电子小跑腿 发表于 2018-4-7 11:15
AR9344+AR9382+B50610KMLG+SE5004L+SKY65174-21 等整套PCB封装下载
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMED1ESDA14V2L_SOT23-3_ESDA14V2LESDA14V2LSOT23-3D2ESDA14V2L_SOT23-3_ESDA14V2LESDA14V2LSOT23-3D3RCLAMP3304NTCT_DFN10-050-2R6X2RRCLAMP3304NTCTDFN10-050-2R6X2R6D4B3D230L_ARRESTER-7R6X5_B3D230LB3D230LARRESTER-7R6X5D5B3D230L_ARRESTER-7R6X5_B3D230LB3D230LARRESTER-7R6X5D6B3D230L_ARRESTER-7R6X5_B3D230LB3D230LARRESTER-7R6X5D7B3D230L_ARRESTER-7R6X5_B3D230LB3D230LARRESTER-7R6X5D8RCLAMP3304NTCT_DFN10-050-2R6X2RRCLAMP3304NTCTDFN10-050-2R6X2R6D9FM4004-T_SMA_FM4004-TFM4004-TSMAD10FM4004-T_SMA_FM4004-TFM4004-TSMAD11FM4004-T_SMA_FM4004-TFM4004-TSMAD12FM4004-T_SMA_FM4004-TFM4004-TSMAD13SMDJ58A_SMC_SMDJ58ASMDJ58ASMCD14FM4004-T_SMA_FM4004-TFM4004-TSMAD15FM4004-T_SMA_FM4004-TFM4004-TSMAD16FM4004-T_SMA_FM4004-TFM4004-TSMAD17FM4004-T_SMA_FM4004-TFM4004-TSMAD27MBRS240LT3G_SMB_MBRS240LT3GMBRS240LT3GSMBD28BAS21LT1G_SOT23-3_BAS21LT1GBAS21LT1GSOT23-3D29MBRS240LT3G_SMB_MBRS240LT3GMBRS240LT3GSMBD301SMA5931BT3G_SMA_1SMA5931BT3G1SMA5931BT3GSMAD31BAS21LT1G_SOT23-3_BAS21LT1GBAS21LT1GSOT23-3F1FUSE-2A-SF6127_FUSESM2-6R1X2R7_FUSE-2AFUSESM2-6R1X2R7ID1ID_MARK1R0_ID MARKID MARKMARK1R0ID2ID_MARK1R0_ID MARKID MARKMARK1R0ID3ID_MARK1R0_ID MARKID MARKMARK1R0ID4ID_MARK1R0_ID MARKID MARKMARK1R0ID5ID_MARK1R0_ID MARKID MARKMARK1R0ID6ID_MARK1R0_ID MARKID MARKMARK1R0J1SHEAD-14PIN_HDR2X7-2R54-SM-V_SHSHEAD-14PINHDR2X7-2R54-SM-VJ2RJ45_RJ8-21R85_RJ45RJ45RJ8-21R85J4RJ45_RJ8-21R85_RJ45RJ45RJ8-21R85J5P1251_04_B_FPC4-1R25_P1251_04_BP1251_04_BFPC4-1R25J6MCX_CON5-6X6-SMA_MCXMCXCON5-6X6-SMAJ7MCX_CON5-6X6-SMA_MCXMCXCON5-6X6-SMAJ8MCX_CON5-6X6-SMA_MCXMCXCON5-6X6-SMAJ9MCX_CON5-6X6-SMA_MCXMCXCON5-6X6-SMAL1BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L2BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L3BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L4BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L5BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L6BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L7BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L8BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L9BEAD-2A-SL0805_SL0805_2A2ASL0805L10BEAD-0.5A-SL0805_SL0805_0.5A0.5ASL0805L11BEAD-3A-SL1210_SL1210_3A3ASL1210L12INDUCTOR-3.3NH-190MA-SL0402_SL03.3nHSL0402L13INDUCTOR-NOLOAD-A-SL0402_SL040no loadSL0402L14INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L15INDUCTOR-3.3NH-190MA-SL0402_SL03.3nHSL0402L16INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L20INDUCTOR-10NH-250MA-SL0402_SL0410nHSL0402L21INDUCTOR-4.7NH-160MA-SL0402_SL04.7nHSL0402L22INDUCTOR-3.3NH-190MA-SL0402_SL03.3nHSL0402L23INDUCTOR-NOLOAD-A-SL0402_SL040no loadSL0402L24INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L25INDUCTOR-3.3NH-190MA-SL0402_SL03.3nHSL0402L26INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L30INDUCTOR-10NH-250MA-SL0402_SL0410nHSL0402L31INDUCTOR-4.7NH-160MA-SL0402_SL04.7nHSL0402L32BEAD-2A-SL0805_SL0805_2A2ASL0805L34BEAD-2A-SL0805_SL0805_2A2ASL0805L35BEAD-2A-SL0805_SL0805_2A2ASL0805L36BEAD-2A-SL0805_SL0805_2A2ASL0805L37BEAD-2A-SL0805_SL0805_2A2ASL0805L38BEAD-2A-SL0805_SL0805_2A2ASL0805L40INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L42INDUCTOR-2.7NH-220MA-SL0402_SL02.7nHSL0402L43INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L44INDUCTOR-8.2NH-SL0402_SL0402_8.8.2nHSL0402L51INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L54INDUCTOR-2.7NH-220MA-SL0402_SL02.7nHSL0402L55INDUCTOR-2NH-300MA-SL0402_SL0402nHSL0402L56INDUCTOR-8.2NH-SL0402_SL0402_8.8.2nHSL0402L63BEAD-2A-SL0805_SL0805_2A2ASL0805L64BEAD-2A-SL0805_SL0805_2A2ASL0805L65BEAD-2A-SL0805_SL0805_2A2ASL0805L66BEAD-2A-SL0805_SL0805_2A2ASL0805L71BEAD-2A-SL0805_SL0805_2A2ASL0805L72LFB2H2G45SG7A158_FILSM4-2R5X2R0LFB2H2G45SG7A158FILSM4-2R5X2R0L73LFL182G45TCED448_FILSM6-1R6X0R8LFL182G45TCED448FILSM6-1R6X0R8L74ACPF-7024_ACPF-7024_ACPF-7024ACPF-7024ACPF-7024L75LFB2H2G45SG7A158_FILSM4-2R5X2R0LFB2H2G45SG7A158FILSM4-2R5X2R0L76LFL182G45TCED448_FILSM6-1R6X0R8LFL182G45TCED448FILSM6-1R6X0R8L77LFB2H2G45SG7A158_FILSM4-2R5X2R0LFB2H2G45SG7A158FILSM4-2R5X2R0L78ACPF-7024_ACPF-7024_ACPF-7024ACPF-7024ACPF-7024L79LFB2H2G45SG7A158_FILSM4-2R5X2R0LFB2H2G45SG7A158FILSM4-2R5X2R0L81DEA165850LT-1197B2_FILSM4-1R6X0DEA165850LT-1197B2FILSM4-1R6X0R8L82DEA205425BT-2028A4_FILSM4-2R0X1DEA205425BT-2028A4FILSM4-2R0X1R25L83DEA205425BT-2028A4_FILSM4-2R0X1DEA205425BT-2028A4FILSM4-2R0X1R25L84DEA205425BT-2028A4_FILSM4-2R0X1DEA205425BT-2028A4FILSM4-2R0X1R25L85DEA165850LT-1197B2_FILSM4-1R6X0DEA165850LT-1197B2FILSM4-1R6X0R8L86DEA205425BT-2028A4_FILSM4-2R0X1DEA205425BT-2028A4FILSM4-2R0X1R25L87INDUCTOR-1UH-9A-SPL1209_INDSM2-1uH-9AINDSM2-12R95X9R4L88BEAD-6A-SL1806_SL1806_6A6ASL1806L90INDUCTOR-2.2UH-1.5A-SL1717_INDS2.2uH-1.5AINDSM2-4R2X4R2L91INDUCTOR-2.2UH-1.5A-SL1717_INDS2.2uH-1.5AINDSM2-4R2X4R2L92INDUCTOR-8.2NH-SL0402_SL0402_8.8.2nHSL0402L93INDUCTOR-8.2NH-SL0402_SL0402_8.8.2nHSL0402L94INDUCTOR-1UH-9A-SPL1209_INDSM2-1uH-9AINDSM2-12R95X9R4L95INDUCTOR-NOLOAD-A-SL0402_SL040no loadSL0402L96INDUCTOR-1.8NH-280MA-SL0402_SL01.8nHSL0402L97INDUCTOR-1.8NH-280MA-SL0402_SL01.8nHSL0402L98INDUCTOR-NOLOAD-A-SL0402_SL040no loadSL0402L99INDUCTOR-1.8NH-280MA-SL0402_SL01.8nHSL0402L100INDUCTOR-1.8NH-280MA-SL0402_SL01.8nHSL0402LED1LTST-C190KGKT_LED0603_LTST-C190LTST-C190KGKTLED0603LED2LTST-C190KGKT_LED0603_LTST-C190LTST-C190KGKTLED0603LED3LTST-C190KGKT_LED0603_LTST-C190LTST-C190KGKTLED0603LED4LTST-C190KGKT_LED0603_LTST-C190LTST-C190KGKTLED0603LED5LTST-C190KGKT_LED0603_LTST-C190LTST-C190KGKTLED0603M1HOLE_8R00D3R50_HOLE_8R00D35R0_HHOLE_8R00D3R50HOLE_8R00D35R0M2HOLE_8R00D3R50_HOLE_8R00D35R0_HHOLE_8R00D3R50HOLE_8R00D35R0M4HOLE_8R00D3R50_HOLE_8R00D35R0_HHOLE_8R00D3R50HOLE_8R00D35R0M5HOLE_8R00D3R50_HOLE_8R00D35R0_HHOLE_8R00D3R50HOLE_8R00D35R0M6HOLE_8R00D3R50_HOLE_8R00D35R0_HHOLE_8R00D3R50HOLE_8R00D35R0M7HOLE_8R00D3R50_HOLE_8R00D35R0_HHOLE_8R00D3R50HOLE_8R00D35R0M8HOLE_8R00D3R50_HOLE_8R00D35R0_HHOLE_8R00D3R50HOLE_8R00D35R0Q2MMBT3906LT1G_SOT23-3_MMBT3906LTMMBT3906LT1GSOT23-3Q4MMBT3906LT1G_SOT23-3_MMBT3906LTMMBT3906LT1GSOT23-3Q7MMBTA56_SOT23-3_MMBTA56MMBTA56SOT23-3Q8MMBTA56_SOT23-3_MMBTA56MMBTA56SOT23-3Q9IRLML6401TRPBF_SOT23-3_IRLML640IRLML6401TRPBFSOT23-3Q10IRLML6401TRPBF_SOT23-3_IRLML640IRLML6401TRPBFSOT23-3Q11BFP740_SOT343_BFP740BFP740SOT343Q12BFP740_SOT343_BFP740BFP740SOT343Q17MMBT3906LT1G_SOT23-3_MMBT3906LTMMBT3906LT1GSOT23-3Q18FDMS7672_SO8-5R15X6R15_FDMS7672FDMS7672SO8-5R15X6R15Q19FDD120AN15A0_DPAK_FDD120AN15A0FDD120AN15A0DPAKRV1RV-100V-4500A-VSR2-300_CAPTM-15RV-100V-4500A-VSR2-300CAPTM-15R5X4RV2RV-100V-4500A-VSR2-300_CAPTM-15RV-100V-4500A-VSR2-300CAPTM-15R5X4RV3RV-100V-4500A-VSR2-300_CAPTM-15RV-100V-4500A-VSR2-300CAPTM-15R5X4RV4RV-100V-4500A-VSR2-300_CAPTM-15RV-100V-4500A-VSR2-300CAPTM-15R5X4RV5RV-100V-4500A-VSR2-300_CAPTM-15RV-100V-4500A-VSR2-300CAPTM-15R5X4S1TSW4-RG_SWTM4-7R4X6R55_TSW4-RGTSW4-RGSWTM4-7R4X6R55T10905A00K_XFMRSM24-17R5X12R2_HX6HX6072NLTXFMRSM24-17R5X12R2T4T-10MH_INDSM4-18X17R8_10MH10MHINDSM4-18X17R8T5SUMIDAT224_XFMRSM10-13R5X14R2-SUMIDA T224XFMRSM10-13R5X14R2-AT6T-3.5MH_CM8-001R_3.5MH3.5MHCM8-001RU1AR9344_BGA409-0R65-18X18_(S1+S2AR9344BGA409-0R65-18X18U2DDRII-32M*16BIT_BGA84-0R80-8X12DDRII-32M*16bitBGA84-0R80-8X12R5U3AR9382_QFN108-040-12X12-H6R2X3RAR9382QFN108-040-12X12-H6R2X3R9U7S25FL128S_SOIC16-50-300_SPIFLASPI FLASH 128MbitSOIC16-50-300U10B50610KMLG_QFN48-050-7X7-H4R1_BB50610KMLGQFN48-050-7X7-H4R1U28SE5004L_QFN20-050-4X4-H2R5_SE50SE5004LQFN20-050-4X4-H2R5U31SE5004L_QFN20-050-4X4-H2R5_SE50SE5004LQFN20-050-4X4-H2R5U43DDRII-32M*16BIT_BGA84-0R80-8X12DDRII-32M*16bitBGA84-0R80-8X12R5U67ADM706SAR_REEL_SO8-50-154_ADM70ADM706SAR_REELSO8-50-154U68LM75BIMX_3NOPB_SO8-50-154_LM75BLM75BIMX_3NOPBSO8-50-154U70DB0603N2400ANTR_DB0603N_DB0603NDB0603N2400ANTRDB0603NU71SKY65174-21_MCM10-050-4X4_SKY65SKY65174-21MCM10-050-4X4U72DB0603N2400ANTR_DB0603N_DB0603NDB0603N2400ANTRDB0603NU73SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U74SKY65174-21_MCM10-050-4X4_SKY65SKY65174-21MCM10-050-4X4U75SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U76SKY13370-374LF_DFN6-050-1R5X1R5SKY13370-374LFDFN6-050-1R5X1R5U77SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U78DB0603N2400ANTR_DB0603N_DB0603NDB0603N2400ANTRDB0603NU79SKY65174-21_MCM10-050-4X4_SKY65SKY65174-21MCM10-050-4X4U80DB0603N2400ANTR_DB0603N_DB0603NDB0603N2400ANTRDB0603NU81SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U82SKY65174-21_MCM10-050-4X4_SKY65SKY65174-21MCM10-050-4X4U83SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U84SKY13370-374LF_DFN6-050-1R5X1R5SKY13370-374LFDFN6-050-1R5X1R5U85SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U96MAX15053_BGA9-0R50-1R5X1R5_MAX1MAX15053BGA9-0R50-1R5X1R5U97MIC5209YML_MLF8-065-3X3_MIC5209MIC5209YMLMLF8-065-3X3U99MAX3232E_SSOP16-26-209_MAX3232EMAX3232ESSOP16-26-209U100MAX5969A_TDFN10-050-3X3_MAX5969MAX5969ATDFN10-050-3X3U101DB0603N5800ANTR_DB0603N_DB0603NDB0603N5800ANTRDB0603NU102DB0603N5800ANTR_DB0603N_DB0603NDB0603N5800ANTRDB0603NU103SE5004L_QFN20-050-4X4-H2R5_SE50SE5004LQFN20-050-4X4-H2R5U104SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U105DB0603N5800ANTR_DB0603N_DB0603NDB0603N5800ANTRDB0603NU106DB0603N5800ANTR_DB0603N_DB0603NDB0603N5800ANTRDB0603NU107SE5004L_QFN20-050-4X4-H2R5_SE50SE5004LQFN20-050-4X4-H2R5U108SN74LVC1G125DCK_SC70-5_SN74LVC1SN74LVC1G125DCKSC70-5U109MAX15050_BGA16-0R50-2R0X2R0_MAXMAX15050BGA16-0R50-2R0X2R0U110MAX5974_TQFN16-050-3X3-H1R1_MAXMAX5974TQFN16-050-3X3-H1R1U111FOD817CSD_SOIC4-100-256_FOD817CFOD817CSDSOIC4-100-256U112TLV431AIDBVR_SOT23-5_TLV431AIDBTLV431AIDBVRSOT23-5U113SKY85601-11_QFN16-050-2R5X2R5-HSKY85601-11QFN16-050-2R5X2R5-H1R35U114SKY85601-11_QFN16-050-2R5X2R5-HSKY85601-11QFN16-050-2R5X2R5-H1R35X1CRYSTAL-25M-0532_X4-5R0X3R2_25M25MHzX4-5R0X3R2X2CRYSTAL-40M-3225_X4-3R2X2R5_40M40MHzX4-3R2X2R5X3CRYSTAL-40M-3225_X4-3R2X2R5_40M40MHzX4-3R2X2R5
电子小跑腿 发表于 2018-4-7 11:16
学海无涯 发表于 2018-4-7 11:20
好东西!感谢楼主!
精进攻城狮 发表于 2018-4-7 13:14
canbus007 发表于 2018-4-7 13:28
zhutao19880518 发表于 2018-4-7 14:38
杜甫能动 发表于 2018-4-7 18:14
好东西!感谢楼主!
huang8089 发表于 2018-4-7 21:08
lowuy520 发表于 2018-4-8 09:02
2749237077 发表于 2018-4-9 08:36
查看完整版本: AR9344+AR9382+B50610KMLG+SE5004L+SKY65174-21 等整套PCB封装下载
