老吴 发表于 2019-3-3 17:33
UL50A  8层笔记本电脑主板PCB文件共享 SU9400/SU93
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECE0501CAP_C7343D_H75_DISCRETE_100UF/2100UF/2.5VC7343D_H75CE0502CAP_C7343D_H75_DISCRETE_100UF/2100UF/2.5VC7343D_H75CE6701CAP_C3528_H47_RD9_DISCRETE_47UF47UF/6.3VC3528_H47_RD9CE8001CAP_NB_C7343D_H79_DISCRETE_330U330UF/2VNB_C7343D_H79CE8002CAP_NB_C7343D_H79_DISCRETE_330U330UF/2VNB_C7343D_H79CE8101CAP_C3528_DISCRETE_100UF/6.3V100UF/6.3VC3528CE8102CAP_C3528_DISCRETE_100UF/6.3V100UF/6.3VC3528CE8201CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83CE8202CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83CE8301CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83CE8302CAP_NB_C7343D_H83_DISCRETE_220U220UF/2VNB_C7343D_H83CN3101C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VC_ARRAY_8P_79X49_H28CN3102C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VC_ARRAY_8P_79X49_H28CN3103C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VC_ARRAY_8P_79X49_H28CN3104C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VC_ARRAY_8P_79X49_H28CN3105C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VC_ARRAY_8P_79X49_H28CN3106C_ARRAYS_C_ARRAY_8P_79X49_H28_D33PF/50VC_ARRAY_8P_79X49_H28D0301DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D1501DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D2001BAT54C_SOT23_H43_DISCRETE_BAT54BAT54CSOT23_H43D2201DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D2301BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323D2302BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323D3001DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D3101BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323D4601BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323D4602BAT54AW_SOT323_DISCRETE_BAT54AWBAT54AWSOT323D5001BAT54C_SOT23_H43_DISCRETE_BAT54BAT54CSOT23_H43D6001DIODE_SOD123_DISCRETE_SS0540SS0540SOD123D6005DF5A_SOT23_S5_SC70_RD4_H43_DISCDF5A6.8FUSOT23_S5_SC70_RD4_H43D6101SCHOTTKY_DIODE_CHENMKO_SOD323_OCH751H-40PTSOD323_ON_H35D6701VPORT_0603_D0603_DISCRETE_EGA10EGA10603V05A1D0603D6702VPORT_0603_D0603_DISCRETE_EGA10EGA10603V05A1D0603D8101DUAL_DIODE_CONVERT_1ANODE_SOT32BAT54SWSOT323D8102DUAL_DIODE_CONVERT_1ANODE_SOT32BAT54SWSOT323D8103DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D8201DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D8301DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D8302DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D8801DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D8803DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D8804DIODE_PHILIPS_SOD323_ON_H35_DIS1SS355PTSOD323_ON_H35D9201DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323D9202DUAL_DIODE_3CATHODE_SOT323_DISCBAT54CWSOT323EC6819C_C0402_DISCRETE_33PF/50V33PF/50VC0402EPAD01ANT_PAD_RD9_SMDPAD_264X79_SMD26SMD267X79SMDPAD_264X79F6701POLY_FUSE_POLYSWITCH_2P_1812_H21.1A/6VPOLYSWITCH_2P_1812_H24H1HOLE_PTH_NB_H_C315D110_153_P2_CC315D110NB_H_C315D110_153_P2H2HOLE_PTH_NB_H_C315D110_153_P2_CC315D110NB_H_C315D110_153_P2H3HOLE_PTH_NB_H_C315D110_153_P2_CC315D110NB_H_C315D110_153_P2H4HOLE_PTH_NB_H_C315D110_153_P2_CC315D110NB_H_C315D110_153_P2H5HOLE_PTH_NB_H_C315D110_153_P2_CC315D110NB_H_C315D110_153_P2H6HOLE_PTH_NB_H_C315D110_153_P2_CC315D110NB_H_C315D110_153_P2H7HOLE_PTH_NB_H_CRT335X315B315D11CRT335X315B315D110NB_H_CRT335X315B315D110_P2H8HOLE_PTH_NB_H_C197D110_134_P2_CC197D110NB_H_C197D110_134_P2H9HOLE_PTH_NB_H_C197D110_134_P2_CC197D110NB_H_C197D110_134_P2H10HOLE_PTH_NB_H_C197D110_134_P2_CC197D110NB_H_C197D110_134_P2H11HOLE_PTH_NB_H_C197D110_134_P2_CC197D110NB_H_C197D110_134_P2H12HOLE_PTH_NB_H_ST394B315D110_P2_ST394B315D110NB_H_ST394B315D110_P2H13SCREWHOLE_SMT_NB_SMT_NUT_CT217BT12JNB_SMT_NUT_CT217BI67D47_LF2H14SCREWHOLE_SMT_NB_SMT_NUT_CT217BT12JNB_SMT_NUT_CT217BI67D47_LF2H15HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H16HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H17HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H18HOLE_PTH_NB_H_C177D130_P2_C177IC177I150D130NB_H_C177D130_P2H19SCREWHOLE_SMT_NB_SMT_NUT_CT217BT12JNB_SMT_NUT_CT217BI67D47_LF2H20SCREWHOLE_SMT_NB_SMT_NUT_CT217BT12JNB_SMT_NUT_CT217BI67D47_LF2H21HOLE_NPTH_HOLE_O110X91DO110X91NO110X91DO110X91NHOLE_O110X91DO110X91NJ0301BTOB_CON_31P_F_BTOB_CON_31P_39_BTOB_CON_31PBTOB_CON_31P_39_FJ3101FPC_CON_24P_2HOLD_ENTERY_NB_FPCFPC_CON_24PNB_FPC_24P_39_2HD_RA_ENT_BJ3102ZIF_CON_6P_2HOLD_WTOB_6P_49_2HOWtoB_CON_6PWTOB_6P_49_2HOLD_RA_ACES1J3801FPC_4P_2HOLD_WTOB_4P_49_2HOLD_RWtoB_CON_4PWTOB_4P_49_2HOLD_RA_ACJ4401FPC_CON_12P_2HOLD_SONY_FPC_12P_FPC_CON_12PFPC_12P_20_2HOLD_RA_ET_Z96JJ4601WTOB_CON_40P_13HOLD_WTOB_40P_20WTOB_CON_40PWTOB_40P_20_13HOLDJ5001WTOB_CON_4P_WTOB_4P_49_RA_IO_WTWtoB_CON_4PWTOB_4P_49_RAJ5101SATA_CON_22P_4HOLD_TC_NB_SATA_2SATA_CON_22PNB_SATA_22P_50_4H_SUYN_LF2J5102SATA_CON_13P_4HOLD_OCTEK_NB_SATSATA_CON_13PNB_SATA_13P_4H_SUYIN_LF2J6001HEADER_1X4P_NB_WTOB_D_1X4P_98_SWAFER_HD_4PNB_WTOB_D_1X4P_98_SIN_LF2J6002BATT_CON_9P_2HOLD_M_RA_NB_BATT_BATT_CON_9PNB_BATT_9P_2HLD_M_AL_LF2J6101ZIF_CON_6P_2HOLD_WTOB_6P_49_2HOWtoB_CON_6PWTOB_6P_49_2HOLD_RA_ACES1J6701FPC_CON_18P_2HOLD_ACES_FPC_18P_FPC_CON_18PFPC_18P_20_2HOLD_RA_ACE_BJ6702FPC_CON_8P_2HOLD_MOLEX_FPC_CON_FPC_CON_8PFPC_CON_8P_20_2HOLD_ACESJ6703ZIF_CON_6P_2HOLD_WTOB_6P_49_2HOWtoB_CON_6PWTOB_6P_49_2HOLD_RA_ACES1J6704FPC_4P_2HOLD_WTOB_4P_49_2HOLD_RWtoB_CON_4PWTOB_4P_49_2HOLD_RA_ACJ6801BTOB_CON_60P_8HOLD_M_NB_BTOB_60BTOB_CON_60PNB_BTOB_60P_31_8HOLD_M_H87J6802BTOB_CON_60P_8HOLD_M_NB_BTOB_60BTOB_CON_60PNB_BTOB_60P_31_8HOLD_M_H87J8112SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJ9204SHORT_PIN_SC_SHORTPIN_SHORTPINSHORTPINSHORTPINJP1201SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORTJP1202SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORTJP1203SHORT_PIN_RECTANGLE_TV_RTC_SHORSHORT_PINTV_RTC_SHORTJP14013MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LFJP14023MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LFJP14033MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LFJP14043MMO_S_NB_2MM_OPEN_5MIL_LF_2MM_2MM_OPEN_5MILNB_2MM_OPEN_5MIL_LFJP15023MMO_S_NB_1D8MM_OPEN_5MIL_1.8MM1.8MM_OPEN_5MILNB_1D8MM_OPEN_5MILJP23013MMO_S_NB_1D8MM_OPEN_5MIL_1.8MM1.8MM_OPEN_5MILNB_1D8MM_OPEN_5MILJP80013MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP80023MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPJP81013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPJP81023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP81033MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTJP81043MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTJP81053MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTJP81063MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTJP81073MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTJP81083MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTJP81093MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPJP82013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPJP82043MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP83013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPJP83023MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP83093MMO_S_NB_1MM_OPEN_5MIL_FLASH_L1MM_OPEN_5MILNB_1MM_OPEN_5MIL_FLASH_LFJP84013MMO_S_3MM_OPEN_5MIL_SP_3MM_OPE3MM_OPEN_5MIL3MM_OPEN_5MIL_SPJP8801SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJP8802SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJP8803SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJP8804SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJP8807SHORT_PIN_RECTANGLE_NB_PWR_FB_SSHORT_PINNB_PWR_FB_SHORT_PTJRST13MMO_S_NB_OPEN2_5MIL_PT_SGL_JUMSGL_JUMPNB_OPEN2_5MIL_PTL6701BEAD_L0805_H43_DISCRETE_80OHM/180Ohm/100MhzL0805_H43L6801BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L6802BEAD_L0603_DISCRETE_120OHM/100M120Ohm/100MhzL0603L8001INDUCTOR_INDUCTOR_2P_287X260_DI0.68UHINDUCTOR_2P_287X260L8101INDUCTOR_INDUCTOR_2P_287X260__14.7UHINDUCTOR_2P_287X260L8102INDUCTOR_INDUCTOR_2P_291X264_TO4.7UHINDUCTOR_2P_291X264_TOKOL8201INDUCTOR_INDUCTOR_2P_291X264__11.0UHINDUCTOR_2P_291X264_TOKOL8301INDUCTOR_INDUCTOR_2P_291X264__11.0UHINDUCTOR_2P_291X264_TOKOL8801INDUCTOR_NB_INDUCTOR_2P_244X2284.7UHNB_INDUCTOR_2P_244X228Q0301UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ0501NB_NPN_SOT23_NB_BJT_SOT23_H43_DPMBS3904NB_BJT_SOT23_H43Q0502N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43Q2201N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43Q2202UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ2401N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43Q3001N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43Q4601UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ4602N_MOS_SO6_SO6_H43_DISCRETE_SI34SI3456BDVSO6_H43Q4603N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43Q5001NB_2N7002K_NB_MOS_SOT23_H44_DIS2N7002K_T1_E3NB_MOS_SOT23_H44Q5101N_MOS_SO6_SO6_H43_DISCRETE_SI34SI3456BDVSO6_H43Q5102N_MOS_SOT23_SOT23_H43_DISCRETE_2N7002SOT23_H43Q5701UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5702UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5703UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5704UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5705UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ5706UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ8001SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8002FDMC8884_NB_POW56_5P_50_197X236FDMS7660NB_POW56_5P_50_197X236_H43Q8101SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8102SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8103SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8104SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8201SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8202SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8203SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8204NB_2N7002K_NB_MOS_SOT23_H44_DIS2N7002K_T1_E3NB_MOS_SOT23_H44Q8301SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8302SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8303SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8801P_MOS_SO8_SOIC_8P_50_197X236_HOP2003EVGSOIC_8P_50_197X236_HOLTEKQ8802SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8803SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ8804P_MOS_SO8_SOIC_8P_50_197X236_HOP2003EVGSOIC_8P_50_197X236_HOLTEKQ8808UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ8809UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ8812UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBQ9101SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ9102SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ9103SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ9104NPN_PNP_SOT353_SOT353_DISCRETE_UMC4NSOT353Q9105SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ9106SI7840DP_POWER33_5P_26_130X130_FDMC8884POWER33_5P_26_130X130_PADQ9107NPN_PNP_SOT353_SOT353_DISCRETE_UMC4NSOT353Q9201UM6K1N_NB_SOT363_NB_DISCRETE_UMUM6K1NSOT363_NBRN29132R4PS_2R4P0402_H18_DISCRETE_10K10KOHM2R4P0402_H18RN29142R4PS_2R4P0402_H18_DISCRETE_10K10KOHM2R4P0402_H18RN29162R4PS_2R4P0402_DISCRETE_33OHM33Ohm2R4P0402RN92012R4PS_2R4P0402_H18_DISCRETE_100100KOHM2R4P0402_H18RNX12024R8PS_4R8P_DISCRETE_75OHM75Ohm4R8PRP21018R10PS_8R10P_H24_DISCRETE_10KOH10kOhm8R10P_H24RP21028R10PS_8R10P_H24_DISCRETE_10KOH10kOhm8R10P_H24SLN4601SHORT_LAND_2R4P_NBP_SHORTPIN_2RSHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402_NORMSLN4602SHORT_LAND_2R4P_NBP_SHORTPIN_2RSHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402_NORMSLN4603SHORT_LAND_2R4P_NBP_SHORTPIN_2RSHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402_NORMSLN4604SHORT_LAND_2R4P_NBP_SHORTPIN_2RSHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402_NORMSLN6101SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6701SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6702SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6801SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6802SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6803SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6804SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6805SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6806SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402SLN6807SHORT_LAND_2R4P_NBP_SHORTPIN__1SHORT_LAND_2R4PNBP_SHORTPIN_2R4P0402U0301SU9400_956P_NB_BGA_956P_19_866XSU9400/SU9300NB_BGA_956P_19_866X866_SPEU0701DDR3_DIMM_204P_4HOLD_DDR3_DIMM_DDR3_DIMM_204PDDR3_DIMM_204P_24_4H_MO_REVU0801DDR3_DIMM_204P_4HOLD_DDR3_DIM_1DDR3_DIMM_204PDDR3_DIMM_204P_24_4H_MOU1001897605_NB_BGA_1362P_1063X984_IC897605NB_BGA_1362P_1063X984U2001ICH9M_SFF_NB_BGA_569P_630X630_IICH9M_SFFNB_BGA_569P_630X630U2101NC7SZ08M5_NB_SOT23_S5_SC70_FAIRNC7SZ08P5XNB_SOT23_S5_SC70_FAIRCHILDU2402ATM_SO_8P_SOIC_8P_50_197X236_ICAT24C08ANSOIC_8P_50_197X236U2901RTM875T_336_GRT_SOIC_64P_20_673RTM875T-336-GRTSOIC_64P_20_673X319U3001IT8512E_L_ITE_QFP_128P_16_630X6IT8512E-LQFP_128P_16_630X630U3101AT25HP512_SOIC_8P_50_212X315_ICMX25L8005M2C_15GSOIC_8P_50_212X315U5001G781_1_SOIC_8P_50_197X236_IC_G7G780P11USOIC_8P_50_197X236U8001MAX8796_5VIA_QFN_32P_20_S197_PAMAX8796GTJ+QFN_32P_20_S197_PAD_MAX_5VU8101RT8206AGQW_4VIA_NB_QFN_32P_S197RT8206AGQWNB_QFN_32P_S197_PA_S_H31_4VU8102RT9043_GB_SOT23_S5_H51_IC_RT904RT9043-GBSOT23_S5_H51U8201TPS51117RGYR_QFN_14P_20_138X138TPS51117RGYRQFN_14P_20_138X138_PADU8301TPS51116RGER_5VIA_QFN_24P_20_15TPS51116RGERQFN_24P_20_157X157_PAD_5VIAU8302NC7SZ08M5_NB_SOT23_S5_SC70_FAIRNC7SZ08P5XNB_SOT23_S5_SC70_FAIRCHILDU8401APL5912KACTUL_NB_SOIC_8P_50_196APL5930-KAI-TRGNB_SOIC_8P_50_196X236_PAD_AU8801MB39A132_QFN_32P_20_197X197_PADMB39A132QFN_32P_20_197X197_PAD_AMIU8802LMV321M5X_NB_SOT23_S5_T_IC_LMV3LMV321IDBVRNB_SOT23_S5_TU9201NC7SZ08M5_NB_SOT23_S5_SC70_FAIRNC7SZ08P5XNB_SOT23_S5_SC70_FAIRCHILDX2001CRYSTAL_SMD_23GND_XTAL_4P_272X532.768KhzXTAL_4P_272X55X2901CRYSTAL_XTAL_2P_197X126_TXC_H5114.318MhzXTAL_2P_197X126_TXC_H51X3001CRYSTAL_SMD_23GND_XTAL_4P_272X532.768KhzXTAL_4P_272X55
老吴 发表于 2019-3-3 17:34
PCB文件共享。回复可见。
**** Hidden Message *****
PS: 老吴花钱弄来的给大家共享学习的,禁止转载到网上,谢谢合作
miaomiao 发表于 2019-3-3 18:31
谢谢分享
天心雪 发表于 2019-3-4 08:55
shuszhao 发表于 2019-3-4 08:57
多谢分享资料,有原理图吗??
thanky0u58 发表于 2019-3-4 09:19
学海无涯 发表于 2019-3-5 08:06
精品高大上。
qi2017 发表于 2019-3-5 08:09
感谢分享,学习学习
thanky0u58 发表于 2019-3-5 08:59
liyongyi3 发表于 2019-3-5 18:11
页: [1] 2 3 4
查看完整版本: UL50A  8层笔记本电脑主板PCB文件共享 SU9400/SU9300
