XC7K325TFBG676_FBG676 +88E1111-BAB1I000+ISL6539IA 做的工业通信板PCB文
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBT1BATTERY_0_BR1225HC_TS518FE FL35TS518FE FL35EBR1225HCCD1CAP_POL_4_STC7343_220UF220uFSTC7343CD2CAP_POL_4_STC7343_220UF220uFSTC7343CD3CAP_POL_4_STC7343_220UF220uFSTC7343CD4CAP_POL_STC3528_47UF47uFSTC3528CD5CAP_POL_STC3528_47UF47uFSTC3528CD11CAP_POL_STC3528_47UF47uFSTC3528CD12CAP_POL_4_STC7343_220UF220uFSTC7343CD13CAP_POL_4_STC7343_220UF220uFSTC7343CD14CAP_POL_4_STC7343_220UF220uFSTC7343CD15CAP_POL_STC3528_47UF47uFSTC3528CD16CAP_POL_STC3528_10UF/16V10UF/16VSTC3528CD17CAP_POL_STC3528_220UF220uFSTC3528CD18CAP_POL_STC3528_220UF220uFSTC3528CD19CAP_POL_STC3528_220UF220uFSTC3528CD20CAP_POL_STC3528_220UF220uFSTC3528CD21CAP_POL_STC3528_220UF220uFSTC3528CD22CAP_POL_STC3528_220UF220uFSTC3528CD23CAP_POL_STC3528_220UF220uFSTC3528CD24CAP_POL_STC3528_10UF/16V10UF/16VSTC3528CD25CAP_POL_STC3528_10UF/16V10UF/16VSTC3528CD26CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD27CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD28CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD29CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD30CAP_POL_STC3528_4.7UF/16V4.7UF/16VSTC3528CD31CAP_POL_STC3528_10UF/16V10UF/16VSTC3528CD32CAP_POL_STC3528_10UF/16V10UF/16VSTC3528CD33CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD34CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD35CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD36CAP_POL_STC7343_470UF/6V470UF/6VSTC7343CD37CAP_POL_STC3528_4.7UF/16V4.7UF/16VSTC3528CD38CAP_POL_STC7343_220UF220uFSTC7343CD39CAP_POL_STC7343_220UF220uFSTC7343CD40CAP_POL_STC7343_220UF220uFSTC7343CD41CAP_POL_STC7343_220UF220uFSTC7343CD42CAP_POL_STC7343_220UF220uFSTC7343CD43CAP_POL_STC7343_220UF220uFSTC7343CD44CAP_POL_STC7343_220UF220uFSTC7343CD45CAP_POL_STC7343_220UF220uFSTC7343CD46CAP_POL_STC7343_220UF220uFSTC7343CD47CAP_POL_STC7343_220UF220uFSTC7343CD48CAP_POL_STC7343_220UF220uFSTC7343CD49CAP_POL_STC7343_220UF220uFSTC7343CD50CAP_POL_1_STC7343_47UF/25V47UF/25VSTC7343D2DIODE SCHOTTKY_0_DIODE_SS14SS14DIODED4DIODE SCHOTTKY_2_SD1206_MBR0520MBR0520SD1206D5DIODE SCHOTTKY_3_SD1714_IR_30BQIR_30BQ015SD1714D6DIODE SCHOTTKY_2_SD1206_MBR0520MBR0520SD1206D7DIODE SCHOTTKY_3_SD1714_IR_30BQIR_30BQ015SD1714D8BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23D9BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23D10BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23D11BAT54C_SOT23_SOT23_BAT54CWBAT54CWSOT23D14DIODE SCHOTTKY_0_DL4148_DL4148DL4148 100VDL4148D15DIODE SCHOTTKY_0_MM3Z2V7B_MM3Z2MM3Z2V7B 2.7VMM3Z2V7BF1FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206F2FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206F5FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206F6FUSE_0_F1206_LITTELFUSE0501020LittelFuse0501020F1206J1JTAG_JTAG_JTAGJTAGJTAGJ11FAN3_1_FAN3P_FANFANFAN3PJ12HDR 1X9_HDR1X9_HDR 1X9HDR 1X9HDR1X9J13HDR 1X9_HDR1X9_HDR 1X9HDR 1X9HDR1X9JP1HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP2HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP3HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP4HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP5HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP6HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP7HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP8HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP9HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP10HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP11HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP12HEADER_0_DIP2-79-160_1X21X2DIP2-79-160JP13FAN3_0_2X5P_UARTUART2X5PJP14FAN3_0_2X5P_UARTUART2X5PJP15J31X31X3_2JP16J31X31X3_2JP17J31X31X3_2JP18J31X31X3_2JP19J31X31X3_2JP20J31X31X3_2JP21J31X31X3_2JP22J31X31X3_2L1INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525L2INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525L3INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525L4INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525L5INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525L6INDUCTOR_IHLP2525_IHLP2525CZER1IHLP2525CZER1R0M01IHLP2525LED1LED_32_LED0805_LED_GREENLED_GreenLED0805LED2LED_32_LED0805_LED_GREENLED_GreenLED0805LED3LED_32_LED0805_LED_GREENLED_GreenLED0805LED4LED_32_LED0805_LED_GREENLED_GreenLED0805LED5LED_32_LED0805_LED_GREENLED_GreenLED0805LED6LED_32_LED0805_LED_GREENLED_GreenLED0805LED7LED_32_LED0805_LED_GREENLED_GreenLED0805LED8LED_32_LED0805_LED_GREENLED_GreenLED0805LED9LED_32_LED0805_LED_GREENLED_GreenLED0805LED10LED_32_LED0805_LED_GREENLED_GreenLED0805LED11LED_32_LED0805_LED_GREENLED_GreenLED0805LED12LED_32_LED0805_LED_GREENLED_GreenLED0805LED13LED_32_LED0805_LED_GREENLED_GreenLED0805LED14LED_32_LED0805_LED_GREENLED_GreenLED0805LED17LED_32_LED0805_LED_GREENLED_GreenLED0805LED18LED_LED0805_LEDLEDLED0805LED19LED_LED0805_LEDLEDLED0805LED20LED_LED0805_LEDLEDLED0805LED21LED_LED0805_LEDLEDLED0805LED22LED_32_LED0805_LED_GREENLED_GreenLED0805Q1MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244Q2MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244Q3MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244Q4MOS_NX4_0_SOP8-50-244_SI4410DYSI4410DYSOP8-50-244Q5MOSFET_N_TO252_AOD452AOD452TO252Q6MOSFET_N_TO252_AOD452AOD452TO252Q7MOSFET_N_TO252_AOD452AOD452TO252Q8MOSFET_N_TO252_AOD452AOD452TO252Q9MOSFET_N_TO252_AOD452AOD452TO252Q10MOSFET_N_TO252_AOD452AOD452TO252Q11MOSFET_N_TO252_AOD452AOD452TO252Q12MOSFET_N_TO252_AOD452AOD452TO252Q39MOSFET_N_NDS331N_NDS331N 460MWNDS331N 460MWNDS331NQ402020000600_0_NDT3055L_NDT3055LNDT3055L 1.3WNDT3055LR262R-0603_1_R2512_0.005,1%0.005,1%R2512R280R-0603_1_R2512_0.005,1%0.005,1%R2512SW1FPGA SEL SWITCH_2_SDA05H1SBD_SDSDA05H1SBDSDA05H1SBDTP1TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP2TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP3TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP4TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP5TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP6TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP7TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP8TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68TP9TP_TPC26B_S4_68_TPC26BTPC26bTPC26B_S4_68U1CPCI1_M_PHM0625A-T_CPCI1_MCPCI1_MPHM0625A-TU2SN74AVC4T245_D_0_D16_VALUEValueD16U3SN74AVC4T245_D_0_D16_VALUEValueD16U4SN74AVC4T245_D_0_D16_VALUEValueD16U5SN74AVC4T245_D_0_D16_VALUEValueD16U6SN74AVC4T245_D_0_D16_VALUEValueD16U8SN74AVC32T245_ZKE_0_ZKE96_VALUEValueZKE96U10CPCI4_M_6_PHM0625A-T_CPCI4_MCPCI4_MPHM0625A-TU11CPCI5_M_5_PHM0622B-T_CPCI5_MCPCI5_MPHM0622B-TU1288E1111_TFBGA117_88E1111-BAB1I088E1111-BAB1I000TFBGA117U13MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28U14MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28U1574LV14DB_SOP14-26-173_SN74HC14PSN74HC14PWSOP14-26-173U16MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150U17MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150U18MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150U19MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150U20MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U21MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U22MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U23MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U24LSF0204PWR_0_PW0014A_N_VALUEValuePW0014A_NU25SN74AVC4T245_D_0_D16_VALUEValueD16U26SN74AVC4T245_D_0_D16_VALUEValueD16U27SN74AVC4T245_D_0_D16_VALUEValueD16U5088E1111_TFBGA117_88E1111-BAB1I088E1111-BAB1I000TFBGA117U51PC28F00AP30TF_BGA64_8X10MM_BGA6BGA64_8X10MMBGA64_8X10MMU52N25Q128_SO16_SO16_SPI_FLASHSPI_FLASHSO16U54SN74LVC1T45_DVB_0_DVB_SN74LVC1TSN74LVC1T45DVBU55XC7K325TFBG676_FBG676_(S1+S2+S3xc7k325tfbg676FBG676U56IS62WV20488BLL_0_IS62WV20488BLLIS62WV20488BLLIS62WV20488BLLU57LTC1736_SOP24-26-208_LTC1736IGLTC1736IGSOP24-26-208U58ISL80102_0_DFN10-3X3_ISL80103IRISL80103IRAJZDFN10-3X3U59ISL80102_0_DFN10-3X3_ISL80103IRISL80103IRAJZDFN10-3X3U60LTC1736_SOP24-26-208_LTC1736IGLTC1736IGSOP24-26-208U61ISL6539_SSOP28_150_ISL6539IAISL6539IASSOP28_150U62ISL6539_SSOP28_150_ISL6539IAISL6539IASSOP28_150U63H5020_0_TFM48-40-300_HX5020NLHX5020NLTFM48-40-300U64MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28U65MAX3243_0_SSOP28_MAX3243EAIMAX3243EAISSOP28U6674LV14DB_SOP14-26-173_SN74HC14PSN74HC14PWSOP14-26-173U67MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150U68MAX485_1_SOP8-50-150_MAX485ESAMAX485ESASOP8-50-150U69MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150U70MAX489_0_SOP14-50-150_MAX489ESDMAX489ESDSOP14-50-150U71MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U72MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U73MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U74MAX4616_SOP14-50-150_MAX4614ESDMAX4614ESDSOP14-50-150U75PCA82C250_2_SOT96-1_PCA82C250PCA82C250SOT96-1U76PCA82C250_2_SOT96-1_PCA82C250PCA82C250SOT96-1U77DIGILENT_USB_JTAG_2_DIGILENT_USDIGILENT_USB_JTAGDIGILENT_USB_JTAGU78SN74AVC2T245_RSW_1_RSW10_VALUEValueRSW10U79SN74LVC1T45_DVB_1_DVB_SN74LVC1TSN74LVC1T45DVBU81ADP123AUJZ_R7_0_UJ_5_VALUEValueUJ_5U82SN74LVC1G18DBVR_SOT23_6_SOT23_6SOT23_6SOT23_6U83LSF0108PWR_PW0020A_VALUEValuePW0020AU84LSF0108PWR_PW0020A_VALUEValuePW0020AU85LSF0108PWR_PW0020A_VALUEValuePW0020AU86LSF0108PWR_PW0020A_VALUEValuePW0020AY1XTAL_0_X53F_XVHEELNANF-25MHZXVHEELNANF-25MHZX53FY2XTAL_0_X53F_XVHEELNANF-25MHZXVHEELNANF-25MHZX53FY3SIT9102_0_SIT9102_SIT9102SIT9102SIT9102Y4OSC_OSC4-XO53_OCJTDLJANF-125MHZOCJTDLJANF-125MHZ NCOSC4-XO53Y5OSC_OSC4-XO53_OCJTDLJANF-66MHZOCJTDLJANF-66MHZOSC4-XO53Y7OSC_OSC4-XO53_OVETDLJANF-33MHZOVETDLJANF-33MHZOSC4-XO53 学习学习一下 来看看了 期待期待
