重要提示:PCB作品文件展下载说明
| Name | PCB Decal | Value | Part Type | | CS1 | C0805 | 22UF | C0805 | | D2 | DO214AC | PMEG3030 | DO214AC | | D4 | SOT23 | BAT54C | SOT23 | | D8 | SOD323 | 1N4148 | SOD323 | | D9 | SOD323 | 1N4148 | SOD323 | | D10 | SOD128 | MPEG3030EP | SOD128 | | D11 | SOD323 | 1N4148 | SOD323 | | EC3 | E3528 | 100UF/4V | E3528 | | EC4 | E3528 | 100UF/4V | E3528 | | J1 | DC-JACK | DC12V | DC-JACK | | J2 | TF_CARD-M7 | TF_SD_SOCKET | TF_CARD-M7 | | J4 | MT10103_1 | MT10103_1 | MT10103_1 | | J6 | FPC40-0.5MM | HSD101PWW1-A | FPC40-0.5MM | | J8 | HDMI-19PF_C_3.5 | HDMI_C | HDMI-19PF_C_3.5 | | J12 | AJ320B | AJ320B | AJ320B | | J16 | HUM011D-5-S | USB | HUM011D-5-S | | L3 | IND-3X3 | 2.2UH/1A | IND-3X3 | | L4 | IND-3X3 | 2.2UH/1A | IND-3X3 | | L5 | IND-4X4 | 2.2UH/2A | IND-4X4 | | L6 | IND-4X4 | 2.2UH/2A | IND-4X4 | | L7 | SMD_L_5X5 | 2.2UH/2A | SMD_L_5X5 | | L8 | IND-3X3 | 3.3UH/2A | IND-3X3 | | L12 | R0402 | NC | R0402 | | L13 | R0402 | NC | R0402 | | L17 | IND-3X3 | 2.2UH/1A | IND-3X3 | | L29 | L0603 | BLM18PG181SN1 | L0603 | | L30 | L0603 | BLM18PG181SN1 | L0603 | | L31 | L0603 | NC | L0603 | | MIC2 | MIC-4020 | MIC | MIC-4020 | | P1 | PAD2X2.5 | SPK_R+ | PAD2X2.5 | | P2 | PAD2X2.5 | SPK_R- | PAD2X2.5 | | P3 | PAD2X2.5 | SPK_L+ | PAD2X2.5 | | P4 | PAD2X2.5 | SPK_L- | PAD2X2.5 | | P5 | PAD2X2.5 | BATT+ | PAD2X2.5 | | P6 | PAD2X2.5 | BATT- | PAD2X2.5 | | P7 | PAD2X2.5 | NTC | PAD2X2.5 | | Q8 | SOT23 | WPM2341 | SOT23 | | Q10 | SOT23 | WNM2021 | SOT23 | | Q11 | SOT23 | WPM3401 | SOT23 | | Q13 | SOT23 | WPM3401 | SOT23 | | Q14 | SOT23 | WNM2021 | SOT23 | | Q15 | SOT23 | WNM2021 | SOT23 | | Q16 | SOT23 | WPM3401 | SOT23 | | Q17 | SOT23 | WNM2016 | SOT23 | | Q18 | SOT23 | WNM2021 | SOT23 | | Q19 | SOT23 | NC | SOT23 | | Q20 | SOT23 | WPM3401 | SOT23 | | Q21 | SOT23 | 8050 | SOT23 | | Q22 | SOT23 | WPM2341 | SOT23 | | Q23 | SOT23 | WNM2016 | SOT23 | | SW6 | TC-13121 | POWER | TC-13121 | | SW8 | TC-13121 | VOL- | TC-13121 | | SW9 | TC-13121 | ESC | TC-13121 | | SW10 | TC-13121 | VOL+ | TC-13121 | | SW11 | KEY4.5MM | HOME | KEY4.5MM | | U1 | BGA453-19X19 | RK3066 | BGA453-19X19 | | U2 | BGA78 | DDR3_256M_8BIT | BGA78 | | U3 | BGA78 | DDR3_256M_8BIT | BGA78 | | U4 | BGA78 | DDR3_256M_8BIT | BGA78 | | U5 | BGA78 | DDR3_256M_8BIT | BGA78 | | U6 | TSOP1-48 | NAND_FLASH | TSOP1-48 | | U7 | TSOP1-48 | NAND_FLASH | TSOP1-48 | | U13 | WM8326_3 | WM8326 | WM8326_3 | | U14 | TSSOP8 | NC | TSSOP8 | | U15 | OZ8555_1 | OZ8555 | OZ8555_1 | | U20 | SOT26 | SY7208ABC | SOT26 | | U25 | SLP2510P8 | NC | SLP2510P8 | | U26 | SLP2510P8 | NC | SLP2510P8 | | U27 | SLP2510P8 | NC | SLP2510P8 | | U32 | L3G4200D | NC | L3G4200D | | U33 | MMA8452Q | LIS3DH | MMA8452Q | | U34 | AK8975B | NC | AK8975B | | U36 | RK903 | RK903 | RK903 | | U37 | BSM-24 | ZT300B1 | BSM-24 | | U44 | QFN88 | CT365 | QFN88 | | U46 | FPC10-0.5-F | NC | FPC10-0.5-F | | U49 | WIFICONA | NC | WIFICONA | | U50 | WIFICONA | NC | WIFICONA | | U86 | BGA144 | RK610-G | BGA144 | | U88 | MSOP8 | IT4010 | MSOP8 | | U89 | MSOP8 | IT4010 | MSOP8 | | U93 | OZ8806 | OZ8806 | OZ8806 | | U94 | MT10103_2 | MT10103_2 | MT10103_2 | | U95 | BL-8188-2F | BL8188-2F | BL-8188-2F | | Y1 | CRY-MC146 | 32.768K | CRY-MC146 | | Y2 | CRY-D3225 | 24M-20PPM | CRY-D3225 | | Y3 | CRY-D3225 | 26M-20PPM | CRY-D3225 |
重要提示:PCB作品文件展下载说明
