RTM_4SFP_3QSFP
RTM_4SFP_3QSFP is simple RTM module with SFP+ and QSFP cages. It is compatible with AFCZ and Sayma AMC modules. Features:4 SFP+ cages3 QSFP cagesRF backplane support for White Rabbit clock distributed by low jitter WR receiverall SFP and QSFP signals controlled by I2C
https://github.com/gkasprow/RTM_4SFP_3QSFP/raw/master/RTM_SFP_QSFP.PNG
BOMCommentDescriptionDesignatorFootprintLibRefQuantity10uFNon-polarised capacitorC1, C2, C3, C4, C12A, C12B, C12C, C12D, C14A, C14B, C14C, C14D, C23A, C23B, C23C, C23D, C33A, C33B, C33C, C35A, C35B, C35C, C41A, C41B, C41C, C43A, C43B, C43CCAPC2012X135NCC0805_10UF_10V_10%_X7R28100uFPolarised capacitorC5CAPAE660X540NCAE660-540_100UF_16V_20%110uFNon-polarised capacitorC6, C7CAPC3216X140NCC1206_10UF_16V_10%_X7R2100nFNon-polarised capacitorC8, C10, C13A, C13B, C13C, C13D, C20A, C20B, C20C, C20D, C21, C22A, C22B, C22C, C22D, C24A, C24B, C24C, C24D, C25, C26, C27, C29CAPC1005X55NCC0402_100NF_16V_10%_X5R, CC0402_100NF_16V_10%_X7R231nFNon-polarised capacitorC9CAPC1005X55NCC0402_1NF_50V_10%_X7R112pFNon-polarised capacitorC11CAPC1005X55NCC0402_12PF_50V_5%_C0G11uFNon-polarised capacitorC15A, C15B, C15C, C15D, C36A, C36B, C36C, C37A, C37B, C37CCAPC1608X87NCC0603_1UF_25V_10%_X7R10100nFNon-polarised capacitorC16, C17, C28, C34A, C34B, C34C, C38A, C38B, C38C, C39A, C39B, C39C, C40A, C40B, C40C, C42A, C42B, C42C, C44A, C44B, C44C, C402CAPC0603X33NCC0201_100NF_6.3V_10%_X5R2210nFNon-polarised capacitorC18, C19CAPC1005X55NCC0402_10NF_16V_10%_X7R2zQSFP+QSFP+ 1x3 Cage (23Pins)Cage1TYCO_2170737-1TYCO_2170737-11SFP+SFP+1x4 Cage (46 Pins)Cage2TYCO_2007132-1TYCO_2007132-111888247-120 Position SFP+ Connector (Small Form-factor Pluggable)CON1A, CON1B, CON1C, CON1DTYCO_1888247-1TYCO_1888247-14BAT165Schottky DiodeD1SOD2512X110NBAT1651220R@100MHzInductorFB1A, FB1B, FB1C, FB1D, FB2A, FB2B, FB2C, FB3A, FB3B, FB3C, FB4A, FB4B, FB4C, FB5A, FB5B, FB5C, FB5DINDC2012X105NIND0805_MURATA_BLM21PG221SN1D17RTM_FRONTPANELRTM FrontpanelFP1RTM_FRONTPANELRTM_FRONTPANEL1Use only in PCBFiducial TargetFTG1, FTG2, FTG3, FTG4, FTG5, FTG6, FTG7, FTG8FIDUCIAL_TOP_S100-200FIDUCIAL_TARGET_S100-2008MIC45116-1YMP0.8V to 85% PVIN (4.75-19V), 6A Synchronous Step-Down Regulator ModuleIC1MICROCHIP_H3QFN88-52LD-PL-3MIC45116-1YMP1PCA9534PW8-Bit I2C-Bus and SMBus Low Power I/O Port with InterruptIC2A, IC2B, IC2C, IC3A, IC3B, IC3C, IC3DSOP65P640X110-16NPCA9534PW7LM75AIMM/NOPBDigital Temperature Sensor and Thermal Watchdog with Two-Wire InterfaceIC4, IC6, IC8SOP65P490X109-8NLM75AIMM/NOPB3AT24MAC402-XHM1.7V to 5.5V, I2C-Compatible (2-wire) 2-Kbit (256 x 8) Serial EEPROMIC10SOP65P640X120-8NAT24MAC402-XHM1PCA9554DB8-bit I2C-bus SMBus I/O port with interruptIC14SOP65P640X120-16NPCA9554D1MAX7357ETG+8-channel I2C-bus multiplexer with reset, INT and timeoutIC39HVQFN24IIC_MUX_MAX7357ETG+1#NAME?Single Pin MaleJ1TYCO_1469265-1TYCO_1469265-11Advanced TCAConnector 60 ATCA Male 30 Pairs (60 Signals) + 3x10 GroundJ2, J4TYCO_6469183-1TYCO_6469183-12SMAJ3AMPHENOL_132203AMPHENOL_1322031zQSFP+38Position QSFP Connector(Quad Small Form-factor Pluggable)J5A, J5B, J5CTYCO_1551920-2TYCO_1551920-23Hard Metric Type ZD90 Contacts, 6 Rows(a,b,c,d,e,f) of 10 positions + 3 Shield Rows (ab, cd, ef) of 10 Positions, Pitch 2.5 mm,Press-Fit, Right Angle ERmet ZD High Speed Differential Hard Metric Female ConnectorJ8ERNI_973028ERNI_9730281LED_AVAGO_HSME-C120LED Green 1C 2ALD1A, LD1B, LD1C, LD3A, LD3B, LD3C, LD3DLED_AVAGO_HSME-C120LED_AVAGO_HSME-C1207RedLED Red Avago C120LD2A, LD2B, LD2C, LD4A, LD4B, LD4C, LD4DLED_AVAGO_HSME-C120rev7GreenLED Green Avago C120LDxLED_AVAGO_HSME-C120rev1BlueLED Blue Avago C120LDyLED_AVAGO_HSME-C120rev1LED0603-P-RW120 or LYN971-ZLED 0603 redLED17led_0603RLED_0603R1Push ButtonPush-Button Switch SPDTPB1SW_C&K_HDT0001SW_C&K_HDT000117k5Resistor - 1%R1RESC1005X40NR0402_7K5_1%_0.0625W_100PPM1100kResistor - 1%R2RESC1005X40NR0402_100K_1%_0.0625W_100PPM12k4Resistor - 1%R3RESC1005X40NR0402_2K4_1%_0.0625W_100PPM110kResistor - 1%R4, R5, R10A, R10B, R10C, R11A, R11B, R11C, R12A, R12B, R12C, R13A, R13B, R13C, R14, R15, R16, R17A, R17B, R17C, R25, R26, R28, R31, R32, R33, R34, R35, R36, R37A, R37B, R37C, R37D, R38A, R38B, R38C, R38D, R39A, R39B, R39C, R39D, R40A, R40B, R40C, R40D, R41A, R41B, R41C, R41D, R45, R46, R48, R74, R75, R316, R317, R318, R319, R320, R321, R322, R323, R324, R325, R326, R327, R328, R329, R330, R331, R332, R333, R334, R335, R336RESC1005X40NR0402_10K_1%_0.0625W_100PPM751k6Resistor - 1%R6RESC1005X40NR0402_1K6_1%_0.0625W_100PPM1330Resistor - 1%R7, R8, R9, R18A, R18B, R18C, R29A, R29B, R29C, R42A, R42B, R42C, R42D, R43A, R43B, R43C, R43DRESC1608X55NR0603_330R_1%_0.1W_100PPM171MResistor - 1%R19, R20, R21, R22RESC3216X65NR1206_1M_1%_0.25W_100PPM40ResistorR23, R24, R27, R30, R44, R47, R73RESC1608X55NR0603_0R_JUMPER7BSS138LT1GN-CHANNEL MOSFET WITH DIODET1, T2SOT95P240X110-3NBSS138LT1G2TPTestpointTP1, TP2, TP3, TP4TPTP4#NAME?50 Ohm 3 to 300MHz RF TransformersTR1XFMR_MINI-CIRCUITS_AT1521XFMR_MINI-CIRCUITS_TC2-1TX+1 好东西啊 谢谢分享RTM_4SFP_3QSFP 学习学习一下 收藏 ,谢谢分享。 谢谢分享 学习学习
