ntel Ghost Canyon幽灵峡谷拆解
Intel Ghost Canyon采用正方形设计,体积比以往任何一款Intel NUC都要大https://image.koolshare.cn/attachment/forum/201909/28/171648i17sbmrc7sl88sf7.jpg
▲正面从上往下是电源按钮,SD读卡器,两个USB3.1 GEN2 Type-A接口,3.5mm音频接口
https://image.koolshare.cn/attachment/forum/201909/27/151819j8zdceqh6meca96u.jpg
▲左侧的盖板采用网状镂空设计,左下角有代表性能的骷髅印记
https://image.koolshare.cn/attachment/forum/201909/27/152116cv537vqz7eiqvml7.jpg
▲换个角度,这里可以看到背后的IO接口
https://image.koolshare.cn/attachment/forum/201909/27/152405jirklhigiillznqi.jpg
▲IO接口部分,有4个USB3.1 GEN2 Type-A接口。两个千兆RJ45端口,一个HDMI 2.0a接口,两个雷电3接口和一个3.5mm音频接口。最下方是电源,左侧是C14电源插孔,右侧是电源散热风扇
https://image.koolshare.cn/attachment/forum/201909/27/152949a10uuzg9n21q8tn3.jpg
▲右侧盖板依旧采用网状镂空设计,右下角有代表性能的骷髅印记和左侧盖板形成对称。冷空气从这面被吸入,再从上方排出
https://image.koolshare.cn/attachment/forum/201909/28/201219wtwaiwiji5kcz5af.jpg
▲NUC的顶部有两个风扇,用于将内部的热量排出
https://image.koolshare.cn/attachment/forum/201909/27/155722a9o87coob9neo8c3.gif
▲冷空气从右侧被涡轮风扇吸入,热空气从上方风扇排出
https://image.koolshare.cn/attachment/forum/201909/28/201349b0sqqpk0ms6qzkk0.jpg
▲底部的铭牌,标注了NUC的生产日期和SN等信息
https://image.koolshare.cn/attachment/forum/201909/28/203145ztpobdnnzfh3uapb.gif
▲冷空气从NUC底部进入,带走电源器件热量,被电源风扇排出
拆解
https://image.koolshare.cn/attachment/forum/201909/28/210403lzef3pmjjdz3430j.jpg
▲将背部的两颗螺丝拧松,就可以向后滑出顶盖了
https://image.koolshare.cn/attachment/forum/201909/28/210403pii99vvy9ieykzz5.jpg
▲拿下顶盖部分
https://image.koolshare.cn/attachment/forum/201909/28/210403i3nc4a7scrzsgu9b.jpg
▲顶盖上侧面粘有缓冲垫,能有效遏制共振的发生
https://image.koolshare.cn/attachment/forum/201909/28/210403d2zg2qa4qg6gtp2o.jpg
▲内部有两颗风扇,其中一个风扇上半面覆盖有金属挡板,用于防止风扇打到内部的电源线缆。挡板采用镂空设计,能保证通风量。前端是风扇集线器,采用4pin PWM调速方式,两颗风扇的线缆都接在这里,统一调速
https://image.koolshare.cn/attachment/forum/201909/28/210403r9gg2h4zhksmg29g.jpg
▲拆下风扇集线器,非常小巧
https://image.koolshare.cn/attachment/forum/201909/28/210403b9ctty69dng8vr6b.jpg
▲集线器通过中间的金属触点与机箱前盖上的PCB板相连,而不是通过传统的线缆连接方式,这点做得比较精致
https://image.koolshare.cn/attachment/forum/201909/28/210403nf88r10ckm1fm88m.jpg
▲分离风扇和顶盖
https://image.koolshare.cn/attachment/forum/201909/28/210403gqaew2ia4l4eee4a.jpg
▲12V风扇,80x80x15mm,厂商是建准
https://image.koolshare.cn/attachment/forum/201909/28/210404wbvsvaov8ueziuhm.jpg
▲拆下NUC两侧的盖板
https://image.koolshare.cn/attachment/forum/201909/28/210404hmzazkojzjj0ahmk.jpg
▲拆下盖板的NUC正面
https://image.koolshare.cn/attachment/forum/201909/28/210404nc1wwcdkk2ws2gwd.jpg
▲拆下盖板的NUC背面
https://image.koolshare.cn/attachment/forum/201909/28/210404ufk3ozfoaqklicyj.jpg
▲继续拆下横梁
https://image.koolshare.cn/attachment/forum/201909/28/210404zaf8bibxwwvxpwfh.jpg
▲撬开天馈线接头
https://image.koolshare.cn/attachment/forum/201909/28/210404v9qk6ciqcx96evaq.jpg
▲移除主板卡上的8PIN供电接口和USB3.1 GEN2前置面板接口的线缆
https://image.koolshare.cn/attachment/forum/201909/28/210404wu1fi1uzi0xbd2wg.jpg
▲拿下主板卡,CPU i9 9980HK就在这块板卡中
https://image.koolshare.cn/attachment/forum/201909/28/210404yjso58yyojw8jt5k.jpg
▲继续拆下PCIe接口板卡
https://image.koolshare.cn/attachment/forum/201909/28/215431fyjku68qqno3655t.gif
▲移除前置面板USB3.1 GEN 2接口和SD读卡器所在的板卡
https://image.koolshare.cn/attachment/forum/201909/28/221603sg88p182sppi5p8j.jpg
▲板卡侧面有两个USB3.1 GEN 2下行接口,一个SD卡读卡器,正面有一个USB3.1 GEN 2下行接口和一个USB3.1 GEN 2上行接口
https://image.koolshare.cn/attachment/forum/201909/28/221617yneg3e0zefo1f09t.jpg
▲板卡背面一览
https://image.koolshare.cn/attachment/forum/201909/28/221844icjs1ydwg7tisiie.jpg
▲GL3227芯片,USB 3.1 Gen 1到SD4.0单LUN存储卡读卡器控制器。支持SD3.0 UHS-I和最新一代高速存储卡SD4.0 UHS-II卡。GL3590是一款低功耗USB 3.1 Gen 2 HUB
https://image.koolshare.cn/attachment/forum/201909/28/210405s7jz2ir99bpcz5pw.jpg
▲此时就能轻松拿出电源了。除了主板卡的8PIN电缆线和PCIe板卡的8PIN电缆线。电源还预留了6+2PIN和8PIN电缆线,用于给第二张板卡供电。都9012年了,竟然还不是全模组的电源。缺点也是显而易见的,不方便整理电缆线
https://image.koolshare.cn/attachment/forum/201909/28/223800vbdapawwdwswchsc.jpg
▲电源功率为500W,厂商是FSP(全汉)
https://image.koolshare.cn/attachment/forum/201909/28/210405umz1pgojg3nbhz0n.jpg
▲拆开电源
https://image.koolshare.cn/attachment/forum/201909/28/220827jod2dybduduhoxaa.jpg
▲电源内部构造,电源内部的元器件布局非常紧密,个别元件还使用胶水固定
https://image.koolshare.cn/attachment/forum/201909/29/110318arry9m6y33d69dwb.jpg
▲PCIe板卡正面一览,M.2插槽上覆盖有散热装甲
https://image.koolshare.cn/attachment/forum/201909/29/110318g8jzoru700zpocci.jpg
▲拆除散热装甲后可以看到,整个PCIe板卡有两条PCIe3.0x16插槽,一条未封口的PCIe3.0x4插槽,它的边上有两颗PI3EQX信号放大芯片,可以在PCIe插槽上使用软排线拓展,自由度更高。一条直通CPU的PCIe NVMe 3.0 x4插槽
https://image.koolshare.cn/attachment/forum/201909/30/003600vuf5q9y5ya44naw5.jpg
▲ASM1480,PCI-E通道Switch芯片
https://image.koolshare.cn/attachment/forum/201909/29/110318fs755kxx2ihixkce.jpg
▲侧面的10PIN供电接口和Micro-Fit接口
https://image.koolshare.cn/attachment/forum/201909/29/110318nyuu0ddmwpdxdqrp.jpg
▲PCIe板卡背面一览,两条PCIe3.0x16插槽的焊点都是完整的
https://image.koolshare.cn/attachment/forum/201909/29/110318hf9ge01k3kq1djed.jpg
▲主板卡正面一览,塑料外壳覆盖整块板卡,右下角是涡轮风扇
https://image.koolshare.cn/attachment/forum/201909/29/110318kgnsp7l7gdphvm7h.jpg
▲主板卡背面一览
https://image.koolshare.cn/attachment/forum/201909/29/122131d8z8e1bbw1n25edv.jpg
▲拆下涡轮风扇所在的外壳就能给看到内部构造了,靠近IO挡板的一侧可以安装M.2 SSD,另一侧则是安装内存。涡轮风扇规格是12v 2.46w,厂商是建准
https://image.koolshare.cn/attachment/forum/201909/29/110319dzmh7hr4zd6h51k8.jpg
▲将塑料外壳部分拆除,PCB主板卡的正面一览
https://image.koolshare.cn/attachment/forum/201909/29/110319j1nr667tzobi22tg.jpg
▲将IO挡板和散热装甲拆除。这里CPU和芯片组共同使用一个散热装甲
https://image.koolshare.cn/attachment/forum/201909/29/110319lz44hdq1p4z14zhk.jpg
▲CPU采用的是i9 9980HK,8C/16T,14nm工艺,45W TDP热设计功耗,集成HD 630 GPU。CPU采用3+2+1相供电,3相CPU核心供电,2相核显供电,1相VCCSA供电。Mosfet都为GAF8049
https://image.koolshare.cn/attachment/forum/201909/29/114449s1d8nlm8l11paipe.jpg
▲PCP81215P芯片,电源PWM管理芯片。MCDP2800BC,HDMI 2.0a芯片,厂商是MegaChips
https://image.koolshare.cn/attachment/forum/201909/29/110319h5pblaa4iib5y1yf.jpg
▲芯片组为CM246
https://image.koolshare.cn/attachment/forum/201909/29/110319zqszkrry3ywjwsk3.jpg
▲Intel i210AT网卡芯片,为IO接口中的一个RJ45端口提供支持
https://image.koolshare.cn/attachment/forum/201909/29/110319ev2ssttxgvtxv2zi.jpg
▲Intel JHL7540,Thunderbolt 3 双端口控制芯片
https://image.koolshare.cn/attachment/forum/201909/29/110319kv6kmlmli9y99vmk.jpg
▲IT5571VG芯片,来自ITE。用于控制开机时序,风扇控制,温度保护等等
https://image.koolshare.cn/attachment/forum/201909/29/110319fu9rsoku9k9xko3j.jpg
▲移除主板卡背面的屏蔽胶带,就能看到无线网卡了。网卡被焊接在PCB板上,杜绝了用户自己更换无线网卡的可能性
https://image.koolshare.cn/attachment/forum/201909/29/110320mddwwwlq9w9wb9mq.jpg
▲无线网卡采用的是Intel的AX200,2x2空间流,支持WiFi 6,支持160MHz频宽,最高速率为2.4Gbps
https://image.koolshare.cn/attachment/forum/201909/29/110320rtqtnneevc1816dk.jpg
▲Intel i219LM网卡芯片,为IO接口中的另一个RJ45端口提供支持
https://image.koolshare.cn/attachment/forum/201909/29/110320dwwp5p02f09zl3vx.jpg
▲ALC256,声卡芯片,来自Realtek
https://image.koolshare.cn/attachment/forum/201910/21/094756loo9bk1185mn3yaz.jpg
▲Intel Ghost Canyon整体芯片简单示意图 最新发布?
