-ST1114RA_NC/RESET_KEY | NC/Reset_KEY | SW-ST1114RA |
| 1TP1 | CON1_SPAD_CON1 | CON1 | SPAD |
| 1TP2 | CON1_SPAD1_CON1 | CON1 | SPAD1 |
| 1TP3 | CON1_SPAD_CON1 | CON1 | SPAD |
| 1U2 | RN5T618_QFN48-PT04-6X6MM_RN5T618M | RN5T618M | QFN48-PT04-6X6MM |
| 1U3 | ZEN056_0_ZEN056_NC/ZEN056 | NC/ZEN056 | ZEN056 |
| 1U4 | BF1303_SOT23-5_WL2803E12-5 | WL2803E12-5 | SOT23-5 |
| 1U5 | BOOST-SOT236_SOT23-6_SY7208C/SY7152 | SY7208C/SY7152 | SOT23-6 |
| 1U6 | SY8009BABC_SOT23-6_SY8009BABC/2A | SY8009BABC/2A | SOT23-6 |
| 1U7 | BF1303_SOT23-5_WL2801E18-5 | WL2801E18-5 | SOT23-5 |
| 1U9 | BF1303_SOT23-5_NC/WL2801E28-5 | NC/WL2801E28-5 | SOT23-5 |
| 2J1 | CON4P_0_CON4-PT2MM-JTAG_NC/CON4P | NC/CON4P | CON4-PT2MM-JTAG |
| 2Y1 | CRYSTAL_1_XT-MC_146_XTAL_32.768KHZ | XTAL_32.768KHz | XT-MC_146 |
| 2Y2 | SMD_CRYSTAL_XT-SMD4P3225_24MHZ_12PF_20PPM | 24MHz_12pF_20PPM | XT-SMD4P3225 |
| 3C13 | CAPNP_C0603_10UF_6.3V | 10uF_6.3V | C0603 |
| 3TP2 | T POINTR_TEST08_T\POINT\R | T\POINT\R | TEST08 |
| 3U4 | DDR3_96P_16B_2CE_BGA96-0P8MM_H5TQ4G63AFR-PBC | H5TQ4G63AFR-PBC | BGA96-0P8MM |
| 3U5 | DDR3_96P_16B_2CE_BGA96-0P8MM_H5TQ4G63AFR-PBC | H5TQ4G63AFR-PBC | BGA96-0P8MM |
| 4C1 | CAPNP_C0402_NC/0.1UF | NC/0.1uF | C0402 |
| 4C2 | CAPNP_C0402_NC/1UF_6.3V | NC/1uF_6.3V | C0402 |
| 4U2 | EMMC_V50_BGA169-INAND_NC/SDIN7DP2-8G | NC/SDIN7DP2-8G | BGA169-INAND |
| 4U3 | TSD_FLASH_TSOP-48_NC/TSTS35-04G/NCTSXXX2-04G-08G | /TSTS35-04G/NCTSXXX2-04G-08G | TSOP-48 |
| 4U4 | 24C02A_6_SOIC-8-150MIL_NC/512KBYTE_SPI_NOR | NC/512KByte_SPI_Nor | SOIC-8-150MIL |
| 4U5 | NAND-ALL_11_TSOP-48_29F32G08CBACA | 29F32G08CBACA | TSOP-48 |
| 4U6 | NAND-ALL_11_TSOP-48_NC/29F32G08CBACA | NC/29F32G08CBACA | TSOP-48 |
| 5D1 | SCHOTTKY_SOD123H14A_B5819W | B5819W | SOD123H14A |
| 5J1 | B079XAN01_CON36-B079XAN01_B079XAN01 | B079XAN01 | CON36-B079XAN01 |
| 5L1 | INDUCTOR_POWER_L4040_10UH_1.2A | 10uH_1.2A | L4040 |
| 5Q2 | MOSFETP_21_SOT-23_WPM2026 | WPM2026 | SOT-23 |
| 5R1 | RESISTOR_R0402_10K | 10K | R0402 |
| 5R7 | RESISTOR_R0805_1.62R_1% | 1.62R_1% | R0805 |
| 5R8 | RESISTOR_R0402_1.65K_1% | 1.65K_1% | R0402 |
| 5R10 | RESISTOR_R0402_10K | 10K | R0402 |
| 5R11 | RESISTOR_R0402_10K_1% | 10K_1% | R0402 |
| 5R12 | RESISTOR_R0402_100K_1% | 100K_1% | R0402 |
| 5R14 | RESISTOR_R0402_NC/10K | NC/10K | R0402 |
| 5R16 | RESISTOR_R0402_536R_1% | 536R_1% | R0402 |
| 5R17 | RESISTOR_R0402_47K | 47K | R0402 |
| 5R18 | RESISTOR_R0402_470K | 470K | R0402 |
| 5R19 | RESISTOR_R0402_NC/1K | NC/1K | R0402 |
| 5U2 | AT1312_0_SOT23-6_SY7200AABC | SY7200AABC | SOT23-6 |
| 6C1 | CAPNP_C0402_0.1UF | 0.1uF | C0402 |
| 6C2 | CAPNP_C0402_1NF | 1nF | C0402 |
| 6C3 | CAPNP_C0402_1NF | 1nF | C0402 |
| 6C4 | CAPNP_C0402_NC/10PF | NC/10pF | C0402 |
| 6C5 | CAPNP_C0402_1UF_6.3V | 1uF_6.3V | C0402 |
| 6C6 | CAPNP_C0402_1NF | 1nF | C0402 |
| 6C7 | CAPNP_C0805_22UF_6.3V | 22uF_6.3V | C0805 |
| 6C8 | CAPNP_C0603_10UF_6.3V | 10uF_6.3V | C0603 |
| 6C9 | CAPNP_C0402_1UF_6.3V | 1uF_6.3V | C0402 |
| 6CON1 | JP_USB-0400ASMT_USB-P0565-H24-0336_MICROUSB PORT | Micro USB Port | USB-P0565-H24-0336 |
| 6D8 | DIODESCHOTTKY_D0402_AZ5725-01F | AZ5725-01F | D0402 |
| 6FB1 | FB0805_0_L0805_120R/100MHZ_3A | 120R/100MHz_3A | L0805 |
| 6J1 | CON-4PIN_SMD_FPC4-PT05-L_FPC-4PIN | FPC-4PIN | FPC4-PT05-L |
| 6L1 | L_EXD24CD900U_0_L0805X2_NC/EXD24CD900U | NC/EXD24CD900U | L0805X2 |
| 6U2 | TFCARD_TFC-01B_TF_SD_SOCKET | TF_SD_SOCKET | TFC-01B |
| 6U3 | U_RT9701_2_SOT23-5_SY6280AAAC | SY6280AAAC | SOT23-5 |
| 7FM1 | T POINTR_TEST08_T\POINT\R | T\POINT\R | TEST08 |
| 7FM2 | T POINTR_TEST08_T\POINT\R | T\POINT\R | TEST08 |
| 7J1 | ANT_0_MS-156_NC | NC | MS-156 |
| 7L1 | INDUCTOR_1_L3030_NC/3.3UH_1A | NC/3.3uH_1A | L3030 |
| 7M1 | AP6493_6XXX_QFN44-PT09MM_NC/AP6210 | NC/AP6210 | QFN44-PT09MM |
| 7Q1 | MOSFETP_21_SOT-23_WPM2015 | WPM2015 | SOT-23 |
| 7Q2 | T_NPN_SOT-23_PMBT3904 | PMBT3904 | SOT-23 |
| 7TP3 | T POINTR_TEST08_T\POINT\R | T\POINT\R | TEST08 |
| 7U1 | EM78P372_1_WF-UM02BS_RTL8188-EUS | RTL8188-EUS | WF-UM02BS |
| 7U4 | NL27WZU04_SOT23-6_NC/NL27WZU04DTT1G | NC/NL27WZU04DTT1G | SOT23-6 |
| 7Y2 | SMD_CRYSTAL_XT-SMD4P3225_NC/26M_16PF_10PPM | NC/26M_16pF_10ppm | XT-SMD4P3225 |
| 7Y3 | SMD_CRYSTAL_XT-SMD4P3225_NC/26M_16PF_10PPM | NC/26M_16pF_10ppm | XT-SMD4P3225 |
| 8FB2 | FB0805_0_L0603_120R/100MHZ_0.3A | 120R/100MHz_0.3A | L0603 |
| 8U5 | MMA8653FC_DFN10-PT04_MMA8653FC | MMA8653FC | DFN10-PT04 |
| 8U7 | MMA8452Q_QFN16-PT1-3X3_NC/MMA8452Q | NC/MMA8452Q | QFN16-PT1-3X3 |
| 8U8 | MPU-6885A_QFN24-PT04_NC/MPU-6500A | NC/MPU-6500A | QFN24-PT04 |
| 9CN1 | GC0328_FPC24-PT05-R_GC0308-30M | GC0308-30M | FPC24-PT05-R |
| 9D2 | DIODESCHOTTKY_D0402_AZ5725-01F | AZ5725-01F | D0402 |
| 9D3 | DIODESCHOTTKY_D0402_AZ5725-01F | AZ5725-01F | D0402 |
| 9FB1 | FB0805_L0603_120R/100MHZ_0.3A | 120R/100MHz_0.3A | L0603 |
| 9J1 | HDMI_C_HDMI_JSHD_006_HDMI_C | HDMI_C | HDMI_JSHD_006 |
| 9Q2 | MOSFETP_4_SOT-23_WNM2016 | WNM2016 | SOT-23 |
| 9Q3 | MOSFETP_4_SOT-23_WNM2016 | WNM2016 | SOT-23 |
| 9U2 | RCLAMP0524P_ESD-RCLAMP0524P_AZ1045-04F | AZ1045-04F | ESD-RCLAMP0524P |
| 9U3 | RCLAMP0524P_ESD-RCLAMP0524P_AZ1045-04F | AZ1045-04F | ESD-RCLAMP0524P |
| 9U4 | BF1303_SOT23-5_NC/WL2801E15-5 | NC/WL2801E15-5 | SOT23-5 |
| AFB1 | FB0805_L0603_0R | 0R | L0603 |
| AFB2 | FB0805_L0603_0R | 0R | L0603 |
| AJ1 | CON5_2_JH-RD-W06_ST-0279D00-061-182 | ST-0279D00-061-182 | JH-RD-W06 |
| AL+1 | CON1_SPAD_CON1 | CON1 | SPAD |
| AL-1 | CON1_SPAD_CON1 | CON1 | SPAD |
| AMK1 | MICROPHONE_0_MIC-6027C_MICROPHONE | MICROPHONE | MIC-6027C |
| AU2 | AW8010A_BGA12-PT05_AW8010AFCR | AW8010AFCR | BGA12-PT05 |
| CCA1 | TF2010A4X_EMI-TF2010A4X_4X0R/TF2010A4X900MT | 4X0R/TF2010A4X900MT | EMI-TF2010A4X |
| CCA2 | TF2010A4X_EMI-TF2010A4X_4X0R/TF2010A4X900MT | 4X0R/TF2010A4X900MT | EMI-TF2010A4X |
| EC4 | CAPNP_C0402_1UF_6.3V | 1uF_6.3V | C0402 |
| ECN1 | CON-6PIN_FPC6-PT05-R_CN_TOUCH | CN_TOUCH | FPC6-PT05-R |
| ED1 | DIODESCHOTTKY_D0402_NC/AZ5725-01F | NC/AZ5725-01F | D0402 |
| ED2 | DIODESCHOTTKY_D0402_NC/AZ5725-01F | NC/AZ5725-01F | D0402 |
| EFB1 | FB0805_L0603_120R/100MHZ_0.3A | 120R/100MHz_0.3A | L0603 |
| ER1 | RESISTOR_R0402_1K | 1K | R0402 |
| ER2 | RESISTOR_R0402_NC/0R | NC/0R | R0402 |
| ER3 | RESISTOR_R0402_NC/4.7K | NC/4.7K | R0402 |
| ER7 | RESISTOR_R0402_NC/10K | NC/10K | R0402 |
| U1 | AML-M802_BGA531_0P65_M801 | M801 | BGA531_0P65 |
