带雷电3端口的NAS,QNAP TS-453BT3拆解
这次为QNAP TS-453BT3搭载的是来自Western Digital的四块RED 2T硬盘。该硬盘适合家庭和中小型企业使用,采用了西数独一无二的NASware 3.0技术,提高了兼容性、集成度、可升级能力和可靠性,进而改进了NAS系统的存储性能https://image.koolshare.cn/attachment/forum/201909/18/163011hj2lienx0ldx0xlr.jpg
▲将四块RED 2T硬盘装上QNAP TS-453BT3,由于NAS系统要一直保持运行,因此可靠的硬盘至关重要。而WD RED硬盘自带的3D Active Balance Plus技术能够确保您的数据免受NAS或RAID环境中的剧烈振动和噪声影响。这项增强型双面平衡控制技术可以确保硬盘性能持续稳定
https://image.koolshare.cn/attachment/forum/201909/19/153839zzl1il80lvh1pn48.jpg
▲全家福
拆解
https://image.koolshare.cn/attachment/forum/201909/18/190723fzdpotsznaaesitp.jpg
▲将所有硬盘托盘取出
https://image.koolshare.cn/attachment/forum/201909/18/190911ef9sqijbmi9bisff.jpg
▲将背后外壳上的三颗螺丝拆除,往后推开外壳
https://image.koolshare.cn/attachment/forum/201909/21/211146vq0evc9ahqy5266q.jpg
▲拆下外壳后就能看到NAS内部的结构了。TS-453BT3出厂就搭载了双端口M.2 SATA SSD/10GbE扩充卡
https://image.koolshare.cn/attachment/forum/201909/18/191713gxbp8zpgp8lx37nc.jpg
▲拆下PCIe转SATA转接卡,卡上有四个SATA接口
https://image.koolshare.cn/attachment/forum/201909/18/191902qfhh19c91h2w1wto.jpg
▲PCIe to SATA转接卡正面
https://image.koolshare.cn/attachment/forum/201909/18/192107cs2s6addoaj26iof.jpg
▲卡上有两块ASM1062芯片,用于PCIe转SATA x2 。一块ASM1062为SATA1和SATA2提供支持,另一块ASM1062为SATA3和SATA4提供支持
https://image.koolshare.cn/attachment/forum/201909/18/192343dgm3z5x1axtbma7o.jpg
▲PCIe to SATA转接卡背面
https://image.koolshare.cn/attachment/forum/201909/18/192629dejcvvnve6xkqn1n.jpg
▲将双端口M.2 SATA SSD/10GbE扩充卡拆下
https://image.koolshare.cn/attachment/forum/201909/18/192823zg6ulmr4o833tunm.jpg
▲拆下QM2 M.2 SSD/10GbE PCIe扩充卡上的散热装甲
https://image.koolshare.cn/attachment/forum/201909/18/193142kvvh2bssosuqrqku.jpg
▲QM2 M.2 SSD/10GbE PCIe扩充卡正面一览,右侧的两个M.2槽位只支持SATA SSD
https://image.koolshare.cn/attachment/forum/201909/18/193423cwgway8dqm0yhn8y.jpg
▲TN4010,10GbE MAC芯片
https://image.koolshare.cn/attachment/forum/201909/18/194124gghur416rwuvn2uz.jpg
▲卡上还有一颗88x3310p为卡背后的RJ45端口提供支持。88x3310p是一颗5速率PHY,来自Marvell,支持100M/1G/2.5G/5G/10G
https://image.koolshare.cn/attachment/forum/201909/18/194328vqf1uuf1h4phqog2.jpg
▲将金属框架从外壳中拆出
https://image.koolshare.cn/attachment/forum/201909/18/194816geu3khz57bil3ei2.jpg
▲拧下螺丝,拿下PCB主板
https://image.koolshare.cn/attachment/forum/201909/18/195049kugssukq96igisdz.jpg
▲最后拆除风扇
https://image.koolshare.cn/attachment/forum/201909/18/195250cacbctbzzmyl00vf.jpg
▲风扇型号EFC0251B2-Q020-S99。规格12V 1.8W,大小12x12x25cm,厂商是建准
https://image.koolshare.cn/attachment/forum/201909/18/200951u3p11xwk213kvzpf.jpg
▲PCB主板反面
https://image.koolshare.cn/attachment/forum/201909/18/200330wo6fimyz3rkyifpr.jpg
▲PCB主板正面
https://image.koolshare.cn/attachment/forum/201909/18/200821qdr3d5s3x50nw95v.jpg
▲QNAP TS-453BT3搭载的内存是DDR3L 2x4GB内存,采用海力士颗粒,频率为1866MHz,电压为1.35V
https://image.koolshare.cn/attachment/forum/201909/18/201228adhcctc5zgu9znhf.jpg
▲拆除正面的散热装甲,就能看到CPU了
https://image.koolshare.cn/attachment/forum/201909/18/201318utetlvzgvzi2ka4z.jpg
▲14nm工艺Intel Celeron J3455 四核心1.5GHz处理器 (boost频率达 2.3 GHz)
https://image.koolshare.cn/attachment/forum/201909/18/201650bh8unhue9hn55uum.jpg
▲Intel i211千兆网卡,一共有两块,为背部IO接口中的两个RJ45端口提供支持
https://image.koolshare.cn/attachment/forum/201909/18/201934cz8wkvlpkpa94pqq.jpg
▲Realtek ALC262声卡,为扬声器以及背部的音频接口提供支持
https://image.koolshare.cn/attachment/forum/201909/18/202400kiazqs9s95ux1dnb.jpg
▲ASM1074,USB3.0 4端口HUB
https://image.koolshare.cn/attachment/forum/201909/18/202511seysz8wwvwl1mn8l.jpg
▲ASM1182e芯片,PCIe通道交换芯片。一共有两颗ASM1182e,一颗将J3455上的一条PCIe通道进行翻倍扩展后分成两条,一条接Intel i211网卡芯片,一条接PCIe转SATA转接卡上的一颗ASM1062芯片。另一颗将J3455上的一条PCIe通道进行翻倍扩展后分成两条,一条接Intel i211网卡芯片,一条接PCIe转SATA转接卡上的一颗ASM1062芯片
https://image.koolshare.cn/attachment/forum/201909/18/203106nnbi886g0q6iohun.jpg
▲ASM1442K,HDMI 1.4芯片,一共有两颗,分别为两个HDMI接口提供支持
https://image.koolshare.cn/attachment/forum/201909/19/152923xurhz3iuz5zr29ku.jpg
▲IT8528E EC芯片,来自ITE。用于控制开机时序,风扇控制,温度保护等等
https://image.koolshare.cn/attachment/forum/201909/18/203442b7cz68q8w0a0yc0q.jpg
▲THGBMDG5D1LBAIL,Flash芯片,大小4GB
https://image.koolshare.cn/attachment/forum/201909/18/203827ubv3jzv1zvsy91vr.jpg
▲英特尔 DSL6540 Thunderbolt3双端口控制器。TPS65983,USB Type-C和USB PD控制器
https://image.koolshare.cn/attachment/forum/201909/22/102034whabcdrhrmaqejcq.jpg
▲芯片简单示意图 谢谢分享 WD的nas看看就好,不过没ST那么坑 不错 高大上啊,只能膜拜一下了
