10层DSP信号处理板PCB和原理图 TMS320DM8168+SiI9022ACNU+RTL8211DG+TPS
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECON1SD11-S7_SSIM9-98-2734_503500-09503500-0991SSIM9-98-2734CON2RJ45_2_MJ1-0204SRL_406549-1406549-1MJ1-0204SRLCON3DC-005_PWC3-DC-005_DC-005DC-005PWC3-DC-005CON4PH-3_PH100-3_CI0103P1VK0CI0103P1VK0PH100-3D1BAS70-06/SOT_SOT23-28X44_BAT54ABAT54ASOT23-28X44D2BAS70-06/SOT_SOT23-28X44_BAT54ABAT54ASOT23-28X44D3BAV70L_DPAK_STPS640CBSTPS640CBDPAKD4DIODE_SD-DO-214_SMCJ1.5KE16ASMCJ1.5KE16ASD-DO-214D5D-AAC_SOT23-3B_BAT54CLT1GBAT54CLT1GSOT23-3BDVI1DVI-JDR11-241L-A_DVI0308-3RF-B_DVI-JDR11-241LDVI0308-3RF-BDVI2DVI-JDR11-241L-A_DVI0308-3RF-B_DVI-JDR11-241LDVI0308-3RF-BF1FUSE_SF2-2410_LITTELFUSE/0452LITTELFUSE/0452SF2-2410FB1FB_SL0805_PBY201209TPBY201209TSL0805FB2INDUCTOR_0_SL0805_PBY201209T201PBY201209T201Y-NSL0805FB3FB_SL0603_PZ1608D221PZ1608D221SL0603FB13FB_SL0805_PBY201209T/NCPBY201209T/NCSL0805FB14FB_SL0805_PBY201209TPBY201209TSL0805J1CON10_DG141R-5_CON10CON10DG141R-5J2HEADER4X15_0_CONN2X10-29X110-F20 PIN CTI INTERFACECONN2X10-29X110-FTRJ3DIPSOC-4X2_DM-4_DIPSOC-4X2DIPSOC-4x2DM-4J4USB-ASTACKED2_USB_STACKED2_USBUSB-A connectorUSB_STACKED2J6CON40A_IDC40_100_CON40ACON40AIDC40_100J7CON40A_IDC40_100_CON40ACON40AIDC40_100J8CON2_PC250_PC250PC250PC250J9CON2_PC250_PC250PC250PC250J10CON2_XH100-2_CON2CON2XH100-2J11CON15_XH100-15_CON15CON15XH100-15L1SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L2SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L3SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L4SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L5INDUCTOR_SL0805_BLM21PG221SN1DBLM21PG221SN1DSL0805L6INDUCTOR_3_SL0805_BLM21PG221SN1BLM21PG221SN1SL0805L7INDUCTOR_3_SL0805_BLM21PG221S_1BLM21PG221SN1/NCSL0805L8INDUCTOR_3_SL0805_BLM21PG221SN1BLM21PG221SN1SL0805L10INDUCTORIRON_NR4018_4.7UH_NR404.7uH_NR4018T4R7MNR4018L11INDUCTOR_SL0805_BLM21PG221SN1DBLM21PG221SN1DSL0805L12SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L13SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L14SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L15SCDW_STFM4-60-2012_SDCW2012HSDCW2012HSTFM4-60-2012L16INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L17FERRITEBEAD_0_INDUCTOR_NR10050NR10050T3R8NINDUCTORL18INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L19INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L20INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L21FERRITEBEAD_0_INDUCTOR_NR10050NR10050T3R8NINDUCTORL22INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L23INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L24INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L25FERRITEBEAD_0_IND109X100_1.5UH1.5uH-WURTH7443330150IND109X100L26INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L27FERRITEBEAD_0_INDUCTOR_NR10050NR10050T3R8NINDUCTORL28INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L29INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L30INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L31FERRITEBEAD_0_INDUCTOR_NR10050NR10050T3R8NINDUCTORL32INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L33INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L34INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L35FERRITEBEAD_0_CHOKE-115X212_1.1.8uH-7447715001CHOKE-115X212L36INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806L37INDUCTOR_0_1806_BLM41P750SPTBLM41P750SPT1806LED1LED_LED_17-215-SURC-S530-A3-TR817-215-SURC-S530-A3-TR8_780LEDLED2LED_LED_17-215-SURC-S530-A3-TR817-215-SURC-S530-A3-TR8_780LEDQ12N2222_1_SOT23-28X44_MMBT2222AMMBT2222ASOT23-28X44Q2CSD86330Q3D_SON_0_DQZ8_1P8X2P7_CSD86330Q3DDQZ8_1P8X2P7Q32N2222_1_SOT23-28X44_MMBT2222AMMBT2222ASOT23-28X44Q42N2222_1_SOT23-28X44_MMBT2222AMMBT2222ASOT23-28X44Q52N2222_1_SOT23-28X44_MMBT2222AMMBT2222ASOT23-28X44Q62N2222_1_SOT23-28X44_MMBT2222AMMBT2222ASOT23-28X44RN14R-PAK4_SRN4-0402_RPACK4-47RPack4-47SRN4-0402RN15R-PAK4_SRN4-0402_RPACK4-47RPack4-47SRN4-0402RN16R-PAK4_SRN4-0402_RPACK4-47RPack4-47SRN4-0402RN17RN_SRN4-0402_33R33RSRN4-0402RN18RN_SRN4-0402_33R33RSRN4-0402RN19RN_SRN4-0402_33R33RSRN4-0402RN20RN_SRN4-0402_33R33RSRN4-0402RN21RN_SRN4-0402_33R33RSRN4-0402RN22RN_SRN4-0402_33R33RSRN4-0402SW1PSW4-DTS_STSW4-TG-A_LTL-613SVLTL-613SVSTSW4-TG-ASW2KFC-A06_0_KFC-A06_KFC-A06KFC-A06KFC-A06TC1TC_STC3216-A_10UF10uFSTC3216-AU1TMS320DM8168_0_BGA1031-26-3737_TMS320DM8168BCYG2BGA1031-26-3737U2TPD12S521_SOP38-20-173_TPD12S52TPD12S521SOP38-20-173U3MT29F2G16ABAEAWP-IT_0_SOP48-20-MT29F2G16ABAEAWP-ITSOP48-20-725U4MAX3232_SOP16-26-173_MAX3232EEUMAX3232EEUESOP16-26-173U5DS1621S_SOP8-50-160_DS1621Sds1621sSOP8-50-160U6TPS3808G01DBVR_SOT23-6_TPS3808GTPS3808G01DBVRSOT23-6U71G08_DCK-5_1G081G08DCK-5U9H6096NL_H6096NL_H6096NLH6096NLH6096NLU11TPS2061_1_SO8-25X75_TPS2065DTPS2065DSO8-25X75U12TPDE0001RSE_0_DRL5-12X40_TPD2E0TPD2E001DRLDRL5-12X40U13TPS2061_1_SO8-25X75_TPS2065DTPS2065DSO8-25X75U14TPDE0001RSE_0_DRL5-12X40_TPD2E0TPD2E001DRLDRL5-12X40U15MT41J128M16JT-125_0_BGA96-32-16MT41J256M16HA-125BGA96-32-1609-BU16MT41J128M16JT-125_0_BGA96-32-16MT41J256M16HA-125BGA96-32-1609-BU17MT41J128M16JT-125_0_BGA96-32-16MT41J256M16HA-125BGA96-32-1609-BU18MT41J128M16JT-125_0_BGA96-32-16MT41J256M16HA-125BGA96-32-1609-BU19RTL8169S_3_QFN64_RTL8211DGRTL8211DGQFN64U20SII9022AQFN_1_QFN72-10X10_SII90SiI9022ACNUQFN72-10X10U21TPS71701DCK_0_DCK-5_TPS71701DCKTPS71701DCKDCK-5U221G08_DCK-5_1G081G08DCK-5U23TPD12S521_SOP38-20-173_TPD12S52TPD12S521SOP38-20-173U24MQ7802T120-R_MQ7802-R_MQ7802T12MQ7802T120-RMQ7802-RU25TPS54620_RGY14-12X34_TPS54620TPS54620RGY14-12X34U26TPS54620_RGY14-12X34_TPS54620TPS54620RGY14-12X34U27TPS40400RHL_QFN24_0_RHL24_TPS40TPS40400RHLRHL24U28TPS54620_RGY14-12X34_TPS54620TPS54620RGY14-12X34U29TPS54620_RGY14-12X34_TPS54620TPS54620RGY14-12X34U30TPS54620_RGY14-12X34_TPS54620TPS54620RGY14-12X34U31TPS71701DCK_DCK-5_TPS71701DCKTPS71701DCKDCK-5U33TPS51200DRCR_MLF10-050-0303L_TPTPS51200DRCRMLF10-050-0303LVT1SI4413DY_0_SOP8-50-160_SI4413ADSi4413ADYSOP8-50-160X1XTAL-4P_SX4-3225_27.000MHZ27.000MHzSX4-3225X2XTAL-2P_XTAL2-192_25MHZ25MHZXTAL2-192 PCB 原理图。回复下载。
**** Hidden Message ***** 多谢楼主无私分享 多谢楼主 谢谢分享DSP信号处理板PCB和原理图 大神,回复看看
