yangyida137324 发表于 2021-1-14 13:45
XC7A100T-2FGG484带两片DDR3
XC7A100T-2FGG484,有HDMI,SDI转RGB口
以下内容由管理员编辑补充。温馨提示:带有图片,更多人购买下载。
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECON1FX10A-144P-SV2_1_FX10A_144P_SV2FX10A-144P-SVFX10A_144P_SV2D1LED_D0603_LEDLEDD0603D2LED_0_D0603_LEDLEDD0603D3LED_0_D0603_LEDLEDD0603D4LED_0_D0603_LEDLEDD0603D5LED_0_D0603_LEDLEDD0603D6BYT3400B/DD_0_DO-214AC_B340AB340ADO-214ACD7LED_D0603_LEDLEDD0603D8DIODETVS_0_DO-214AC_SMAJ12ASMAJ12ADO-214ACD9LED_D0603_LEDLEDD0603D25DIODE-2A_TVS1006_RCLAMP0521PATCRCLAMP0521PATCTTVS1006D26DIODE_0_SOD-123_1N4148W1N4148WSOD-123D27DIODE_0_SOD-123_1N4148W1N4148WSOD-123D28DIODE_0_SOD-123_1N4148W1N4148WSOD-123D29DIODE_0_SOD-123_1N4148W1N4148WSOD-123F1FUSE_1_F2920_SMD2920P300TF/15SMD2920P300TF/15F2920F2FUSE_F0603_SMD0603P050TFSMD0603P050TFF0603F3FUSE_F0603_SMD0603P050TFSMD0603P050TFF0603FB1MAGNETICBEAD_FB0603_BLM18PG121BLM18PG121SN1DFB0603J1HEADER5X2_1_HDR2X7-2R54-VM-TH_510-90-14GB00HDR2X7-2R54-VM-THJ2CONNJACK PWR_POWER-JACK-DC005_DC005POWER-JACK-DC005J3CON6_0_CON4-533980471_53398-04753398-0471CON4-533980471J4HDMICONNECTOR_HDMI_HDMI CONHDMICONHDMIJ5BNC_0_CON3-U-FL_RECE-20279-001ERECE-20279-001E-01CON3-U-FLJ6BNC_0_CON3-U-FL_RECE-20279-001ERECE-20279-001E-01CON3-U-FLJ7BNC_0_CON3-U-FL_RECE-20279-001ERECE-20279-001E-01CON3-U-FLJ8MICROSD_2_CON-SD-DM3AT_DM3AT_SDM3AT_SF_PEJM5CON-SD-DM3ATJ9A74307-003HR911130ARJ45-HR911130CJ10USB-UEA3119C_2_USB3R0-VM-TH_U23U231-091N-4BLCC14-F-5USB3R0-VM-THJ11CON9_HDR9-2R54-VM-TH_CON9CON9HDR9-2R54-VM-THJ13VPX_P0_0_VPX-P0-1410189-3_VPX-PVPX-P0-1410189-3VPX-P0-1410189-3J14VPX_P1_1_VPX-P1-1410187-3_VPX_PVPX_P1_1410187-3VPX-P1-1410187-3J16MINI_USB_MINI_USB_MINI_USB_U-MMINI_USB_U-M-M5SS-W-2MINI_USBL1L_L1210_1277AS-H-R68M1277AS-H-R68ML1210L2L_L0402_6.2NH6.2nHL0402L3L_L0402_4.7NH4.7nHL0402L4L_L0402_4.7NH4.7nHL0402L5L_L0402_5.6NH5.6nHL0402L6L_L0402_4.7NH4.7nHL0402L7L_L0402_4.7NH4.7nHL0402L8L_L0402_5.6NH5.6nHL0402L9CHOKE-4I_T-DLW21HN-H1_4_DLW21HNDLW21HN900HQ2LT-DLW21HN-H1_4L10CHOKE-4I_T-DLW21HN-H1_4_DLW21HNDLW21HN900HQ2LT-DLW21HN-H1_4L11CHOKE-4I_T-DLW21HN-H1_4_DLW21HNDLW21HN900HQ2LT-DLW21HN-H1_4MAKR1TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCMAKR2TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCMAKR3TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCMAKR4TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCMAKR5TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCMAKR6TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCMAKR7TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCMAKR8TPOINT_MARKC_TEST POINT_453000TESTPOINTMARKCP1MTG280_700_PADC2R7_MTG280_700MTG280_700PADC2R7P2MTG280_700_PADC2R7_MTG280_700MTG280_700PADC2R7P3MTG280_700_PADC2R7_MTG280_700MTG280_700PADC2R7P4MTG280_700_PADC2R7_MTG280_700MTG280_700PADC2R7Q1MMBT3904/SOT_1_SOT23_MMBT3904MMBT3904SOT23Q2MMBT3904/SOT_1_SOT23_MMBT3904MMBT3904SOT23Q4MMBT3904/SOT_1_SOT23_MMBT3904MMBT3904SOT23Q5MMBT3904/SOT_1_SOT23_MMBT3904MMBT3904SOT23U1XC7A100T-2FGG484I_BGA484-1R0-22XC7A100T-2FGG484IBGA484-1R0-22X22-23X23U2W25Q128FVSI_1_SOIC8-1R27-5R2_N2N25Q128A13ESE40/MicronSOIC8-1R27-5R2U3JZA77-1CC3-50MHZ_1_OSC6-5X3R2_SIT9121AI-2C1-33E200.00000MHZOSC6-5X3R2U4JZA77-1CC3-50MHZ_1_OSC6-5X3R_1SIT9121AI-2C1-33E100.00000MHZOSC6-5X3R2U5LT4644_BGA77-LTM4644_LTM4644IY#LTM4644IY#PBFBGA77-LTM4644U6TPS82140_QFN8P1-0R65-2R8X3-SIL0TPS82130SILTQFN8P1-0R65-2R8X3-SIL0008CU7TPS7A9201DSKT_0_WSON10_TPS7A92_TPS7A9201DSKTWSON10_TPS7A92U8TPS82140_QFN8P1-0R65-2R8X3-SIL0TPS82130SILTQFN8P1-0R65-2R8X3-SIL0008CU9TPS7A9201DSKT_0_WSON10_TPS7A92_TPS7A9201DSKTWSON10_TPS7A92U10TPS82140_QFN8P1-0R65-2R8X3-SIL0TPS82130SILTQFN8P1-0R65-2R8X3-SIL0008CU11TPS82140_QFN8P1-0R65-2R8X3-SIL0TPS82130SILTQFN8P1-0R65-2R8X3-SIL0008CU12TPS82140_QFN8P1-0R65-2R8X3-SIL0TPS82130SILTQFN8P1-0R65-2R8X3-SIL0008CU13TPS7A9201DSKT_0_WSON10_TPS7A92_TPS7A9201DSKTWSON10_TPS7A92U14MT41J256M16_BGA96-0R8-10X14_MT4MT41K256M16TW-125ITBGA96-0R8-10X14U15MT41J256M16_0_BGA96-0R8-10X14_MMT41K256M16TW-125ITBGA96-0R8-10X14U16TPS51200DRCR_QFN10P1-0R5-3X3_TPTPS51200DRCRQFN10P1-0R5-3X3U17SII9134CTU_0_TQFP100-0R5-14_SIISiI9134CTUTQFP100-0R5-14U18RCLAMP0524P_0_ESD-RCLAMP0524P_RRClamp0524PESD-RCLAMP0524PU19RCLAMP0524P_0_ESD-RCLAMP0524P_RRClamp0524PESD-RCLAMP0524PU20GS2971AIBE3_1_BGA100-1R0-11_GS2GS2971AIBE3BGA100-1R0-11U21XO32YAGRC8MHZ_0_OSC4-3R2X2R5_XOXO32YAGRC27MHzOSC4-3R2X2R5U22GS2972-IBE3_9_BGA100-1R0-11_GS2GS2972-IBE3BGA100-1R0-11U23H26M41204HPR_BGA153-0R5-EMMC_(SH26M41204HPRBGA153-0R5-EMMCU25MA124/TO_SOT23-6_SRV05-4TCTSRV05-4TCTSOT23-6U26MA124/TO_SOT23-6_SRV05-4TCTSRV05-4TCTSOT23-6U27KSZ9031RN_QFN48P1-0R5-7-KSZ9031KSZ9031RNXIAQFN48P1-0R5-7-KSZ9031U28XO32YAGRC8MHZ_0_OSC4-3R2X2R5__1XO32YAGRC25MHzOSC4-3R2X2R5U29TXS0104EPWR_TSSOP14-0R65-4R4_TXTXS0104EPWRTSSOP14-0R65-4R4U30TXS0104EPWR_TSSOP14-0R65-4R4_TXTXS0104EPWRTSSOP14-0R65-4R4U31TP485E-VR_3_SOIC8-1R27-3R8_MAX3MAX3490ESASOIC8-1R27-3R8U32TP485E-VR_3_SOIC8-1R27-3R8_MAX3MAX3490ESASOIC8-1R27-3R8U33VPX-P2-1410190-3_0_VPX-P2-14101VPX_P2_1410190-3VPX-P2-1410190-3U34CP2102N-A01-GQFN20_2_QFN28-0_5-CP2102N-A01-GQFN28QFN28-0_5-5_0X5_0U35TXS0104EPWR_TSSOP14-0R65-4R4_TXTXS0104EPWRTSSOP14-0R65-4R4U37CDCV304PW_TSSOP-8_CDCV304PWCDCV304PWTSSOP-8
sun5304 发表于 2021-1-14 14:30
luchonghui74 发表于 2021-1-14 16:58
谢谢分享!
heming2216 发表于 2021-1-14 17:54
asdf140 发表于 2021-1-14 18:45
66新资源
if+else 发表于 2021-1-14 21:42
看一下,感谢分享
richardz 发表于 2021-1-14 22:04
longxuekai 发表于 2021-1-15 06:10
学习了吧
wangy2000 发表于 2021-1-15 06:58
lqsgg 发表于 2021-1-15 08:01
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: XC7A100T-2FGG484带两片DDR3
