| Comment | Designator | Footprint | Quantity | | | | | | NI | C1 | 402 | 1 | | 4.7uF | C2 | 0603 | 1 | | 0 ohm | C3 | 0402 | 1 | | 10nF | C4 | 0402 | 1 | | NI | C5 | 0402 | 1 | | 10pF | C6 | 0402 | 1 | | 100pF | C7 | 0402 | 1 | | 1uF | C8 | 0402 | 1 | | 0.1uF | C9 | 0402 | 1 | | 100pF | C10 | 0402 | 1 | | 100pF/NI | C11 | 0402 | 1 | | 0.1uF/NI | C12 | 0402 | 1 | | 1uF | C14 | 0402 | 1 | | 27pF | C15 | 0402 | 1 | | 0.1uF | C16 | 0402 | 1 | | 10pF | C17 | 0402 | 1 | | 22nF | C18 | 0402 | 1 | | 2.7pF | C35 | 0402 | 1 | | 1.2pF | C36 | 0402 | 1 | | 1.5pF | C37 | 0402 | 1 | | 2.7pF | C38 | 0402 | 1 | | 1.2pF | C40 | 0402 | 1 | | 4.7uF | C42 | 0603 | 1 | | 0.1uF | C43 | 0402 | 1 | | 1.2nF | C48 | 0402 | 1 | | 1.2nF | C50 | 0402 | 1 | | 0.1uF/NI | C51 | 0402 | 1 | | 1.2nF | C58 | 0402 | 1 | | 1.2nF | C60 | 0402 | 1 | | 1.2nF | C65 | 0402 | 1 | | 1.2nF | C67 | 0402 | 1 | | 1.2nF | C71 | 0402 | 1 | | 1.2nF | C73 | 0402 | 1 | | 1.2nF | C77 | 0402 | 1 | | 1.2nF | C79 | 0402 | 1 | | 4.7uF | C84 | 0603 | 1 | | 4.7uF/NI | C90 | 0603 | 1 | | 0.1uF | C91 | 0402 | 1 | | 0.1uF | C92 | 0402 | 1 | | 4.7uF | C93 | 0603 | 1 | | 0.1uF | C98 | 0402 | 1 | | 6.8nF | C100 | 0402 | 1 | | 220uF | C101 | CAP315 | 1 | | 10uF | C102 | 0603 | 1 | | 4.7uF/NI | C103 | 0603 | 1 | | 0.1uF | C104 | 0402 | 1 | | 1.5nF | C105 | 0402 | 1 | | 68pF | C106 | 0402 | 1 | | 4.7uF/NI | C107 | 0603 | 1 | | 0.1uF | C108 | 0402 | 1 | | 4.7uF | C109 | 0603 | 1 | | 0.1uF | C110 | 0402 | 1 | | 1uF | C111 | 0402 | 1 | | 4.7uF | C112 | 0603 | 1 | | 0.1uF | C113 | 0402 | 1 | | 0.1uF | C114 | 0402 | 1 | | 0.1uF/NI | C115 | 0402 | 1 | | 470pF/NI | C153 | 0402 | 1 | | 470pF | C154 | 0402 | 1 | | 1000pF/2KV/NI | C155 | 1206 | 1 | | 470pF/NI | C156 | 0402 | 1 | | 470pF | C157 | 0402 | 1 | | 0 ohm/SB | C158 | 1206 | 1 | | 0 ohm/SB | C159 | 1206 | 1 | | 0 ohm/SB | C160 | 1206 | 1 | | 470pF | C161 | 0402 | 1 | | 0 ohm/SB | C162 | 1206 | 1 | | 1000pF/2KV/NI | C163 | 1206 | 1 | | 330uF/25V | C165 | CAP315 | 1 | | 22uF/NI | C195 | 1206 | 1 | | 10uF/NI | C196 | 1206 | 1 | | 0.1uF/NI | C197 | 0402 | 1 | | 0.1uF/NI | C198 | 0402 | 1 | | 4.7uF/NI | C199 | 1206 | 1 | | 0.1uF/NI | C200 | 0402 | 1 | | 470uF | C236 | CAP315 | 1 | | 0.1uF | C242 | 0402 | 1 | | 10nF/NI | C243 | 0402 | 1 | | 470uF | C244 | CAP315 | 1 | | 0.1uF | C247 | 0402 | 1 | | 8.2nF | C248 | 0402 | 1 | | 680pF/NI | C249 | 0402 | 1 | | 0.1uF/NI | C250 | 0402 | 1 | | 4.7uF | C251 | 0402 | 1 | | 10PF/NI | C252 | 0402 | 1 | | 10pF | C278 | 0402 | 1 | | 5.6nH | C284 | 0402 | 1 | | 2.2pF | C285 | 0402 | 1 | | 1.8pF | C286 | 0402 | 1 | | NI | C287 | 0402 | 1 | | 3.3nH | C381 | 0402 | 1 | | 2.7nH | C382 | 0402 | 1 | | 10PF/NI | C384 | 0402 | 1 | | 10uF/NI | C386 | 0805 | 1 | | 0.1uF | C387 | 0402 | 1 | | 0.1uF | C388 | 0402 | 1 | | 0.1uF | C389 | 0402 | 1 | | 0.1uF | C390 | 0402 | 1 | | 0.1uF | C391 | 0402 | 1 | | 0.1uF/NI | C392 | 0402 | 1 | | 0 ohm | C405 | 0402 | 1 | | 1.2pF/NI | C406 | 0402 | 1 | | 1.5pF/NI | C407 | 0402 | 1 | | 1.2pF | C409 | 0402 | 1 | | 0.1uF | C414 | 0402 | 1 | | 1.5pF/NI | C415 | 0402 | 1 | | 0 ohm/NI | C420 | 0402 | 1 | | 0.1uF | C422 | 0402 | 1 | | 4.7uF/NI | C423 | 0603 | 1 | | 10PF/NI | C424 | 0402 | 1 | | 10PF/NI | C425 | 0603 | 1 | | 10PF/NI | C426 | 0603 | 1 | | 10PF/NI | C427 | 0603 | 1 | | 10PF/NI | C428 | 0603 | 1 | | 10PF/NI | C429 | 0603 | 1 | | 10PF/NI | C430 | 0603 | 1 | | 4.7uF/NI | C433 | 0603 | 1 | | 0.1uF/NI | C434 | 0402 | 1 | | 0.1uF/NI | C435 | 0603 | 1 | | 470uF/NI | C436 | CAP-1106-DIP | 1 | | 0.1uF/NI | C437 | 0603 | 1 | | 1000pF/NI | C438 | 0402 | 1 | | 100pF/0603 | C441 | 0603/0402 | 1 | | 0.1uF/NI | C442 | 0402 | 1 | | 10pF | C443 | 0402 | 1 | | 3.3nH | C444 | 0402 | 1 | | 0.1uF/NI | C445 | 0402 | 1 | | SMA/UFLR | CON1 | UFLR-MINIPCI | 1 | | SMA/UFLR | CON2 | UFLR-MINIPCI | 1 | | TVS SMCJ16A/NI | D16 | DO-214AB | 1 | | 1N4148/NI | D19 | DO-214AC | 1 | | LED | D20 | 0603 | 1 | | LED | D21 | 0603 | 1 | | LED | D23 | 0603 | 1 | | LED | D24 | 0603 | 1 | | LED | D25 | 0603 | 1 | | LED | D26 | 0603 | 1 | | LED | D27 | 0603 | 1 | | LED | D28 | 0603 | 1 | | LED | D29 | 0603 | 1 | | SK34A/NI | D31 | DO-214AC | 1 | | V-PORT/NI | D34 | 0603 | 1 | | V-PORT/NI | D35 | 0603 | 1 | | 1N5819,DO1607/NI | D36 | DO1607 | 1 | | USB-ANT-RA | E1 | ANT-RT5370-AP-D9595 | 1 | | DC JACK | J3 | DC-JACK | 1 | | HEADER 4x1 | J4 | SIP4 | 1 | | 0 ohm/SB | L1 | 0603/0402 | 1 | | 2.2nH | L11 | 0402 | 1 | | 2.7nH | L12 | 0402 | 1 | | 4.7uH/VLC5045 | L14 | VLC5045T | 1 | | 0 ohm/SB | L16 | 0603/0402 | 1 | | 0 ohm/SB | L17 | 0603/0402 | 1 | | 0 ohm | L24 | 1206 | 1 | | 0 ohm | L25 | 1206 | 1 | | 15uH/GDR0810PU150K | L33 | GDR-0810 | 1 | | 0 ohm | L34 | 0603 | 1 | | 0.8pF | L51 | 0402 | 1 | | 3.3pF | L52 | 0402 | 1 | | 0 ohm | L53 | 0402 | 1 | | 22uH,DIP,RingCoil/NI | L670 | L_D6H14 | 1 | | 12K 1% | R1 | 0402 | 1 | | 8.2K 1% | R8 | 0402 | 1 | | 10K | R12 | 0402 | 1 | | 1K | R13 | 0402 | 1 | | 1K | R14 | 0402 | 1 | | 1K | R15 | 0402 | 1 | | 1K | R16 | 0402 | 1 | | 1K | R17 | 0402 | 1 | | 1K | R18 | 0402 | 1 | | 22 | R21 | 0402 | 1 | | 4.7K/NI | R24 | 0402 | 1 | | 4.7K/NI | R25 | 0402 | 1 | | 49.9 1% | R26 | 0402 | 1 | | 49.9 1% | R27 | 0402 | 1 | | 49.9 1% | R28 | 0402 | 1 | | 49.9 1% | R29 | 0402 | 1 | | 49.9 1% | R31 | 0402 | 1 | | 49.9 1% | R32 | 0402 | 1 | | 49.9 1% | R38 | 0402 | 1 | | 49.9 1% | R39 | 0402 | 1 | | 49.9 1% | R40 | 0402 | 1 | | 49.9 1% | R41 | 0402 | 1 | | 49.9 1% | R48 | 0402 | 1 | | 49.9 1% | R49 | 0402 | 1 | | 9.1K 1% | R50 | 0402 | 1 | | 49.9 1% | R51 | 0402 | 1 | | 49.9 1% | R52 | 0402 | 1 | | 49.9 1% | R53 | 0402 | 1 | | 49.9 1% | R54 | 0402 | 1 | | 49.9 1% | R55 | 0402 | 1 | | 49.9 1% | R56 | 0402 | 1 | | 49.9 1% | R57 | 0402 | 1 | | 49.9 1% | R58 | 0402 | 1 | | 4.7K/NI | R66 | 0402 | 1 | | 2K 1% | R67 | 0402 | 1 | | 47 ohm 1% | R68 | 0402 | 1 | | 16.9K 1% | R70 | 0402 | 1 | | 4.7K | R71 | 0402 | 1 | | 4.7K/NI | R88 | 0402 | 1 | | 4.7K/NI | R89 | 0402 | 1 | | 4.7K | R94 | 0402 | 1 | | 4.7K | R95 | 0402 | 1 | | 4.7K/NI | R101 | 0402 | 1 | | 4.7K | R107 | 0402 | 1 | | 4.7K/NI | R112 | 0402 | 1 | | 4.7K/NI | R113 | 0402 | 1 | | 4.7k ohm | R118 | 0402 | 1 | | 4.7K | R119 | 0402 | 1 | | 4.7K/NI | R136 | 0402 | 1 | | 4.7k ohm | R142 | 0402 | 1 | | 4.7K | R144 | 0402 | 1 | | 4.7K/NI | R146 | 0402 | 1 | | 4.7K/NI | R148 | 0402 | 1 | | 4.7k ohm | R150 | 0402 | 1 | | 4.7K/NI | R152 | 0402 | 1 | | 4.7k ohm | R154 | 0402 | 1 | | 75 | R160 | 0402 | 1 | | 75 | R161 | 0402 | 1 | | 75 | R162 | 0402 | 1 | | 75 | R163 | 0402 | 1 | | 75 | R164 | 0402 | 1 | | 75 | R165 | 0402 | 1 | | 75 | R166 | 0402 | 1 | | 75 | R167 | 0402 | 1 | | 75 | R168 | 0402 | 1 | | 75 | R169 | 0402 | 1 | | 75 | R170 | 0402 | 1 | | 75 | R171 | 0402 | 1 | | 75 | R172 | 0402 | 1 | | 75 | R173 | 0402 | 1 | | 75 | R174 | 0402 | 1 | | 0 ohm/SB | R183 | 0402 | 1 | | 20K | R188 | 0402 | 1 | | 22 | R189 | 0402 | 1 | | 4.7K/NI | R190 | 0402 | 1 | | 330 | R191 | 0402 | 1 | | 4.7K | R192 | 0402 | 1 | | 330 | R193 | 0402 | 1 | | 4.7K/NI | R195 | 0402 | 1 | | 0 ohm/NI | R196 | 0402 | 1 | | 330 | R197 | 0402 | 1 | | 4.7K/NI | R198 | 0402 | 1 | | 4.7K | R199 | 0402 | 1 | | 0 ohm | R200 | 0402 | 1 | | 330 | R201 | 0402 | 1 | | 330 | R202 | 0402 | 1 | | 330 | R203 | 0402 | 1 | | 330 | R204 | 0402 | 1 | | 330 | R205 | 0402 | 1 | | 330 | R206 | 0402 | 1 | | 0 ohm/SB | R210 | 0402 | 1 | | 845K 1%/NI | R211 | 0402 | 1 | | 1K ohm | R212 | 0402 | 1 | | 100K | R248 | 0402 | 1 | | 39K 1% | R250 | 0402 | 1 | | 15K 1% | R251 | 0402 | 1 | | 3K 1% | R252 | 0402 | 1 | | 0 ohm/SB | R280 | 0402 | 1 | | 2K 1% | R284 | 0402 | 1 | | 0 ohm/NI | R286 | 0402 | 1 | | 4.7K | R293 | 0402 | 1 | | 33/NI | R295 | 0402 | 1 | | 10K | R298 | 0402 | 1 | | 51 ohm | R300 | 0402 | 1 | | 0 ohm/SB | R306 | 0402 | 1 | | 4.7K/NI | R307 | 0402 | 1 | | 4.7k ohm | R308 | 0402 | 1 | | 0 ohm | R309 | 0402 | 1 | | 0 ohm | R310 | 1206 | 1 | | 0 ohm | R311 | 1206 | 1 | | 0 ohm | R312 | 1206 | 1 | | 0R | R313 | 1206 | 1 | | 100KR/NI | R314 | 0805 | 1 | | 5.6KR,1%/NI | R315 | 0805 | 1 | | 1KR,1%NI | R316 | 0805 | 1 | | 0 ohm/NI | R317 | 0402 | 1 | | 4.7K | R318 | 0402 | 1 | | 0R | R319 | 0402 | 1 | | 100 ohm/1%/0603 | R320 | 0603/0402 | 1 | | 10uF | RC1 | 0603 | 1 | | SW TACT-SPST | S1 | SW4P | 1 | | SW TACT-SPST-RA | S2 | SW2P | 1 | | SW TACT-SPST-RA | S3 | SW2P | 1 | | XTAL_3.2x2.5 | SH1 | RT5350-SHELDING | 1 | | 22 | SR1 | 0402 | 1 | | 4.7K | SR2 | 0402 | 1 | | RT5350SF | U1 | TFBGA196 | 1 | | 7x2 Header /BOX | U5 | DCONN7X2 | 1 | | AT24C02A/SB/NI | U6 | SOIC-8 | 1 | | BAT1664M3/NI | U7 | SOT-89 | 1 | | APM2701AC | U8 | SOT-23-6 | 1 | | MX25L3205DM2I | U10 | SO8 | 1 | | HN2066CG | U16 | DIP-20PIN-2510 | 1 | | RJ-45X4-No-Shield | U17 | RJ45-4P | 1 | | HN2066CG | U18 | DIP-20PIN-2510 | 1 | | RJ-45X1P | U19 | RJ45A | 1 | | hn1674CG | U20 | DIP-16PIN-2010 | 1 | | G693L_R3132Q/NI | U25 | SOT-143/SC-82AB | 1 | | IT7652/2A | U28 | SOP8-1.27-6-EP | 1 | | 20MHz +/- 10ppm | U33 | XTAL-DIP-3X9 | 1 | | SDRAM 16MX16 | U35 | TSOP2-54P-400mil | 1 | | AX3023,SOT23-5/NI | U36 | SOT23-5 | 1 | | 5pF/NI | UC1 | 0402 | 1 | | 5pF/NI | UC2 | 0402 | 1 | | C-UBR27-00-00 | USB1 | USB_A-RECEPT-R/A-DIP | 1 |
