pekyhuang6 发表于 2018-11-9 22:21
LinkIt_7697(MTK7697) 原理图及PCB
LinkIt_7697(MTK7697) 原理图及PCB用EAGLE软件打开原理图及PCBhttp://dl.ntpcb.com/attachment/photo/Day_181109/1978_c43e15417731623208c79249f9929.pnghttp://dl.ntpcb.com/attachment/photo/Day_181109/1978_b41f1541773165c2198066e21010e.png
Part    Value            Device                     Package                           Description        C1      10uF             C-0402                     C0402                           Ceramic Capacitors        C2      10uF             C-0402                     C0402                           Ceramic Capacitors        C3      100nF            C-0402                     C0402                           Ceramic Capacitors        C4      100nF            C-0402                     C0402                           Ceramic Capacitors        C5      100nF            C-0402                     C0402                           Ceramic Capacitors        C6      1uF            C-0402                     C0402                           Ceramic Capacitors        C8      10uF             C-0402                     C0402                           Ceramic Capacitors        C9      10pF             C-0402                     C0402                           Ceramic Capacitors        C10   10pF             C-0402                     C0402                           Ceramic Capacitors        C19   10uF             C-0402                     C0402                           Ceramic Capacitors        C21   10uF             C-0402                     C0402                           Ceramic Capacitors        C26   10uF             C-0402                     C0402                           Ceramic Capacitors        C27   10uF             C-0402                     C0402                           Ceramic Capacitors        D1      DF2S6.8FS      D-ESD-2P'DF2S6.8FS'      SOD-923                           SOD-923:304060009;SOD-123:304060001        D2      DF2S6.8FS      D-ESD-2P'DF2S6.8FS'      SOD-923                           SOD-923:304060009;SOD-123:304060001        D3      DF2S6.8FS      D-ESD-2P'DF2S6.8FS'      SOD-923                           SOD-923:304060009;SOD-123:304060001        D4      DF2S6.8FS      D-ESD-2P'DF2S6.8FS'      SOD-923                           SOD-923:304060009;SOD-123:304060001        F1      1A               FUSE'1206'               F1206        FR1                     SEEEDSTUDIO-OPEN-SCH-FRAME SEEEDSTUDIO-PCB-FRAME        FR2                     SEEEDSTUDIO-OPEN-SCH-FRAME SEEEDSTUDIO-PCB-FRAME        J1                     HEADER-14P-2.54            H14-2.54                        Header 14        J2                     HEADER-14P-2.54            H14-2.54                        Header 14        J3                     MICRO-USB5+4P             MICRO-USB5+5P-SMD-0.65-7.2X5.06MM5+4P-SMD-0.65-B:320010000;5+2P-SMD-0.65-AB:340032001;5+5P-SMD-0.65-7.2X5.06MM:320010050;        J4      DNP            HEADER-2P-2.0            H2-2.0-C55D32MIL        K3      button 311020045 BUTTON-4P-4.5X3.2          SW4P-SMD-4.5X3.2X2.5MM         SW4-6.0X6.0X5.0MM:311020024;SW4-8.0X8.0X9.0MM:311020028;SW4-SMD-6.0X6.0X5.0MM:311020004;SW4-SMD-3.35X3.35X1.5MM:311020030;SW4-SMD-5.2X5.2X2.5MM:311020046 L1      WLB1608-300T15   L-0603                     L0603        L4      0.33uH         L-MPM201610SR33_T          L201610        ORANGEOrange         LED'0603'                  LED-0603        PWR   GREEN            LED'0603'                  LED-0603        Q1      2N7002         MOSFET-N'SI1304BDL'      SOT-323        Q2      S9013W         TRANSISTOR-NPN-SOT323      SOT-323                           NPN audion        Q3      S9013W         TRANSISTOR-NPN-SOT323      SOT-323                           NPN audion        Q4                     TRANSISTOR-PNP             SOT-323                           PNP audion        R1      1k               R-0402                     R0402        R2      0R               R-0603                     R0603        R3      10k            R-0402                     R0402        R4      10k            R-0402                     R0402        R6      4.7k             R-0402                     R0402        R7      1k               R-0402                     R0402        R8      100k             R-0402                     R0402        R9      10k            R-0402                     R0402        R10   0R               R-0402                     R0402        R12   1k               R-0402                     R0402        R13   1k               R-0402                     R0402        R14   22R            R-0402                     R0402        R15   22R            R-0402                     R0402        R17   100R             R-0402                     R0402        R18   100R             R-0402                     R0402        R23   47k            R-0402                     R0402        R24   4.7k             R-0402                     R0402        R25   4.7k             R-0402                     R0402        R26   10k            R-0402                     R0402        R28   100K_1%          R-0402                     R0402        R29   22K_1%         R-0402                     R0402        RX      RED            LED'0603'                  LED-0603        SYS_RSTbutton 311020045 BUTTON-4P-4.5X3.2         SW4P-SMD-4.5X3.2X2.5MM         SW4-6.0X6.0X5.0MM:311020024;SW4-8.0X8.0X9.0MM:311020028;SW4-SMD-6.0X6.0X5.0MM:311020004;SW4-SMD-3.35X3.35X1.5MM:311020030;SW4-SMD-5.2X5.2X2.5MM:311020046 TX      GREEN            LED'0603'                  LED-0603        U1      CP2102N          CONVERTER-CP2102N(QFN24)   QFN24G-0.5-4X4MM        U2                     MOUDLE-MT7697F             MOUDLE40P-1.27-22X18MM        U6      ETA3410          CONVERTER-ETA3410          DFN8G-0.5-2X2MM                   3MHZ 2A High Step-DownConverter in DFN2x2-8L Package
junkyoung 发表于 2026-7-12 10:12
好好地学习。。。
hkw221 发表于 2026-7-14 09:01
好东西,支持下
查看完整版本: LinkIt_7697(MTK7697) 原理图及PCB
