| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| ANT1 | ANT_WFL-R-SMT_ANT-IPEX_WFL-R-SM | WFL-R-SMT | ANT-IPEX |
| ANT2 | ANT-WIFI-2_0_ANT-WIFI-2_ANT-WIF | ANT-WIFI-2 | ANT-WIFI-2 |
| BAT1 | BATTERY_0_CON-SMT-1_25-5P_LI_3. | LI_3.7V | CON-SMT-1_25-5P |
| CON14 | CON RF I-PEXMHF-20279_0_ANT-IP | U.FL-R-SMT | ANT-IPEX |
| CR24 | LED0603_LED0603_LED0603 | LED0603 | LED0603 |
| CR25 | LED0603_LED0603_LED0603 | LED0603 | LED0603 |
| CR3502 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9400 | ESD9X7V_SMCR_1P0XP6_FBP02C_ESD9 | ESD9X7V-2T/R | SMCR_1P0XP6_FBP02C |
| CR9401 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9402 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9403 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9500 | DIODE_SMCR_SC79_BAP63-02_H11513 | BAP63-02 | SMCR_SC79 |
| CR9501 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9502 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9503 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9504 | DIO_ESD_E0402S_ESD9N5BM-2/TR_H3 | ESD9N5BM-2/TR | E0402S |
| CR9507 | DIODE_SMCR_SC79_BAP63-02_H11513 | BAP63-02 | SMCR_SC79 |
| D6 | LED_6_IR-LED-D3_IR12-21C-TR8 | IR12-21C-TR8 | IR-LED-D3 |
| D10 | DIODE_0_SOD123_1N5819 | 1N5819 | SOD123 |
| D902 | D_1N5819HW_SOD123_1N5819HW | 1N5819HW | SOD123 |
| D903 | DIODE_0_SOD123_1N5819 | 1N5819 | SOD123 |
| ED26 | DIODE BI-DIRTRIG_E0402S_ESD9B5 | ESD9B5V | E0402S |
| ED27 | DIODE BI-DIRTRIG_E0402S_ESD9B5 | ESD9B5V | E0402S |
| ED28 | DIODE BI-DIRTRIG_E0402S_ESD9B5 | ESD9B5V | E0402S |
| ED29 | DIODE BI-DIRTRIG_E0402S_ESD9B5 | ESD9B5V | E0402S |
| ED30 | DIODE BI-DIRTRIG_E0402S_ESD9B5 | ESD9B5V | E0402S |
| FB7 | FB0402_SMR0402_600R@100MHZ | 600R@100MHz | SMR0402 |
| FB7000 | FERRITE_ALTSIZE_SMF0402_1P15XP6 | FERRITE_ALTSIZE | SMF0402_1P15XP65_P65H |
| FB7015 | INDUCTOR_L0402_600R/100MHZ | 600R/100MHz | L0402 |
| FB7016 | INDUCTOR_L0402_600R/100MHZ | 600R/100MHz | L0402 |
| FIL1 | FIL_SAW-856561_DFN5_B9482(1575M | B9482(1575MHz) | DFN5 |
| FIL2 | FIL_SAW-856561_DFN5_B9482(1575M | B9482(1575MHz) | DFN5 |
| IR1 | IR_RECEIVE_2_IRM-V538_TR1_IRM-V | IRM-V538/TR1 | IRM-V538_TR1 |
| J6 | CON6_0_CON-FPC-0_5-5P-OP_5PIN0. | 5PIN0.5 | CON-FPC-0_5-5P-OP |
| J7 | HDMI CONG3168-0500XXXX-00_HDMI | HDMI-MINI-19P-CBS-B4501H-BELL | HDMI-MINI-19P-CBS-B4501H-BELL-1 |
| J11 | PJ381-2_0_PJ-B2318S-BELL_PJ-B23 | pj-b2318s-bell | PJ-B2318S-BELL |
| J13 | TOUCH_SCREEN_1_CON-FPC-0_5-12P_ | Touch_screen | CON-FPC-0_5-12P |
| J3500 | CON6_WTB_MTG2_1X6_P8MM_WTB_ACES | CON6_WTB_MTG2 | 1X6_P8MM_WTB_ACES_50208 |
| J3501 | CON12_MICROSD_MTG4_3_TF-CARD_CO | CON12_MICROSD_MTG4 | TF-CARD |
| J8504 | CON24_RCPT_CAM_BYT_CR_CON-BTB-P | CON24_RCPT_CAM_BYT_CR | CON-BTB-P0_4H1_5W4_1F-24P-OP |
| J8505 | CON24_RCPT_CAM_BYT_CR_CON-BTB-P | CON24_RCPT_CAM_BYT_CR | CON-BTB-P0_4H1_5W4_1F-24P-OP |
| J9700 | CON40_RCPT_2X20_P4MM_BTB_RCPT_D | CON40_RCPT | 2X20_P4MM_BTB_RCPT_DF40C |
| J9900 | CABLE_HOLDER_CABLE_HOLDER_SV08M | CABLE_HOLDER | CABLE_HOLDER_SV08M |
| J9901 | CON-SMT-1_0_CON-PAD-2_5-2P_CON- | con-pad-2_5-2p | CON-PAD-2_5-2P |
| J9902 | CON-SMT-1_1_CON-PAD-2_5-2P_CON- | con-pad-2_5-2p | CON-PAD-2_5-2P |
| L14 | L0402_SMR0402_0R | 0R | SMR0402 |
| L15 | L0402_SMR0402_6.8NH | 6.8nH | SMR0402 |
| L16 | L0402_SMR0402_6.8NH | 6.8nH | SMR0402 |
| L19 | INDUCTOR_1_IND-4X4_4.7UH/1.5A | 4.7uH/1.5A | IND-4X4 |
| L901 | L_LVS404018_IND-4X4_10UH | 10uH | IND-4X4 |
| L2000 | IND_ALTSIZE_SML2520_1P2H_1.0UH_ | 1.0UH | SML2520_1P2H |
| L9509 | CHOKE_4PIN_ALT_SML_4P_43X53_C_1 | 80OHM_100MHZ | SML_4P_43X53_CM_P35H |
| L9510 | INDUCTOR_0_L0201_4.7NH | 4.7nH | L0201 |
| L9511 | INDUCTOR_0_L0201_NC/4.7NH | NC/4.7nH | L0201 |
| LCD4 | LD089WU1_2_CON-FPC-0_5-40P_LD08 | LD089WU1 | CON-FPC-0_5-40P |
| Q5 | MOSFET_N_SOT523_CJ1012 | CJ1012 | SOT523 |
| Q10 | 40852_1_SOT23_3904 | 3904 | SOT23 |
| Q30 | MOSFETP_SOT23_VIC1121 | VIC1121 | SOT23 |
| Q31 | MOSFETP_SOT23_VIC1121 | VIC1121 | SOT23 |
| Q34 | MOSFETP_SOT23_VIC1121 | VIC1121 | SOT23 |
| Q35 | NPN_0_SOT23_VIC1221 | VIC1221 | SOT23 |
| Q54 | MOSFET_N_SOT523_2SK3019 | 2SK3019 | SOT523 |
| Q55 | MOSFET_N_SOT523_CJ1012 | CJ1012 | SOT523 |
| Q56 | MOSFET_N_SOT523_2SK3019 | 2SK3019 | SOT523 |
| Q57 | MOSFET_N_SOT523_2SK3019 | 2SK3019 | SOT523 |
| Q58 | MOSFET_N_SOT523_NC/2SK3019 | NC/2SK3019 | SOT523 |
| Q59 | MOSFET_N_SOT523_NC/2SK3019 | NC/2SK3019 | SOT523 |
| Q60 | MOSFET_N_SOT523_2SK3019 | 2SK3019 | SOT523 |
| Q74 | MOSFET_N_SOT523_2SK3019 | 2SK3019 | SOT523 |
| Q91 | MOSFETN_SOT23_VIC1221 | VIC1221 | SOT23 |
| Q2000 | WPM1481_LCC6_P65MM_SQ2P05MM_NS_ | WPM1481 | LCC6_P65MM_SQ2P05MM_NS |
| Q8405 | MOSFETN_SOT23_VIC1221 | VIC1221 | SOT23 |
| RT2000 | THERMISTOR_SMRT0402_27X47_10K_D | 10K | SMRT0402_27X47 |
| RT2001 | THERMISTOR#1_SMRT0402_27X47_10K | 10K | SMRT0402_27X47 |
| SH1000 | SHUNT_LOCAL_SHUNT_0402_SHUNT_LO | SHUNT_LOCAL | SHUNT_0402 |
| SH2003 | SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_P | SHUNT_BYT_CR_MRD | SHUNT_L4-SIG_PWR_P4XP6 |
| SH2004 | SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_P | SHUNT_BYT_CR_MRD | SHUNT_L4-SIG_PWR_P4XP6 |
| SH2005 | SHUNT_BYT_CR_MRD_SHUNT_BOTTOM_P | SHUNT_BYT_CR_MRD | SHUNT_BOTTOM_P4XP6 |
| SH2006 | SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_P | SHUNT_BYT_CR_MRD | SHUNT_L4-SIG_PWR_P4XP6 |
| SH2007 | SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_P | SHUNT_BYT_CR_MRD | SHUNT_L4-SIG_PWR_P4XP6 |
| SH2008 | SHUNT_BYT_CR_MRD_SHUNT_L4-SIG_P | SHUNT_BYT_CR_MRD | SHUNT_L4-SIG_PWR_P4XP6 |
| SH9001 | SHUNT_LOCAL_SHUNT_0402_SHUNT_LO | SHUNT_LOCAL | SHUNT_0402 |
| SW7000 | LS77C2DE_T_0_SWI-INT-1100AAGS-A | LS77C2DE_T | SWI-INT-1100AAGS-AIR-1 |
| SW7001 | LS77C2DE_T_0_SWI-INT-1100AAGS-A | LS77C2DE_T | SWI-INT-1100AAGS-AIR-1 |
| SW7002 | LS77C2DE_T_0_SWI-INT-1100AAGS-A | LS77C2DE_T | SWI-INT-1100AAGS-AIR-1 |
| T8 | TEST_1_SHIELD-PTC0703B-5P_SHIEL | SHIELD | SHIELD-PTC0703B-5P |
| TP46 | TP_1_TESTPAD_C20_TESTPAD_C20 | TESTPAD_C20 | TESTPAD_C20 |
| U10 | MINIUSB_0_USB-5P-MICRO-DIP-BEL | USB | USB-5P-MICRO-DIP-BELL-1 |
| U17 | MAX2659_0_AFN_MAX2659_MAX2659 | MAX2659 | AFN_MAX2659 |
| U18 | U_BCM4752IFBG_BGA49_P65_5SQ_1P3 | BCM4752IFBG | BGA49_P65_5SQ_1P3H_PAD12MIL |
| U19 | LPW5206H_SOT25_DS9715ABG | DS9715ABG | SOT25 |
| U24 | ESD SPE6V8UDDFN-10_0_SLP2510P8 | SPE6V8UDFN10RGB | SLP2510P8 |
| U26 | BCM43438_0_WLBGA60-0_4-5_35X3_3 | BCM43438 | WLBGA60-0_4-5_35X3_35-BCM43438 |
| U27 | LFB212G45CG7D227_1_LFB212G45CG7 | LFB212G45CG7D227 | LFB212G45CG7D227 |
| U42 | DS8008_4_SOT23_5_NC/ME6211-33 | NC/ME6211-33 | SOT23_5 |
| U214 | ESD SPE6V8UDDFN-10_0_SLP2510P8 | SPE6V8UDFN10RGB | SLP2510P8 |
| U225 | KXCJ9-1008_LGA10_0_65_3X3MM_KXC | KXCJ9-1008 | LGA10_0_65_3X3MM |
| U902 | U_MP3202_SOT26_MT9201 | MT9201 | SOT26 |
| U1000 | SOC_VLV2_CR_CONCEPT_CUST_WW3_BG | SOC_VLV2_CR_CONCEPT_CUST_WW3 | BGA592_P65MM_17X17 |
| U2003 | AXP288_1P04_LCC76_P4MM_SQ9P1MM_ | AXP288_1P04 | LCC76_P4MM_SQ9P1MM_EP5P5 |
| U2005 | LP3211_0_SOT23_6_1P295H_LP3211_ | LP3211 | SOT23_6_1P295H |
| U2006 | G5121_1_SOT26_MT3608 | MT3608 | SOT26 |
| U3005 | MT41K256M16_BGA96_P8MM_9P1X14P1 | MT41K256M16 | BGA96_P8MM_9P1X14P1 |
| U3006 | MT41K256M16_BGA96_P8MM_9P1X14P1 | MT41K256M16 | BGA96_P8MM_9P1X14P1 |
| U3101 | MT41K256M16_BGA96_P8MM_9P1X14P1 | MT41K256M16 | BGA96_P8MM_9P1X14P1 |
| U3102 | MT41K256M16_BGA96_P8MM_9P1X14P1 | MT41K256M16 | BGA96_P8MM_9P1X14P1 |
| U3500 | MX25U1635E_0_SOP8-50-210_MX25U1 | MX25U1635E | SOP8-50-210 |
| U3501 | KLM8G1WEMB_B031_0_BGA153_11P5X1 | KLM8G1WEMB_B031 | BGA153_11P5X13_12MILPAD |
| U6206 | RL_SM02BD_8723BS_LCC44_P9MM_SQ1 | RL_SM02BD_8723BS | LCC44_P9MM_SQ12_1P6H |
| U7001 | ALC5640_VB_LCC48_P4MM_SQ6MM_1P0 | ALC5640_VB | LCC48_P4MM_SQ6MM_1P0H |
| U7002 | 74LVC1G126_SOT23_5_74LVC1G126_G | 74LVC1G126 | SOT23_5 |
| U7200 | MIC_AMS_O40S42_EC1_1_MIC-4020_S | MIC_AMS_O40S42_EC1 | MIC-4020_SMD-P2_4 |
| U8001 | KXCJK_1013_LCC16_NS_P5MM_SQ3MM_ | KXCJK_1013 | LCC16_NS_P5MM_SQ3MM_1P01H |
| U8002 | AK09911C_12MILPAD_BGA8_P4MM_1P1 | AK09911C_12MILPAD | BGA8_P4MM_1P19SQ_P57H_12MILPAD |
| U8003 | BMC150_LCC14_P4MM_2P2SQ_BMC150_ | BMC150 | LCC14_P4MM_2P2SQ_BMC150 |
| U8024 | BMG160_LCC12_NS_P5MM_SQ3MM_1P0H | BMG160 | LCC12_NS_P5MM_SQ3MM_1P0H |
| U9001 | TUSB1210_LCC32_P5MM_5SQ_EP3P45_ | TUSB1210 | LCC32_P5MM_5SQ_EP3P45 |
| U9009 | 74AVC1T45YZP_BGA6_5MM_1P4_P9_74 | 74AVC1T45YZP | BGA6_5MM_1P4_P9 |
| U9010 | AOZ6184_DPDT_LCC10_P4MM_1P8X1P4 | AOZ6184_DPDT | LCC10_P4MM_1P8X1P4 |
| Y5 | KT2016A26000ACW18TLG_BRCM_0_TCX | KT2016A26000ACW18NAN | TCXO_KT2016_2X1D6_0D8 |
| Y6 | CRYSTAL-4_0_CRY-D3225_26M-20PPM | 26M-20ppm | CRY-D3225 |
| Y1000 | XTAL_4PIN_SMY_4P_79X98_PAD37X39 | 25.0MHZ | SMY_4P_79X98_PAD37X39_24H |
| Y1001 | XTAL_0_FC135_32.768KHZ_G41053-0 | 32.768KHZ | FC135 |
| Y6200 | OSC_TCXO_ALT_SMY_4P_2P15X2P65_P | 26MHZ | SMY_4P_2P15X2P65_P8H |
