| Name | Part Type | PCB Decal | Value |
| ANT4 | ANTENNA | PAD/SMD/1.8X4 | ANT / 1.8mmX4mm / KRF1S2001R |
| ANT402 | ANTENNA_0 | PAD/SMD/1.8X4 | ANT / 1.8mmX4mm / KRF1S2001R |
| ANT403 | ANTENNA_0 | PAD/SMD/1.8X4 | ANT / 1.8mmX4mm / KRF1S2001R |
| ANT501 | ANTENNA | PAD/SMD/1.8X4 | ANTENNA_FM_FPC |
| BEAD3 | FB_/_BLM18BD252SN1 | R0603 | FB / BLM18BD252SN1 |
| D201 | D_/_UDZS_5.6B | PMDU | D / UDZS 5.1B |
| J16 | CON40AP_2 | KB14243110R | CON / 24 / KB14243110R_LF |
| J201 | VIB_/_Z4PC3B8129521 | VIBRATOR/SMD | VIB / Z4PC3B8129521 |
| J301 | BATCON/4P_0 | BAT/SMD/KBC23S360R | BAT_CON / 4 / KBC23S3M1PR |
| J401 | TST_PORT_0 | MM8430-2600B | Car_Kit / MM8430-2610 |
| J901 | LCM_45PIN_ZIF_1 | H61/SMD/FH26-61S-0.3SHW/A | CON / 61 / FH26W-61S-0.3SHW |
| J1002 | JACK_CON_/_7_/_KJA1339C01R | AUDIOJACK/6P/SMD/KJA1339C01R_ | JACK_CON / 7 / KJA1339C01R |
| J1004 | USB_CON_/_6_/_22AD_018 | MINIUSB(Y16-102) | USB_CON / 6 / 22AD_018 |
| J1101 | SIM_CON_/_7_/_CAF98-06206-SA00 | SIM/SMD/7P/CAF98-06206-SA00-B | SIM_CON / 7 / CAF98-06206-SA00 |
| J1104 | SIM_SOCKET_1 | SIM/8P/SMD/5190008-XS1-R | SIM_CON / 8 / IM049-0180-KT |
| J1105 | CON40AP_2 | KB14243110R | CON / 24 / KB14243110R_LF |
| L33 | INDUCTOR_FERRITE_0 | L0603 | BLM18PG221SH1 |
| L35 | INDUCTOR | L0603 | 100nH(LQW18ANR10G00) |
| L505 | L_/_72_/_NH_/_0603_/_HQ | L0603 | L / 72 / nH / 0603 / HQ |
| L1002 | INDUCTOR_FERRITE_0 | L0603 | BLM18PG221SH1 |
| LS1001 | 2-PIN__0 | SPEAKER_PAD | NC_SPK / DMS1808EJ-02-F10-G |
| Q301 | Q_/_STT818B | SOT-6 | Q / STT818B |
| Q302 | Q_/_SSM3K35MFV | 2-1L1B/SMD/SSM3K35MFV | Q / SSM3K35MFV |
| SW501 | CITIZENLS10_BOSS | CITIZENLS10_BOSS | KEY / LS10N2 |
| SW505 | CITIZENLS10_BOSS | CITIZENLS10_BOSS | KEY / LS10N2 |
| SW1101 | KEY_/_EVQQ0C03K | SW/3P/SMD/EVQQ0C03K | KEY / EVQQ0C03K |
| SW1102 | CITIZENLS10_BOSS | CITIZENLS10_BOSS | KEY / LS10N2 |
| SW1104 | CITIZENLS10_BOSS | CITIZENLS10_BOSS | KEY / LS10N2 |
| SW1105 | CITIZENLS10_BOSS | CITIZENLS10_BOSS | KEY / LS10N2 |
| T11 | ESD9B5_0.0ST5G | SOD523/ESD5Z2.5T1 | ESD / ESD5B5.0ST1G |
| T1013 | TVS/SOD523 | SOD523/ESD5Z2.5T1 | ESD / ESD5Z12T1G |
| U1 | MT6260_15 | MT6260/TFBGA199/ | MT6260 |
| U304 | ESD_/_M1005C080MTAAB | R0402 | NC_ESD |
| U402 | RF7163_4 | RF7170 | FEM / RF7176 / QFN23 |
| U902 | CM8249QR-B_3 | DF30FC-24DS-0.4V | FPC-24-0.8 |
| U1001 | AUDIO_JACK_0 | FILTER/SMD/SPM0410HR5H-PB | MIC / SPM0410HR5H-PB |
| U1105 | SD_CARD_0 | T-FLASH/8P/SMD/HY-TFP08-TP19-01 | MC_CON / 9 / HY-TFP08-TP19-01 |
| X401 | TCVCXO_0 | TCXO3225 | X / 26MHz / TZ1689A |
