sii9000 发表于 2017-12-29 14:45
发一打PCB封装库 和对应的原理图,板子没走线
NamePart TypePCB DecalValueD1DIODE_TVSSMB_DO_214AASMBJ6.5AF4FUSER18120.7A/24VJ1HEADER_10X2HEADER_200_2X10HEADER 10X2J2DSP_JTAG_0HDR7X2DSP_JTAGJ3HEADER_7X2HDR7X2HEADER 7X2L1INDRC0603BLM18PG121L2INDRC0603BLM18PG121L3INDRC0603BLM18PG121L4INDUCTOR_IRONLC12543.6 uHL5INDUCTORXAL70704.7uH/2.5AL6INDR0805BLM18PG121L7INDR0805BLM18PG121L8INDUCTORXAL70704.7uH/2.5AL9INDR0805BLM18PG121L10INDR0805BLM18PG121L11INDR0805BLM18PG121L12INDR0805BLM18PG121L18BEAD__FERRITEC0805220ohm at 100MHzL19INDUCTORXAL70704.7uH/2.5AL20INDUCTORXAL70704.7uH/2.5AL21INDUCTORXAL70704.7uH/2.5AL22INDUCTORXAL70704.7uH/2.5AT2TRANSFORMER_CT_6SM-22MABAES0060U5MAX3221/SO_1TSSOP16_170_25MAX3221/SOU6MAX3485SOP1_27_8MAX485U7UN3E5_90LSMDUN3E5_90LSMDUN3E5_90LSMDU8TLV1702VSSOP8TLV1702DGKU9MAX3485SOP1_27_8MAX485U10UN3E5_90LSMDUN3E5_90LSMDUN3E5_90LSMDU12ADUM1201SOIC8_208_50ADuM1201ARU14IS61LV51216-15TIIS61LV51216IS61LV25616ALU17CAT1021WI-28SOIC8_208_50CAT1025-30U18LT1762-25_2MSOP_8LT1762-25U19LT6362_0LT6362LT6362U20LT2377_0LTC2377IMS-16LT2377U21DNM01_0DNM01DNM01U23LM3560HSSOP14LM3150U25LT8610_0MSOP16LT8610U26LT8610_0MSOP16LT8610U27TS3808G33DBVRSOT23_6TS3808G33DBVRU30XB1085P25_0TO-252XB1085P18U32LT1762-25_1MSOP_8LT1965-3.3U33LTC3260EMSE_0MSOP17LTC3260EMSEU35XC5VSX95T-1FFG1136C_2XC5VSX95T-FF1136XC5VSX95T-1FFG1136C_1U36XCF128XFT64C_2XC_FT64XCF128XFT64CU39AD9245_3LFCSP_WQAD9245U41SN74LVTH16245A_1TSSOP48_027SN74LVTH16245A_1U42SN74LVTH16245A_1TSSOP48_027SN74LVTH16245A_1U43SN74LVTH16245A_1TSSOP48_027SN74LVTH16245A_1U44AD5764_0TQFP32AD5764U45DSP_7PQFP176DSP_7U46EN6360QI_0QFN_68PINEN6360QI_0U47EN5339QI_0EN5339QIEN5339QI_0U48AD8830QSOP-16AD8830U49XB1085P25_0TO-252LT1086-5U50LT1175-5_0DD_PKLT1175-5U51SI7478SO-8DPSI7580U52SI7478SO-8DPSI7478XDA1SMASMASMA-KXDA2SMASMASMA-KXDA3SMASMASMA-KXDA4SMASMASMA-KXS1SMASMASMA-KXS2HEADER_5X2HD2X5_2_54Y50EX-0810ZK10XS3SMASMASMA-KXS4HEADER_4SIP4_254Y50EX-0804ZK10XS5HEAD7HDR7X1PWRY50EX-0807ZK10XS6SMASMASMA-KXS7J30J-25J30J-25TJW-JJ30J-25ZKW-JXS8J30J-25J30J-25TJW-JJ30J-25TJW-JXS9J30J-9J30J-9TJW-JJ30J-9ZKW-JXS10HEADER_5X2HD2X5_2_54Y50EX-0810ZK10Y1OSCILLATORCRYSTAL503250MHzY2OSCILLATORCRYSTAL503250MHzY3OSCILLATORCRYSTAL503250MHz
yintx 发表于 2017-12-29 15:27
老牛vvvv 发表于 2017-12-29 17:33
查看完整版本: 发一打PCB封装库 和对应的原理图,板子没走线
