Intel NUC8CHK Chaco Canyon 开箱拆解评测
一款特殊的NUC—NUC8CHK,这是一款商用NUC,主打低功耗,0噪音,能够7x24稳定运行。这是Intel NUC有史以来第一台无风扇的NUC,下面来看看它的表现https://image.koolshare.cn/attachment/forum/201908/26/141832dwb6tc06uuudoowu.jpg
▲本次评测的NUC8CHK是工程样机,使用牛皮纸包装
https://image.koolshare.cn/attachment/forum/201909/02/100046pkm0mmrymxnb0sfr.jpg
▲产品规格
开箱
https://image.koolshare.cn/attachment/forum/201908/26/144053ezbtqxymzthrxry9.jpg
▲NUC包装盒正面,见惯了的牛皮纸盒包装,十足的工业风
https://image.koolshare.cn/attachment/forum/201908/26/145719m4lsscsc486cmnlj.jpg
▲NUC包装盒背面
https://image.koolshare.cn/attachment/forum/201908/26/150141jrxybtbxgtbbjgee.jpg
▲打开盒盖,内部的NUC本体被泡沫包裹,可以避免运输过程中的磕碰
https://image.koolshare.cn/attachment/forum/201908/26/150443i6zi3q7wrgiwzq3i.jpg
▲揭掉最上层的泡沫垫后就能看到NUC8CHK了
https://image.koolshare.cn/attachment/forum/201908/26/150706bwpxopjjbsopcppr.jpg
▲取出NUC8CHK,可以看到每层都有泡沫垫隔开,可谓是非常严实
https://image.koolshare.cn/attachment/forum/201908/26/150839tbsevtevicvwv4ug.jpg
▲盒子底部是NUC电源适配器和附件
https://image.koolshare.cn/attachment/forum/201908/26/151239q4i74f904z777nvb.jpg
▲包装盒内所有部件,全家福一张。由于是测试机的原因,电源线配备的欧标插头,国行将改为国标电源线
https://image.koolshare.cn/attachment/forum/201908/26/192510zdygmpyldxm0dgxg.jpg
▲电源厂商是LITEON
https://image.koolshare.cn/attachment/forum/201908/26/192646ngfqveamxnq30k99.jpg
▲规格是19V 3.42A,65W
https://image.koolshare.cn/attachment/forum/201908/27/090559qhg5kajajrr2bvgp.jpg
▲Intel NUC8CHK顶部
https://image.koolshare.cn/attachment/forum/201908/27/090636ty4lw4v4ba62j42o.jpg
▲Intel NUC8CHK底盖。底盖上有挂孔,支持挂壁安装
https://image.koolshare.cn/attachment/forum/201908/27/090900cyckn18v1nmnt1jk.jpg
▲使用随机附赠的橡胶圈可以放置在桌面使用
https://image.koolshare.cn/attachment/forum/201908/27/091312avos52aa2s221af1.jpg
▲正面有一个USB3.0接口和一个电源按钮
https://image.koolshare.cn/attachment/forum/201908/27/091645d2okeecwq2qfe4em.jpg
▲NUC8CHK左侧的防盗锁孔
https://image.koolshare.cn/attachment/forum/201908/27/091911m7ore0c9n0w9wu1t.jpg
▲NUC8CHK背部IO接口一览。从左往右分别是音频插孔,USB2.0接口两个,USB3.0接口一个,HDMI 1.4接口一个,HDMI 2.0接口一个,千兆RJ45端口一个,电源直流插孔一个
https://image.koolshare.cn/attachment/forum/201908/27/092221gynrmly1ctqzctne.jpg
▲NUC8CHK本体重量在547.5g左右
小结:这样一台体积小巧的NUC配备了双HDMI接口,HDMI 1.4接口最大带宽为10.2Gbps,支持8bit的色深,可以支持4K@30Hz视频播放。而HDMI 2.0接口最大带宽为18Gbps,支持10bit的色深,能够支持4K@60Hz视频播放。有了两个HDMI接口就可以组双屏,也能够音频视频分离输出。Intel NUC8CHK自带EDID emulation (扩展显示标识数据仿真)功能,由于多屏显示时因为屏幕比例和屏幕拼接方式的多样化而导致画面混乱,有了EDID emulation功能之后,即使有坏掉的显示装备也不影响整个输出设置。当坏掉的屏幕被修复或者替换之后,可以继续显示原有正常的画面。这代的Chaco Canyon ,下一代商用主机普罗沃峡谷,以及基于计算模块的Austin Beach这三个产品都有支持这个功能
拆解
https://image.koolshare.cn/attachment/forum/201908/27/112841dq3uw56uucq41o0r.jpg
▲将底壳上的4个螺丝拧松,就能拆下底壳
https://image.koolshare.cn/attachment/forum/201908/27/140702xlqf69hq9lql6t9t.jpg
▲底壳为金属,上面预置了导热贴,用于将NUC内部的M.2 SSD热量传导至底壳
https://image.koolshare.cn/attachment/forum/201908/27/140945mu00rdztz1dd7w13.jpg
▲将PCB主板从外壳中分离开
https://image.koolshare.cn/attachment/forum/201908/27/142243xq7q5q5948cdmd4d.jpg
▲PCB主板上预装了无线网卡,并预留了M.2 SSD插槽
https://image.koolshare.cn/attachment/forum/201908/27/142608x8cxk0nijzuz000i.jpg
▲背面是一块一体成型的铝板,铝板的两侧留有无线网卡的天线
https://image.koolshare.cn/attachment/forum/201908/27/143322mn88mdzvgll8v081.jpg
▲拆开铝板。可以看到NUC8CHK采用被动散热设计,没有风扇,消除了噪音,避免了灰尘可能带来的影响,减少故障的发生
https://image.koolshare.cn/attachment/forum/201908/27/143501n99wgao375gqg1z1.jpg
▲PCB主板正面
https://image.koolshare.cn/attachment/forum/201908/27/143700v6j0pzz36ap7094j.jpg
▲无线网卡为3168NGW,版型M.2 2230,1x1 MIMO规格,支持2.4G和5G,支持802.11ac,最高速率为433Mbps,集成蓝牙4.2。WiFi模块采用可拆卸设计,可以自主更换无线网卡,在WiFi 6大兴的今天,相信更多人会换上ax200
https://image.koolshare.cn/attachment/forum/201908/27/144331xn54xwn57x64m7id.jpg
▲BIOS芯片采用可拆卸设计,这样的好处是万一BIOS出问题,可以通过取下BIOS芯片使用编程器救回
https://image.koolshare.cn/attachment/forum/201908/27/144627hmbcizbtzxeipqpe.jpg
▲金士顿EMMC芯片,容量为64G,用于安装系统。芯片周围打上了一层胶,具备一定的抗摔能力,并能来带更好的稳定性。板载EMMC在容量和性能之间取得了平衡,比起传统的SSD,功耗大大降低
https://image.koolshare.cn/attachment/forum/201908/27/150448hn3u6m6ni4pn27fn.jpg
▲PS175HDM芯片,HDMI2.0a芯片,为IO接口中的HDMI2.0接口提供支持。HDMI 2.0a在HDMI 2.0的标准上加入了对HDR的支持,能够显著增强图像质量
https://image.koolshare.cn/attachment/forum/201908/27/151421wc2fs1hxmztwvfor.jpg
▲PCB主板背面
https://image.koolshare.cn/attachment/forum/201908/27/151758xz7sqqqjktjd38y3.jpg
▲CPU是Intel N3350,14nm工艺,2核2线程,主频1.10GHz,Boost频率2.4GHz,热设计功耗为6W,集成Intel HDGraphics 500GPU
https://image.koolshare.cn/attachment/forum/201908/27/151812ngkcx57ua7k3q396.jpg
▲K4E8E324EB-EGCG, LPDDR3芯片,速率为1866Mbps,单颗容量1GB,4颗共4GB。芯片周围引脚用胶水固定,具备一定的抗摔能力,并能来带更好的稳定性。板载内存能避免兼容性问题,为7x24h运行提供了保障
https://image.koolshare.cn/attachment/forum/201908/27/153410yixcip52nxww5b4e.jpg
▲IT8987VG是一款高度集成的嵌入式控制器,具有适用于移动系统应用的系统功能。用于硬件监控和系统电源管理
https://image.koolshare.cn/attachment/forum/201908/27/154928xg0l7qgcxvxcfqc7.jpg
▲Intel i211千兆网卡芯片,为IO接口中的RJ45端口提供支持
https://image.koolshare.cn/attachment/forum/201908/27/155540hs006ya6mjha0n4j.jpg
▲BD2670MWV,电源管理IC,来自ROHM
https://image.koolshare.cn/attachment/forum/201908/27/160235u81vf1050uir58iv.jpg
▲ALC256,声卡芯片,来自Realtek
https://image.koolshare.cn/attachment/forum/201908/27/172232rv8ulkqr5x8r558z.jpg
▲芯片简单示意图
小结:Intel NUC8CHK采用被动散热设计,没有风扇,消除了噪音,避免了灰尘可能带来的影响,减少故障的发生。另外,板载EMMC和内存也保证了最佳的兼容性和稳定性,可以减少后期维护的时间,为7x24h运行提供了保障 挺精致的东东,就是玩不起 终于出无风扇版本了,考虑公司以后用这个! 谢谢分享
