shuszhao 发表于 2020-2-29 09:47
华硕WiFi6灵耀分布式路由AX6600开箱拆解
华硕灵耀AX6600 WiFi 6智联分布式路由采用两只装,不分主次,每一只都保留了完整的功能和强悍的性能。下面为大家打来这款灵耀智联分布式路由评测
https://image.koolshare.cn/attachment/forum/202002/09/145846qk2zs942zetwtz34.jpg
▲华硕WiFi6灵耀分布式路由AX6600由两台白色的AX6600组成。每一只的规格为2.4G574 Mbps+5.2G 1201Mbps+5.8G 4804Mbps
https://image.koolshare.cn/attachment/forum/202002/12/154107ky60znpmp6mgqqek.jpg
▲产品规格
开箱
https://image.koolshare.cn/attachment/forum/202002/09/145914y19tnl3xtln1k5q5.jpg
▲华硕WiFi6灵耀分布式路由AX6600包装盒正面。左上角有着WiFi 6的标识
https://image.koolshare.cn/attachment/forum/202002/09/150048keiawq50ae4oeazo.jpg
▲包装盒背面阐述了华硕灵耀AX6600的优点
https://image.koolshare.cn/attachment/forum/202002/09/150141fofqvq80i5qirq8z.jpg
▲盒内分上下两层。上层装着两台白色AX6600和说明书
https://image.koolshare.cn/attachment/forum/202002/09/150222xftl59d4gzrztgre.jpg
▲下层则是电源适配器,网线和保修卡
https://image.koolshare.cn/attachment/forum/202002/09/150252k5jnddrdr3qyd8r5.jpg
▲将包装盒内所有部件取出。有两台AX6600,一根6类屏蔽线,两个电源适配器,说明书和保修卡各一张
https://image.koolshare.cn/attachment/forum/202002/09/150326l1lhjgg1gu3b2bbf.jpg
▲电源适配器规格为19V 1.75A
https://image.koolshare.cn/attachment/forum/202002/09/150440jb9bo1mmm1s9gmmo.jpg
▲AX6600正面一览,看起来非常简洁,只有接近底部的位置有ASUS的烫金logo和指示灯
https://image.koolshare.cn/attachment/forum/202002/09/150607wxeo7mh0hwwlww3r.jpg
▲侧面做了开孔,有利于热量散出
https://image.koolshare.cn/attachment/forum/202002/09/151251j3p4dn8f4449pa7f.jpg
▲AX6600背面一览。最下方IO接口部分从左往右分别是DC电源插孔,电源开关,3个千兆LAN口,一个2.5G WAN口,一个USB3.0接口
https://image.koolshare.cn/attachment/forum/202002/09/150812qr8j7d2n1d7jjmms.jpg
▲底部采用了整块橡胶设计。左侧是WPS按钮,中间是铭牌,右侧是Reset按钮
https://image.koolshare.cn/attachment/forum/202002/09/150921hvre4roo6rst1tev.jpg
▲两台AX6600就组成了华硕WiFi6灵耀分布式路由AX6600
拆解
https://image.koolshare.cn/attachment/forum/202002/09/183721ohv1gt4dg13tp1vu.jpg
▲拆开外壳,可以看到固定在背壳上的PCB主板和天线支架
https://image.koolshare.cn/attachment/forum/202002/09/183757ufi9q70wifoxuz3t.jpg
▲去除连接到PCB主板的天馈线,取下主板。天线支架上有6根天线
https://image.koolshare.cn/attachment/forum/202002/09/184221qdkk2059ts0dh9qs.png
▲这六根天线分布如上图所示。其中有四根垂直,两根倾斜45度。垂直的四根天线中,有两根是2.4G与5.2G复用天线。这样设计的好处是,天线间彼此留有恰好的空间和器件摆布,能最小化无线发射的彼此干扰,最大化各方位信号覆盖
https://image.koolshare.cn/attachment/forum/202002/09/184532nlmuq0bjgxmi1iky.jpg
▲拆下PCB主板正面的散热装甲,露出内部的金属屏蔽盖
https://image.koolshare.cn/attachment/forum/202002/09/191955sdgu1ldddd1o3rrp.jpg
▲FLASH芯片,容量大小为256MB,用于存放路由器的固件
https://image.koolshare.cn/attachment/forum/202002/09/184615lm2vfjpllmez3e77.jpg
▲继续拆下金属屏蔽盖。金属屏蔽盖中并没有任何芯片,这块金属屏蔽盖主要为PCB另一侧的芯片做背面屏蔽
https://image.koolshare.cn/attachment/forum/202002/09/184738tnqzqiafbsbqsy1x.jpg
▲PCB主板背面做了堆叠设计,IO接口主板和PCB主板通过针脚对接。这里拆除IO接口板卡
https://image.koolshare.cn/attachment/forum/202002/09/184850evpbb8bvc8p88uu4.jpg
▲拆下PCB主板背面的金属散热装甲,内部是用于无线芯片屏蔽的金属盖
https://image.koolshare.cn/attachment/forum/202002/09/185006dk5rlopapwkl5aek.jpg
▲去除PCB主板背面的金属屏蔽盖。上侧是芯片所在区域,下侧则是PA和LNA所在区域
https://image.koolshare.cn/attachment/forum/202002/09/185101znq1m6tb9um9ym9q.jpg
▲路由器核心区域。BCM6755,2x2 Wi-Fi 6 Soc,具有一个四核1.5 GHz ARM-A7 CPU,集成两个802.11ax(2×2)WLAN,支持20/40/80 MHz频宽。在它的左侧是NT5CC256M16ER-EK,RAM芯片,容量为512MB。左上方是54991E,2.5G PHY。它的右上方是BCM53134,这是一个千兆Switch芯片
https://image.koolshare.cn/attachment/forum/202002/09/191528lnen3y29z75n57aa.jpg
▲BCM6755 Soc下方是四颗PA和LNA芯片,2.4G和5.2G各两颗
https://image.koolshare.cn/attachment/forum/202002/09/192322wv1k57y0vuh1p1vu.jpg
▲BCM43684,5G WLAN芯片,来自博通。支持4x4空间流,支持160MHz频宽,支持MU-MIMO,支持802.11ax,支持的最高速率为4.8Gbps。在它的左侧是四颗PA和LNA芯片
https://image.koolshare.cn/attachment/forum/202002/09/191831cviake3mgcbgl0i2.jpg
▲Atheros 3012,蓝牙4.0芯片,来自高通,用于手机APP客户端配置路由
https://image.koolshare.cn/attachment/forum/202002/10/132859nno57zz0i82ni53n.jpg
▲芯片简单示意图
木子健518 发表于 2020-3-26 15:09
mqchun 发表于 2020-3-26 22:15
chenwei2410 发表于 2020-3-28 09:57
好漂亮,好复杂!
xjun 发表于 2020-3-28 13:16
zlei 发表于 2020-3-28 23:08
好漂亮,好复杂!
tianfeng988 发表于 2020-8-4 08:22
学海无涯 发表于 2020-8-4 08:52
这东西不错。
5425188 发表于 2020-8-5 09:52
harmony 发表于 2021-3-13 21:32
6666666666666666
查看完整版本: 华硕WiFi6灵耀分布式路由AX6600开箱拆解
