| BD1 | KBP310_SIP4X150_KBP310 | KBP310 | SIP4X150 |
| CON1 | CON3X1-7P62MM_DIP_3PIN_5_08V_PS | PS-WFR-003 | DIP_3PIN_5_08 |
| D1 | D-FR107_DIODE_DIP200_50_FR107 | FR107 | DIODE_DIP200_50 |
| D2 | D-P6KE200A_DIODE_DIP400_40_P6KE | P6KE13A | DIODE_DIP400_40 |
| D3 | FUSE_250V_3P15A_F350X150_50_FUS | FUSE_250V_3P15A | F350X150_50 |
| D4 | D-P6KE200A_DIODE_DIP400_40_P6KE | P6KE13A | DIODE_DIP400_40 |
| D5 | D-FR107_DIODE_DIP200_50_FR107 | FR107 | DIODE_DIP200_50 |
| D7 | D-P6KE200A_DIODE_DIP400_40_P6KE | P6KE13A | DIODE_DIP400_40 |
| D8 | D-V20100C_V20100C_V20100C | V20100C | V20100C |
| D9 | D-P6KE200A_DIODE_DIP400_40_P6KE | P6KE13A | DIODE_DIP400_40 |
| D10 | D-LL4148_LL4148_LL4148 | LL4148 | LL4148 |
| D11 | D-ZMM5245B_DIODE_150X60_ZMM5245 | ZMM5245B | DIODE_150X60 |
| J2 | DIP180-CON2X1-2P54MM_DIP_2PIN_5 | PS-WF-00020 | DIP_2PIN_5_08 |
| L1 | INDUCTOR_L1206_1MH_(T:WE480X440 | 1mH | L1206 |
| L2 | INDUCTOR_L1206_1MH_(T:WE480X440 | 1mH | L1206 |
| LF1 | INS_COM_3.3MH_LF2_INS_COM_3.3MH | INS_COM_3.3mH | LF2 |
| Q3 | MOSFET-N-60V-7.6A-SUD23N06_TO-2 | SUD23N06 | TO-252 |
| Q5 | MOSFET-P--55V--31A-IRF5305_TO-2 | IRF5305 | TO-252 |
| Q6 | MOSFET-N-60V-7.6A-SUD23N06_TO-2 | SUD23N06 | TO-252 |
| Q10 | LT6106HS5_SOT-25_LT6106HS5 | LT6106HS5 | SOT-25 |
| Q11 | D-TL431_SOT-23_TL431 | TL431 | SOT-23 |
| S2 | SRX-YI25_SRX-YI20_SRX-YI20 | SRX-YI20 | SRX-YI20 |
| T1 | EI28_EI28_EI28 | EI28 | EI28 |
| U1 | PC817B_PC817B_PC817B | PC817B | PC817B |
| U2 | TOP254YN_TO-220-7C_TOP254YN | TOP254YN | TO-220-7C |
| U3 | LM393_SO-8_LM393 | LM393 | SO-8 |
| U4 | LM393_SO-8_LM393 | LM393 | SO-8 |
| CAP4 | CAP_X_AC275V_100NF_CAP13X6_10_C | CAP_X_AC275V_100nF | CAP13X6_10 |
| CAP8 | CAP_Y_AC250V_1NF_CAP10_CAP_Y_AC | CAP_Y_AC250V_1nF | CAP10 |
| CAP10 | CAP_Y_AC250V_1NF_CAP10_CAP_Y_AC | CAP_Y_AC250V_1nF | CAP10 |
| D10 | DIODE_2_SMA_B340A | B340A | SMA |
| D11 | FUSE_250V_3P15A_F350X150_50_FUS | FUSE_250V_3P15A | F350X150_50 |
| D15 | 1N4148_SOD-323_1N4148WS | 1N4148WS | SOD-323 |
| D16 | P3100_1_SMA_BS0080M | BS0080M | SMA |
| D17 | DIODE TAZ BI-DIR_R1812_BA201N | BA201N | R1812 |
| D18 | P3100_1_SMA_BS0080M | BS0080M | SMA |
| D19 | DIODE TAZ BI-DIR_R1812_BA201N | BA201N | R1812 |
| D20 | P3100_1_SMA_BS0080M | BS0080M | SMA |
| D21 | DIODE TAZ BI-DIR_R1812_BA201N | BA201N | R1812 |
| D24 | ESD5Z5.0T1_SOD-523_ESD5Z12T1-G | ESD5Z12T1-G | SOD-523 |
| D26 | ESD5Z5.0T1_SOD-523_ESD5Z5.0T1/N | ESD5Z5.0T1/NC | SOD-523 |
| D27 | ESD5Z5.0T1_SOD-523_ESD5Z5.0T1/N | ESD5Z5.0T1/NC | SOD-523 |
| D30 | 1N4148_SOD-323_1N4148WS | 1N4148WS | SOD-323 |
| D31 | ESD5Z5.0T1_SOD-523_ESD5Z12T1-G | ESD5Z12T1-G | SOD-523 |
| FB7 | FBEAD_1_R0805_FBEAD | FBEAD | R0805 |
| H1 | TEST POINT_1_MC40_HOLE | HOLE | MC40 |
| J1 | CON3_4_DIP_7PIN_5_08_7P 7.62MM | 7P 7.62mm | DIP_7PIN_5_08 |
| J2 | CON10X2_8_DIP-22-2M0_DIP-22-2.0 | DIP-22-2.0 | DIP-22-2M0 |
| J3 | CON10X2_8_DIP-22-2M0_CON10X2_8 | CON10X2_8 | DIP-22-2M0 |
| J7 | SIP7_9_SIP_5P_1M5_CON5 | CON5 | SIP_5P_1M5 |
| J8 | SIP7_6_V4-2M0_V4-2M0 | V4-2M0 | V4-2M0 |
| J9 | CON14_PS-WFR-114_CON14 | CON14 | PS-WFR-114 |
| J10 | CON4_SIP_4P_1_5-SKT_CON4 | CON4 | SIP_4P_1_5-SKT |
| J12 | CON14_PS-WFR-114_CON14 | CON14 | PS-WFR-114 |
| J13 | SIP7_9_SIP_5P_1M5_CON5 | CON5 | SIP_5P_1M5 |
| JQ1 | HFD23_HFD23012-1Z_HFD23/012-1ZS | HFD23/012-1ZS/555 | HFD23012-1Z |
| JQ2 | HFD23_HFD23012-1Z_HFD23/012-1ZS | HFD23/012-1ZS/555 | HFD23012-1Z |
| L1 | IND_0603L_L-8M3X8M3_6.8UH/3A-SM | 6.8uH/3A-SMDRH8D43-6R8M | L-8M3X8M3 |
| L2 | INDUCTOR_L1806_BLM41PG750SN1 | BLM41PG750SN1 | L1806 |
| L3 | IND_0603L_L-8M3X8M3_6.8UH/3A-SM | 6.8uH/3A-SMDRH8D43-6R8M | L-8M3X8M3 |
| L4 | INDUCTOR_L1806_BLM41PG750SN1 | BLM41PG750SN1 | L1806 |
| L5 | IND_0603L_L-8M3X8M3_6.8UH/3A-SM | 6.8uH/3A-SMDRH8D43-6R8M | L-8M3X8M3 |
| L6 | INDUCTOR_L1806_BLM41PG750SN1 | BLM41PG750SN1 | L1806 |
| L7 | IND_0603L_L-8M3X8M3_6.8UH/3A-SM | 6.8uH/3A-SMDRH8D43-6R8M | L-8M3X8M3 |
| L8 | INDUCTOR_L1806_BLM41PG750SN1 | BLM41PG750SN1 | L1806 |
| PTC1 | R_0_R1812_MF-MSMF150/24X | MF-MSMF150/24X | R1812 |
| R116 | R_R0603_0_(SIP_2P_2_54) | 0 | SIP_2P_2_54 |
| R117 | R_R0603_0_(SIP_2P_2_54) | 0 | SIP_2P_2_54 |
| T1 | H1102_0_PM-16-12M7X9M4-1M27_PM4 | PM44-11BG | PM-16-12M7X9M4-1M27 |
| TP6 | TESTPIN_TEST_1_GND | GND | TEST_1 |
| TP7 | TESTPIN_TEST_1_GND | GND | TEST_1 |
| U2 | AC127-DC12_2_DIANYUAN3_CFA25S12 | CFA25S12W | DIANYUAN3 |
| U6 | TPS5420_2_SO-8-4M9X6M-1M27_TPS5 | TPS54331D | SO-8-4M9X6M-1M27 |
| U10 | SLVU2.8-4_SO-8-5MX4M-1M27_SLVU2 | SLVU2.8-4 | SO-8-5MX4M-1M27 |
| U13 | MAX485EESA_SO-8-4M9X6M-1M27_MAX | MAX13085EESA | SO-8-4M9X6M-1M27 |
| U14 | TCMT1100_0_SMD4-2M8X7M-1M27_TCM | TCMT1100 | SMD4-2M8X7M-1M27 |
| U15 | TCMT1100_0_SMD4-2M8X7M-1M27_TCM | TCMT1100 | SMD4-2M8X7M-1M27 |
| U16 | MAX3221_SO_16_0M65_MAX3221IPW | MAX3221IPW | SO_16_0M65 |
| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| D11 | DIODE_2_SMA_B340A | B340A | SMA |
| D12 | DIODE_3_SMA_B340A | B340A | SMA |
| GND | TEST POINT SMD1_1.0_STP40_TEST | TEST POINT SMD1.0 | STP40 |
| J3 | SIP7_9_SIP_5P_1M5_CON5 | CON5 | SIP_5P_1M5 |
| J8 | HEADER 8_0_DIP_4PIN_3_5_SHORT_P | PLTB1.5-02-SF-3.50 | DIP_4PIN_3_5_SHORT |
| J10 | SIP7_6_V4-2M0_V4-2M0 | V4-2M0 | V4-2M0 |
| L11 | INDUCTOR_L1806_BLM41PG750SN1 | BLM41PG750SN1 | L1806 |
| L12 | IND_0603L_L-8M3X8M3_6.8UH/3A-SM | 6.8uH/3A-SMDRH8D43-6R8M | L-8M3X8M3 |
| T2 | H1102_0_PM-16-12M7X9M4-1M27_PM4 | PM44-11BG | PM-16-12M7X9M4-1M27 |
| U7 | TPS5420_0_SO-8-4M9X6M-1M27_AT24 | AT24C02 | SO-8-4M9X6M-1M27 |
| U8 | KS8995M_1_KS8995MA_KS8995M | KS8995M | KS8995MA |
| U11 | SLVU2.8-4_SO-8-5MX4M-1M27_SLVU2 | SLVU2.8-4 | SO-8-5MX4M-1M27 |
| U12 | 2X5 1_0.3GBIT TRANSCEIVER_1X9FI | 1x9/SC/SIP | 1X9FIBER |
| U18 | TPS5420_2_SO-8-4M9X6M-1M27_TPS5 | TPS54331D | SO-8-4M9X6M-1M27 |
| U19 | 2X5 1_0.3GBIT TRANSCEIVER_1X9FI | 1x9/SC/SIP | 1X9FIBER |
| U21 | LM350/TO3_2_SOT_223_AMS1117/(SO | AMS1117/(SOT-223) | SOT_223 |
| VNET_1V8 | TEST POINT SMD1_1.0_STP40_TEST | TEST POINT SMD1.0 | STP40 |
| Y2 | CYSTAL-SMD4_XTL3225_25M | 25M | XTL3225 |
| 1V2 | TEST POINT_TEST_VCC_1V2 | VCC_1V2 | TEST |
| BT1 | BAT_HB414-IV01E_HB414-IV01E | HB414-IV01E | HB414-IV01E |
| D6 | ESD5Z5.0T1_SOD-523_ESD5Z5.0T1 | ESD5Z5.0T1 | SOD-523 |
| D27 | DIODE_0_SMA_B1100 | B1100 | SMA |
| D30 | MAX809_SOT23_MAX809R/NC | MAX809R/NC | SOT23 |
| D32 | DIODE_4_SOD-323_1SS355 | 1SS355 | SOD-323 |
| D34 | ESD5Z5.0T1_SOD-523_ESD5Z5.0T1 | ESD5Z5.0T1 | SOD-523 |
| D46 | D-B320A_SMA_B240A | B240A | SMA |
| E1 | FILTER_3_PIN_NFM18C_NFM18CC223R | NFM18CC223R1C3/NC | NFM18C |
| J1 | HEADER 2_SIP_2P_1_27-SKT_HEADER | HEADER 2X1.27 | SIP_2P_1_27-SKT |
| J2 | HEADER 6_SIP_6P_1_27W-SKT_HEADE | HEADER 6 | SIP_6P_1_27W-SKT |
| J5 | CON10X2_8_DIP-22-2M0_DIP-22-2M0 | DIP-22-2M0 | DIP-22-2M0 |
| J8 | CON5_SIP_5P_1_5-SKT_CON5-1.5 | CON5-1.5 | SIP_5P_1_5-SKT |
| J14 | HEADER 30_USL30_0_4_USL00-30L-C | USL00-30L-C | USL30_0_4 |
| J17 | HEADER 21X2_FPC40_0_5L_FPC40/0. | FPC40/0.5L | FPC40_0_5L |
| J22 | CON10X2_8_DIP-22-2M0_DIP-22-2M0 | DIP-22-2M0 | DIP-22-2M0 |
| J23 | SIP7_6_V4-2M0_V4-2M0 | V4-2M0 | V4-2M0 |
| J24 | SIP7_6_SIP_4P_1_5-SKT_V4-2M0 | V4-2M0 | SIP_4P_1_5-SKT |
| J25 | HEADER 7X2_DIP2X7_14 | 14 | DIP2X7 |
| L2 | L0805_221SN1D_L0805_BLM21PG221S | BLM21PG221SN1D | L0805 |
| Q1 | ASM811SEUS-T_SOT143_PT7M7811TTB | PT7M7811TTBE | SOT143 |
| Q2 | MMBT3904_SOT-23_MMBT3904 | MMBT3904 | SOT-23 |
| Q3 | TLV1117IDCYR_0_SOT-223_TLV1117D | TLV1117DCYR | SOT-223 |
| Q4 | MMBT3904_SOT-23_MMBT3904 | MMBT3904 | SOT-23 |
| RN17 | RESISTOR DIP 8_1_R8-0402_RN8-22 | RN8-22 | R8-0402 |
| RN19 | RPACK4_0_R4-0402_RN4-22 | RN4-22 | R4-0402 |
| U1 | LCMXO2-1200-TG100_VQ100_LCMXO2- | LCMXO2-1200-TG100 | VQ100 |
| U3 | MEMORY-NAND-128MX8BITS-TSOP48_T | K9F1G08U0C | TSOP48 |
| U6 | MT47H64M16BT-5E_0_FBGA84_K4T1G1 | K4T1G164QF-BCF7 | FBGA84 |
| U8 | DAVINCIHD | TMS320DM6467TZUT1 | BGA_23X23_0P8MM |
| U9 | AT88SC0104C_SOP8_AT88SC0104CA | AT88SC0104CA | SOP8 |
| U12 | HT1381_1_TSSOP8_S-35390A-T8T1G | S-35390A-T8T1G | TSSOP8 |
| U13 | TLV320AIC23_TSSOP-28-4M5X9M8-0M | TLV320AIC23BPWR | TSSOP-28-4M5X9M8-0M65 |
| U14 | S-24C02C_SOP8_S-24C02CI-J8T1U | S-24C02CI-J8T1U | SOP8 |
| U15 | RTL8169S_4_QFN32_RTL8201E | RTL8201E | QFN32 |
| Y1 | 24MHZ_XTAL | 24MHz | OSC-3225 |
| Y2 | 33MHZ_XTAL | 33MHz | OSC-3225 |
| Y4 | 12MHZ_XTAL | 12MHz | OSC-3225 |
| Y5 | OSC4/SM_1_OSC-4-3M2X2M5_27MHZ | 27MHz | OSC-4-3M2X2M5 |
| Y7 | ZTB_3_SSP-T7_32.768KHZ | 32.768KHz | SSP-T7 |
| Y8 | 25MHZ_XTAL | 25MHz | OSC-3225 |
