英特尔8层 IBEXPEAK-M+N11M-GE1笔记本电脑主板PCB共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECE0604CAP_NB_C7343D_H79_DISCRETE_330U330UF/2VNB_C7343D_H79CE2703CAP_C7343D_H75_DISCRETE_220UF/4220UF/4VC7343D_H75CE2704CAP_C7343D_H75_DISCRETE_220UF/4220UF/4VC7343D_H75CE5001CAP_C3528_DISCRETE_47UF/6.3V47UF/6.3VC3528CE5202CAP_C3528_DISCRETE_100UF/6.3V100UF/6.3VC3528CX5104C_C0402_DISCRETE_0.01UF/16V0.01UF/16VC0402D0301DIODE_SOD323_H35_DISCRETE_RB751RB751V-40SOD323_H35D2001DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D2202DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D2203DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D2205DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D2206DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D2207DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D2605DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D2701DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D2702DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D3101PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D3102PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D3103PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D3104PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D3105PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D3106IP4223_CZ6_SOT457_DISCRETE_IP42IP4223-CZ6SOT457D3107PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D3108VPORT0603_VARISTOR_0402_PANASON331KVARISTOR_0402_PANASONICD3109VPORT0603_VARISTOR_0402_PANASON331KVARISTOR_0402_PANASONICD3110PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D3111VPORT0603_VARISTOR_0402_PANASON331KVARISTOR_0402_PANASONICD3112VPORT0603_VARISTOR_0402_PANASON331KVARISTOR_0402_PANASONICD3204DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D3501DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D4508DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D4509BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323D4510BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323D4604DUAL_DIODE_CONVERT_1ANODE_SOT23BAV99SOT23D4605IP4223_CZ6_SOT457_DISCRETE_IP42IP4223-CZ6SOT457D4606DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D4609VPORT_0603_D0603_DISCRETE_EGA10EGA10603V05A1D0603D4610VPORT_0603_D0603_DISCRETE_EGA10EGA10603V05A1D0603D4801DIODE_SOD123_DISCRETE_SS0520SS0520SOD123D4802DUAL_DIODE_CONVERT_1ANODE_SOT_1BAV99SOT23_H43D5201IP4223_CZ6_SOT457_DISCRETE_IP42IP4223-CZ6SOT457D5800DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D5801DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D6101DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D6102DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D6201IP4223_CZ6_SOT457_DISCRETE_IP42IP4223-CZ6SOT457D6204PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D6205PACDN045_SC70_DISCRETE_PACDN045PACDN045YB6SC70D7601DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D7602DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D7603DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D7604DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35F4801POLY_FUSE_POLYSWITCH_2P_1812_H30.2A/30VPOLYSWITCH_2P_1812_H39F5201POLY_FUSE_POLYSWITCH_2P_1206_H71.5A/6VPOLYSWITCH_2P_1206_H71H6501SCREWHOLE_SMT_NB_SMT_NUT_C236B1U5F-M-EXPREENB_SMT_NUT_C236B189D150_LF2H6502SCREWHOLE_SMT_NB_SMT_NUT_C236B1U5F-M-EXPREENB_SMT_NUT_C236B189D150_LF2H6504SCREWHOLE_4VIA_NB_H_CT354B276D9CT354B276D94NNB_H_CT354B276D94N_P2_V4H6505SCREWHOLE_4VIA_NB_H_C354D94N_M2C354D94NB_H_C354D94N_M2_P2_V4H6506SCREWHOLE_4VIA_NB_H_C354D94N_M2C354D94NB_H_C354D94N_M2_P2_V4H6508SCREWHOLE_4VIA_NB_H_C354D94N_M2C354D94NB_H_C354D94N_M2_P2_V4H6509SCREWHOLE_4VIA_NB_H_CT354B276D9CT354B276D94NNB_H_CT354B276D94N_P2_V4H6510HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H6511HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H6512HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H6513HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H6514HOLE_NPTH_HOLE_C98D98N_C98D98NC98D98NHOLE_C98D98NH6515SCREWHOLE_4VIA_NB_H_C354D94N_M2C354D94NB_H_C354D94N_M2_P2_V4H6516SCREWHOLE_4VIA_NB_H_CT354B276D9CT354B276D94NNB_H_CT354B276D94N_P2_V4H6517SCREWHOLE_4VIA_NB_H_C354D94N_M2C354D94NB_H_C354D94N_M2_P2_V4H6518SCREWHOLE_4VIA_NB_H_CT354B276D9CT354B276D94NNB_H_CT354B276D94N_P2_V4H6519SCREWHOLE_SMT_NB_SMT_NUT_C236B1U5F-M-EXPREENB_SMT_NUT_C236B189D150_LF2H6520SCREWHOLE_SMT_NB_SMT_NUT_C236B1U5F-M-EXPREENB_SMT_NUT_C236B189D150_LF2H6521SCREWHOLE_4VIA_NB_H_C354D94N_M2C354D94NB_H_C354D94N_M2_P2_V4H6522SCREWHOLE_4VIA_NB_H_R335X335D94R335X335D94NNB_H_R335X335D94N_P2_V4H6523SCREWHOLE_4VIA_NB_H_CT276B276D9C276D94NNB_H_CT276B276D94N_P2_V4J0701ZIF_CON_30P_2HOLD_ACES_FPC_30P_FPC_CON_30PFPC_30P_20_2HOLD_RA_ACEJ1601DDR3_DIMM_204P_4HOLD_DDR3_DIMM_DDR3_DIMM_204PDDR3_DIMM_204P_24_4H_MOJ1701DDR3_DIMM_204P_4HOLD_DDR3_DIM_1DDR3_DIMM_204PDDR3_DIMM_204P_24_4H_MO_REVJ3101FPC_CON_24P_2HOLD_ENTERY_NB_FPCFPC_CON_24PNB_FPC_24P_39_2HD_RA_ENT_BJ3102FPC_CON_12P_2HOLD_SONY_FPC_12P_FPC_CON_12PFPC_12P_20_2HOLD_RA_ACESJ3103FPC_CON_12P_2HOLD_SONY_FPC_12P_FPC_CON_12PFPC_12P_20_2HOLD_RA_ACESJ4401FPC_CON_12P_2HOLD_SONY_FPC_12P_FPC_CON_12PFPC_12P_20_2HOLD_RA_ACESJ4511WTOB_CON_30P_4HOLD_IP_WTOB_30P_WTOB_CON_30PWTOB_30P_4HOLD_RAJ4601D_SUB_15P_2HOLD_SUYI_NB_D_SUB_1D_SUB_15P3RNB_D_SUB_15P_2H_SI_LF2J4801HDMI_CON_19P_4HOLD_CRE_NB_HDMI_HDMI_CON_19PNB_HDMI_19P_4H_H210_LF2J5001FPC_4P_2HOLD_WTOB_4P_49_2HOLD_RWtoB_CON_4PWTOB_4P_49_2HOLD_RAJ5103SATA_CON_22P_4HOLD_TC_NB_SATA_2SATA_CON_22PNB_SATA_22P_50_4H_SUYN_LF2J5202USB_CON_1X4P_4HOLD_SUY_USB_1X4PUSB_CON_1X4PUSB_1X4P_4HOLD_SUN_LF3J6002BATT_CON_9P_2HOLD_M_RA_NB_BATT_BATT_CON_9PNB_BATT_9P_2HLD_M_AL_LF2J6003BATT_CON_9P_2HD_ALLTOP_NB_BATT_BATT_CON_9PNB_BATT_9P_2HD_M_LF2J6101ZIF_CON_6P_2HOLD_WTOB_6P_39_2HOWTOB_CON_6PWTOB_6P_39_2HOLDJ6201ZIF_CON_6P_2HOLD_WTOB_CON_6P_31WTOB_CON_6PWTOB_CON_6P_31_2HOLD_RAJ6202BATT_CON_6P_2HOLD_FPC_6P_20_2HOFPC_CON_6PFPC_6P_20_2HOLD_ACESJ6203BATT_CON_6P_2HOLD_FPC_6P_20_2HOFPC_CON_6PFPC_6P_20_2HOLD_ACESJ6301HEADER_2X20P_NB_HD_2X20P_50_RA_HEADER_2X20PNB_HD_2X20P_50_RA_SUYNJ6302HEADER_2X20P_NB_HD_2X20P_50_RA_HEADER_2X20PNB_HD_2X20P_50_RA_SUYNJ6303HEADER_2X5P_NB_HD_2X5P_50_RA_SUHEADER_2X5PNB_HD_2X5P_50_RA_SUYJ6501ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6502ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6503ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6504ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6505ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6506ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6507ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6508ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6509ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6510ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87J6511ANT_PAD_RD9_EMI_SPRING_106X87_EEMI_SPRING_PADEMI_SPRING_106X87JP20013MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP26013MMO_S_NB_3MM_OPEN_5MIL_LF_3MM_3MM_OPEN_5MILNB_3MM_OPEN_5MIL_LFJP26023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP26033MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LFJP27013MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LFJP27023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP27033MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP27043MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP27053MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP30013MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP45113MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP4601SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJP4602SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJP4603SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJP48013MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP7201SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORTJP7202SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORTJP7203SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORTJRST20013MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTJRST20023MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTL2601BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2605BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2608BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2609BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2704BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2705BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2706BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2707BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L2902BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L2903BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L2904BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L2905BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L2906BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L4501BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43L4509BEAD_L0603_DISCRETE_1KOHM/100MH1KOhm/100MhzL0603L4510BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L4601INDUCTOR_L0603_DISCRETE_0.082UH0.082uHL0603L4602INDUCTOR_L0603_DISCRETE_0.082UH0.082uHL0603L4603INDUCTOR_L0603_DISCRETE_0.082UH0.082uHL0603L4801COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUIL4802COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUIL4803COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUIL4804COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUIL5201BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43L6101COMMON_CHOKE_12_43_CHOKE_4P_7_190Ohm/100MhzCHOKE_4P_79X47L6202COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUIL6302COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUIL7001BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L7101BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L7201BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L7202BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L7203BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L7204BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L7205BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L7302BEAD_L0603_DISCRETE_30OHM/100MH30Ohm/100MhzL0603L7304BEAD_L0603_DISCRETE_30OHM/100MH30Ohm/100MhzL0603LX5202COMMON_CHOKE_12_43_CHOKE_4P_79X90Ohm/100MhzCHOKE_4P_79X47_FUKUIPC6004C_C0603_DISCRETE_0.1UF/25V0.1UF/25VC0603PC6005C_C0603_DISCRETE_33PF/50V33PF/50VC0603PC6006C_C0603_DISCRETE_33PF/50V33PF/50VC0603PC6007C_C0603_DISCRETE_33PF/50V33PF/50VC0603PC8001C_C0402_DISCRETE_3300PF/25V3300PF/25VC0402PC8002C_C0402_DISCRETE_0.1UF/16V0.1UF/16VC0402PC8003C_C0402_DISCRETE_0.1UF/16V0.1UF/16VC0402PC8004C_C0603_DISCRETE_0.1UF/25V0.1UF/25VC0603PC8005C_C0603_DISCRETE_0.1UF/25V0.1UF/25VC0603PC8006C_C0603_DISCRETE_0.1UF/25V0.1UF/25VC0603PC8007C_C0603_DISCRETE_1UF/16V1UF/16VC0603PC8008C_C0603_DISCRETE_1UF/16V1UF/16VC0603PC8009C_C0603_DISCRETE_1UF/16V1UF/16VC0603PC8010C_C1206_H75_DISCRETE_10UF/25V10UF/25VC1206_H75PC8011C_C1206_H75_DISCRETE_10UF/25V10UF/25VC1206_H75PC8012C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8013C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8014C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8015C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8016C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8017C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8018C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8019C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8020C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8021C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8022C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8023C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8024C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8025C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8027C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8028C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8029C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8030C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8031C_C0805_H57_DISCRETE_10UF/6.3V10UF/6.3VC0805_H57PC8032C_C0402_DISCRETE_47PF/50V47PF/50VC0402PC8033C_C0402_DISCRETE_100PF/50V100PF/50VC0402PCE8001CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83PCE8002CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83PCE8100CAP_C7343D_H87_DISCRETE_100UF/6100UF/6.3VC7343D_H87PCE8101CAP_C7343D_H87_DISCRETE_100UF/6100UF/6.3VC7343D_H87PCE8200CAP_C7343D_H75_DISCRETE_100UF/2100UF/2.5VC7343D_H75PCE8201CAP_C7343D_H75_DISCRETE_100UF/2100UF/2.5VC7343D_H75PCE8300CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83PCE8500CAP_C7343D_H75_DISCRETE_100UF/2100UF/2.5VC7343D_H75PCE8501CAP_C7343D_H75_DISCRETE_100UF/2100UF/2.5VC7343D_H75PCE8600CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83PD6001IP4223_CZ6_SOT457_DISCRETE_IP42IP4223-CZ6SOT457PD8100DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8101DUAL_DIODE_CONVERT_1ANODE_SOT32BAT54SWSOT323PD8102DUAL_DIODE_CONVERT_1ANODE_SOT32BAT54SWSOT323PD8200DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8201DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8300DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8301DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8400DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8500DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8501DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8800DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PD8801DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323PJ8004SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8005SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8006SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8007SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8100SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8101SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8102SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8103SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJ8104SHORT_PIN_SC_SHORTPIN_SHORTPINSHORTPINSHORTPINPJ8807SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTPJP80013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP80023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP80033MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP81003MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHINGPJP81013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP81023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP81033MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFPJP81043MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFPJP81053MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFPJP82003MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP82013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP82023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP82033MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP82043MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP83003MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHINGPJP83013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP83023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFPJP83033MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFPJP83043MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP84013MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHINGPJP84023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP85013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP85023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP85033MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP86003MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHINGPJP86013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP86023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPJP88003MMO_S_1MM_OPEN_5MIL_FLASHING_11MM_OPEN_5MIL1MM_OPEN_5MIL_FLASHINGPJP88013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPPL8001INDUCTOR_INDUCTOR_2P_287X260_DI1UHINDUCTOR_2P_287X260PL8002INDUCTOR_INDUCTOR_2P_287X260_DI1UHINDUCTOR_2P_287X260PL8100INDUCTOR_INDUCTOR_2P_287X260__14.7UHINDUCTOR_2P_287X260PL8101INDUCTOR_INDUCTOR_2P_287X260__22.2UHINDUCTOR_2P_287X260PL8200INDUCTOR_CHOKE_2P_453X394_CYN_D0.56UHCHOKE_2P_453X394_CYNPL8300INDUCTOR_INDUCTOR_2P_287X260_DI1UHINDUCTOR_2P_287X260PL8400INDUCTOR_NB_INDUCTOR_2P_205X1852.2UHNB_INDUCTOR_2P_205X185PL8500INDUCTOR_CHOKE_2P_453X394_CYN_D0.56UHCHOKE_2P_453X394_CYNPL8600INDUCTOR_INDUCTOR_2P_287X260_DI1UHINDUCTOR_2P_287X260PL8800INDUCTOR_INDUCTOR_2P_287X260__36.8UHINDUCTOR_2P_287X260PL8801BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43PL8802BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43PL8803BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43PQ8001PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8002PH8230E_MB_SOT669_COLAY_DISCR_1RJK0353DPA-00-J0MB_SOT669_COLAYPQ8003PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8004PH8230E_MB_SOT669_COLAY_DISCR_1RJK0353DPA-00-J0MB_SOT669_COLAYPQ8051UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBPQ8052UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBPQ8100SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ8101SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ8102PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8103PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8200PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8201PH8230E_MB_SOT669_COLAY_DISCR_1RJK0353DPA-00-J0MB_SOT669_COLAYPQ8202UM6K1N_NB_SC70_S6_DISCRETE_UM6KUM6K31NSC70_S6PQ8203PH8230E_MB_SOT669_COLAY_DISCR_1RJK0353DPA-00-J0MB_SOT669_COLAYPQ8300PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8301PH8230E_MB_SOT669_COLAY_DISCR_1RJK0353DPA-00-J0MB_SOT669_COLAYPQ8302UM6K1N_NB_SC70_S6_DISCRETE_UM6KUM6K31NSC70_S6PQ8400N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43PQ8500PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8501PH8230E_MB_SOT669_COLAY_DISCR_1RJK0353DPA-00-J0MB_SOT669_COLAYPQ8502UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBPQ8503PH8230E_MB_SOT669_COLAY_DISCR_1RJK0353DPA-00-J0MB_SOT669_COLAYPQ8600PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8601PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ8602N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43PQ8603NPN_SOT23_SOT23_H43_DISCRETE_PMPMBS3904SOT23_H43PQ8800SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ8801SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ8802P_MOS_SO8_SOIC_8P_50_197X236_DIPMK35EPSOIC_8P_50_197X236PQ8803P_MOS_SO8_SOIC_8P_50_197X236_DIPMK35EPSOIC_8P_50_197X236PQ8804UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBPQ8805UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBPQ8808N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43PQ9100PH8230E_MB_SOT669_COLAY_DISCRETRJK0355DPA-00-J0MB_SOT669_COLAYPQ9101SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ9102SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ9103SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ9104SI7840DP_EMB20N03V_DISCRETE_EMBEMB20N03VEMB20N03VPQ9105PUMD12_SOT363_PHILIPS_DISCRETE_PUMD12SOT363_PHILIPSPQ9106PUMD12_SOT363_PHILIPS_DISCRETE_PUMD12SOT363_PHILIPSPRN86004R8PS_4R8P0402_H20_DISCRETE_100100KOHM4R8P0402_H20PRN86014R8PS_4R8P0402_H20_DISCRETE_100100KOHM4R8P0402_H20PRN86024R8PS_4R8P0402_H20_DISCRETE_10K10KOHM4R8P0402_H20PRN88014R8PS_4R8P0402_H20_DISCRETE_100100KOHM4R8P0402_H20PT6008TEST_POINT_NB_TPC28T_68_TPC28TTPC28TNB_TPC28T_68PU8000RT8152GQW_MB_QFN_32P_20_S197_RIRT8152DGQWMB_QFN_32P_20_S197_RIC_4VIAPU8101RT8206AGQW_4VIA_NB_QFN_32P_S197RT8206AGQWNB_QFN_32P_S197_PA_S_H31_4VPU8102UP7714HMA5_MB_SOT23_S5_MAX_IC_UUP7714BMA5-00MB_SOT23_S5_MAXPU8200RT8202APQW_4VIA_MB_QFN_16P_20_SRT8202APQWMB_QFN_16P_20_S118_PAD_4VPU8300RT8202APQW_4VIA_MB_QFN_16P_20_SRT8202APQWMB_QFN_16P_20_S118_PAD_4VPU8301UP7711U8_4VIA_MB_SOIC_8P_50_197UP7711U8MB_SOIC_8P_50_197X236_PD_4VPU8400RT8015BGQW_MB_DFN_10P_20_S118_PRT8015BGQWMB_DFN_10P_20_S118_PAD_RIPU8500RT8202APQW_4VIA_MB_QFN_16P_20_SRT8202APQWMB_QFN_16P_20_S118_PAD_4VPU8600RT8152GQW_MB_QFN_32P_20_S197_RIRT8152DGQWMB_QFN_32P_20_S197_RIC_4VIAPU8800MB39A132_4VIA_MB_QFN_32P_20_S19MB39A132MB_QFN_32P_20_S197_PAD_A_4VPU8801LMV321M5X_NB_SOT23_S5_T_IC_LMV3LMV321IDBVRNB_SOT23_S5_TQ0301N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q2001N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q2101N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q2104N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q2404N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q2620N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q2621N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q2801UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ2802UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ2803UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ2901N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002ET1GSOT23_H43Q2902UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ2903UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ3002N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q3101UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ3102UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ3204N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q3512N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q3552N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q4501UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ4502N_MOS_SO6_SO6_H43_DISCRETE_SI34SI3456BDVSO6_H43Q4503N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q4504P_MOS_SOT23_SOT23_PROLIFIC_DISCPA203EMGSOT23_PROLIFICQ4602UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ4801N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q5001NB_NPN_SOT23_NB_BJT_SOT23_H43_DPMBS3904NB_BJT_SOT23_H43Q5701UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5702UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5703UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5704UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5705UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5706UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5707UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5712UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5713UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5715UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5800UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ6201UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ7201N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q7202N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q7401N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q7403N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q7404N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q7407N_MOS_SOT23_NBS_SOT23_H43_DISCR2N7002NBS_SOT23_H43Q7601SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ7602SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ7603SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ7604UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ7605SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ7606UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ7607UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBR0301R_R0402_H16_DISCRETE_49.9OHM49.9OhmR0402_H16SLR1804SL_0603_SHORTPIN_R0603_SHORTLASHORT LANDSHORTPIN_R0603U0301CN80617004128AA_NB_BGA_1288P_13CN80617004128AANB_BGA_1288P_1339X1102U1801LMV321M5X_SOT23_S5_RD1_IC_LMV32LMV321IDBVRSOT23_S5_RD1U2001IBEXPEAK_M_NB_BGA_1071P_20_1063IBEXPEAK-MNB_BGA_1071P_20_1063X984U2401NC7SZ08M5_SC70_S5_IC_NC7SZ08P5XNC7SZ08P5X_NLSC70_S5U2801SST25LF040A_SOIC_8P_50_213X311_SST25VF032BSOIC_8P_50_213X311U2901ICS9LVS3162AKLFT_VIA_NB_QFN_32PICS9LVS3162AKLFTNB_QFN_32P_S197_PAD_ICS_VU3001IT8541E_L_QFP_128P_16_630X630_IIT8570EQFP_128P_16_630X630U3501ASM1452_VIA_NB_QFN_42P_20_354X1ASM1452NB_QFN_42P_20_354X138_PAD_VU3502PI5V330_SOIC_16P_25_197X236_IC_TS5V330CDBQRSOIC_16P_25_197X236U3504PI3L100_SOIC_16P_25_193X236_IC_PI5C3257QESOIC_16P_25_193X236U3505PI3L100_SOIC_16P_25_193X236_IC_PI5C3257QESOIC_16P_25_193X236U3507PI3L100_SOIC_16P_25_193X236_IC_PI5C3257QESOIC_16P_25_193X236U4601SN74LVC1G125DCKR_SOT753_IC_74LV74LVC1G125GVSOT753U4602SN74LVC1G125DCKR_SOT753_IC_74LV74LVC1G125GVSOT753U4801PI3HDMI201ZFE_PERICOM_QFN_56P_2PI3HDMI201ZFEQFN_56P_20_433X197_PADU4803NC7SZ08M5_SOT23_S5_SC70_RD4_H43NC7SZ08P5XSOT23_S5_SC70_RD4_H43U5002G781_1_SO8_H69_IC_G781G781SO8_H69U5801NC7SZ08M5_SOT23_S5_SC70_RD4_H43NC7SZ08P5XSOT23_S5_SC70_RD4_H43U5802NC7SZ08M5_NB_SOT23_S5_SC70_FAIRNC7SZ08P5XNB_SOT23_S5_SC70_FAIRCHILDU5803NC7SZ08M5_SOT23_S5_SC70_RD4_H43NC7SZ08P5XSOT23_S5_SC70_RD4_H43U7001N10M_GS_S_NB_BGA_533P_31_906X90N11M-GE1NB_BGA_533P_31_906X906_H83U7002NC7SZ08M5_SC70_S5_IC_NC7SZ08P5XNC7SZ08P5X_NLSC70_S5U7501EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7502EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7503EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7504EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7505EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7506EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7507EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7508EDJ1108BDBG_NB_BGA_78P_31_417X2EDJ1108BDBG-DJ-FNB_BGA_78P_31_417X295U7601NC7SZ08M5_NB_SOT23_S5_SC70_FAIRNC7SZ08P5XNB_SOT23_S5_SC70_FAIRCHILDX2001CRYSTAL_SMD_23GND_XTAL_4P_315X132.768KhzXTAL_4P_315X150X2101CRYSTAL_XTAL_2P_236X138_DISCRET25MhzXTAL_2P_236X138X2902CRYSTAL_SMD_24GND_XTAL_4P_126X914.31818MhzXTAL_4P_126X98_EPSX3001CRYSTAL_SMD_23GND_XTAL_4P_272X532.768KhzXTAL_4P_272X55X7401CRYSTAL_SMD_24GND_XTAL_4P_236X127MhzXTAL_4P_236X138 PCB文件共享。没有原理图。。 回复可见下载。。
**** Hidden Message *****
PS: 老吴花钱弄来的给大家共享学习的,禁止转载到网上,谢谢合作 谢谢分享 高端啊
