重要提示:PCB作品文件展下载说明
| Name | Part Type | PCB Decal | Value | | CN102 | INVERTER_1 | CN6-20A | CON6-2.0 | | CN201 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | | CN202 | CON9_1 | CN8-20A | CON8-2.0 | | CN301 | DIP-36(2_18)_0 | CON20X2-2.0-LVDS | DIP\40\2X20 | | CN401 | CON6_2_0.0MM | CN7-20A | CON7-2.0 | | CN407 | HEADER_1X4-2MM_180D | CN4-20A | CON4-2.0 | | CN601 | CON2 | CN2-20A | CON2-2.0 | | CN602 | CON2 | CN2-20A | CON2-2.0 | | D401 | BAV99_0 | D0402 | ESD | | D402 | BAV99_0 | D0402 | ESD | | D404 | BAV99_0 | D0402 | NC | | D405 | BAV99_0 | D0402 | NC | | F701 | FUSE | R1206 | NC | | F702 | FUSE | AXIAL0.4 | 5A/12V | | H107 | HOLE-V8 | HOLE4-7 | NC | | H108 | HOLE-V8 | HOLE4-7 | NC | | H109 | HOLE-V8 | HOLE4-7 | NC | | H110 | CON3_3 | TPAD | NC | | H111 | CON3_3 | TPAD | NC | | H112 | CON3_3 | TPAD | NC | | H113 | CON3_3 | TPAD | NC | | H114 | CON3_3 | TPAD | NC | | H115 | CON3_3 | TPAD | NC | | L19 | INDUCTOR_0 | L0402 | NC/18nH | | L20 | INDUCTOR_0 | L0402 | 0R | | L21 | INDUCTOR_0 | L0402 | 0R/390nH | | L22 | INDUCTOR_0 | L0402 | 560nH | | L23 | INDUCTOR_0 | L0402 | 560nH | | L24 | INDUCTOR_1 | L0402 | FB/200mA/1000ohm | | L25 | INDUCTOR_5 | L0805 | NC/0R | | L26 | INDUCTOR_0 | L0402 | NC/220nH | | L27 | INDUCTOR_1 | L0402 | FB/200mA/1000ohm | | L87 | INDUCTOR_1 | L0402 | FB/50mA/1000ohm | | L101 | L3X3_2.2UH_1_0.5A | SMD03X03 | 2.2uH/1.5A | | L701 | INDUCTOR_IRON_2 | SMD08X08 | SPM6530T-4R7M | | LED701 | 7012X/SM_2 | LED | LED/RED | | P401 | HDMI_J_2_VERTER_2 | HDMI_TYPE_A | HDMI/90D | | P402 | USB-B_1 | USB_MINI_4P | USB2.0/90D | | P403 | CONNECTOR_COAX-J_0 | RCV3-14MM-1 | AV3 | | P404 | CONNECTOR_COAX-J_0_2 | RCV2-14MM-1 | AV2 | | P701 | DC_JACK_0 | DC-JACK3P | DCJACK | | Q201 | NPN(BEC)_1 | SOT-23 | NC/3904 | | Q301 | P_DGS_3 | SOT23-100 | AO3401A | | Q302 | P_DGS_3 | SOT23-100 | NC/AO3401A | | Q303 | NPN(BEC)_1 | SOT-23 | 3904 | | Q402 | NPN(BEC)_1 | SOT-23 | 3904 | | Q601 | NPN_BEC_3 | SOT-23 | 3904 | | Q602 | PNP(BEC)_0 | SOT-23 | 3906 | | Q603 | NPN_BEC_3 | SOT-23 | 3904 | | Q701 | P_DGS_2 | SOT23-100 | AO3401A | | Q702 | P_DGS_2 | SOT23-100 | AO3401A | | Q703 | NPN(BEC)_1 | SOT-23 | 3904 | | Q704 | NPN(BEC)_1 | SOT-23 | 3904 | | Q705 | NPN(BEC)_1 | SOT-23 | 3904 | | T1 | TRF_ATB2012_75011_NTP | TRANS_ATB2012 | BW21S7511A01TF | | TP201 | TEST_POINT_1 | TP-0.5MM | NC | | TU4 | FK1602_CAN_TUNER | FK1602 | NC/FK1602 | | TU5 | CON3_2 | TUNER-C2 | RF | | U7 | MXL601RF_0 | QFN24_MXL601 | MxL661 | | U8 | SOT-223 | SOT-223 | AMS1117L-3.3 | | U9 | MSD91RQN_80_1 | IC-80P-LQFP-10X10-P04 | TSUMV56RJXX | | U101 | SOT-223_1 | SOT-223 | AS1117L-3.3 | | U102 | SY8008B_1.2A | SOT-23-5 | SY8077/1A | | U103 | LDO_SOT-223_1117-ADJ | SOT-223 | 1117-ADJ | | U202 | IR | IR-1 | IR | | U203 | M24CXX_0 | SOP8-255-50 | MX25L3236F | | U204 | M24CXX_0 | SOP8-255-50 | NC | | U601 | TC0177/TPA3110_0 | QFN4X5_28L_0-5_3 | RT9116 | | U701 | AOZ1036_2 | DFN4X3-12 | SY8205 | | Y5 | CRYSTAL-2PIN_0 | XTAL\HC49\F | 24.000MHz | | Y201 | CRYSTAL_12 | XTAL\HC49\F | 24MHz |
重要提示:PCB作品文件展下载说明
