重要提示:PCB作品文件展下载说明
| Name | Part Type | PCB Decal | Value | | CN11 | PHONEJACK_STEREO_SW_8 | AUDIO-DW8.3X14.5 | Line in | | CN20 | 8_HEADER_1 | JP-H4X2.0 | NC/4X2.0 | | CN21 | 8_HEADER_1 | JP-H4X2.0 | NC/4X2.0 | | CN103 | CON5_3 | 3PIN/2.0MM_NO-TESTPAD | 3Pin/2.0MM | | CN201 | HEADER_4_6 | 2PIN/2.0MM_NO-TESTPAD | 2Pin/2.0mm | | CN203 | HEADER_4_6 | 2PIN/2.0MM_NO-TESTPAD | 2Pin/2.0mm | | CN602 | DVI_0 | DVI-W24 | 74320-1004 | | CNF2 | FI-RE41S-HF_1 | FIRE-41MR-0.5 | NC | | CNF6 | FI-RE41S-HF_5 | FIRE-51MR-0.5-SLK-A | WF23-400-513C | | CON4 | HEADER_7X2_2 | 8PIN/2.0MM_NO-TESTPAD | 8pin/2.0MM | | CON5 | HEADER_7X2_34 | 5PIN/2.0MM_NO-TESTPAD | 5pin/2.0MM | | CON11 | HEADER_7X2_1 | 12PIN/2.0MM_NO-TESTPAD | 12pin/2.0MM | | D1 | DIODE | D-SMAS-1206 | SS34 | | D5 | ZC2800E/SOT_1 | D-SOD323S | UDZ5.6B | | D6 | ZC2800E/SOT_1 | D-SOD323S | UDZ5.6B | | D8 | BAT54CW-F | Q-SOT23 | BAT54CW-F | | D22 | BAT54CW-F | Q-SOT23 | NC/BAT54CW-F | | D32 | ZC2800E/SOT_1 | D-SOD323S | UDZ5.6B | | D33 | ZC2800E/SOT_1 | D-SOD323S | UDZ5.6B | | D34 | BAT54CW-F | Q-SOT23 | BAT54CW-F | | D43 | BAT54CW-F | SOT23 | BAT54CW-F | | D44 | ZC2800E/SOT_2 | ZD0805 | NC/UDZ5.6B | | D45 | BAS70-04/SOT | BAV99-SOT23 | BAV99 | | D46 | BAS70-04/SOT | BAV99-SOT23 | BAV99 | | D47 | BAS70-04/SOT | BAV99-SOT23 | BAV99 | | D48 | DIODE_1 | SOD323 | 1N4148WS | | D204 | 1_2.5KE10CA | D1206 | 1N4148 | | D205 | 1_2.5KE10CA | D1206 | 1N4148 | | DP1 | DISPLAY_PORT_1 | MOLEX\47272 | DISPLAY_PORT-CON | | E2 | ESD_4 | RV-0603 | NC_5pF | | E3 | ESD_4 | RV-0603 | NC_5pF | | F4 | FUSE | R0603 | 0R | | H5 | JQIRMI | PMARKA | mark | | H6 | JQIRMI | PMARKA | mark | | H7 | ORIENTATION_4 | SCREW3.5RM | orientation | | H8 | JQIRMI | PMARKA | mark | | H9 | JQIRMI | PMARKA | mark | | HDMI1 | CON34_3 | HDMI-S19X0.5-23 | HDMI-CON | | HDMI2 | CON34_3 | HDMI-S19X0.5-23 | HDMI-CON | | L1 | INDUCTOR_IRON_0 | L1206 | NC/FEB_1206 | | L14 | INDUCTOR | L0603 | 0£[ | | L21 | INDUCTOR_IRON_0 | L1206 | FEB_1206 | | L22 | INDUCTOR_IRON_0 | L1206 | NC/FEB_1206 | | L24 | INDUCTOR_IRON_2 | SMD08X08 | SWPA8040S2R2NT/4A | | L26 | INDUCTOR_IRON_2 | IND-4X4 | SWPA3015S2R2NT/1.5A | | L1204 | INDUCTOR_IRON_2 | SMD08X08 | SWPA8040S4R7NT/4A | | LW3 | L | L0805 | BEAD/60R/0805 | | LW4 | L | L0805 | BEAD/60R/0805 | | LW5 | L | L0805 | BEAD/60R/0805 | | Q7 | TRX_NPN-O | Q-SOT23 | MMBT3904LT1G | | Q8 | MOSFET_P_GSD | Q-SOT23 | NC/AO3401 | | Q10 | PNP_0_2 | Q-SOT23 | PMBT3906L | | Q11 | PNP_0_2 | Q-SOT23 | PMBT3906L | | Q12 | MMBT3904L_0 | Q-SOT23 | LMBT3904LT1G | | Q15 | MOSFET_P_GSD_2 | Q-SOT23 | AO3401 | | Q16 | NPN_3 | Q-SOT23 | PMBT3904 | | Q23 | MOSFET_P_GSD_2 | Q-SOT23 | NC/AO3401 | | Q24 | PNP_0 | Q-SOT23 | SST3906F | | Q25 | NPN_3 | Q-SOT23 | PMBT3904 | | Q26 | NPN | Q-SOT23 | 2N3904 | | Q27 | NPN | Q-SOT23 | 2N3904 | | Q39 | NPN(BEC)_0 | SOT-23 | 3904 | | Q206 | PNP_3 | SOT-23 | 3906 | | S1 | SOT223-GOI-1234_14 | SINK_58X58MM | PB | | U7 | LT1086_2 | U-SOT223 | 1117/3.3V | | U9 | STS7PF30L | U-SOP8/1.3 | 9435 | | U10 | CS4334_2 | RT9026_MSOP-10 | RT9026 | | U11 | BGA_34 | BGA1024_P0_8_27X27 | BGA_32X32 | | U13 | X24C04_0 | U-SOP8/1.3 | X24C16 (SMD) | | U15 | VGA_CON15_0 | 15P229-2F | VGA_CON15 | | U16 | SOIC8/P1.27/7_0.98 | U-SOP8A/1.3 | SFLASH | | U17 | 2421_6 | U-SOT23-5 | UP7534GMA5 | | U18 | SOT-223 | TO-252_NEW | AMS1117L-3.3 | | U20 | PAM2301 | SOT-23-5 | SY8088B | | U21 | SOT-223 | TO-252_NEW | AMS1117L-3.3 | | U22 | AOZ1036_32 | DFN2X2-8 | SY8805 | | U23 | AOZ1036_32 | DFN2X2-8 | SY8805 | | U201 | TPA3110D2_1 | TSSOP-28 | TPA3110LD2 | | UD3 | DDR2_9 | DDR3 | DDR3 | | UD4 | DDR2_9 | DDR3 | DDR3 | | UDDC6 | 2421_0 | SO08 | 24C02 | | UX16 | CS4334_1 | RCLAMP524P | NC/RClamp0524P | | Y3 | CRYSTAL_0 | Y-DH5 | 14.318MHz |
重要提示:PCB作品文件展下载说明
