topdenzengzhi 发表于 2018-12-17 21:46
采用MC9S12HY设计的带LCD接口的S12HY汽车HVAC控制板原理图与PCB
**** Hidden Message *****
Bill of Material ReportSYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_TOLCOMP_CLASSREFDESMH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH1MH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH2MH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH3MH140P108MOUNT_HOLE_MH140P108_0.1MM_280-MOUNTING HOLE ICBH4MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH5MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH6MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH7MH180-135PMOUNT_HOLE_MH180-135P_0.1 MM_28MH_180 ICBH8CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC1CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC2CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_21000PF5%DISCRETEC3CC7343-43CAP_POL_CC7343-43_DISCRETE_4.3M68UF10%DISCRETEC4C200_RAD_POLCAP_POL_C200_RAD_POL_DISCRETE_21000UF20%DISCRETEC5CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC6CC7343-31CAP_POL_CC7343-31_DISCRETE_3.1M10UF10%DISCRETEC7CC7343-43CAP_POL_CC7343-43_DISCRETE_4._168UF10%DISCRETEC8CC7343ACAP_POL_CC7343A_DISCRETE_3.1MM_47UF10%DISCRETEC9CC7343ACAP_POL_CC7343A_DISCRETE_3.1MM_47UF10%DISCRETEC10CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC11CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC12CC2012-12CAP_POL_CC2012-12_DISCRETE_1.2M10uF10%DISCRETEC13CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC14CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC15CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC16CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC17CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC18CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM18PF5%DISCRETEC19CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM18PF5%DISCRETEC20CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC27CC1210CAP_NP_CC1210_DISCRETE_2.79MM_110UF10%DISCRETEC28CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.1 M3.3 UF DISCRETEC29CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC30CC0805_OVCAP_NP_CC0805_OV_DISCRETE_0.7 M0.1uF DISCRETEC31CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_10.047UF DISCRETEC32CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC34CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC35CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC36CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_10.1 UF10%DISCRETEC37CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_31UF10%DISCRETEC41CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.35M1uF10%DISCRETEC42CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC43CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC44CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC45CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC46CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC47CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC48CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC49CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC50CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC51CCE63X55CAP_POL_CCE63X55_DISCRETE_5.5MM47UF20%DISCRETEC52CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC53CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_40.033UF10%DISCRETEC54CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC55CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC56CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC57CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4730.01UF10%DISCRETEC58SMB_4P57X3P94MMDIODE_SCHTKY_SMB_4P57X3P94MM_ICB130LB-13 ICD2SMB_4P57X3P94MMDIODE_SCHTKY_SMB_4P57X3P94MM_ICB130LB-13 ICD31206LDLED_1206LD_IC_0.75MM_370-75142_LED GREEN ICD4SMB_4P57X3P94MMDIODE_SMB_4P57X3P94MM_IC_2.40 MS1MB-13-F ICD5SMB_4P57X3P94MMDIODE_SCHTKY_SMB_4P57X3P94MM_ICB130LB-13 ICD17DIOMELF_5025ZDIODE_DIOMELF_5025_IC_2.6MM_48ZM4728A ICD18D_SMCZDIODE_D_SMC_IC_2.56 MM_480-3001SMC12AT3 ICD19LCD41_2P54_70X51MMLCD_41P_LCD41_2P54_70X51MM_IC_3GDC8799 ICDS1LCD4_5P02_79X45MMLCD_LX88461594WS6_LCD4_5P02_79XLX88461594WS6 ICDS2FUSE_26X9FUSE_FUSE_26X9_IC_13.5MM_510-00Fuse Holder ICF1CON_2X1_5P08CONN_HDR_2X1_CON_2X1_5P08_IO_18CON TB 2 IOJ1HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ2HDR203_M20CONN_HDR_3X2_HDR203_M20_IO_8.64HDR 2X3 IOJ3JUMP1X4-6040HDR-1X4_JUMP1X4-6040_IO_8.4MM_2HDR_1X4 IOJ4HDR2X8_4P2_SHRD_THPLUG_8X2_HDR2X8_4P2_SHRD_TH_IO_CON_2X8 IOJ7HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 TH IOJ8HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ9JUMP2X2-6040HDR-2X2_JUMP2X2-6040_IO_8.58MM_HDR 2X2 IOJ10JUMP1X4-6040HDR-1X4_JUMP1X4-6040_IO_8.4MM_2HDR_1X4 IOJ11HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ12HDR102CONN_HDR_2X1_HDR102_IO_8.71 MM_HDR 1X2 TH IOJ13HDR102CONN_HDR_2X1_HDR102_IO_8.58MM_2HDR 1X2 IOJ17HDR103CONN_HDR_3X1_HDR103_IO_8.6MM_21HDR TH 1X3 IOJ18HDR205CONN_HDR_5X2_HDR205_IO_330MIL_2HDR_2X5 IOJ20HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP1HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP2HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP3HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP4HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP5HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP6HDR101CONN_HDR_1X1_HDR101_IO_8.585 MMHDR 1X1 IOJP7IND_SRU1038_SMINDUCTOR_FERRITE_A_IND_SRU1038_47UH DISCRETEL1DR127INDUCTOR_FERRITE_DR127_DISCRETE68UH20%DISCRETEL2IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL3IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL4IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL5IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL10IND_0805BEAD_IND_0805_DISCRETE_1.05 MM_330 OHM25%DISCRETEL11SOT23NPN_SOT23_IC_1.26 MM_480-75156_BC847AL ICQ1SOT23MOSFET_N_SOT23_IC_1.11MM_480-75MGSF1N02LT1G ICQ2SOT23NPN_SOT23_IC_1.26 MM_480-75156_BC847AL ICQ3RC0805_OVRES_RC0805_OV_DISCRETE_0.6MM_475601%DISCRETER1RC2010RES_RC2010_DISCRETE_0.889MM_4700.01 OHM1%DISCRETER2RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER3RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER4RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER5RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER6RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER7RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_13.9K5%DISCRETER8RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER9RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER10RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER11RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER12RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_11005%DISCRETER13RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER14RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER15RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER16RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER17RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER18RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER19RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER20RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER24RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_32.2K5%DISCRETER25RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER26RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_41.0K5%DISCRETER27RC1206_OVRES_RC1206_OV_DISCRETE_470-782460.4 DISCRETER29RC0805_OVRES_RC0805_OV_DISCRETE_470-759010K DISCRETER30RC1206_OVRES_RC1206_OV_DISCRETE_470-782460.4 DISCRETER31RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER32RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_52205%DISCRETER34RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER36RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER37RC0805_OVRES_RC0805_OV_DISCRETE_0.55MM_41M5%DISCRETER38RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER39RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER40RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER42RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER43RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER44RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER45POT3_3310YPOT_POT3_3310Y_DISCRETE_18.9MM_10k20%DISCRETER46RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER47RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER48RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER49RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER50RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER51RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER52RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER53RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER54RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_6820.0K5%DISCRETER55RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER56RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_44.7K5%DISCRETER57RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER58RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER59RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER60RC0805_OVRES_RC0805_OV_DISCRETE_0.7MM_4710.0K1%DISCRETER61RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER62RC0805_OVRES_RC0805_OV_DISCRETE_0.7 MM_21.0K1%DISCRETER63RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER64RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER65RC0805_OVRES_RC0805_OV_DISCRETE_0.6 MM_40ohm1%DISCRETER66RC0805_OVRES_RC0805_OV_DISCRETE_0.70 MM_1.5K1%DISCRETER67TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP1TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP2TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP3TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP4TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP5TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP6TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP7TESTPOINT_400MILT_POINT_S_TESTPOINT_400MIL_IC_0TOUCH PAD ICTP8TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP9TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP10TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP11TESTPOINT_135_070MILTESTLOOP_TESTPOINT_135_070MIL_ITESTLOOP IOTP12TO263_8LM2676_8P_TO263_8_IC_4.64MM_312LM2676S-5.0 ICU1LQFP100_0P5_14X14P9S12HY64J0MLL_LQFP100_0P5_14X1MC9S12HY/HA ICU2TSOP3_2P54_6X5P6TSOP34838_3P_TSOP3_2P54_6X5P6_ITSOP34838 ICU3SC70-5_ACI_LM94022_SC70-5_A_IC_1.1 MM_3LM94022 ICU4PQFN_16_12X12_AMC33988_16P_PQFN_16_12X12_A_IC_MC33984CPNA ICU7SO8_1P27_4X5TJA1040T_SO_8P_SO8_1P27_4X5_IC_TJA1040T ICU8TSSOP16MPR083EJR2_TSSOP16_IC_1.2MM_312MPR084EJ ICU9HSOP44_11X16MMMC33932_HSOP44_11X16MM_IC_3.4 MMC33932 ICU10HSOP44_11X16MMMC33932_HSOP44_11X16MM_IC_3.4 MMC33932 ICU11XTAL-XT49MXTAL_XTAL-XT49M_IC_5.8MM_230-778MHz ICY1
bidezhi7777 发表于 2018-12-18 20:18
yfchen1003 发表于 2018-12-19 08:18
谢谢分享
zblin1987 发表于 2018-12-19 08:21
boo 发表于 2018-12-19 08:47
as3218710 发表于 2018-12-19 08:49
liangguige 发表于 2018-12-19 08:59
不错
jayehong 发表于 2018-12-19 09:01
感谢分享
liyongyi3 发表于 2018-12-19 09:11
益达 发表于 2018-12-21 09:23
页: [1] 2 3 4 5 6 7
查看完整版本: 采用MC9S12HY设计的带LCD接口的S12HY汽车HVAC控制板原理图与PCB
