| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BL1 | DXP18_DXP18BN_DXP18BN5014T | DXP18BN5014T | DXP18BN |
| D1 | ESD5V3U1U-2RH_TSLP-2-7_ESD5V3U1 | ESD5V3U1U-02LRH | TSLP-2-7 |
| D101 | DIODE_SOD-523_RB520S-30 | RB520S-30 | SOD-523 |
| D102 | DIODE_SOD-523_RB520S-30 | RB520S-30 | SOD-523 |
| D103 | DIODE_SOD-523_RB520S-30 | RB520S-30 | SOD-523 |
| FB4 | CHOKE_L0402_600R | 600R | L0402 |
| FB5 | CHOKE_L0402_600R | 600R | L0402 |
| FB16 | FERRITEBEAD_0_FB_0603_FBM-11-1 | FBM-11-160808-500T | FB_0603 |
| G_C601 | CAP-NP_C0402_100NF | 100nf | C0402 |
| G_C602 | CAP-NP_C0402_10NF | 10nf | C0402 |
| G_C603 | CAP-NP_C0402_10NF | 10nf | C0402 |
| G_C604 | CAP-NP_C0402_100P | 100p | C0402 |
| G_C606 | CAP-NP_C0402_22PF | 22pf | C0402 |
| G_C607 | CAP-NP_C0402_10NF | 10nf | C0402 |
| G_C610 | CAP-NP_C0402_100NF | 100nf | C0402 |
| G_C611 | CAP-NP_C0402_10NF | 10nf | C0402 |
| G_C614 | CAP-NP_C0402_10NF | 10nf | C0402 |
| G_C615 | CAP-NP_C0402_10PF | 10pf | C0402 |
| G_C617 | CAP-NP_C0402_10NF | 10nf | C0402 |
| G_C618 | CAP-NP_C0603_2.2UF | 2.2uf | C0603 |
| G_C619 | CAP-NP_C0402_100NF | 100nf | C0402 |
| G_F602 | SAW-5P_SAW-5PIN-1_4X1_1_FAR-F6K | FAR-F6KA-1G5754-L4AJ | SAW-5PIN-1_4X1_1 |
| G_J1 | ANT6_6_ANT5_5_ANT6_6 | ANT6_6 | ANT5_5 |
| G_L601 | INDUCE_L0402_39NH | 39nH | L0402 |
| G_L604 | BEAD_L0603_60OHM | 60ohm | L0603 |
| G_L605 | BEAD_L0603_60OHM | 60ohm | L0603 |
| G_R601 | RES_R0402_100 | 100 | R0402 |
| G_R602 | RES_R0402_100 | 100 | R0402 |
| G_R603 | RES_R0402_100 | 100 | R0402 |
| G_R604 | RES_R0402_10K | 10K | R0402 |
| G_R605 | RES_R0402_0 | 0 | R0402 |
| G_R606 | RES_R0402_10K | 10K | R0402 |
| G_R607 | RES_R0402_NC/0 | NC/0 | R0402 |
| G_R608 | RES_R0402_0R | 0R | R0402 |
| G_R609 | RES_R0402_0 | 0 | R0402 |
| G_U601 | SE4150L_QFN_24_SE4150L | SE4150L | QFN_24 |
| G_Y601 | CRYSTAL-4P-P3OUT_CRYSTAL-3225_1 | 16.367667 MHz | CRYSTAL-3225 |
| J10 | ANT6_6_ANT5_5_ANT6_6 | ANT6_6 | ANT5_5 |
| J12 | COM-30P-SMT_1_FPC-0D5MM-30PIN-B | COM-30P-SMT | FPC-0D5MM-30PIN-BOT-YCX-A5 |
| J13 | HEADER-5_HDR200M-1X5_CON-5P | CON-5P | HDR200M-1X5 |
| J14 | CON-35P_0_HDR200M-1X35_CON-35P | CON-35P | HDR200M-1X35 |
| JP9 | HOLE_HOLE_A_HOLE | hole | HOLE_A |
| JP10 | HOLE_0_HOLE_A_HOLE_0 | hole_0 | HOLE_A |
| JP11 | HOLE_HOLE_A_HOLE | hole | HOLE_A |
| JP12 | HOLE_0_HOLE_A_HOLE_0 | hole_0 | HOLE_A |
| L901 | INDUCE_INDUCE-PT04X18_2.2UH | 2.2uH | INDUCE-PT04X18 |
| L902 | INDUCE_INDUCE-PT04X18_2.2UH | 2.2uH | INDUCE-PT04X18 |
| L1101 | CHOKE_R0402_6.2NH | 6.2nH | R0402 |
| L1102 | CHOKE_R0402_12NH | 12nH | R0402 |
| L1103 | CHOKE_R0402_24NH | 24nH | R0402 |
| L1104 | CHOKE_R0402_1.5NH | 1.5nH | R0402 |
| L1105 | CHOKE_R0402_24NH | 24nH | R0402 |
| L1114 | INDUCTOR_1_INDUCE-PT04X18_4.7UH | 4.7uH | INDUCE-PT04X18 |
| LED2 | LED_LED_0805_LED | LED | LED_0805 |
| M901 | MARK_MASK_ID_MARK | MARK | MASK_ID |
| M902 | MARK_MASK_ID_MARK | MARK | MASK_ID |
| M903 | MARK_MASK_ID_MARK | MARK | MASK_ID |
| M904 | MARK_MASK_ID_MARK | MARK | MASK_ID |
| M905 | MARK_MASK_ID_MARK | MARK | MASK_ID |
| M906 | MARK_MASK_ID_MARK | MARK | MASK_ID |
| Q4 | MMBT3904_SOT-23_MMBT3904 | MMBT3904 | SOT-23 |
| TP1 | TEST_TEST_TEST | TEST | TEST |
| TP18 | TP_2_D-2_2MM_TP_2 | TP_2 | D-2_2MM |
| TP19 | TP_2_D-2_2MM_TP_2 | TP_2 | D-2_2MM |
| TP20 | TP_2_D-2_2MM_TP_2 | TP_2 | D-2_2MM |
| TP21 | TP_2_D-2_2MM_TP_2 | TP_2 | D-2_2MM |
| TP22 | TP_2_PAD1_2DHDH_TP_2 | TP_2 | PAD1_2DHDH |
| TP23 | TP_2_PAD1_2DHDH_TP_2 | TP_2 | PAD1_2DHDH |
| TP25 | TP_2_PAD1_2DHDH_TP_2 | TP_2 | PAD1_2DHDH |
| TP26 | TP_2_PAD1_2DHDH_TP_2 | TP_2 | PAD1_2DHDH |
| TP27 | TEST_TEST_TEST | TEST | TEST |
| TP28 | TEST_TEST_TEST | TEST | TEST |
| TP1006 | TEST_TEST_TEST | TEST | TEST |
| TP1008 | TEST_TEST_TEST | TEST | TEST |
| U24 | RT9179_SOT23_5_RT9179 | RT9179 | SOT23_5 |
| U28 | SMS1180_0_BGA-86-SMS1184_SMS118 | SMS1184 | BGA-86-SMS1184 |
| U29 | RT8009PB_SOT23_5_RT8009PB | RT8009PB | SOT23_5 |
| U30 | RT9179_SOT23_5_RT9179 | RT9179 | SOT23_5 |
| U31 | P5CC072_SSOP-20_P5CC072 | P5CC072 | SSOP-20 |
| U101 | ATLAS-V_AVBGA-285_(S1+S2+S3+S4+ | ATLAS-V | AVBGA-285 |
| U201 | DDR2-FBGA-84P-16BIT_FBGA-84-SAM | K4T51163QG-HCF7 | FBGA-84-SAMSUN |
| U306 | NAND-TSOP_TSOP_48_H27UBG8T2ATR- | H27UBG8T2ATR-BC | TSOP_48 |
| U307 | LDO-3P-2_SOT-23_XC61FN2712MR | XC61FN2712MR | SOT-23 |
| U903 | LDO-SOT235_SOT-23-5_XC6219B332M | XC6219B332MR,RT9193-33PB | SOT-23-5 |
| U1204 | SN8P2501B_SO-8_SN8P2501B | SN8P2501B | SO-8 |
| Y7 | CRYSTAL-4P-13_CRYSTAL-3225_12MH | 12MHz | CRYSTAL-3225 |
| Y101 | CRYSTAL-4P-13_CRYSTAL-5032_24MH | 24MHz | CRYSTAL-5032 |
| Y102 | CRYSTAL-4P-14_CRYSTAL-MC-146_32 | 32.768kHz | CRYSTAL-MC-146 |
